- 13-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-Event MIB configuration
- 07-NETCONF configuration
- 08-EAA configuration
- 09-Process monitoring and maintenance configuration
- 10-BFD configuration
- 11-Track configuration
- 12-Process placement configuration
- 13-Fast log output configuration
- 14-Flow log configuration
- 15-Information center configuration
- 16-Packet capture configuration
- 17-Email alerting configuration
| 00-Preface | 100.81 KB |
Preface
This configuration guide describes features and tasks that help you get started with the device, It includes the following feature modules: System maintenance and debugging, NQA , NTP, SNMP, RMON, Event MIB, NETCONF, EAA, Process monitoring and maintenance, BFD, Track, Process placement, Fast log output, Flow log, Information center, Packet capture and Email alerting.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
