12-Security Configuration Guide
HomeSupportResource CenterTechnical DocumentsConfigure & DeployConfiguration GuidesH3C MSR810[830][2600][3600] Routers Configuration Guides(V7)-R0821-6W50012-Security Configuration Guide
16-SSL VPN configuration
16-SSL VPN configuration 1.13 MB
Configuring SSL VPN·· 1
About SSL VPN· 1
SSL VPN operating mechanism·· 1
SSL VPN networking modes· 2
SSL VPN access modes· 2
SSL VPN user authentication· 6
Resource access control 8
VRF-aware SSL VPN· 9
Restrictions: Hardware compatibility with SSL VPN· 10
Restrictions: Licensing requirements for SSL VPN· 11
Restrictions and guidelines: SSL VPN configuration· 11
SSL VPN tasks at a glance· 12
Prerequisites for SSL VPN· 12
Configuring an SSL VPN gateway· 13
Configuring an SSL VPN context 13
Configuring user authentication in an SSL VPN context 15
Restrictions and guidelines for user authentication configuration in an SSL VPN context 15
User authentication tasks at a glance· 15
Specifying the authentication methods required for user login· 15
Configuring username/password authentication· 16
Configuring certificate authentication· 16
Configuring verification code authentication· 16
Configuring dynamic password authentication· 16
Configuring IMC SMS authentication· 17
Configuring SMS gateway authentication· 17
Configuring password modification for users· 18
Configuring the SSL VPN user authentication server 19
Specifying the SSL VPN user authentication server type· 19
Configuring the custom authentication server 19
Configuring a URI ACL· 21
Configuring the Web access service· 21
Web access service tasks at a glance· 21
Configuring a URL list 21
Configuring an SSL VPN policy group for Web access· 23
Configuring a file policy· 24
Configuring the TCP access service· 25
TCP access service tasks at a glance· 25
Configuring a port forwarding list 25
Configuring an SSL VPN policy group for TCP access· 26
Configuring the IP access service· 27
Restrictions and guidelines for IP access service configuration· 27
IP access service tasks at a glance· 27
Configuring an SSL VPN AC interface for IP access· 27
Creating an address pool for IP access users· 28
Configuring IP access parameters in an SSL VPN context 28
Configuring an SSL VPN policy group for IP access· 29
Configuring SSL VPN access for mobile clients· 31
SSL VPN access for mobile clients tasks at a glance· 31
Specifying an EMO server for mobile clients· 31
Specifying a message server for mobile clients· 31
Configuring shortcuts· 32
Configuring redirect resources· 33
Configuring HTTP redirection· 33
Configuring the default policy group for an SSL VPN context 34
Configuring VRF-aware SSL VPN· 35
Associating an SSL VPN context with a VPN instance· 35
Specifying a VPN instance for an SSL VPN gateway· 35
Configuring online SSL VPN user control 36
Configuring SSL VPN session rate limit 36
Configuring SSL VPN cracking prevention· 37
Configuring SSL VPN SSO login· 38
About configuring SSL VPN SSO login· 38
Restrictions and guidelines· 38
Configuring SSO login in auto-build method· 38
Configuring SSO login through basic authentication· 39
Customizing SSL VPN webpages· 40
Restrictions and guidelines· 40
Customizing SSL VPN webpage elements· 40
Specifying an SSL VPN webpage template· 41
Enabling SSL VPN logging· 42
Display and maintenance commands for SSL VPN· 42
SSL VPN configuration examples· 43
Example: Configuring Web access with self-signed certificate· 43
Example: Configuring Web access with CA-signed certificate· 49
Example: Configuring TCP access with self-signed certificate· 54
Example: Configuring TCP access with CA-signed certificate· 57
Example: Configuring IP access with self-signed certificate· 60
Example: Configuring IP access with CA-signed certificate· 66
Configuring SSL VPN
About SSL VPN
SSL VPN provides SSL-based secure remote access services through an SSL VPN gateway. Users from anywhere on the Internet can establish a secure connection to an SSL VPN gateway through an SSL-enabled browser to access protected resources behind the gateway.
To allow remote user access to protected resources behind an SSL VPN gateway, you must configure these resources on the gateway. Remote users can access only the resources authorized to them after they establish an SSL-encrypted connection to the gateway and pass the identity authentication.
As shown in Figure 1, SSL VPN operates as follows:
1.     The remote user establishes an HTTPS connection to the SSL VPN gateway.
In this process, the remote user and the SSL VPN gateway perform SSL certificate authentication.
2.     The remote user enters the username and password.
3.     The SSL VPN gateway authenticates the credentials that the user entered, and authorizes the user to access a range of resources.
4.     The user selects a resource to access.
An access request for that resource is sent to the SSL VPN gateway through the SSL connection.
5.     The SSL VPN gateway resolves the request and forwards the request to the corresponding internal server.
6.     The SSL VPN gateway forwards the server's reply to the user through the SSL connection.
Figure 1 SSL VPN network diagram
Gateway mode
In gateway mode, the SSL VPN gateway acts as a gateway that connects remote users and the internal servers network, as shown in Figure 2. Because the SSL VPN gateway is deployed in line, it can provide full protection to the internal network but it affects data transmission performance.
Figure 2 Gateway mode
Single-arm mode
In single-arm mode, the SSL VPN gateway is attached to the network gateway, as shown in Figure 3.
The gateway forwards user-to-server traffic to the SSL VPN gateway. The SSL VPN gateway processes the traffic and sends the processed traffic back to the gateway. The gateway forwards the traffic to the internal servers. The SSL VPN gateway is not a performance bottleneck in the network because it is not deployed on the key path. However, the SSL VPN gateway cannot provide full protection to the internal network.
Figure 3 Single-arm mode
Web access
In Web access mode, remote users use browsers to access Web resources allowed by an SSL VPN gateway through HTTPS. After login, a user can access any resources listed on the webpage. In Web access mode, all operations are performed on webpages.
The resources available for SSL VPN Web access users are Web servers only.
To implement Web access, you must configure a list of URLs on the SSL VPN gateway. A URL is the IP address or domain name of an internal Web server.
The Web access procedure is as follows:
1.     A user uses a browser to log in to an SSL VPN gateway through HTTPS.
2.     The SSL VPN gateway authenticates the user and authorizes the user to access the available URLs.
The authorized URLs are displayed on the SSL VPN gateway webpage as URL links.
3.     The user selects a URL to access on the SSL VPN gateway webpage. The browser sends the access request to the SSL VPN gateway through the SSL connection for HTTPS.
4.     The SSL VPN gateway resolves the request and sends the request to the Web server through HTTP or HTTPS.
5.     After receiving the reply from the Web server, the SSL VPN gateway forwards the reply to the user through the SSL connection for HTTPS.
Figure 4 illustrates the Web access process. The administrator configures a URL of www.h3c.com on the SSL VPN gateway. Then, the SSL VPN user can access the internal Web server by accessing the URL on the SSL VPN gateway webpage.
Figure 4 Network diagram for Web access
TCP access
In TCP access mode, users access TCP applications on internal servers by accessing the applications' open ports. Supported applications include remote access services (such as Telnet), desktop sharing services, mail services, Notes services, and other TCP services that use fixed ports.
In TCP access mode, a user installs the TCP access client software on the SSL VPN client (the terminal device that the user uses). The client software uses an SSL connection to transmit the application layer data.
To implement TCP access, you must configure port forwarding instances on the SSL VPN gateway. A port forwarding instance maps a TCP service (identified by an IP address/domain name and port number) to an SSL VPN client's local IP address (or host name) and port number.
The TCP access procedure is as follows:
2.     The SSL VPN gateway authenticates the user and authorizes the user to access the Telnet service (port forwarding instance).
3.     The user downloads the TCP access client software from the webpage of the SSL VPN gateway, and launches the software. The software opens the authorized local port in the port forwarding instance.
4.     The user tries to access the local IP address and port number. The TCP access client software sends the access request to the SSL VPN gateway through an SSL connection.
5.     The SSL VPN gateway resolves the request and sends the request to the Telnet server according to the port forwarding instance.
6.     After receiving the reply from the Telnet server, the SSL VPN gateway forwards the reply to the user through the SSL connection.
As shown in Figure 5, the administrator creates a port forwarding instance for the Telnet service on the SSL VPN gateway. The rule maps the internal Telnet server address 10.1.1.2 and port number 23 to the SSL VPN client's local address 127.0.0.1 and local port number 2000. Then, the SSL VPN user can access the internal Telnet server by telneting the local address 127.0.0.1 and local port number 2000.
Figure 5 Network diagram for TCP access
For mobile clients to use the TCP access mode, you do not need to configure port forwarding instances on the SSL VPN gateway. However, client software dedicated for mobile clients is required, and you must specify an Endpoint Mobile Office (EMO) server for mobile clients on the SSL VPN gateway. Mobile clients access internal resources through the EMO server. Figure 6 shows the access process.
Figure 6 Network diagram for mobile client access to internal servers
IP access
IP access implements secured IP communication between remote users and internal servers.
To access an internal server in IP access mode, a user must install dedicated IP access client software. The client software will install a virtual network interface card (VNIC) on the SSL VPN client.
To implement IP access, you must configure the following on the SSL VPN gateway:
·     An SSL VPN AC interface.
·     Routes to accessible IP resources. The routes will be issued to SSL VPN clients to instruct packet forwarding.
Figure 7 uses a ping operation to illustrate the IP access process. The administrator must first configure a route to the ping destination (server 10.1.1.2/24) on the SSL VPN gateway.
The access process is as follows:
1.     The user installs the IP access client software and launches the client software to log in to the SSL VPN gateway.
2.     The SSL VPN gateway performs the following operations:
a.     Authenticates and authorizes the user.
b.     Allocates an IP address to the VNIC of the user.
c.     Issues the authorized IP access resources to the client.
In this example, a route to server 10.1.1.2/24 is issued.
3.     The client specifies the allocated IP address as the VNIC's address and adds the route to the local routing table, using the VNIC as output interface.
4.     The user pings the server address.
The ping request matches the route. Matching packets will be encapsulated by SSL.
5.     The client uses SSL to encapsulate the ping request packet, and then sends the packet to the SSL VPN AC interface through the VNIC.
6.     The SSL VPN gateway de-encapsulates the SSL packet into the IP packet and forwards the IP packet to the corresponding internal server.
7.     The internal server sends a reply to the SSL VPN gateway.
8.     The SSL VPN gateway uses SSL to encapsulate the reply packet and then sends the packet to the client through the SSL VPN AC interface.
Figure 7 Network diagram for IP access
To access resources in an SSL VPN context, a user must first pass identity authentication to log in to the SSL VPN context. The authentication methods for an SSL VPN context include username/password authentication, certificate authentication, verification code authentication, dynamic password verification, SMS authentication, and custom authentication. If SMS authentication and custom authentication are both enabled, only custom authentication takes effect.
You can enable username/password authentication, certificate authentication, or both in an SSL VPN context. Whether these authentication methods are required for logging in to the SSL VPN context depends on the configuration of the authentication use command. To use username/password authentication for users, you must also create accounts for the users in AAA. For more information, see "Configuring AAA."
You can also enable the verification code authentication, dynamic password verification, SMS authentication, and custom authentication in an SSL VPN context. These authentication methods are required for login authentication if they are configured.
Username/password authentication
The username/password authentication process is as follows:
1.     The SSL VPN user enters the login username and password on the SSL VPN login page. The username and password are sent to the SSL VPN gateway.
2.     The SSL VPN gateway sends the received username and password to AAA for authentication, authorization, and accounting, or to a custom authentication server for authentication and authorization.
Certification authentication
As shown in Figure 8, the certificate authentication process is as follows:
1.     The SSL VPN user selects the certificate for login when prompted. The certificate is sent in an SSL connection request to the SSL VPN gateway.
2.     The SSL VPN gateway verifies the validity of the user certificate.
¡     If the certificate is verified as invalid, the gateway rejects the SSL connection request. The user cannot log in to the SSL VPN context.
¡     If the certificate is verified as valid, the SSL connection is established and the gateway performs the next step.
3.     The SSL VPN gateway checks for certificate revocation if CRL checking is enabled.
¡     If the certificate is verified as not revoked, the SSL connection is established and the gateway performs the next step.
¡     If the certificate is verified as revoked, the gateway rejects the SSL connection request. The user cannot log in to the SSL VPN context.
For more inforamtion about CRL checking, see "Configuring PKI."
4.     The SSL VPN gateway extracts the username from the certificate attribute (CN attribute by default). Then, the SSL VPN gateway sends the username to AAA for authorization and accounting, or to a custom authentication server for authorization.
To use certificate authentication, make sure the username extracted from the specified certificate attribute exists on the authentication server.
Figure 8 Certificate authentication process
Combined username/password authentication and certificate authentication
The authentication process of combined username/password authentication and certificate authentication is as follows:
4.     The SSL VPN gateway extracts the username from the certificate and compares the extracted username with the username provided by the user:
¡     The user passes identity authentication if the two usernames match. The SSL VPN gateway then sends the username and password to AAA for authentication, authorization and accounting, or to a custom authentication server for authentication and authorization.
¡     The user fails the identity authentication if the two usernames do not match.
A user might enter the username and password when the user selects the certificate or after the SSL connection is established, depending on the access mode.
SMS authentication
After you enable SMS authentication, the device uses SMS verification codes to authenticate SSL VPN users. A user is allowed to log in to the SSL VPN gateway only when the user passes the SMS authentication.
The device supports the following types of SMS authentication:
·     IMC SMS authentication.
SMS authentication for SSL VPN users is performed by an IMC server. You must configure the IP address and port number for the IMC server in IMC SMS authentication view.
·     SMS gateway authentication.
SMS gateway authentication for SSL VPN users is performed by an SMS gateway. You must specify the SMS gateway, the verification code resend interval, and the verification code validity period in SMS gateway authentication view.
The two SMS authentication types cannot both be configured.
For SMS gateway authentication, one username can be bound to only one mobile number. When multiple users log in to the SSL VPN gateway by using the same username, the users must check the verification codes reception order. A user must submit the verification code received right for his own login attempt.
Dynamic password verification
Dynamic password verification requires a user to enter a dynamic password generated by the authentication server. Then, the device sends the dynamic password to the authentication server for verification.
Custom authentication
Custom authentication allows you to set up and configure a custom authentication server as needed. The device can use the custom authentication server for user authentication and authorization. The custom authentication server does not support accounting.
SSL VPN controls user access to resources on a per-user basis.
As shown in Figure 9, an SSL VPN gateway can be associated with multiple SSL VPN contexts. An SSL VPN context contains multiple policy groups. A policy group defines accessible Web resources, TCP resources, and IP resources.
Figure 9 SSL VPN resource access control
You can specify domain names or virtual host names for the SSL VPN contexts associated with an SSL VPN gateway. When a user logs in to the SSL VPN gateway, the SSL VPN gateway performs the following operations:
1.     Uses the domain name or virtual host name that the user entered to determine the SSL VPN context to which the user belongs.
2.     Uses the authentication and authorization methods of the ISP domain specified for the context to perform authentication and authorization for the user.
¡     If the SSL VPN gateway authorizes the user to use a policy group, the user can access resources allowed by the policy group.
¡     If the SSL VPN gateway does not authorize the user to use a policy group, the user can access resources allowed by the default policy group.
The SSL VPN gateway uses an AAA server or a custom authentication server to perform user authentication and authorization. SSL VPN supports AAA protocols RADIUS and LDAP. RADIUS is most often used.
VRF-aware SSL VPN
VRF-aware SSL VPN provides the following functionalities:
·     VRF-aware SSL VPN context—You associate different SSL VPN contexts with different VRF instances (VPN instances) on the SSL VPN gateway. Users in an SSL VPN context can access only the resources in the VPN instance associated with the SSL VPN context. VRF-aware SSL VPN contexts also allow server addresses to overlap.
·     VRF-aware SSL VPN gateway—You specify the VPN instance to which the SSL VPN gateway belongs. Only users in the same VPN can access the SSL VPN gateway. The VRF-aware SSL VPN gateway prevents the internal server resources from leaking into the public network or other VPNs.
For more information about VPN instances, see MPLS L3VPN in MPLS Configuration Guide.
Figure 10 VRF-aware SSL VPN
Hardware
SSL VPN compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
By default, the SSL VPN gateway supports a maximum of 15 online user accounts.
You can purchase and install a license to increase the number of supported online users. For more information about licenses, see license management in Fundamentals Configuration Guide.
The maximum number of online users supported by an IRF fabric is calculated as follows:
Maximum online users supported by the IRF fabric = Sum of the maximum online users permitted by the license of each member device + maximum online users supported by default.
After a member device becomes faulty, its license can still take effect on the IRF fabric for 60 days.
The SSL VPN gateway generates only one session for a user who accesses both Web and IP resources in the following method:
1.     First, the user accesses the SSL VPN gateway through a Web browser.
2.     Then, the user downloads the IP access client through the Web page and launches the IP access client.
Once the user exits the Web browser or IP access client, the session is terminated and the user can access neither Web nor IP access resources.
You can specify ACLs for user access filtering in an SSL VPN policy group. Rules in the specified ACLs do not take effect if they contain VPN settings.
To configure SSL VPN, perform the following tasks on the SSL VPN gateway:
1.     Configuring an SSL VPN gateway
2.     Configuring an SSL VPN context
3.     Configuring SSL VPN user authentication, authorization, and accounting
a.     Configuring user authentication in an SSL VPN context
b.     Configuring the SSL VPN user authentication server
A custom authentication server must be configured for custom authentication.
4.     Configuring SSL VPN resource access control as needed
¡     Configuring a URI ACL
¡     Configuring the Web access service
¡     Configuring the TCP access service
¡     Configuring the IP access service
¡     Configuring SSL VPN access for mobile clients
¡     (Optional.) Configuring shortcuts
¡     (Optional.) Configuring redirect resources
¡     (Optional.) Configuring HTTP redirection
¡     (Optional.) Configuring the default policy group for an SSL VPN context
5.     (Optional.) Configuring VRF-aware SSL VPN
¡     Associating an SSL VPN context with a VPN instance
¡     Specifying a VPN instance for an SSL VPN gateway
6.     (Optional.) Configuring SSL VPN user control
¡     Configuring online SSL VPN user control
¡     Configuring SSL VPN session rate limit
¡     Configuring SSL VPN cracking prevention
¡     Configuring SSL VPN SSO login
7.     (Optional.) Customizing SSL VPN webpages
¡     Customizing SSL VPN webpage elements
¡     Specifying an SSL VPN webpage template
8.     (Optional.) Enabling SSL VPN logging
Before you configure the SSL VPN gateway, complete the following tasks:
·     Configure PKI and obtain a digital certificate for the SSL VPN gateway (see "Configuring PKI").
·     Configure an SSL server policy to be used by the SSL VPN gateway (see "Configuring SSL").
An SSL VPN gateway that uses the default IPv4 or IPv6 address must use a port number that is different from the HTTPS service port number.
If the settings of the SSL server policy applied to an SSL VPN gateway are changed, you must disable and then enable the SSL VPN gateway to use the modified policy.
The IP address and port number of an SSL VPN gateway cannot both be the same as those of the HTTPS server on the device. Otherwise, you can access only the SSL VPN Web interface but cannot access the device management Web interface by using those IP address and port number.
2.     Create an SSL VPN gateway and enter its view.
sslvpn gateway gateway-name
3.     Configure an IPv4 address and a port number for the SSL VPN gateway.
ip address ip-address [ port port-number ]
By default, the SSL VPN gateway uses IPv4 address 0.0.0.0 and port number 443.
If you configure the ip address command without specifying a port number, the default port number (443) is used.
4.     Apply an SSL server policy to the SSL VPN gateway.
ssl server-policy policy-name
By default, an SSL VPN gateway uses the SSL server policy of its self-signed certificate.
5.     Enable the SSL VPN gateway.
service enable
By default, the SSL VPN gateway is disabled.
An SSL VPN context manages user sessions and resources available to users.
When you associate an SSL VPN context with an SSL VPN gateway, follow these guidelines:
·     Make sure the context has a domain name or virtual host name different than any existing contexts associated with the SSL VPN gateway.
·     If you do not specify a domain name or virtual host name for the context, you cannot associate other SSL VPN contexts with the SSL VPN gateway.
·     If you specify a virtual host name, deploy a DNS server in the network to resolve the virtual host name to the SSL VPN gateway's IP address.
You can associate an SSL VPN context with a maximum of 10 SSL VPN gateways.
2.     Create an SSL VPN context and enter its view.
sslvpn context context-name
3.     Associate the context with an SSL VPN gateway.
gateway gateway-name [ domain domain-name | virtual-host virtual-host-name ]
By default, the context is not associated with an SSL VPN gateway.
4.     Specify an ISP domain for AAA of SSL VPN users in the context.
aaa domain domain-name
By default, the default ISP domain is used for AAA of SSL VPN users in an SSL VPN context.
An SSL VPN username cannot carry ISP domain information. After this command is executed, the SSL VPN gateway uses the specified domain for AAA of SSL VPN users in the context.
5.     Enable the context.
service enable
By default, the context is disabled.
6.     (Optional.) Set the maximum number of sessions (online users) for the context.
max-users max-number
By default, an SSL VPN context supports a maximum of 1048575 sessions (online users).
7.     (Optional.) Set the idle timeout timer for SSL VPN sessions.
timeout idle minutes
By default, the idle timeout timer for SSL VPN sessions is 30 minutes.
8.     (Optional.) Set the idle-cut traffic threshold for SSL VPN sessions.
idle-cut traffic-threshold
By default, the SSL VPN session idle-cut traffic threshold is 0 bytes. An SSL VPN session will be disconnected if no traffic is transmitted within the session idle timeout time specified by the timeout idle command.
9.     (Optional.) Apply an SSL client policy to the SSL VPN context.
ssl client-policy policy-name
In non-FIPS mode:
The default SSL client policy for SSL VPN is used. This policy supports the dhe_rsa_aes_128_cbc_sha, dhe_rsa_aes_256_cbc_sha, rsa_3des_ede_cbc_sha, rsa_aes_128_cbc_sha, and rsa_aes_256_cbc_sha cipher suites.
In FIPS mode:
The default SSL client policy for SSL VPN is used. This policy supports the rsa_aes_128_cbc_sha and rsa_aes_256_cbc_sha cipher suites.
The SSL VPN gateway will use the settings in the specified SSL client policy to connect to HTTPS servers.
10.     (Optional.) Enable URL masking globally.
url-masking enable
URL masking is disabled by default.
After URL masking is enabled, the URLs of the Web access resources configured in the SSL VPN context are converted into coded strings.
How certificate authentication works depends on the configuration of the client-verify command in SSL server policy view. You can use the command to enable mandatory or optional SSL client authentication. Mandatory certificate authentication is supported only for Web users and IP access users. For TCP access users and mobile client users to access the SSL VPN gateway successfully, optional SSL client authentication must be used.
To configure user authentication in an SSL VPN context, perform the following tasks:
1.     Specifying the authentication methods required for user login
2.     Configuring basic authentication methods
¡     Configuring username/password authentication
¡     Configuring certificate authentication
3.     (Optional.) Configuring verification code authentication
4.     (Optional.) Configuring dynamic password authentication
5.     (Optional.) Configuring IMC SMS authentication
6.     (Optional.) Configuring SMS gateway authentication
7.     (Optional.) Configuring password modification for users
You can enable username/password authentication, certificate authentication, or both in an SSL VPN context. Whether these authentication methods are required for logging in to the SSL VPN context depend on the configuration of the authentication use all command:
·     If the authentication use all command is configured, a user must pass all the enabled authentication methods for login.
·     If the authentication use any-one command is configured, a user can log in after passing any enabled authentication method.
2.     Enter SSL VPN context view.
3.     Specify the authentication methods required for user login.
authentication use { all | any-one }
By default, a user must pass all the enabled authentication methods to log in to an SSL VPN context.
3.     Enable username/password authentication.
password-authentication enable
Username/password authentication is enabled by default.
3.     Enable certificate authentication.
certificate-authentication enable
Certificate authentication is disabled by default.
4.     Specify the certificate attribute as the SSL VPN username.
certificate username-attribute { cn | email-prefix | oid extern-id }
By default, the device uses the value of the CN attribute in the subject of the certificate as the SSL VPN username.
3.     Enable verification code authentication.
verify-code enable
By default, verification code authentication is enabled.
3.     Enable dynamic password verification.
dynamic-password enable
By default, dynamic password verification is disabled.
3.     Enable IMC SMS authentication.
sms-auth type imc
By default, IMC SMS authentication is disabled.
4.     Create and enter IMC SMS authentication view.
sms-auth imc
5.     Specify an IMC server.
server-address ip-address port port-number [ vpn-instance vpn-instance-name ]
By default, no IMC server is specified.
Complete the SMS gateway configuration. For information about configuring an SMS gateway, see "Configuring SMS."
3.     Enter SSL VPN user view.
user username
4.     Specify the mobile number for the SSL VPN user to receive SMS messages.
mobile-num number
By default, no mobile number is specified for receiving SMS messages.
5.     Return to SSL VPN context view.
6.     Enable SMS gateway authentication.
sms-auth type sms-gw
By default, SMS gateway authentication is disabled.
7.     Create and enter SMS gateway authentication view.
sms-auth sms-gw
By default, the SMS gateway authentication view does not exist.
8.     Specify an SMS gateway.
gateway sms-gateway-name
By default, no SMS gateway is specified.
9.     Enable mobile number binding.
mobile-num-binding enable
By default, mobile number binding is disabled.
10.     Set the verification code resend interval.
verification-code send-interval seconds
By default, the verification code resend interval is 60 seconds.
11.     Set the verification code validity period.
verification-code validity minutes
By default, the verification code validity period is one minute.
12.     Specify the mobile country code.
country-code country-code
By default, the mobile country code is 86.
13.     Configure the SMS content template.
sms-content string
By default, the SMS content template is Hello, $$USER$$, the verification code is $$VERIFYCODE$$, and its validity period is $$VALIDTIME$$ in minutes..
Password modification allows SSL VPN users to modify login passwords on the personal settings page after logging in to the SSL VPN Web interface. This feature is available only for IMC authentication users.
If you disable this feature, the modify password function will be hidden on the SSL VPN Web interface, so users cannot modify their passwords.
3.     Enable SSL VPN users in the SSL VPN context to modify passwords.
password-changing enable
By default, SSL VPN users in the SSL VPN context are allowed to modify passwords.
4.     Enter SSL VPN user view.
user username
5.     (Optional.) Enable password modification for the SSL VPN user.
By default, an SSL VPN user is allowed to modify the password.
6.     Specify an IMC server for password modification.
self-service imc address ip-address port port-number [ vpn-instance vpn-instance-name ]
By default, no IMC server is specified for password modification.
Execute this command only when IMC authentication users need to modify the SSL VPN login passwords.
The SSL VPN user authentication supports the following types of servers:
·     AAA authentication server—The device uses an AAA server for user authentication, authorization, and accounting. For more information about AAA, see "Configuring AAA."
·     Custom authentication server—You can set up and configure a custom authentication server as needed. The device can use the custom authentication server for user authentication and authorization. The custom authentication server does not support accounting. For more information about configuring the custom authentication server, see "Configuring the custom authentication server."
3.     Specify the authentication server type.
authentication server-type { aaa | custom }
By default, the SSL VPN authentication server is an AAA server.
To use a custom authentication server for user authentication and authorization, configure the following settings:
·     URL of the custom authentication server.
The SSL VPN gateway uses HTTP to send authentication requests to the specified URL.
·     Custom authentication timeout.
After sending an HTTP request to the custom authentication server, the SSL VPN gateway waits for reponses from the server. If the gateway receives no response within the authentication timeout, it returns an authentication failure message to the SSL VPN client.
·     HTTP request settings for custom authentication.
The SSL VPN gateway constructs an HTTP request based on the authentication request settings, including HTTP request method, request header fields, and request template.
·     HTTP response settings for custom authentication.
The SSL VPN gateway parses an HTTP response based on the authentication response settings. The settings include HTTP response format, authentication success value in the response, field names in the response, and response templates for the custom-format HTTP response.
3.     Configure the URL of the custom authentication server.
custom-authentication url url
By default, no custom authentication server URL is configured.
4.     Specify the custom authentication timeout.
custom-authentication timeout seconds
By default, the custom authentication timeout is 15 seconds.
5.     Configure settings for a custom authentication request:
a.     Configure the HTTP request method.
custom-authentication request-method { get | post }
By default, the HTTP request method is GET.
b.     Configure HTTP request header fields.
custom-authentication request-header-field field-name value value
By default, a custom authentication request header includes the following fields:
-     Content-type:application/x-www-form-urlencoded.
-     User-Agent:nodejs 4.1.
-     Accept:text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q.
c.     Configure the HTTP request template.
custom-authentication request-template template
By default, no request template is configured.
6.     Configure settings for a custom authentication response:
a.     Specify the HTTP response format.
custom-authentication response-format { custom | json | xml }
By default, the HTTP response format is JSON.
b.     Configure the authentication success value in the HTTP response.
custom-authentication response-success-value success-value
By default, no authentication success value is configured for the HTTP response.
c.     Configure field names in the HTTP response.
custom-authentication response-field { group group | message message | result result }
By default, no HTTP response field names are configured.
You must configure HTTP response field names if the HTTP response format is JSON or XML.
d.     Configure response templates for the fields in the custom-format HTTP response.
custom-authentication response-custom-template { group | message | result } template
By default, no response templates are configured.
The response templates are required when the HTTP response format is custom.
A URI ACL is a set of rules that permit or deny access to resources. You can use URI ACLs for fine-grained IP, TCP, and Web access filtering of SSL VPN users.
You can add multiple rules to a URI ACL. The device matches a packet against the rules in ascending order of rule ID. The match process stops once a matching rule is found.
You can create multiple URI ACLs in an SSL VPN context.
A URI ACL can filter SSL VPN users' HTTP, HTTPS, TCP, UDP, ICMP, and IP traffic based on the following fields:
·     Protocol type.
·     IP address.
·     Host name.
·     Port number.
·     URL.
3.     Create a URI ACL and enter its view.
uri-acl uri-acl-name
4.     Configure a rule in the URI ACL.
rule [ rule-id ] { deny | permit } uri uri-pattern-string
By default, no rules are configured in a URI ACL.
To allow remote users to access internal resources in Web access mode, you must configure Web access resources and associate the resources with an SSL VPN policy group.
To configure the Web access service, perform the following tasks:
1.     Configuring a URL list
2.     Configuring an SSL VPN policy group for Web access
3.     (Optional.) Configuring a file policy
A URL list is a list of URL items that define the accessible Web resources behind the SSL VPN gateway. Each URL item corresponds to an internal Web resource.
The SSL VPN gateway rewrites the resource URL returned from the internal server before sending the URL to the requesting user. The URL mapping type determines how the gateway rewrites the URL.
The following example describes how URL mapping works when the user accesses internal resources at URL http://www.server.com:8080. The SSL VPN gateway name is gw, domain name is https://www.gateway.com:4430, and IP address is 1.1.1.1.
·     Normal rewriting—This is the default mapping method. The resource URL returned to the client will be rewritten to https://www.gateway.com:4430/_proxy2/http/8080/www.server.com.
·     Domain mapping—The resource URL returned to the client will be rewritten to https://mapped domain name:4430, where mapped domain name is the user-defined domain name.
·     Port mapping—You can specify a gateway name with or without a virtual host name for port mapping. For example:
¡     If you specify gw2 as the gateway name and do not specify a virtual host name, the resource URL will be rewritten to https://2.2.2.2:4430, where 2.2.2.2 and 4430 are the IP address and port number of SSL VPN gateway gw2.
¡     If you specify gw as the gateway name and vhosta as the virtual host name, the resource URL will be rewritten to https://vhosta:4430.
Resource URL rewriting is available only for resource access responses that contain HTML, XML, CSS, or JavaScript files.
Normal rewriting might cause problems such as missed URL rewriting and rewriting errors, resulting in SSL VPN clients not being able to access the internal resources. Use domain mapping or URL mapping as a best practice.
3.     Create a URL item and enter its view.
url-item name
4.     Specify the resource URL in the URL item.
url url
By default, no resource URL is specified in a URL item.
If you do not specify a protocol type in the resource URL, the default protocol (HTTP) is used.
5.     (Optional.) Enable URL masking.
url-masking enable
By default, URL masking is disabled.
After URL masking is enabled, the Web resource URL for the URL item is converted into a coded string.
6.     (Optional.) Specify a URI ACL in the URL item.
resources uri-acl uri-acl-name
By default, no URI ACL is specified.
7.     (Optional.) Configure the URL mapping method.
url-mapping { domain-mapping domain-name | port-mapping gateway gateway-name [ virtual-host virtual-host-name ] } [ rewrite-enable ]
By default, the normal rewriting method is used.
8.     Return to SSL VPN context view.
9.     Create a URL list and enter its view.
url-list name
10.     (Optional.) Configure a heading for the URL list.
heading string
By default, the URL list heading is Web.
11.     Add the URL item to the URL list.
resources url-item name
By default, a URL list does not contain any URL items.
To configure an SSL VPN policy group for Web access, associate a URL list with the policy group. After the authentication server authorizes a user to use a policy group, the user can access the Web resources provided by the URL list associated with the policy group.
In a policy group, you can specify an advanced ACL and a URI ACL to filter users' Web access requests.
The advanced ACL supports filtering Web access requests by destination IP address and destination port number. The URI ACL supports filtering Web access requests by protocol type, destination address, domain name, port number, and URL.
The SSL VPN gateway uses the following procedure to determine whether to forward a Web access request:
1.     Matches the request against the authorized URL list.
¡     If the request matches a URL item in the list, the gateway forwards the request.
¡     If the request does not match any URL items in the list, the gateway proceeds to the next step.
2.     Matches the request against rules in the URI ACL:
¡     If the request matches a permit rule, the gateway forwards the request.
¡     If the request matches a deny rule, the gateway drops the request.
¡     If the request does not match any rules in the URI ACL or if no URI ACL is available, the gateway proceeds to the next step.
3.     Matches the request against rules in the advanced ACL:
¡     If the request does not match any rules in the advanced ACL or if no advanced ACL is available, the gateway drops the request.
3.     Create an SSL VPN policy group and enter SSL VPN policy group view.
policy-group group-name
4.     Associate a URL list with the policy group.
resources url-list url-list-name
By default, no URL list associated with a policy group.
5.     (Optional.) Specify the ACLs for Web access filtering:
¡     Specify an advanced ACL for Web access filtering.
filter web-access [ ipv6 ] acl advanced-acl-number
¡     Specify a URI ACL for Web access filtering.
filter web-access uri-acl uri-acl-name
By default, users can access only the Web resources authorized to them through the URL list.
A file policy enables the SSL VPN gateway to rewrite Web page files before forwarding them to requesting Web access users.
A file policy contains the following settings:
·     A URL that identifies the path of the file to which the file policy is applied.
·     One or more rewrite rules.
A rewrite rule defines the old file content to be rewritten and the new content used to replace the old content.
·     (Optional.) The file type that the file is changed to after being rewritten by the file policy.
3.     Create a file policy and enter its view.
file-policy policy-name
By default, no file policies exist.
4.     Specify the URL of the file to be rewritten.
url url
By default, no file URL is specified in a file policy.
5.     Specify the file type that a file is changed to after being rewritten by the file policy.
content-type { css | html | javascript | other }
By default, a file policy rewrites a file in an HTTP response to the file type indicated by the content-type field in the HTTP response.
6.     Create a rewrite rule and enter its view.
rewrite-rule rule-name
7.     Specify the old content to be rewritten.
old-content string
By default, the old content to be rewritten is not specified.
8.     Specify the new content used to replace the old content.
new-content string
By default, the new content used to replace the old content is not specified.
To allow remote users to access internal resources in TCP access mode, you must configure TCP access resources and associate the resources with an SSL VPN policy group.
To configure the TCP access service, perform the following tasks:
1.     Configuring a port forwarding list
2.     Configuring an SSL VPN policy group for TCP access
A port forwarding list is a list of port forwarding items. Each port forwarding item contains a port forwarding instance.
A port forwarding instance maps a TCP service (such as Telnet, SSH, or POP3) hosted on an internal server to a local address and port number on the SSL VPN client. Remote users can access the TCP service though the local address and port number.
The port forwarding instance is displayed together with the port forwarding item name on the SSL VPN Web page. If you configure a resource link for the port forwarding item, the port forwarding item name will be displayed as a link on the SSL VPN Web page. You can click the link to access the resource directly.
3.     Create a port forwarding item and enter its view.
port-forward-item item-name
4.     Configure a port forwarding instance for the port forwarding item.
local-port local-port-number local-name local-name remote-server remote-server remote-port remote-port-number [ description text ]
6.     Create a port forwarding list and enter its view.
port-forward port-forward-name
7.     Assign the port forwarding item to the port forwarding list.
resources port-forward-item item-name
By default, a port forwarding list does not contain port forwarding items.
To configure an SSL VPN policy group for TCP access, associate a port forwarding list with the policy group. After the authentication server authorizes a user to use a policy group, the user can access the TCP services provided by the port forwarding list associated with the policy group.
In a policy group, you can specify an advanced ACL and a URI ACL to filter users' TCP access requests.
The advanced ACL supports filtering TCP access requests by destination IP address and destination port number. The URI ACL supports filtering TCP access requests by protocol type, destination address, domain name, port number, and URL.
For PC users, the ACLs configured for TCP access filtering do not take effect. They can access only the TCP resources authorized to them through the TCP port forwarding list.
For mobile client users, the SSL VPN gateway uses the following procedure to determine whether to forward a TCP access request:
1.     Matches the request against the authorized port forwarding list.
¡     If the request matches a port forwarding item in the list, the gateway forwards the request.
¡     If the request does not match any port forwarding items in the list, the gateway proceeds to the next step.
2.     Matches the request against the rules in the URI ACL:
3.     Matches the request against the rules in the advanced ACL:
4.     Associate a port forwarding list with the policy group.
resources port-forward port-forward-name
By default, no port forwarding list is associated with a policy group.
5.     (Optional.) Specify the ACLs for TCP access filtering:
¡     Specify an advanced ACL for TCP access filtering.
filter tcp-access [ ipv6 ] acl advanced-acl-number
¡     Specify a URI ACL for TCP access filtering.
filter tcp-access uri-acl uri-acl-name
By default, users can access only the TCP resources authorized to them through the TCP port forwarding list.
To allow remote users to access internal resources in IP access mode, you must configure IP access resources and associate the resources with an SSL VPN policy group.
To ensure correct forwarding of reply packets to an SSL VPN client, configure static routes from the internal servers to the network segment where the client's VNIC resides.
To configure the IP access service, perform the following tasks:
1.     Configuring an SSL VPN AC interface for IP access
2.     Creating an address pool for IP access users
3.     Configuring IP access parameters in an SSL VPN context
4.     Configuring an SSL VPN policy group for IP access
2.     Create an SSL VPN AC interface and enter its view.
interface sslvpn-ac interface-number
3.     Configure an IP address for the interface.
ip address ip-address { mask | mask-length }
By default, no IP address is configured for an AC interface.
4.     (Optional.) Set the expected bandwidth for the interface.
bandwidth bandwidth-value
The expected bandwidth is 64 kbps by default.
5.     (Optional.) Configure the description of the interface.
The default interface description is interface name Interface. For example, SSLVPN-AC1000 Interface.
6.     (Optional.) Set the MTU of the interface.
mtu size
The default MTU is 1500 bytes.
7.     Bring up the interface.
By default, an SSL VPN AC interface is up.
Restoring the default settings for the SSL VPN AC interface
IMPORTANT
IMPORTANT:
Restoring the default interface settings might interrupt ongoing network services. Make sure you are fully aware of the impact of this operation when you perform it on a live network.
To restore the default settings for the SSL VPN AC interface:
2.     Enter SSL VPN AC interface view.
3.     Restore the default settings for the SSL VPN AC interface.
default
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their respective default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
An address pool defines the IP addresses that can be assigned to IP access users.
2.     Create an address pool.
sslvpn ip address-pool pool-name start-ip-address end-ip-address
To provide service to IP access users, you must configure IP access parameters in an SSL VPN context, including the SSL VPN AC interface, address pool, and route list. After a user passes identity authentication, the SSL VPN context allocates an IP address to the VNIC of the user from the specified address pool. The route list can be used by an SSL VPN policy group to issue route entries to users.
3.     Specify an SSL VPN AC interface for IP access.
ip-tunnel interface sslvpn-ac interface-number
By default, no SSL VPN AC interface is specified for IP access in the SSL VPN context.
4.     Configure a route list:
a.     Create a route list and enter its view.
ip-route-list list-name
b.     Add an included route to the route list.
include ip-address { mask | mask-length }
c.     Return to SSL VPN context view.
5.     Specify an address pool for IP access.
ip-tunnel address-pool pool-name mask { mask-length | mask }
By default, no address pool is specified for IP access.
6.     (Optional.) Set the keepalive interval.
ip-tunnel keepalive seconds
By default, the keepalive interval is 30 seconds.
7.     (Optional.) Specify a DNS server for IP access.
ip-tunnel dns-server { primary | secondary } ip-address
By default, no DNS servers are specified for IP access.
8.     (Optional.) Specify a WINS server for IP access.
ip-tunnel wins-server { primary | secondary } ip-address
By default, no WINS servers are specified for IP access.
9.     (Optional.) Enable automatic startup of the IP access client after Web login.
web-access ip-client auto-activate
By default, automatic startup of the IP access client after Web login is disabled.
10.     (Optional.) Enable automatic pushing of accessible resources to IP access users through the Web page.
ip-tunnel web-resource auto-push
By default, automatic pushing of accessible resources to IP access users through the Web page is disabled.
11.     (Optional.) Set a rate limit for IP access upstream or downstream traffic.
ip-tunnel rate-limit { downstream | upstream } { kbps | pps } value
By default, no rate limit is set for IP access upstream or downstream traffic.
To configure an SSL VPN policy group for IP access, configure routes for the accessible IP resources in the policy group. After the AAA server or custom authentication server authorizes a user to use a policy group, the SSL VPN gateway issues the routes to the user so the user can access the IP resources.
You can configure the routes to be issued to users by using one of the following methods:
·     Manually configure a route.
·     Specify a route list.
·     Force all traffic to be sent to the SSL VPN gateway.
The SSL VPN gateway issues a default route to the SSL VPN client. The default route uses the VNIC as the output interface and has the highest priority among all default routes on the client. Packets for destinations not in the routing table are sent to the SSL VPN gateway through the VNIC. The SSL VPN gateway monitors the SSL VPN client in real time. It does not allow the client to delete the default route or add a default route with a higher priority.
In a policy group, you can specify an advanced ACL and a URI ACL to filter users' IP access requests.
The SSL VPN gateway uses the following procedure to determine whether to forward an IP access request:
1.     Matches the request against the rules in the URI ACL:
¡     If the request does not match any rules in the URI ACL or if no URI ACL is available, the gateway proceeds to step 2.
2.     Matches the request against the rules in the advanced ACL:
If no URI ACL or advanced ACL is specified for IP access filtering, the SSL VPN gateway permits all IP accesses by default.
The advanced ACL supports filtering IP access requests by using the following criteria:
·     Destination IP address.
·     Destination port number.
·     Source IP address.
·     Source port number.
·     Protocol type.
·     Packet priority.
·     Fragment information.
·     TCP flag.
·     ICMP message type and message code.
The URI ACL supports filtering IP access requests by protocol type, destination address, domain name, port number, and URL.
If a rule in the URI ACL specified for IP access filtering contains HTTP or HTTPS settings, the rule does not take effect.
4.     Specify the routes to be issued to clients.
ip-tunnel access-route { ip-address { mask-length | mask } | force-all | ip-route-list list-name }
By default, no routes are configured.
5.     Specify the ACLs for IP access filtering:
¡     Specify an advanced ACL for IP access filtering.
filter ip-tunnel [ ipv6 ] acl advanced-acl-number
¡     Specify a URI ACL for IP access filtering.
filter ip-tunnel uri-acl uri-acl-name
By default, an SSL VPN gateway permits all IP access requests.
6.     (Optional.) Specify an address pool for IP access.
By default, no address pool is specified for IP access in an SSL VPN policy group.
If no free address is available in the address pool or the address pool does not exist, address allocation to IP access users will fail and the users' access requests will be rejected.
If no address pool is specified for the policy group, the SSL VPN gateway allocates IP addresses to users from the address pool specified for the SSL VPN context.
To configure SSL VPN access for mobile clients, perform the following tasks:
1.     Specifying an EMO server for mobile clients
2.     (Optional.) Specifying a message server for mobile clients
An EMO server provides services for mobile clients. After you specify an EMO server for mobile clients, the SSL VPN gateway issues the EMO server information to the clients. The clients can access available service resources through the EMO server.
3.     Specify an EMO server for mobile clients.
emo-server address { host-name | ipv4-address } port port-number
By default, no EMO server is specified for mobile clients.
A message server provides services for mobile clients. After you specify a message server for mobile clients, the SSL VPN gateway issues the message server information to the clients. The clients can access the message server.
3.     Specify a message server for mobile clients.
message-server address { host-name | ipv4-address } port port-number
By default, no message server is specified for mobile clients.
To provide quick access to resources on internal servers, configure shortcuts for these resources. A shortcut provides the access link to a protected resource on the SSL VPN Web page. Users can click a shortcut name on the SSL VPN Web page to access the associated resource.
3.     Create a shortcut and enter its view.
shortcut shortcut-name
By default, no shortcuts exist.
4.     (Optional.) Configure a description for the shortcut.
By default, no description is configured for a shortcut.
5.     Configure a resource link for the shortcut.
execution script
By default, no resource link is configured for a shortcut.
6.     Return to SSL VPN context view.
7.     Create a shortcut list and enter its view.
shortcut-list list-name
8.     Assign the shortcut to the shortcut list.
resources shortcut shortcut-name
By default, a shortcut list does not contain shortcuts.
9.     Return to SSL VPN context view.
10.     Enter SSL VPN policy group view.
11.     Assign the shortcut list to the SSL VPN policy group.
resources shortcut-list list-name
By default, an SSL VPN policy group does not contain a shortcut list.
By default, a user enters the SSL VPN webpage after logging in to the SSL VPN gateway. To provide quick access to the specified Web resource on internal servers, configure the resource as a redirect resource. Users will directly enter the specified redirect resource after a short stay on the SSL VPN Web page.
3.     Enter SSL VPN policy group view.
4.     Configure the Web resource for SSL VPN users to access after login.
redirect-resource { shortcut | url-item } resource-name
By default, after logging in to the SSL VPN gateway, a user directly enters the SSL VPN webpage, and no redirection is performed.
An SSL VPN gateway communicates with users through HTTPS. To allow HTTP to access the SSL VPN gateway, you must configure HTTP redirection.
HTTP redirection enables an SSL VPN gateway to perform the following operations:
1.     Listen to an HTTP port.
2.     Redirect HTTP requests with the port number to the port used by HTTPS.
3.     Send redirection packets to clients.
2.     Enter SSL VPN gateway view.
3.     Enable HTTP redirection.
http-redirect [ port port-number ]
By default, HTTP redirection is disabled. An SSL VPN gateway does not process HTTP traffic.
If the AAA server or custom authentication server does not authorize a policy group to a user after the user logs in, the SSL VPN gateway authorizes the default policy group to the user. If no default policy group is configured, the SSL VPN gateway denies all access requests from the user.
4.     Configure accessible resources in the policy group:
¡     Configure Web access resources.
By default, no Web access resources are configured in a policy group.
¡     Configure TCP access resources.
By default, no TCP access resources are configured in a policy group.
¡     Configure IP access resources.
By default, no IP access resources are configured in a policy group.
6.     (Optional.) Specify the ACLs for TCP access filtering:
7.     (Optional.) Specify the ACLs for IP access filtering:
9.     Specify the policy group as the default policy group for the SSL VPN context.
default-policy-group group-name
By default, no default policy group is specified for an SSL VPN context.
You can associate different SSL VPN contexts with different VPN instances on the SSL VPN gateway. Users in an SSL VPN context can access only the resources in the VPN instance associated with the SSL VPN context. VRF-aware SSL VPN contexts also allow server addresses to overlap.
Before you configure this feature, complete the following tasks:
·     Create the VPN instance.
·     Associate the SSL VPN gateway's interface connected to the internal server with the VPN instance.
·     (Required for IP access.) Associate the SSL VPN AC interface specified by the ip-tunnel interface command with the VPN instance.
For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide.
3.     Associate the SSL VPN context with a VPN instance.
By default, an SSL VPN context is associated with the public network.
After you specify a VPN instance for an SSL VPN gateway, only users in the specified VPN can access the SSL VPN gateway. The VRF-aware SSL VPN gateway prevents the internal server resources from leaking into the public network or other VPNs.
·     Associate the VPN instance with the SSL VPN gateway's interface connected to the user.
·     Bind the SSL VPN AC interface to
3.     Specify a VPN instance for the gateway.
By default, an SSL VPN gateway belongs to the public network.
Perform this task to configure the SSL VPN user login control features, such as the force logout feature, the maximum number of concurrent logins for each account, and the maximum number of connections allowed per session.
3.     Force online users to log out.
force-logout [ all | session session-id | user user-name ]
4.     Set the maximum number of concurrent logins for each account.
max-onlines number
By default, the maximum number of concurrent logins for each account is 32.
5.     Enable the force logout feature.
force-logout max-onlines enable
By default, the force logout feature is disabled. A user cannot log in if the number of logins using the account reaches the maximum.
When a login is attempted but logins using the account reach the maximum, this feature logs out the user with the longest idle time to allow the new login.
6.     Set the maximum number of connections allowed per session.
session-connections number
By default, a maximum of 64 connections are allowed per session.
If the number of connections in a session has reached the maximum, new connection requests for the session will be rejected with a 503 Service Unavailable message.
Perform this task to set a rate limit for SSL VPN session upstream and downstream traffic, respectively. If the SSL VPN session upstream or downstream traffic exceeds the rate limit, subsequent upstream or downstream traffic will be discarded.
3.     Set a rate limit for SSL VPN session upstream or downstream traffic.
rate-limit { downstream | upstream } value
By default, no rate limit is set for SSL VPN session upstream or downstream traffic.
This feature reduces the risk of brute-force cracking of user login information by limiting the number of login attempts from the same IP address.
If the number of consecutive login failures of the same IP address reaches the specified number, the IP address will be frozen for the specified period of time. During the freeze period, the IP address is prohibited from logging in to the SSL VPN context. When the freeze period expires, the frozen IP address will be unfrozen automatically. To unfreeze the frozen IP address immediately, execute the prevent-cracking unfreeze-ip command.
3.     Enable IP address freezing for cracking prevention.
prevent-cracking freeze-ip enable
By default, IP address freezing for cracking prevention is disabled.
4.     (Optional.) Specify the maximum number of consecutive login failures allowed for an IP address and the period of time to freeze an IP address for cracking prevention.
prevent-cracking freeze-ip login-failures login-failures freeze-time freeze-time
By default, the maximum number of consecutive login failures allowed for an IP address is 64, and the period of time to freeze an IP address is 30 seconds.
5.     Enable code verification for cracking prevention.
prevent-cracking verify-code enable
By default, code verification for cracking prevention is disabled.
6.     (Optional.) Specify the maximum number of consecutive login failures allowed for an IP address before performing code verification to prevent cracking.
prevent-cracking verify-code login-failures login-failures
By default, a maximum of five consecutive login failures are allowed for an IP address before performing code verification.
7.     (Optional.) Unfreeze frozen IP addresses.
prevent-cracking unfreeze-ip { all | { ipv4 | ipv6 } ip-address }
About configuring SSL VPN SSO login
SSO allows a user to use one set of login credentials (such as username and password) to access multiple trusted systems. With SSO, SSL VPN Web access users can gain access to internal servers without entering the login credentials for the internal servers. The device supports the following methods for SSO login:
·     Auto-build method (automatically build login requests)
Use a packet capture tool to obtain internal server login requests, and then configure SSO login settings based on the login requests to automatically build login requests to the internal servers. SSO login settings include the HTTP request method, login request encoding method, login parameters, and login data encryption file.
·     Basic authentication method
Basic authentication is a simple HTTP authentication scheme, which requires a Web client to enter a username and password to access the server. The server authenticates the client based on the username and password.
To implement SSO in the basic authentication method, the SSL VPN gateway acts as a Web client and automatically enters a username and password to perform HTTP basic authentication. The entered username and password can be SSL VPN username and password or custom username and password.
The basic authentication SSO method is applicable only for logging in to the internal servers that support basic authentication.
For the auto-build SSO method, the following requirements must be met:
·     SSO login is available only for SSL VPN Web access users.
·     If a user group name is specified as the SSO login parameter, only remote users are supported.
·     SSO login is available only for accessing resources by clicking the URL links on the SSL VPN Web interface. SSO does not work if you access the resources by entering the URLs in a browser address bar or a URL input box.
·     SSO login is not available for Web resources that require graphic verification codes.
·     SSO login is not available for Web resources that require two-factor authentication or script invocation.
Configuring SSO login in auto-build method
url-item name
url url
5.     Enable Web access SOO and specify the auto-build method.
sso method auto-build
By default, Web access SSO login is disabled.
6.     Specify the HTTP request method for sending SSO login requests.
sso auto-build request-method { get | post }
By default, the GET request method is used for sending SSO login requests.
7.     Specify an encoding method for SSO login requests.
sso auto-build code { gb18030 | utf-8 }
By default, UTF-8 encoding is used for SSO login requests.
8.     Configure a login parameter for automatic building of SSO login requests.
sso auto-build login-parameter { cert-fingerprint | cert-serial | cert-title | custom-password | custom-username | login-name | login-password | mobile-num | user-group } name parameter-name [ encrypt ]
By default, no login parameter is configured for automatic building of SSO login requests.
9.     Configure a custom login parameter for automatic building of SSO login requests.
sso auto-build custom-login-parameter name parameter-name value value [ encrypt ]
By default, no custom parameter is configured for automatic building of SSO login requests.
10.     Specify an encryption file to encrypt the values of parameters in SSO login requests.
sso auto-build encrypt-file filename
By default, no encryption file is specified.
Configuring SSO login through basic authentication
url-item name
url url
5.     Enable Web access SSO and specify the SSO method as basic authentication.
sso method basic
6.     (Optional.) Enable using a custom username and password for SSO login through basic authentication.
sso basic custom-username-password enable
By default, SSL VPN login username and password are used for SSO login through basic authentication.
If a user-defined webpage template is specified in an SSL VPN context, all other webpage customization settings are invalid for the SSL VPN context.
You can customize the following elements on the SSL VPN webpage:
·     Login message.
·     Password input box displaying.
·     Title.
·     Logo.
·     Notification message on the SSL VPN gateway login page and resource page.
·     Files for users to download on the SSL VPN resource page.
·     Password complexity description.
·     Server reply message rewriting.
3.     Configure a login message.
login-message { chinese chinese-message | english english-message }
By default, the login message is Welcome to SSL VPN.
4.     Hide the password input box on the SSL VPN Web login page.
password-box hide
By default, the password input box is displayed on the SSL VPN Web login page.
5.     Configure a title.
title { chinese chinese-title | english english-title }
By default, the title is SSL VPN.
6.     Specify a logo.
logo { file file-name | none }
By default, the H3C logo is displayed.
7.     Configure the notification message to be displayed on the SSL VPN gateway login page or resource page.
notify-message { login-page | resource-page } { chinese chinese-message | english english-message }
By default, no notification message is configured.
8.     Specify a file for users to download on the SSL VPN gateway resource page.
resources-file { chinese chinese-filename | english english-filename }
By default, no file is provided for users to download.
9.     Configure the password complexity message to be displayed on the SSL VPN password modification page.
password-complexity-message { chinese chinese-message | english english-message }
By default, no password complexity message is configured.
10.     Rewrite a server reply message.
rewrite server-response-message server-response-message { chinese chinese-message | english english-message }
By default, no server reply message is rewritten.
This task allows you to customize SSL VPN webpages by specifying an SSL VPN webpage template. An SSL VPN webpage template defines the style of the SSL VPN gateway login page and resource page.
You can specify a webpage template in system view and in SSL VPN context view.
·     The webpage template set in system view is the global SSL VPN webpage template, which is applicable to all SSL VPN contexts.
·     The webpage template set in SSL VPN context view is applicable only to the current SSL VPN context.
Upload the user-defined webpage templates to the file system of the device from the webpage.
Restrictions and guidelines for SSL VPN webpage customization
The SSL VPN webpage template specified in SSL VPN context view takes precedence over that in system view.
Specifying an SSL VPN webpage template in system view
2.     Specify the global SSL VPN webpage template.
sslvpn webpage-customize template-name
By default, no global SSL VPN webpage template is specified. SSL VPN uses the system default SSL VPN webpages.
Specifying an SSL VPN webpage template in an SSL VPN context
3.     Specify an SSL VPN webpage template.
By default, no SSL VPN webpage template is specified for an SSL VPN context. An SSL VPN context uses the global SSL VPN webpage template.
Logs generated by SSL VPN logging are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
2.     Enable the SSL VPN global logging feature.
sslvpn log enable
By default, the SSL VPN global logging feature is disabled.
3.     Enter SSL VPN context view.
4.     Enable logging for user login and logoff events.
log user-login enable
By default, logging for user login and logoff events is disabled.
5.     Enable logging for resource accesses of users.
log resource-access enable [ brief | filtering ] *
By default, resource access logging is disabled.
6.     Enable logging for IP access connection close events.
ip-tunnel log connection-close
By default, logging for IP access connection close events is disabled.
7.     Enable logging for IP access packet drop events.
ip-tunnel log packet-drop
By default, logging for IP access packet drop events is disabled.
Display and maintenance commands for SSL VPN
Display SSL VPN AC interface information.
display interface sslvpn-ac [ interface-number ] [ brief [ description | down ] ]
Display SSL VPN context information.
display sslvpn context [ brief | name context-name ]
Display SSL VPN gateway information.
display sslvpn gateway [ brief | name gateway-name ]
Display packet statistics for IP access users.
display sslvpn ip-tunnel statistics [ context context-name ] [ user user-name ]
Display SSL VPN policy group information.
display sslvpn policy-group group-name [ context context-name ]
Display TCP port forwarding connection information.
display sslvpn port-forward connection [ context context-name ]
In IRF mode:
display sslvpn port-forward connection [ context context-name ] [ slot slot-number ]
Display information about IP addresses frozen for cracking prevention.
display sslvpn prevent-cracking frozen-ip { statistics | table } [ context context-name ]
Display SSL VPN session information.
display sslvpn session [ context context-name ] [ user user-name | verbose ]
Display SSL VPN webpage template information.
display sslvpn webpage-customize template
Clear SSL VPN AC interface statistics.
reset counters interface [ sslvpn-ac [ interface-number ] ]
Clear packet statistics for IP access users.
reset sslvpn ip-tunnel statistics [ context context-name [ session session-id ] ]
SSL VPN configuration examples
Example: Configuring Web access with self-signed certificate
As shown in Figure 11, the device acts as the SSL VPN gateway that connects the public network and the private network. Server A and Server B are internal Web servers. Server A uses HTTP over port 80. Server B uses HTTPS over port 443.
The device uses a self-signed SSL server certificate.
Configure SSL VPN Web access on the device to allow user 1 to access only Server A and user 2 to access only Server B.
Configure the device to perform local authentication and authorization for the users.
Figure 11 Network diagram
1.     Configure IP addresses for interfaces on the device. (Details not shown.)
2.     Make sure the device and the users, the device and Server A, and the device and Server B can reach each other. (Details not shown.)
3.     Configure the SSL VPN gateway:
# Configure the IP address for SSL VPN gateway gw as 1.1.1.2 and port number as 4430.
[Device] sslvpn gateway gw
[Device-sslvpn-gateway-gw] ip address 1.1.1.2 port 4430
# Enable the SSL VPN gateway.
[Device-sslvpn-gateway-gw] service enable
[Device-sslvpn-gateway-gw] quit
4.     Configure SSL VPN contexts:
# Create SSL VPN context ctxweb1, and then specify gateway gw and domain domainweb1 for the context.
[Device] sslvpn context ctxweb1
[Device-sslvpn-context-ctxweb1] gateway gw domain domainweb1
# Create a URL item named urlitem and specify the resource URL in the URL item.
[Device-sslvpn-context-ctxweb1] url-item urlitem
[Device-sslvpn-context-ctxweb1-url-item-urlitem] url http://20.2.2.2
[Device-sslvpn-context-ctxweb1-url-item-urlitem] quit
# Create a URL list named urllist in SSL VPN context ctxweb1.
[Device-sslvpn-context-ctxweb1] url-list urllist
# Configure the heading as web for the URL list.
[Device-sslvpn-context-ctxweb1-url-list-urllist] heading web
# Assign URL item urlitem to URL list urllist.
[Device-sslvpn-context-ctxweb1-url-list-urllist] resources url-item urlitem
[Device-sslvpn-context-ctxweb1-url-list-urllist] quit
# Create an SSL VPN policy group named resourcegrp1 for SSL VPN context ctxweb1, and then add URL list urllist to the policy group for Web access.
[Device-sslvpn-context-ctxweb1] policy-group resourcegrp1
[Device-sslvpn-context-ctxweb1-policy-group-resourcegrp1] resources url-list urllist
[Device-sslvpn-context-ctxweb1-policy-group-resourcegrp1] quit
# Enable SSL VPN context ctxweb1.
[Device-sslvpn-context-ctxweb1] service enable
[Device-sslvpn-context-ctxweb1] quit
# Create SSL VPN context ctxweb2, and then specify gateway gw and domain domainweb2 for the context.
[Device] sslvpn context ctxweb2
[Device-sslvpn-context-ctxweb2] gateway gw domain domainweb2
[Device-sslvpn-context-ctxweb2] url-item urlitem
[Device-sslvpn-context-ctxweb2-url-item-urlitem] url http://30.3.3.3
[Device-sslvpn-context-ctxweb2-url-item-urlitem] quit
# Create a URL list named urllist in SSL VPN context ctxweb2.
[Device-sslvpn-context-ctxweb2] url-list urllist
[Device-sslvpn-context-ctxweb2-url-list-urllist] heading web
# Create an SSL VPN policy group named resourcegrp2 for SSL VPN context ctxweb2, and then add URL list urllist to the policy group for Web access.
[Device-sslvpn-context-ctxweb2] policy-group resourcegrp2
[Device-sslvpn-context-ctxweb2-policy-group-resourcegrp2] resources url-list urllist
[Device-sslvpn-context-ctxweb2-policy-group-resourcegrp2] quit
# Enable SSL VPN context ctxweb2.
[Device-sslvpn-context-ctxweb2] service enable
[Device-sslvpn-context-ctxweb2] quit
5.     Configure SSL VPN users:
# Create a local user account for user 1. Set the username to sslvpnuser1, password to 123456TESTplat&!, service type to sslvpn, and user role to network-operator. Authorize the user to use policy group resourcegrp1.
[Device] local-user sslvpnuser1 class network
[Device-luser-network-sslvpnuser1] password simple 123456TESTplat&!
[Device-luser-network-sslvpnuser1] service-type sslvpn
[Device-luser-network-sslvpnuser1] authorization-attribute user-role network-operator
[Device-luser-network-sslvpnuser1] authorization-attribute sslvpn-policy-group resourcegrp1
[Device-luser-network-sslvpnuser1] quit
# Create a local user account for user 2. Set the username to sslvpnuser2, password to 123456TESTplat&!, service type to sslvpn, and user role to network-operator. Authorize the user to use policy group resourcegrp2.
[Device] local-user sslvpnuser2 class network
[Device-luser-network-sslvpnuser2] password simple 123456TESTplat&!
[Device-luser-network-sslvpnuser2] service-type sslvpn
[Device-luser-network-sslvpnuser2] authorization-attribute user-role network-operator
[Device-luser-network-sslvpnuser2] authorization-attribute sslvpn-policy-group resourcegrp2
[Device-luser-network-sslvpnuser2] quit
# Verify that SSL VPN gateway gw is up on the device.
[Device] display sslvpn gateway
Gateway name: gw
  Operation state: Up
  IP: 1.1.1.2  Port: 4430
  Front VPN instance: Not configured
# Verify that SSL VPN contexts ctxweb1 and ctxweb2 are up on the device.
[Device] display sslvpn context
Context name: ctxweb1
  Operation state: Up
  AAA domain: Not specified
  Certificate authentication: Disabled
  Password authentication: Enabled
  Authentication use: All
  Certificate username-attribute: CN
  Dynamic password: Disabled
  Code verification: Disabled
  Default policy group: Not configured
  Associated SSL VPN gateway: gw
    Domain name: domainweb1
  Maximum users allowed: 1048575
  Idle timeout: 30 min
Context name: ctxweb2
  Operation state: Up
    Domain name: domainweb2
# On the PC of user 1, enter https://1.1.1.2:4430/ in the browser address bar to open the domain list page.
Because the SSL VPN gateway uses a self-signed SSL server certificate, the browser displays a certificate not trusted error when you attempt to access the gateway. Choose to continue to access the gateway.
Figure 12 Domain list page
# Select domainweb1 to access the login page.
# On the login page, enter username sslvpnuser1 and password 123456, and then click Login.
Figure 13 Login page
# The SSL VPN home page opens, displaying the Web resources the user can access in the BookMark area. In this example, serverA is displayed, as shown in Figure 14. Click the serverA link to access Web resources on Server A.
Figure 14 SSL VPN gateway home page
# On the PC of user 2, enter https://1.1.1.2:4430/ in the browser address bar to open the domain list page.
Figure 15 Domain list page
# Select domainweb2 to access the login page.
# On the login page, enter username sslvpnuser2 and password 123456, and then click Login.
Figure 16 Login page
# The SSL VPN home page opens, displaying the Web resources the user can access in the BookMark area. In this example, serverB is displayed, as shown in Figure 17. Click the serverB link to access Web resources on Server B.
Figure 17 SSL VPN gateway home page
# Display SSL VPN session information on the device.
[Device] display sslvpn session
Total users: 2
SSL VPN context: ctxweb1
Users: 1
Username        Connections  Idle time   Created       User IP
sslvpnuser1     6            0/00:00:23  0/00:00:23    40.1.1.1
SSL VPN context: ctxweb2
Users: 1
sslvpnuser2     6            0/00:00:03  0/00:00:03    50.1.1.1
Example: Configuring Web access with CA-signed certificate
As shown in Figure 18, the device acts as the SSL VPN gateway that connects the public network and private networks VPN 1 and VPN 2. Server A and Server B are internal Web servers. Server A uses HTTP over port 80. Server B uses HTTPS over port 443.
The device uses a CA-signed SSL server certificate.
Configure SSL VPN Web access on the device to allow the user to access Server A in VPN 1 and Server B in VPN 2.
Configure the device to perform local authentication and authorization for the user.
Figure 18 Network diagram
2.     Create VPN instances and bind the interfaces to the VPN instances. (Details not shown.)
3.     Obtain CA certificate file ca.cer and local certificate file server.pfx for the device. (Details not shown.)
4.     Make sure the device and the user, the device and Server A, and the device and Server B can reach each other. (Details not shown.)
5.     Configure a PKI domain:
# Configure PKI domain sslvpn.
[Device] pki domain sslvpn
[Device-pki-domain-sslvpn] public-key rsa general name sslvpn
[Device-pki-domain-sslvpn] undo crl check enable
[Device-pki-domain-sslvpn] quit
# Import CA certificate file ca.cer and local certificate file server.pfx to PKI domain sslvpn.
[Device] pki import domain sslvpn der ca filename ca.cer
[Device] pki import domain sslvpn p12 local filename server.pfx
6.     Create an SSL server policy named ssl and specify PKI domain sslvpn for the policy.
[Device] ssl server-policy ssl
[Device-ssl-server-policy-ssl] pki-domain sslvpn
[Device-ssl-server-policy-ssl] quit
7.     Configure the SSL VPN gateway:
# Configure the IP address for SSL VPN gateway gw as 1.1.1.2 and port number as 2000, and then apply server policy ssl to the gateway.
[Device-sslvpn-gateway-gw] ip address 1.1.1.2 port 2000
[Device-sslvpn-gateway-gw] ssl server-policy ssl
# Enable SSL VPN gateway gw.
8.     Configure SSL VPN contexts:
# Create SSL VPN context ctx1, specify gateway gw and domain domain1 for the context, and then associate the context with VPN instance VPN1.
[Device] sslvpn context ctx1
[Device-sslvpn-context-ctx1] gateway gw domain domain1
[Device-sslvpn-context-ctx1] vpn-instance VPN1
[Device-sslvpn-context-ctx1] url-item urlitem
[Device-sslvpn-context-ctx1-url-item-urlitem] url http://20.2.2.2
[Device-sslvpn-context-ctx1-url-item-urlitem] quit
# Create a URL list named urllist in SSL VPN context ctx1.
[Device-sslvpn-context-ctx1] url-list urllist
[Device-sslvpn-context-ctx1-url-list-urllist] heading web
[Device-sslvpn-context-ctx1-url-list-urllist] resources url-item urlitem
[Device-sslvpn-context-ctx1-url-list-urllist] quit
# Create an SSL VPN policy group named pgroup for SSL VPN context ctx1, and then specify URL list urllist for Web access.
[Device-sslvpn-context-ctx1] policy-group pgroup
[Device-sslvpn-context-ctx1-policy-group-pgroup] resources url-list urllist
[Device-sslvpn-context-ctx1-policy-group-pgroup] quit
# Specify SSL VPN policy group pgroup as the default policy group.
[Device-sslvpn-context-ctx1] default-policy-group pgroup
# Enable SSL VPN context ctx1.
[Device-sslvpn-context-ctx1] service enable
[Device-sslvpn-context-ctx1] quit
# Create SSL VPN context ctx2, specify gateway gw and domain domain2 for the context, and then associate the context with VPN instance VPN2.
[Device] sslvpn context ctx2
[Device-sslvpn-context-ctx2] gateway gw domain domain2
[Device-sslvpn-context-ctx2] vpn-instance VPN2
[Device-sslvpn-context-ctx2] url-item urlitem
[Device-sslvpn-context-ctx2-url-item-urlitem] url http://30.3.3.3
[Device-sslvpn-context-ctx2-url-item-urlitem] quit
# Create a URL list named urllist in SSL VPN context ctx2.
[Device-sslvpn-context-ctx2] url-list urllist
[Device-sslvpn-context-ctx2-url-list-urllist] heading web
[Device-sslvpn-context-ctx2-url-list-urllist] resources url-item urlitem
[Device-sslvpn-context-ctx2-url-list-urllist] quit
# Create an SSL VPN policy group named pgroup for SSL VPN context ctx2, and then specify URL list urllist for Web access.
[Device-sslvpn-context-ctx2] policy-group pgroup
[Device-sslvpn-context-ctx2-policy-group-pgroup] resources url-list urllist
[Device-sslvpn-context-ctx2-policy-group-pgroup] quit
[Device-sslvpn-context-ctx2] default-policy-group pgroup
# Enable SSL VPN context ctx2.
[Device-sslvpn-context-ctx2] service enable
[Device-sslvpn-context-ctx2] quit
9.     Create a local user named sslvpn, set the password to 123456TESTplat&!, service type to sslvpn, and user role to network-operator. Authorize the user to use policy group pgroup.
[Device] local-user sslvpn class network
[Device-luser-network-sslvpn] password simple 123456TESTplat&!
[Device-luser-network-sslvpn] service-type sslvpn
[Device-luser-network-sslvpn] authorization-attribute user-role network-operator
[Device-luser-network-sslvpn] authorization-attribute sslvpn-policy-group pgroup
[Device-luser-network-sslvpn] quit
Gateway name: gw
  Operation state: Up
  IP: 1.1.1.2  Port: 2000
  SSL server policy configured: ssl
  SSL server policy in use: ssl
# Verify that SSL VPN contexts ctx1 and ctx2 are up on the device.
Context name: ctx1
  Operation state: Up
  Default policy group: pgroup
    Domain name: domain1
  SSL client policy configured: ssl
  SSL client policy in use: ssl
  VPN instance: VPN1
Context name: ctx2
  Operation state: Up
    Domain name: domain2
  VPN instance: VPN2
# On the user PC, enter https://1.1.1.2:2000/ in the browser address bar to open the domain list page.
Figure 19 Domain list page
# Select domain1 to enter the login page.
# On the login page, enter username sslvpn and password 123456, and then click Login.
Figure 20 Login page
# Display SSL VPN session information on the device after the user logged in.
[Device] display sslvpn session context ctx1
SSL VPN context: ctx1
Users: 1
sslvpn          6            0/00:12:05  0/00:04:14    40.1.1.1
# On the SSL VPN gateway home page, click the serverA link in the BookMark area to open the webpage of Server A. The URL https://1.1.1.2:2000/_proxy2/http/80/20.2.2.2/ is displayed in the browser address bar.
Figure 21 SSL VPN gateway home page
# Log out and restart the browser. Enter https://1.1.1.2:2000/ to enter the domain list page, and then select domain2 to enter the login page. On the login page, enter username sslvpn and password 123456, and then click Login. (Details not shown.)
[Device] display sslvpn session context ctx2
SSL VPN context: ctx2
Users: 1
sslvpn          6            0/00:02:05  0/00:01:11    40.1.1.1
# On the SSL VPN gateway home page, click the serverB link in the BookMark area to open the webpage of Server B. The URL https://1.1.1.2:2000/_proxy2/https/443/30.3.3.3/ is displayed in the browser address bar.
Figure 22 SSL VPN gateway home page
Example: Configuring TCP access with self-signed certificate
As shown in Figure 23, the device acts as an SSL VPN gateway that connects the public network and the private network.
Configure SSL VPN TCP access on the device to allow the user to access the internal Telnet server.
Configure the device to perform local authentication and local authorization for the user.
Figure 23 Network diagram
Before using the user's PC to access the SSL VPN gateway (the device), make sure the Java Runtime Environment is installed on the client host.
2.     Make sure the device and the user, and the device and the server can reach each other. (Details not shown.)
# Create SSL VPN context ctxtcp, and then specify gateway gw and domain domaintcp for the context.
[Device] sslvpn context ctxtcp
[Device-sslvpn-context-ctxtcp] gateway gw domain domaintcp
# Create a port forwarding item named pfitem.
[Device-sslvpn-context-ctxtcp] port-forward-item pfitem
# Create a port forwarding instance that maps internal server address 20.2.2.2 and port 23 to local address 127.0.0.23 and local port 2323.
[Device-sslvpn-context-ctxtcp-port-forward-item-pfitem] local-port 2323 local-name 127.0.0.23 remote-server 20.2.2.2 remote-port 23
[Device-sslvpn-context-ctx-port-forward-item-pfitem1] quit
# Create a port forwarding list named pflist, and then assign port forwarding item pfitem to the port forwarding list.
[Device-sslvpn-context-ctxtcp] port-forward pflist
[Device-sslvpn-context-ctxtcp-port-forward-pflist] resources port-forward-item pfitem
[Device-sslvpn-context-ctxtcp-port-forward-pflist] quit
# Create an SSL VPN policy group named resourcegrp and assign port forwarding list pflist to the group.
[Device-sslvpn-context-ctxtcp] policy-group resourcegrp
[Device-sslvpn-context-ctxtcp-policy-group-resourcegrp] resources port-forward pflist
[Device-sslvpn-context-ctxtcp-policy-group-resourcegrp] quit
# Enable SSL VPN context ctxtcp.
[Device-sslvpn-context-ctxtcp] service enable
[Device-sslvpn-context-ctxtcp] quit
5.     Create a local user named sslvpnuser, set the password to 123456TESTplat&!, service type to sslvpn, and user role to network-operator. Authorize the user to use policy group resourcegrp.
[Device] local-user sslvpnuser class network
[Device-luser-network-sslvpnuser] password simple 123456TESTplat&!
[Device-luser-network-sslvpnuser] service-type sslvpn
[Device-luser-network-sslvpnuser] authorization-attribute sslvpn-policy-group resourcegrp
[Device-luser-network-sslvpnuser] authorization-attribute user-role network-operator
[Device-luser-network-sslvpnuser] quit
Gateway name: gw
  Operation state: Up
# Verify that SSL VPN context ctx is up on the device.
Context name: ctxtcp
  Operation state: Up
    Domain name: domaintcp
# On the user PC, enter https://1.1.1.2:4430/ in the browser address bar to open the domain list page.
Figure 24 Domain list page
# Select domaintcp to access the login page.
# On the login page, enter username sslvpnuser and password 123456, and then click Login.
Figure 25 Login page
# On the SSL VPN home page that opens, click Start to download the TCP client application and start the application.
You cannot start the TCP client application by double-clicking it.
# Telnet to the local address (127.0.0.1) and local port (2323) on the PC. The user can remotely access the server. (Details not shown.)
Total users: 1
SSL VPN context: ctxtcp
Users: 1
sslvpnuser      5            0/00:00:51  0/00:17:26    40.1.1.1
# Display SSL VPN port forwarding connection information on the device.
[Device] display sslvpn port-forward connection
 Client address: 40.1.1.1
 Client port   : 50335
 Server address: 20.2.2.2
 Server port   : 23
 State         : Connected
Example: Configuring TCP access with CA-signed certificate
As shown in Figure 26, the device acts as an SSL VPN gateway that connects the public network and private network VPN 1.
Configure SSL VPN TCP access on the device to allow the user to access the internal Telnet server in VPN 1.
Figure 26 Network diagram
2.     Create a VPN instance and bind GigabitEthernet 1/0/2 to the VPN instance. (Details not shown.)
4.     Make sure the device and the user, and the device and the server can reach each other. (Details not shown.)
# Create SSL VPN context ctx, specify gateway gw for the context, and then associate the context with VPN instance VPN1.
[Device-sslvpn-context-ctx] gateway gw
[Device-sslvpn-context-ctx] vpn-instance VPN1
# Create a port forwarding item named pfitem1.
[Device-sslvpn-context-ctx] port-forward-item pfitem1
# Create a port forwarding instance that maps internal server address 20.2.2.2 and port 23 to local address 127.0.0.1 and local port 2323.
[Device-sslvpn-context-ctx-port-forward-item-pfitem1] local-port 2323 local-name 127.0.0.1 remote-server 20.2.2.2 remote-port 23 description telnet
# Create a port forwarding list named plist, and then assign port forwarding item pfitem1 to the port forwarding list.
[Device-sslvpn-context-ctx] port-forward plist
[Device-sslvpn-context-ctx-port-forward-plist] resources port-forward-item pfitem1
[Device-sslvpn-context-ctx-port-forward-plist] quit
# Create an SSL VPN policy group named pgroup and assign port forwarding list plist to the group.
[Device-sslvpn-context-ctx] policy-group pgroup
[Device-sslvpn-context-ctx-policy-group-pgroup] resources port-forward plist
[Device-sslvpn-context-ctx-policy-group-pgroup] quit
# Enable SSL VPN context ctx.
[Device-sslvpn-context-ctx] service enable
[Device-sslvpn-context-ctx] quit
Gateway name: gw
  Operation state: Up
Context name: ctx
  Operation state: Up
  VPN instance: VPN1
# On the user PC, enter https://1.1.1.2:2000/ in the browser address bar to enter login page.
Figure 27 Login page
Users: 1
SSL VPN context  : ctx
  Client address : 40.1.1.1
  Client port    : 50788
  Server address : 20.2.2.2
  Server port    : 23
  State          : Connected
Example: Configuring IP access with self-signed certificate
As shown in Figure 28, the device acts as an SSL VPN gateway that connects the public network and the private network.
Configure SSL VPN IP access on the device to allow the user to access the internal server in the private network.
Figure 28 Network diagram
Before configuring IP access, make sure the server has a route to 10.1.1.0/24.
4.     Create an IP access address pool named sslvpnpool and specify the address range as 10.1.1.1 to 10.1.1.10.
[Device] sslvpn ip address-pool sslvpnpool 10.1.1.1 10.1.1.10
5.     Create SSL VPN AC interface AC 1 and configure the IP address as 10.1.1.100/24 for the interface.
[Device] interface sslvpn-ac 1
[Device-SSLVPN-AC1] ip address 10.1.1.100 24
[Device-SSLVPN-AC1] quit
6.     Configure an SSL VPN context:
# Create SSL VPN context ctxip, and then specify gateway gw and domain domainip for the context.
[Device] sslvpn context ctxip
[Device-sslvpn-context-ctxip] gateway gw domain domainip
# Specify interface SSL VPN AC 1 for IP access.
[Device-sslvpn-context-ctxip] ip-tunnel interface sslvpn-ac 1
# Create a route list named rtlist and add route 20.2.2.0/24 to the list.
[Device-sslvpn-context-ctxip] ip-route-list rtlist
[Device-sslvpn-context-ctxip-route-list-rtlist] include 20.2.2.0 24
[Device-sslvpn-context-ctxip-route-list-rtlist] quit
# Specify address pool sslvpnpool for IP access.
[Device-sslvpn-context-ctxip] ip-tunnel address-pool sslvpnpool mask 24
# Create an SSL VPN policy group named resourcegrp, specify route list rtlist for IP access, and then specify ACL 3000 for IP access filtering.
[Device-sslvpn-context-ctxip] policy-group resourcegrp
[Device-sslvpn-context-ctxip-policy-group-resourcegrp] ip-tunnel access-route ip-route-list rtlist
[Device-sslvpn-context-ctxip-policy-group-resourcegrp] filter ip-tunnel acl 3000
[Device-sslvpn-context-ctxip-policy-group-resourcegrp] quit
[Device-sslvpn-context-ctxip] service enable
[Device-sslvpn-context-ctxip] quit
# Create ACL 3000. Add a rule to permit packets sourced from subnet 10.1.1.0/24 and destined for 20.2.2.0/24.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule permit ip source 10.1.1.0 0.0.0.255 destination 20.2.2.0 0.0.0.255
7.     Create a local user named sslvpnuser, set the password to 123456TESTplat&!, service type to sslvpn, and user role to network-operator. Authorize the user to use policy group resourcegrp.
Gateway name: gw
  Operation state: Up
# Verify that SSL VPN context ctxip is up on the device.
Context name: ctxip
  Operation state: Up
    Domain name: domainip
Figure 29 Domain list page
# Select domainip to access the login page.
Figure 30 Login page
# On the SSL VPN home page that opens, click Start to download the IP client application and install the application.
After the IP client application is installed, start the iNode client, as shown in Figure 31.
Figure 31 Starting the iNode client
# Click Connect to log in to the SSL VPN client, as shown in Figure 32.
Figure 32 Logging in to the SSL VPN client
# Verify that the user can ping the server.
C:\>ping 20.2.2.2
Pinging 20.2.2.2 with 32 bytes of data:
Reply from 20.2.2.2: bytes=32 time=31ms TTL=254
Reply from 20.2.2.2: bytes=32 time=18ms TTL=254
Reply from 20.2.2.2: bytes=32 time=15ms TTL=254
Reply from 20.2.2.2: bytes=32 time=16ms TTL=254
Ping statistics for 20.2.2.2:
    Minimum = 15ms, Maximum = 31ms, Average = 20ms
[Device] display sslvpn session user sslvpnuser
User              : sslvpnuser
Context           : ctxip
Policy group      : resourcegrp
Idle timeout      : 30 min
Created at        : 16:38:48 UTC Wed 07/26/2017
Lastest           : 16:47:41 UTC Wed 07/26/2017
User IPv4 address : 172.16.1.16
Allocated IP      : 10.1.1.1
Session ID        : 14
Web browser/OS    : Windows
Example: Configuring IP access with CA-signed certificate
As shown in Figure 33, the device acts as an SSL VPN gateway that connects the public network and private network VPN 1.
Configure SSL VPN IP access on the device to allow the user to access the internal server in VPN 1.
Configure the device to perform remote authentication and authorization (through the remote RADIUS server) for the user.
Figure 33 Network diagram
Before configuring IP access, perform the following tasks:
·     Make sure the server has a route to 10.1.1.0/24.
·     Configure the RADIUS server to provide authentication and authorization for the user.
8.     Create an IP access address pool named ippool and specify the address range as 10.1.1.1 to 10.1.1.10.
[Device] sslvpn ip address-pool ippool 10.1.1.1 10.1.1.10
9.     Create SSL VPN AC interface AC 1, bind the interface to VPN instance VPN1, and configure the IP address as 10.1.1.100/24 for the interface.
[Device-SSLVPN-AC1] ip binding vpn-instance VPN1
10.     Configure an SSL VPN context:
# Specify ISP domain domain1 for AAA of SSL VPN users in SSL VPN context ctx.
[Device-sslvpn-context-ctx] aaa domain domain1
[Device-sslvpn-context-ctx] ip-route-list rtlist
[Device-sslvpn-context-ctx-route-list-rtlist] include 20.2.2.0 255.255.255.0
[Device-sslvpn-context-ctx-route-list-rtlist] quit
# Create a URI ACL named uriacl and add a rule that permits access to icmp://20.2.2.0 to the ACL.
[Device-sslvpn-context-ctx] uri-acl uriacl
[Device-sslvpn-context-ctx-uri-acl-uriacl] rule 1 permit uri icmp://20.2.2.0
[Device-sslvpn-context-ctx-uri-acl-uriacl] quit
[Device-sslvpn-context-ctx] ip-tunnel interface sslvpn-ac 1
# Specify address pool ippool for IP access.
[Device-sslvpn-context-ctx] ip-tunnel address-pool ippool mask 255.255.255.0
# Create an SSL VPN policy group named pgroup, specify route list rtlist for IP access, and then specify URI ACL uriacl for IP access filtering.
[Device-sslvpn-context-ctx-policy-group-pgroup] ip-tunnel access-route ip-route-list rtlist
[Device-sslvpn-context-ctx-policy-group-pgroup] filter ip-tunnel uri-acl uriacl
11.     Configure RADIUS settings:
# Create a RADIUS scheme named rscheme. Specify the primary authentication server and primary accounting server as 3.3.3.2. Set the keys for communication with the servers to 123456.
[Device] radius scheme rscheme
[Device-radius-rscheme] primary authentication 3.3.3.2
[Device-radius-rscheme] primary accounting 3.3.3.2
[Device-radius-rscheme] accounting-on enable
[Device-radius-rscheme] key authentication simple 123456
[Device-radius-rscheme] key accounting simple 123456
# Exclude the domain name from the username sent to the RADIUS server.
[Device-radius-rscheme] user-name-format without-domain
[Device-radius-rscheme] quit
12.     Create a user group named group1 and authorize the user group to use SSL VPN policy group pgroup.
[Device] user-group group1
[Device-ugroup-group1] authorization-attribute sslvpn-policy-group pgroup
[Device-ugroup-group1] quit
13.     Create an ISP domain named domain1 and authorize the domain to use user group group1.
[Device] domain domain1
[Device-isp-domain1] authorization-attribute user-group group1
# Configure the ISP domain to use RADIUS scheme rscheme for AAA of users.
[Device-isp-domain1] authentication sslvpn radius-scheme rscheme
[Device-isp-domain1] authorization sslvpn radius-scheme rscheme
[Device-isp-domain1] accounting sslvpn radius-scheme rscheme
[Device-isp-domain1] quit
Gateway name: gw
  Operation state: Up
Context name: ctx
  Operation state: Up
  AAA domain: domain1
  VPN instance: VPN1
# On the user PC, launch the IP access client software, and then enter the address 1.1.1.2, port number 2000, username sslvpn, and password 123456 to log in to the SSL VPN gateway. (Details not shown.)
Users: 1
sslvpn          6            0/00:02:05  0/00:03:14    40.1.1.1
# On the user PC, display IPv4 routing table to verify that the user has a route to the server.
The address 40.1.1.1/24 is the address of the local NIC, and 10.1.1.1/24 is the address that the SSL VPN gateway allocates to the user.
>route -4 print
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
         10.1.1.0    255.255.255.0         On-link      10.1.1.1        276
         10.1.1.1  255.255.255.255         On-link      10.1.1.1        276
       10.1.1.255  255.255.255.255         On-link      10.1.1.1        276
         20.2.2.0    255.255.255.0         On-link      10.1.1.1        276
       20.2.2.255  255.255.255.255         On-link      10.1.1.1        276
         40.1.1.0    255.255.255.0         On-link      40.1.1.1        276
         40.1.1.1  255.255.255.255         On-link      40.1.1.1        276
       40.1.1.255  255.255.255.255         On-link      40.1.1.1        276
C:\>ping 20.2.2.2
Reply from 20.2.2.2: bytes=32 time=197ms TTL=254
Reply from 20.2.2.2: bytes=32 time=1ms TTL=254
Reply from 20.2.2.2: bytes=32 time=186ms TTL=254
    Minimum = 1ms, Maximum = 197ms, Average = 96ms
  • Become a Partner
  • Partner Resources
