05-Network Connectivity
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5447P04)-6W10005-Network Connectivity
14-3G and 4G modem management configuration
14-3G and 4G modem management configuration 87.58 KB
Managing a 4G modem
About managing a 4G modem
A 4G modem connects a device to a 4G network.
The device supports SIC 4G modems. A SIC 4G modem is not hot swappable. After a SIC 4G modem is installed, the device creates a cellular interface dynamicaly based on the slot number of the modem and uses the interface to manage the modem. When the modem is removed from the device, the system removes the cellular interface and its configuration.
A cellular interface can be channelized into a serial or an Eth-channel interface. The data link layer protocols of the serial interface and Eth-channel interface are PPP and Ethernet, respectively. The two interfaces support IP at the network layer.
The cellular interface of a 4G modem can be channelized only into an Eth-channel interface.
Restrictions: Hardware compatibility with 4G modem management
Hardware series
Model
Product code
4G modem management compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes: EWP-WX2508H-PWR-LTE
No:
·     EWP-WX2510H-PWR
·     EWP-WX2510H-F-PWR
·     EWP-WX2540H
·     EWP-WX2540H-F
·     EWP-WX2560H
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40 LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Restrictions and guidelines: 3G/4G modem management
Follow these restrictions and guidelines when you configure 3G/4G modem management:
·     Do not remove a USB 3G/4G modem while it is transmitting data. As a best practice, execute the shutdown command to shut down the USB 3G/4G modem before removing it.
·     A USB 3G/4G modem is not usable when the USB interface to which the modem is attached is shut down. For more information about shutting down a USB interface, see Fundamentals Configuration Guide.
·     Unless otherwise noted, the 3G/4G modem configuration in this document is saved in the non-volatile storage on the 3G/4G modem. To verify the configuration, use the display cellular command.
4G modem management tasks at a glance
To manage a 4G modem, perform the following tasks:
1.     Configuring an Eth-channel interface for a 4G modem
2.     (Optional.) Associating 4G link backup with a track entry
3.     (Optional.) Issuing a configuration directive to a 4G modem
4.     (Optional.) Configuring 4G modem reboot
¡     Rebooting a 4G modem manually
Configuring the 4G modem cellular interface
2.     Enter cellular interface view.
controller cellular cellular-number
3.     Configure a description for the cellular interface.
By default, the description for a cellular interface is interface name Interface, for example, Cellular 1/0/6 Interface.
4.     Channelize the cellular interface into an Eth-channel interface.
eth-channel channel-number
This command names the Eth-channel interface as eth-channel cellular-number:channel-number.
Configure DDR and specify an IP address for the Eth-channel interface channelized from the cellular interface of a 4G modem as needed.
5.     Bring up the cellular interface.
By default, a cellular interface is up.
Configuring basic parameters for an Eth-channel interface
2.     Enter Eth-channel interface view.
interface eth-channel interface-number
3.     Configure a description of the Eth-channel interface.
By default, the description for an Eth-channel interface is interface name Interface, for example, Echannel 1/0/6:0 Interface.
4.     Set the MTU for the Eth-channel interface.
mtu size
By default, the MTU for an Eth-channel interface is 1500 bytes.
5.     Set the expected bandwidth of the Eth-channel interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) of an Eth-channel is the interface baud rate divided by 1000.
The baud rate of an Eth-channel interface is 100 Mbps.
6.     Bring up the Eth-channel interface.
Restoring the default settings for an Eth-channel interface
CAUTION
CAUTION:
Restoring the default interface settings might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
The default command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands. Then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
3.     Restore the default configurations.
default
Specifying the primary or secondary SIM card
On a device that uses dual SIM card, you can specify the use of the secondary SIM card when one of the following problems occurs:
·     The 4G link signals of the primary SIM card are weak.
·     The service provider network that the primary SIM card connects to is unavailable.
·     The primary SIM card has failed.
If the problems of the primary SIM card are resolved, you can specify the use of the primary SIM card or enable the 3G/4G modem to automatically switch back to the primary SIM card.
controller cellular interface-number
3.     Specify the primary or secondary SIM card.
sim switch-to card-number
By default, a 4G modem uses the primary SIM card.
This configuration allows the system to use a track entry to monitor the status of the primary 4G link. When the track entry state changes from Positive to Negative, the secondary 4G link takes over.
Configuration directives might cause malfunction of a 4G modem. When you issue a configuration directive to the modem, make sure you understand the impact on the 4G modem.
3.     Issue a configuration directive to the 4G modem.
sendat at-string
A 4G modem can automatically detect running errors and reboot. If the 4G modem fails to reboot by itself, you can use this command to manually reboot it.
3.     Manually reboot the 4G modem.
modem reboot
CAUTION
CAUTION:
This command will disconnect the established 3G/4G modem connections. Execute this command with caution.
Display and maintenance commands for 4G modem management
Display the call connection information for the 4G modem.
display cellular [ interface-number ]
Display information about a cellular interface.
display controller [ cellular [ interface-number ] ]
Display information about an Eth-channel interface.
display interface [ eth-channel [ channel-id ] ] [ brief [ description | down ] ]
Clear the statistics for a cellular interface.
reset counters controller [ cellular [ interface-number ] ]
Clear the statistics for an Eth-channel interface.
reset counters interface [ eth-channel [ channel-id ] ]
Troubleshooting
4G modem malfuntion
Symptom
A 4G modem fails to function correctly. For example, the 4G modem receives no signals or fails to connect to service providers' networks.
Solution
To resolve the issue:
1.     Execute the shutdown command and the undo shutdown command on the cellular interface.
2.     If the 4G modem still fails to function, execute the modem reboot command on the cellular interface.
3.     If the issue persists, contact H3C Support.
