03-Policies
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40203-Policies
22-Security policy optimization
22-Security policy optimization 34.69 KB
This help contains the following topics:
·     Introduction
·     Restrictions and guidelines
·     Perform policy optimization
Introduction
About policy optimization
This feature enables the system to discover potential risks in security policies configured with application filtering criteria and enables users to optimize content security settings to lower the risks.
You can use this feature to optimize the existing security policies or to analyze application security risks to provide reference for precise security policy configuration. To analyze application risks for future reference, configure a security policy with loose filtering criteria and then perform policy optimization.
Operating mechanism
Policy optimization operates as follows:
1.     Identifies application information in the permitted traffic.
2.     Compares the configured content security settings with the recommended settings in the application signature database. The database contains information about the recommended content security settings for each application.
3.     Evaluates the security condition of the security policies based on the comparison result.
The feature scores the overall security condition and provides detailed security risk analysis for each security policy configured with application filtering criteria. Table 1 shows the information on the Policy Optimization page.
Table 1 Policy Optimization page information
Item
Overall security score
Score for the overall security condition of all the security policies. A higher score represents a securer condition.
Security policy name
Name of the security policy.
Security policy type. Options include:
·     IPv4.
·     IPv6.
Security level
Security level, in the range of 1 to 5. A higher value represents higher risks.
Total traffic
Total matching traffic for the security policy.
Application
Applications identified from the permitted traffic.
Traffic
Traffic amount and percentage for each application.
Security risks
Security risks of all identified applications.
Status
Security policy optimization status:
·     Unsolved—Indicates that the security policy has not been optimized.
·     Solved—Indicates that the security policy has been optimized but there still are security risks in the security policy.
Optimization methods
This feature provides the following optimization methods:
·     Automatic batch optimization—Enables the system to optimize content security settings for all the security policies with security risks as recommended in the application signature database.
·     Manual optimization—Enables users to optimize content security settings for a security policy as needed.
Table 2 shows the security risks and the corresponding content security measures.
Table 2 Security risks and the corresponding content security measures
Security risks
Content security measures
Vulnerability
IPS, anti-virus
Malware-vehicle
IPS, anti-virus
Data-loss
File filtering, data filtering
Bandwidth-consuming
URL filtering
You can also specify the maximum bandwidth to lower the risk. For more information, see the online help for bandwidth management.
Misoperation
URL filtering
Tunneling
IPS
Evasive
URL filtering
Productivity-loss
URL filtering
·     This feature analyzes security risks only in packets permitted by security policies.
·     When a large number of security policies exist, policy optimization might consume a lot of CPU resources. Please use this feature when the network is not busy.
·     You cannot add new security policies during automatic batch optimization.
·     Automatic batch optimization stops if a master/backup switchover or memory threshold alert occurs during the optimization process. Policies that have been optimized will not be restored. To restart the optimization, click the Auto batch optimization button after the master/backup switchover finishes or the memory usage drops below the threshold.
Before you perform policy optimization, make sure statistics collection is enabled and security policies configured with application filtering criteria exist.
1.     Click Policies > Security Policies > Policy Optimization.
2.     Click Auto batch optimization to start an automatic batch optimization.
Manual policy optimization
2.     Click the button in the Action field for the security policy to be modified.
3.     In the window that opens, change content security settings as needed.
Table 3 Manual policy optimization configuration items
Item
Application
Select the applications for which you are to modify the content security settings.
Traffic
Traffic amount for each application.
Severity level
Risk severity level in the range of 1 to 5. A higher value represents higher risks.
Security risks
Security risks of the identified applications.
Content security
Select content security measures for the selected applications.
By default, the field displays content security settings configured for the security policy. If no content security settings are configured, the field displays the default content security settings.
Optimization action
Select whether to generate a new security policy. Options include:
·     Generate a new policy—Enables the system to retain the existing security policy and generate a new security policy with the configured settings. The new security policy will be placed before the existing policy and have a higher priority in packet matching.
·     Optimize the existing policy—Enables the system to modify the content security settings of the existing policy.
Auto optimization
Enables users to optimize the security policy as recommended.
4.     Click OK.
