03-Policies
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40203-Policies
24-Load balancing common configuration
24-Load balancing common configuration 128.83 KB
This help contains the following topics:
·     Configure common settings
¡     Configure a link
¡     Configure a sticky group
¡     Configure an SNAT address pool
¡     Configure proximity
¡     Configure ALG
¡     Configure ISP information
¡     Configure a region
¡     Traffic distribution methods
¡     Advanced configuration
Configure a link
A link is a physical link provided by an ISP. A link can belong to only one link group. A link group can have multiple links.
1.     Select Policies > Load Balancing > Common Configuration > Links.
2.     Click Create on the Link page.
3.     Create a link.
Table 1 Link configuration items
Item
Link name
Enter a link name, case insensitive.
Next hop config method
Select a next hop configuration method:
·     Manual
·     Automatic
Next hop IPv4 address
Specify an outbound next hop IPv4 address.
The IPv4 address cannot be an IPv4 address of any interface on the device, loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
Next hop IPv6 address
Specify an outbound next hop IPv6 address.
The IPv6 address cannot be an IPv6 address of any interface on the device, loopback address, multicast address, link-local address, or all-zero address.
Outgoing interface
Specify an outgoing interface for the link. The outgoing interface must be an interface whose IP address can be dynamically obtained.
Link cost for proximity calculation
Specify the link cost for proximity calculation.
Link feature
Enable or disable the link feature.
VRF
Specify the VPN instance to which the link belongs.
VRF inheritance
Enable or disable VRF inheritance. When VRF inheritance is enabled, a link without a VPN instance specified inherits the VPN instance of the virtual server. When VRF inheritance is disabled, a link without a VPN instance specified belongs to the public network.
Enter a description for the link.
Table 2 Advanced link configuration items
Item
Weight
Specify the link weight. For the weighted round robin and weighted least connections algorithms, a greater value means a higher priority to be referenced.
Priority
Specify the priority of the link in a link group.
If the number of links with the highest priority is less than the minimum number, links with lower priority are selected to meet the minimum number or until no links are available.
You can configure the maximum number and minimum number from Policies > Load Balancing > Link Load Balancing > Outbound Link Load Balancing > Link Group.
Link group
Select an existing link group or create a link group.
A created link group can be viewed from the Policies > Load Balancing > Link Load Balancing > Outbound Link Load Balancing > Link Group page.
Probe method
Specify a probe template used to detect the health and availability of the link. You can also configure this parameter for a link group from Policies > Load Balancing > Outbound Link Load Balancing > Link Group. The probe template configured for a link has higher priority over that configured for a link group.
You can select an existing probe template or create a probe template. A created probe template can be viewed from the Objects > Health Monitoring page.
Success criteria
Specify the health monitoring success criteria for the link.
·     All probes succeedHealth monitoring succeeds only when all the specified health monitoring methods succeed.
·     At least n probes succeedHealth monitoring succeeds when a minimum of the specified number of health monitoring methods succeed. When the specified number of health monitoring methods is greater than the number of health monitoring methods on the device, health monitoring succeeds if all health monitoring methods succeed.
Total bandwidth-Bandwidth ratio
Specify the bandwidth ratio. The bandwidth ratio is the percentage of the current bandwidth to the total maximum bandwidth. When the traffic exceeds the maximum expected bandwidth multiplied by the bandwidth ratio of a link, new traffic (traffic that does not match any sticky entries) is not distributed to the link.
If you do not set this parameter, the maximum value that can be set applies.
Total bandwidth-Bandwidth recovery ratio
Specify the bandwidth recovery ratio. When the traffic drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio of the link, the link participates in scheduling again.
The bandwidth recovery ratio of a link must be smaller than or equal to the bandwidth ratio of the link.
Inbound bandwidth-Bandwidth ratio
Specify the inbound bandwidth ratio. The inbound bandwidth ratio is the percentage of the current inbound bandwidth to the maximum inbound bandwidth. When the traffic exceeds the maximum expected bandwidth multiplied by the bandwidth ratio of a link, new traffic (traffic that does not match any sticky entries) is not distributed to the link.
Inbound bandwidth-Bandwidth recovery ratio
Specify the inbound bandwidth recovery ratio. When the traffic drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio of the link, the link participates in scheduling again.
Outbound bandwidth-Bandwidth ratio
Specify the outbound bandwidth ratio. The inbound bandwidth ratio is the percentage of the current inbound bandwidth to the maximum inbound bandwidth. When the traffic exceeds the maximum expected bandwidth multiplied by the bandwidth ratio of a link, new traffic (traffic that does not match any sticky entries) is not distributed to the link.
Outbound bandwidth-Bandwidth recovery ratio
Specify the outbound bandwidth recovery ratio. When the traffic drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio of the link, the link participates in scheduling again.
Maximum bandwidth-Expected bandwidth
Specify the total maximum expected bandwidth. The value 0 means that the total maximum expected bandwidth is not limited. In addition to being used for link protection, the total maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm, maximum bandwidth algorithm, and dynamic proximity algorithm.
Maximum bandwidth-Expected inbound bandwidth
Specify the inbound maximum expected bandwidth. The value 0 means that the inbound maximum expected bandwidth is not limited. In addition to being used for link protection, the inbound maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm, maximum bandwidth algorithm, and dynamic proximity algorithm.
Maximum bandwidth-Expected outbound bandwidth
Specify the outbound maximum expected bandwidth. The value 0 means that the outbound maximum expected bandwidth is not limited. In addition to being used for link protection, the outbound maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm, maximum bandwidth algorithm, and dynamic proximity algorithm.
QoS-Connections
Specify the maximum number of connections allowed on the link. The value 0 means that the number of connections allowed on a link is not limited.
QoS-Connections per second
Specify the maximum number of connections per second allowed on the link. The value 0 means that the number of connections per second allowed on a link is not limited.
QoS-Bandwidth
Specify the total maximum bandwidth allowed on the link. The value 0 means that the total bandwidth allowed on a link is not limited.
QoS-Inbound bandwidth
Specify the inbound maximum bandwidth allowed on the link. The value 0 means that the inbound bandwidth allowed on a link is not limited.
QoS-Outbound bandwidth
Specify the outbound maximum bandwidth allowed on the link. The value 0 means that the outbound bandwidth allowed on a link is not limited.
4.     Click OK. The new link appears on the Link page.
A sticky group uses a sticky method to distribute similar sessions to the same real server or link according to sticky entries. The sticky method applies to the first packet of a session. Other packets of the session are distributed to the same real server or link.
1.     Select Policies > Load Balancing > Common Configuration > Sticky Groups.
2.     Click Create on the Sticky Group page.
3.     Create a sticky group.
Table 3 Sticky group configuration items
Item
Stick group name
Enter a name for the sticky group, case insensitive.
Select a group type:
·     Address and port
·     Payload
·     HTTP-Content
·     HTTP-Cookie
·     HTTP-Header
·     SSL
·     RADIUS
·     SIP
·     HTTP-Passive
·     UDP-Passive
·     TCP-Payload
Aging time
Specify the timeout time for sticky entries. For sticky groups of the HTTP cookie type, the following rules apply:
·     If the sticky method is cookie insert or cookie rewrite, a timeout timer of 0 indicates session persistency.
·     If the sticky method is cookie get, a timeout timer of 0 indicates the timeout time for the sticky entries is 0 seconds.
Override limits
Enable or disable the function of ignoring the limits for sessions that match sticky entries. After this function is enabled, the device ignores the following limits for sessions that match sticky entries:
·     Bandwidth and connection parameters on real servers or links.
·     LB connection limit policies on virtual servers.
Stickiness-over-busyness
Enable or disable the stickiness-over-busyness function. This function enables the device to assign client requests to real servers based on sticky entries, regardless of whether the real servers are busy. When this function is disabled, the device assigns client requests to only real servers in normal state.
Enter a description for the sticky group.
Table 4 Address and port sticky method configuration items
Item
IPv4
Select an IPv4 address/port sticky method:
·     Source address
·     Source address/port
·     Destination address
·     Destination address/port
·     Source address/Destination address
·     Source/Destination address/port
IPv6
Select an IPv6 address/port sticky method:
·     Source address
Table 5 Payload sticky method configuration items
Item
Offset
Specify the offset value of the HTTP payload based on the start of the HTTP packet.
Start string
Specify the regular expression that marks the start of the HTTP payload. The string cannot contain question marks (?).
Length/End string
Specify the length and end string of the HTTP payload.
·     Length—Specify the length of the HTTP payload. The value 0 indicates any length.
·     End string—Specify the regular expression that marks the end of the HTTP payload. The string cannot contain question marks (?).
Table 6 HTTP entity sticky method configuration items
Item
Offset
Specify the offset value of the entity based on the start of the HTTP packet.
Start string
Specify the regular expression that marks the start of the entity. The string cannot contain question marks (?).
Length/End string
Specify the length and end string of the HTTP entity.
·     Length—Specify the length of the HTTP entity. The value 0 indicates any length.
·     End string—Specify the regular expression that marks the end of the HTTP entity. The string cannot contain question marks (?).
Table 7 HTTP cookie sticky method configuration items
Item
Cookie stickiness
Select a cookie sticky method:
·     Cookie insertInserts the Set-Cookie field to the HTTP response packets sent by the server.
·     Cookie rewriteRewrites the Set-Cookie field in the HTTP response packets sent by the server.
·     Cookie getGets the Set-Cookie field in the HTTP response packets sent by the server.
Cookie name
Specify an HTTP cookie by its name, case sensitive.
Cookie domain name
Specifies a domain name indicating the hosts to which the cookie will be sent. If you do not specify this option, the cookie will be sent to only the host where it is created.
Suppose a client can visit hosts example.com, www.example.com, and www.corp.example.com. If you specify example.com, the client includes the cookie when sending HTTP requests to any of the three hosts. If you specify www.corp.example.com, the client includes the cookie only when sending HTTP requests to www.corp.example.com.
This parameter is supported only by the cookie insert sticky method.
Cookie path
Specifies a path to which the cookie will be sent. If you do not specify a path, the cookie will be sent to every path (the root directory / applies) of the specified domain name.
This parameter limits the scope of the cookie to the specified path. Suppose a client can visit folders www.example.com/a and www.example.com/b. If you specify domain name www.example.com and path /a, the client includes the cookie only when sending HTTP requests to www.example.com/a.
HTTPOnly
Enable this option to prevent the cookie from being accessed by scripts. If you disable this option, the cookie can be accessed by scripts.
The option prevents attackers from obtaining cookie information by using scripts.
This option is supported only by the cookie insert and cookie rewrite sticky methods.
Secure
Enable this option to transmit the cookie over only HTTPS connections. If you disable this option, the cookie can be transmitted over any connections.
Check all packets
Enable or disable checking for all packets.
·     If the sticky method is cookie get, use this parameter to get cookies from all HTTP response packets. If this parameter is not configured, the device gets only the Set-Cookie from the first response packet of a connection.
·     If the sticky method is cookie rewrite, use this parameter to rewrite cookies in all HTTP response packets. If this parameter is not configured, the device rewrites only the Set-Cookie in the first response packet of a connection.
·     If the sticky method is cookie insert, use this parameter to insert cookies to all HTTP response packets. If this parameter is not configured, the device inserts only the Set-Cookie to the first response packet of a connection.
Secondary cookie
Specify the name of the secondary cookie, a case-sensitive. The name cannot contain brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), or horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127. Only the cookie get sticky method supports this parameter.
The device locates the secondary cookie in the URI when it fails to locate the specified cookie in the HTTP request packet header.
Offset
Specify the offset value of the cookie based on the start of the HTTP packet. Only the cookie get sticky method supports this parameter.
Start string
Specify the regular expression that marks the start of the cookie. The string cannot contain question marks (?). Only the cookie get sticky method supports this parameter.
Length/End string
Specify the length and end string of the cookie.
·     Length—Specify the length of the cookie. The value 0 indicates any length.
·     End string—Specify the regular expression that marks the end of the HTTP cookie. The string cannot contain question marks (?).
Table 8 HTTP header sticky method configuration items
Item
Header stickiness
Select a header sticky method:
·     URL—HTTP URL based sticky method.
·     HostHTTP host based sticky method.
·     Method—HTTP Request-Method based sticky method.
·     Version—HTTP version based sticky method.
·     Name—HTTP header name based sticky method.
Header name
Specify the HTTP header name. This parameter appears only if you have selected the HTTP header name based sticky method.
Offset
Specify the offset value of the HTTP header based on the start of the HTTP packet.
Start string
Specify the regular expression that marks the start of the HTTP header. The string cannot contain question marks (?).
Length/End string
Specify the length and end string of the HTTP header.
·     Length—Specify the length of the HTTP header. The value 0 indicates any length.
·     End string—Specify the regular expression that marks the end of the HTTP header. The string cannot contain question marks (?).
Table 9 SSL sticky method configuration items
Item
SSL stickiness
Specify the SSL sticky method based on SSL session ID. This sticky method applies only to HTTPS request packets and requires specifying an SSL server policy for the virtual server.
Table 10 RADIUS sticky method configuration items
Item
RADIUS attribute
Specify the RADIUS attribute sticky method. This sticky method applies only to RADIUS packets. The value 1 indicates the User-Name attribute. The value 8 indicates the Framed-IP-Address attribute.
Table 11 SIP sticky method configuration items
Item
SIP stickiness
Specify the SIP sticky method based on the call ID in the header of SIP messages. All SIP messages with same call ID are assigned to the same real server.
Table 12 HTTP-passive sticky method configuration items
Item
Check all packets
This parameter determines whether or not to generate sticky entries from all HTTP response packets. If this parameter is not configured, the device generates sticky entries only from the first response packet of a connection.
Request configuration
Enable the device to obtain the specified string from HTTP requests for matching HTTP-passive sticky entries.
The HTTP-passive sticky method requires both the request and response configuration for generating sticky entries. When the device receives an HTTP request, it obtains the specified string based on the request configuration. If the string matches the HTTP response string obtained using the response configuration, the device generates a sticky entry based on the string in the response. For subsequent HTTP request packets matching the sticky entry, the device forwards them according to the sticky entry.
Follow these guidelines when you configure the request and response:
·     An HTTP-passive sticky group allows the device to obtain a maximum of four strings from HTTP response packets and a maximum of four strings from HTTP request packets.
·     Suppose the device obtains n strings from HTTP response packets. The strings can further generate 2n-1 strings by combining the method IDs in the response configuration. Any of the 2n-1 strings can be used to match the string obtained using the request configuration.
·     Suppose the device obtains n strings from HTTP request packets. Those strings will be combined as one string by following the configuration order of method IDs.
Use an example to illustrate how to generate a sticky entry based on HTTP request and response packets:
·     Configure method IDs 1, 2, and 3 in the response configuration. If the device obtains strings a, b, and c based on your configuration, the strings can further generate seven strings, namely, a, b, c, ab, ac, bc, and abc.
·     Configure method IDs 2, 3, and 4 in the request configuration.
·     After receiving HTTP requests, the device generates a sticky entry when the following conditions are met:
¡     The device obtains strings a, b, and c based on the request configuration.
¡     The combined string abc matches that obtained based on the response configuration.
·     For subsequent HTTP requests matching the sticky entry generated based on the string abc, the device forwards them according to the sticky entry.
To configure the request:
1.     Click Create to create an HTTP-passive sticky method.
¡     ID—Enter the method ID.
¡     Search position—Select the position to obtain the string from the HTTP request. Options are Header and Content.
¡     Header type—Specify the type of string to obtain from the HTTP request. Options are Name and URL. This parameter is available only when the Search position is set to Header.
¡     Header name—Enter the HTTP header name, which is case insensitive. This parameter is available only when the Header type is set to Name.
¡     Start stringSpecify the regular expression that marks the start of the HTTP header, URL, or HTTP entity.
¡     Length/End stringSpecify the length and end string of the HTTP header, URL, or HTTP entity.
2.     Click OK. The HTTP-passive sticky method appears in the request configuration list.
Response configuration
Enable the device to obtain the specified string from HTTP responses for generating HTTP-passive sticky entries.
To configure the response:
¡     Search position—Select the location to obtain the string from the HTTP response. Options are Header and Content.
¡     Header type—Specify the type of string to obtain from the HTTP response. This parameter is available only when the Search position is set to Header.
¡     Start stringSpecify the regular expression that marks the start of the HTTP header or HTTP entity.
¡     Length/End stringSpecify the length and end string of the HTTP header or HTTP entity. Length specifies the length of the HTTP header or HTTP entity. The value 0 indicates any length. End string specifies the regular expression that marks the end of the HTTP header or HTTP entity. The string cannot contain question marks (?).
2.     Click OK. The HTTP-passive sticky method appears in the response configuration list.
Table 13 UDP-passive sticky method configuration items
Item
Enable the device to obtain the specified string from UDP requests for matching UDP-passive sticky entries.
The UDP-passive sticky method requires both the request and response configuration for generating sticky entries.
When the device receives a UDP request, it obtains the specified payload based on the request configuration. If the payload matches the UDP response payload obtained using the response configuration, the device generates a sticky entry based on the payload in the response. For subsequent UDP request packets matching the sticky entry, the device forwards them according to the sticky entry.
Select UDP-Passive sticky method to configure the following parameters:
·     OffsetSpecify the offset value of the UDP payload based on the start of the UDP request packet.
·     Start stringSpecify the regular expression that marks the start of the UDP payload. The string cannot contain question marks (?).
·     Length/End stringSpecify the length and end string of the UDP payload. Length specifies the length of the UDP payload. The value 0 indicates any length. End string specifies the regular expression that marks the end of the UDP payload. The string cannot contain question marks (?).
Enable the device to obtain the specified string from UDP responses for generating UDP-passive sticky entries.
·     OffsetSpecify the offset value of the UDP payload based on the start of the UDP response packet.
Table 14 TCP-payload sticky method configuration items
Item
Offset
Specify the offset value of the TCP payload based on the start of the TCP packet.
Start string
Specify the regular expression that marks the start of the TCP payload. The string cannot contain question marks (?).
Length/End string
Specify the length and end string of the TCP payload.
·     Length—Specify the length of the TCP payload. The value 0 indicates any length.
·     End string—Specify the regular expression that marks the end of the TCP payload. The string cannot contain question marks (?).
4.     Click OK. The new sticky group appears on the Sticky Group page.
After a server farm or a link group references an SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
1.     Select Policies > Load Balancing > Common Configuration > SNAT Address Pools.
2.     Click Create on the SNAT Address Pool page.
3.     Create an SNAT address pool.
Table 15 SNAT address pool configuration items
Item
SNAT pool name
Enter a name for the SNAT address pool, case insensitive.
Address range list
To add an address range:
1.     Click Add.
¡     Start IP address—Enter the start IP address.
¡     End IP address—Enter the end IP address, which cannot be smaller than the start IP address.
2.     Click OK. The new address range appears in the address range list.
Interfaces for sending gratuitous ARP/ND packets
Specify the interfaces for sending gratuitous ARP packets and ND packets.
An address conflict might occur if the IP address of the interface to be connected to the server is in the same network segment as the SNAT address pool. To avoid address conflicts, specify an interface for sending gratuitous ARP/ND packets as the interface to connect to the server.
Enter a description for the SNAT address pool.
4.     Click OK. The new SNAT address pool appears on the SNAT Address Pool page.
Configure proximity
The proximity feature performs link detection to select the optimal link to a destination. If no proximity information for a destination is available, the load balancing module selects a link based on the scheduling algorithm. It then performs proximity detection to generate proximity entries for forwarding subsequent traffic.
To use the proximity feature, configure the proximity probe template and proximity parameters, and then enable the proximity feature in a link group.
1.     Select Policies > Load Balancing > Common Configuration > Proximity.
2.     Click Create on the Proximity Parameter page.
3.     Create a proximity parameter.
Table 16 Proximity parameter configuration items
Item
VRF
Specify the VPN instance to which proximity entries belong.
You can select an existing VPN instance or create a VPN instance. A created VPN instance can be viewed from Network > VRF.
Default probe method
Specify the default probe method.
You can select an existing probe method or create a probe method. A created probe method can be viewed from Policies > Load Balancing > Common Configuration > Proximity > Proximity Probe Method.
Mask length
Specify the mask length for IPv4 proximity entries. The value 0 indicates the natural mask.
Aging time
Set the timeout timer for proximity entries.
TTL weight
Set the TTL weight for proximity calculation. A larger value indicates a higher weight.
RTT weight
Set the network delay weight for proximity calculation. A larger value indicates a higher weight.
Cost weight
Set the cost weight for proximity calculation. A larger value indicates a higher cost weight.
Bandwidth weight
Set the bandwidth weights for proximity calculation.
·     Inbound—Set the inbound bandwidth weight for proximity calculation. A larger value indicates a higher bandwidth weight.
·     Outbound—Set the outbound bandwidth weight for proximity calculation. A larger value indicates a higher bandwidth weight.
Max entries
Set the maximum number of proximity entries. The value 0 indicates that the maximum number of proximity entries is not limited.
Packet loss ratio weight
Set the packet loss ratio weight for proximity calculation.
This parameter specifies the weight of packet loss ratio in calculating the composite link cost. It applies only when you enable the proximity feature or configure the link quality algorithm.
4.     Click OK. The new proximity parameter appears on the Proximity Parameter page.
5.     Click Create on the Proximity Probe Template page.
6.     Create a proximity probe template.
Table 17 Proximity probe template configuration items
Item
Probe template name
Enter a name for the probe template name, case insensitive.
Probe interval
Set the probe interval.
Timeout time
Set the timeout time for probe responses.
7.     Click OK. The new proximity probe template appears on the Proximity Probe Template page.
Configure ALG
The Application Level Gateway (ALG) feature distributes parent and child sessions to the same link. ALG supports the following protocols:
·     DNS
·     FTP
·     H323
·     ICMP error
·     ILS (Internet Locator Service)
·     MGCP (Media Gateway Control Protocol)
·     NBT (NetBIOS over TCP/IP)
·     SIP (Session Initiation Protocol)
·     PPTP (Point-to-Point Tunneling Protocol)
·     RSH (Remote Shell)
·     RTSP (Real Time Streaming Protocol)
·     SCCP (Skinny Client Control Protocol)
·     SQLNET
·     TFTP
·     XDMCP (X Display Manager Control Protocol)
Use the IP addresses assigned by ICANN to configure IP addresses for an ISP. When the destination IP address of packets matches the ISP match rule of an LB class, the LB device selects a link to forward the packets based on the link group configuration.
You can configure ISP information manually, by importing an ISP file, by auto update, or use the combination of these methods.
The system keeps the imported information intact when detecting the following problems:
·     The file does not exist.
·     The file name is invalid.
·     File decryption fails.
If the system quits the import operation because of IP address parsing failure, the system performs the following operations:
·     Clears the most recently imported information.
·     Saves the information imported this time.
You cannot delete the imported ISP or its IPv4 or IPv6 address. If the manually configured and imported ISP information overlaps, you can delete the manually configured ISP information.
If you import multiple ISP files, the newly imported one overwrites the previously imported one.
1.     Select Policies > Load Balancing > Common Configuration > ISP.
2.     Import an ISP file on the ISP page.
a.     Click Select, and select the file to be imported.
b.     Click Import. The imported file appears in the ISP list.
3.     Manually configure ISP information.
a.     Click Create.
Table 18 Manual ISP configuration items
Item
ISP name
Enter a name for the ISP, case insensitive.
Enter a description for the ISP.
Whois maintainer object
Configure a whois maintainer object to identify an ISP.
Enter a name for the whois maintainer object, and click Add.
·     Object name—Enter a name for the whois maintainer object, a string of 1 to 63 characters. A maximum of 10 whois maintainer objects can be configured for one ISP.
·     Source—The way a whois maintainer object is added. It can be Manually configured, Imported from file, and Manually configured and Imported from file.
ISP list
1.     Click Create to configure an ISP address.
¡     Address type—Select the address type: IPv4 or IPv6.
¡     IP address—Enter an IPv4 address and mask length (1-32) or an IPv6 address and prefix length (1-128).
2.     Click OK. The ISP address appears in the ISP list.
¡     Source—The way an ISP address is obtained. It can be Manually configured, Imported from file, and Auto update.
b.     Click OK. The ISP information appears in the ISP list.
4.     Configure ISP auto update on the Auto update page.
a.     Enable ISP auto update and configure ISP auto update parameters.
Table 19 Auto update configuration items
Item
ISP auto update
Enable or disable ISP auto update.
Whois server
Specify the whois server from which the device queries ISP information. You can specify a whois server by specifying a domain name or IP address.
·     Domain name—Specify the domain name of the whois server, a case-insensitive, dot-separated string of 1 to 253 characters. Each dot-separated label in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and periods (.).
·     IPv4 address—Specify the IPv4 address of the whois server.
ISP update frequency
Specify the interval for ISP auto update. Options include Per day, Per week, and Per month. The specific update time is 4:02:00 a.m.
Last successfully updated
Time of the most recent successful update.
Last updated
Time of the most recent update.
Updated ISPs
Number of ISP addresses in the most recent update.
Update result
Result of the most recent update. Values include Success, Connection error, Connection abort, DNS error, and No update.
b.     Click Apply to save and apply the configuration.
Configure a region
A region contains network segments corresponding to different ISPs.
1.     Select Policies > Load Balancing > Common Configuration > Regions.
2.     Click Create on the Region page.
3.     Create a region.
Table 20 Region configuration items
Item
Region name
Enter a name for the region, case insensitive.
ISP
Add an ISP.
1.     Select an existing ISP or create an ISP. A created ISP can be viewed from the Policies > Load Balancing > Common Configuration > ISP page.
2.     Click Add. The added ISP appears in the box below the text box.
4.     Click OK. The new region appears on the Region page.
Support for traffic distribution methods depends on the device model.
If the device has multiple security engines, the system automatically creates a failover group for each security engine. You can also manually create failover groups. The primary node in a failover group processes load balancing traffic. Load balancing does not support cross-card traffic forwarding. To make sure the request and response packets are processed by one failover group, you must enable traffic distribution rule deployment. The following LB traffic distribution methods are available:
·     Evenly distribute traffic among failover groups (default method)—When manual failover groups are available, traffic is evenly distributed among manual failover groups. When manual failover groups are unavailable, traffic is evenly distributed among available, automatic failover groups.
·     Distribute traffic to a Blade aggregate interfaceThis traffic distribution method distributes LB traffic to Blade aggregate interface 257 and distributes the return traffic to Blade aggregate interface 1 if the return traffic does not match any traffic distribution rules. This traffic distribution method requires the following configurations:
¡     Configure the link-aggregation load-sharing mode source-ip command on Blade aggregate interface 257.
¡     Configure the link-aggregation load-sharing mode destination-ip command on Blade aggregate interface 1.
For the correct operation of non-LB services, use the session flow-redirect enable command to enable session flow redirection.
·     Distribute traffic to the specified failover groupThis traffic distribution method distributes LB traffic to the failover group that is selected by NAT Server to process NAT traffic. The traffic distribution rule deployed by NAT Server distributes traffic always to one failover group.
·     Disable LB traffic distributionThe system deletes traffic distribution rules deployed for load balancing and does not deploy new rules.
You can configure the aging time for DNS cache entries. The DNS cache entries can be viewed from Monitor > DNS Cache.
