03-Monitor
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70003-Monitor
Table of Contents
Related Documents
20-Application audit logs
20-Application audit logs 30.98 KB
Introduction
This page displays the Internet access behaviors of users. According to the users' Internet access behaviors, you can adjust the application audit and management policy to regulate the users' Internet access behaviors.
The application audit log displaying function takes effect after the logging function is enabled in the application audit policy. When packets match the policy, logs are output to the application audit logs page.
Click Details on the page to view details of the Internet access behaviors.
If a user does not belong to any user groups, the user group field in the application audit log displays the username.
If a user belongs to only one user group and the user group has been used by an audit policy, the user group field displays the user group name. If the user group is not used by any audit policy, the user group field displays the username.
If a user belongs to multiple user groups, the user group field displays the name of a user group randomly selected from the multiple user groups.
Only one log operation (import, export, or delete) is allowed at a time.
Only one user can perform a log operation at a time. When you import, export, or delete logs, make sure no one else is performing a log operation.
Configure application audit logs
Import logs
1.     Click the Monitor tab.
2.     In the navigation pane, select any item under Application Audit Logs.
3.     Click Import.
4.     In the dialog box that opens, click Yes.
5.     Select a log file, and enter the password for the log file. The password was set when the file was exported.
Export logs
3.     Click Advanced search.
4.     On the page that opens, specify the search criteria to display the logs to be exported.
5.     Click Export.
6.     On the page that opens, configure the log export settings.
Table 1 Log export configuration items
Item
Set password
Enter a password for encrypting the log files. This password is required when you view or import the exported log files.
Log range
Specify the range of logs to be exported. Options are:
·     All results—Exports all logs that satisfy the search criteria. The page displays the total number of logs to be exported.
·     Day on the current page—Exports logs of the day indicated by the Time field on the current page. You can define the ending page to decrease the number of logs to be exported.
7.     Select one of the following export methods.
¡     Export to one file—Exports logs to one file. When a small number of logs are to be exported, select this method.
The system supports exporting a maximum of 65000 logs to one log file.
¡     Export to files—Exports logs to multiple files. If more than 65000 logs are to be exported, select this method.
8.     Perform one of the following tasks as required:
¡     If you have selected Export to one file, click OK in the dialog box that opens.
¡     If you have selected Export to files, specify the number of logs to be exported to each file and click OK in the dialog box that opens.
When a log export to one file is complete, a dialog box opens, asking you whether to continue exporting the remaining logs to a new file.
-     To continue the export, click Yes.
-     To stop the export process, click No.
