05-Network Connectivity
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5447P04)-6W10005-Network Connectivity
32-RIPng configuration
32-RIPng configuration 125.42 KB
Configuring RIPng
About RIPng
RIP next generation (RIPng), as an extension of RIP-2 for support of IPv6, is a distance vector routing protocol. It employs UDP to exchange route information through port 521. Most RIP concepts are applicable to RIPng.
RIPng routing metrics
RIPng uses a hop count to measure the distance to a destination. The hop count is the metric or cost. The hop count from a router to a directly connected network is 0. The hop count between two directly connected routers is 1. When the hop count is greater than or equal to 16, the destination network or host is unreachable.
RIPng route entries
RIPng stores route entries in a database. Each route entry contains the following elements:
·     Destination address—IPv6 address of a destination host or a network.
·     Next hop address—IPv6 address of the next hop.
·     Egress interface—Egress interface of the route.
·     Metric—Cost from the local router to the destination.
·     Route time—Time elapsed since the most recent update. The time is reset to 0 every time the route entry is updated.
·     Route tag—Tag of external routes.
RIPng packets and advertisement
RIPng multicasts request and response packets to exchange routing information. It uses FF02::9 as the link-local-router multicast address and FE80::/10 as the link-local source address. RIPng exchanges routing information as follows:
1.     When RIPng starts or needs to update some route entries, it sends a multicast request packet to neighbors.
2.     When a RIPng neighbor receives the request packet, it sends back a response packet that contains the local routing table. RIPng can also advertise route updates in response packets periodically or advertise a triggered update caused by a route change.
3.     After RIPng receives the response, it checks the validity of the response before adding routes to its routing table, including the following details:
¡     Whether the source IPv6 address is the link-local address.
¡     Whether the port number is correct.
4.     A response packet that fails the check is discarded.
Protocols and standards
·     RFC 2080, RIPng for IPv6
·     RFC 2081, RIPng Protocol Applicability Statement
Restrictions: Hardware compatibility with RIPng
Hardware series
Model
Product code
RIPng compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
Yes
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-L-PWR
·     WX3010H-X-PWR
·     WX3024H-L-PWR
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
RIPng compatibility
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
No
RIPng tasks at a glance
To configure RIPng, perform the following tasks:
1.     Configuring basic RIPng
2.     (Optional.) Configuring RIPng route control
¡     Configuring an additional routing metric
¡     Configuring RIPng route summarization
¡     Advertising a default route
¡     Configuring received/redistributed route filtering
¡     Setting a preference for RIPng
¡     Configuring RIPng route redistribution
3.     (Optional.) Tuning and optimizing the RIPng network
¡     Setting RIPng timers
¡     Configuring split horizon and poison reverse
¡     Setting the maximum number of ECMP routes
¡     Configuring the RIPng packet sending rate
¡     Setting the interval for sending triggered updates
4.     (Optional.) Enhancing RIPng availability
¡     Configuring RIPng GR
5.     (Optional.) Enhancing RIPng security
¡     Configuring zero field check for RIPng packets
¡     Applying an IPsec profile
2.     Enable RIPng and enter its view.
ripng [ process-id ]
By default, RIPng is disabled.
3.     Return to system view.
4.     Enter interface view.
5.     Enable RIPng on the interface.
ripng process-id enable
By default, RIPng is disabled on the interface.
If RIPng is not enabled on an interface, the interface does not send or receive any RIPng route.
An additional routing metric (hop count) can be added to the metric of an inbound or outbound RIPng route.
·     An outbound additional metric is added to the metric of a sent route, and it does not change the route's metric in the routing table.
·     An inbound additional metric is added to the metric of a received route before the route is added into the routing table, and the route's metric is changed.
2.     Enter interface view.
3.     Specify an inbound additional routing metric.
ripng metricin value
The default additional metric of an inbound route is 0.
4.     Specify an outbound additional routing metric.
ripng metricout value
The default additional metric of an outbound route is 1.
RIPng route summarization is interface-based. RIPng advertises a summary route based on the longest match.
RIPng route summarization improves network scalability, reduces routing table size, and increases routing table lookup efficiency.
RIPng advertises a summary route with the smallest metric of all the specific routes.
For example, RIPng has two specific routes to be advertised through an interface: 1:11:11::24 with a metric of a 2 and 1:11:12::34 with a metric of 3. Configure route summarization on the interface, so RIPng advertises a single route 11::0/16 with a metric of 2.
3.     Advertise a summary IPv6 prefix.
ripng summary-address ipv6-address prefix-length
By default, no summary IPv6 prefix is configured on the interface.
You can configure RIPng to advertise a default route with the specified cost to its neighbors.
3.     Configure RIPng to advertise a default route.
ripng default-route { only | originate } [ cost cost-value ]
By default, RIPng does not advertise a default route.
This command advertises a default route on the current interface regardless of whether the default route exists in the local IPv6 routing table.
Perform this task to filter received or redistributed routes by using an IPv6 ACL or IPv6 prefix list. You can also configure RIPng to filter routes redistributed from other routing protocols and routes from a specified neighbor.
2.     Enter RIPng view.
3.     Configure a filter policy to filter received routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } import
By default, RIPng does not filter received routes.
4.     Configure a filter policy to filter redistributed routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
By default, RIPng does not filter redistributed routes.
Routing protocols each have a preference. When they find routes to the same destination, the route found by the routing protocol with the highest preference is selected as the optimal route. You can manually set a preference for RIPng. The smaller the value, the higher the preference.
3.     Set a preference for RIPng.
preference preference
By default, the preference of RIPng is 100.
3.     Configure route redistribution.
¡     Redistribute direct or static routes.
import-route { direct | static } [ cost cost-value ]
¡     Redistribute routes from  other RIPng processes.
import-route ripng [ process-id ] [ allow-direct | cost cost-value ] *
By default, RIPng does not redistribute routes.
4.     (Optional.) Set a default routing metric for redistributed routes.
default cost cost-value
The default metric of redistributed routes is 0.
You can adjust RIPng timers to optimize the performance of the RIPng network.
When you adjust RIPng timers, consider the network performance, and perform unified configurations on routers running RIPng to avoid unnecessary network traffic or route oscillation.
3.     Set RIPng timers.
The default settings are as follows:
¡     The update timer is 30 seconds.
¡     The timeout timer is 180 seconds.
¡     The suppress timer is 120 seconds.
¡     The garbage-collect timer is 120 seconds.
Restrictions and guidelines for split horizon and poison reverse
When you configure split horizon and poison reverse, following these restrictions and guidelines:
·     If both split horizon and poison reverse are configured, only the poison reverse feature takes effect.
·     Split horizon disables RIPng from sending routes through the interface where the routes were learned to prevent routing loops between neighbors. As a best practice, enable split horizon to prevent routing loops in normal cases.
·     Poison reverse enables a route learned from an interface to be advertised through the interface. However, the metric of the route is set to 16, which means the route is unreachable.
3.     Enable split horizon.
ripng split-horizon
By default, split horizon is enabled.
Configuring poison reverse
3.     Enable poison reverse.
ripng poison-reverse
By default, poison reverse is disabled.
3.     Set the maximum number of ECMP routes.
maximum load-balancing number
Perform this task to specify the interval for sending RIPng packets and the maximum number of RIPng packets that can be sent at each interval. This feature can avoid excessive RIPng packets from affecting system performance and consuming too much bandwidth.
3.     Configuring the RIPng packet sending rate.
¡     Execute the following commands in sequence to configure the RIPng packet sending rate in RIPng view:
ripng [ process-id ] [ vpn-instance vpn-instance-name ]
output-delay time count count
By default, an interface that runs the RIPng process sends a maximum of three RIPng packets every 20 milliseconds.
¡     Execute the following commands in sequence to configure the RIPng packet sending rate in interface view:
ripng output-delay time count count
By default, an interface uses the RIPng packet sending rate of the RIPng process that it runs.
Perform this task to avoid network overhead and reduce system resource consumption caused by frequent RIPng triggered updates.
You can use the timer triggered command to set the maximum interval, minimum interval, and incremental interval for sending RIPng triggered updates.
For a stable network, the minimum interval is used. If network changes become frequent, the triggered update sending interval is incremented by the incremental interval × 2n-2 for each triggered update until the maximum interval is reached. The value n is the number of triggered update times.
3.     Set the interval for sending triggered updates.
The default maximum interval is 5 seconds, the default minimum interval is 50 milliseconds, and the default incremental interval is 200 milliseconds.
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
After RIPng restarts on a router, the router must learn RIPng routes again and updates its FIB table, which causes network disconnections and route reconvergence.
With the GR feature, the restarting router (known as the GR restarter) can notify the event to its GR capable neighbors. GR capable neighbors (known as GR helpers) maintain their adjacencies with the router within a configurable GR interval. During this process, the FIB table of the router does not change. After the restart, the router contacts its neighbors to retrieve its FIB.
By default, a RIPng-enabled device acts as the GR helper. Perform this task on the GR restarter.
2.     Enable RIPng and enter RIPng view.
3.     Enable the GR capability for RIPng.
graceful-restart
By default, RIPng GR is disabled.
4.     (Optional.) Set the GR interval.
The default GR interval is 60 seconds.
Some fields in the RIPng packet header must be zero. These fields are called zero fields. You can enable zero field check for incoming RIPng packets. If a zero field of a packet contains a non-zero value, RIPng does not process the packets. If you are certain that all packets are trustworthy, disable the zero field check to save CPU resources.
3.     Enable the zero field check for incoming RIPng packets.
checkzero
By default, zero field check for incoming RIPng packets is enabled.
To protect routing information and prevent attacks, you can configure RIPng to authenticate protocol packets by using an IPsec profile.
An IPsec profile contains inbound and outbound security parameter indexes (SPIs). RIPng compares the inbound SPI defined in the IPsec profile with the outbound SPI in the received packets. Two RIPng devices accept the packets from each other and establish a neighbor relationship only if the SPIs are the same and the relevant IPsec profiles match.
For more information about IPsec profiles, see Security Configuration Guide.
You can apply an IPsec profile to a RIPng process or to an interface. If an interface and its process each have an IPsec profile, the IPsec profile applied to the interface takes effect.
Applying an IPsec profile to a process
3.     Apply an IPsec profile to the process.
enable ipsec-profile profile-name
By default, no IPsec profile is applied.
Applying an IPsec profile to an interface
3.     Apply an IPsec profile to the interface.
ripng ipsec-profile profile-name
Display and maintenance commands for RIPng
Display configuration information for a RIPng process.
display ripng [ process-id ]
Display RIPng GR information.
display ripng [ process-id ] graceful-restart
Display routes in the RIPng database.
display ripng process-id database [ ipv6-address prefix-length ]
Display interface information for a RIPng process.
display ripng process-id interface [ interface-type interface-number ]
Display neighbor information for a RIPng process.
display ripng process-id neighbor [ interface-type interface-number ]
Display the routing information for a RIPng process.
display ripng process-id route [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ]
Restart a RIPng process.
reset ripng process-id process
Clear statistics for a RIPng process.
reset ripng process-id statistics
