| 02-MPLS SR configuration | 1.17 MB |
Dynamic SID allocation through an IGP
Dynamic SID allocation through BGP
SID allocation through BGP EPE
Label forwarding entry installation based on SIDs
Microloop avoidance after a network failure
Microloop avoidance after a failure recovery
Restrictions and guidelines for MPLS SR
IP traffic forwarding over SRLSPs tasks at a glance
MPLS TE traffic forwarding over static SRLSPs tasks at a glance
MPLS TE traffic forwarding over explicit paths tasks at a glance
MPLS TE traffic forwarding over PCE-calculated SRLSPs tasks at a glance
Prerequisites for static segment configuration
Configuring a static adjacency segment
Configuring a static prefix segment
Configuring IGP-based SID advertisement
IGP-based prefix SID advertisement tasks at a glance
IGP-based adjacency SID advertisement tasks at a glance (for non-member interfaces)
Prerequisites for configuring IGP-based SID advertisement
Configuring the IGP to support MPLS SR
Enabling MPLS SR adjacency SID allocation for the IGP
Configuring BGP-based SID advertisement
BGP-based SID advertisement tasks at a glance
Prerequisites for configuring BGP-based SID advertisement
Configuring BGP to support MPLS SR
Specifying the type of label to advertise to the penultimate hop
Configuring BGP EPE-based SID allocation
Configuring the SRLSP establishment triggering policy
Configuring the device to prefer SRLSPs in traffic forwarding
Configuring an MPLS TE tunnel over a static SRLSP
Binding a static SRLSP to an MPLS TE tunnel interface
Configuring an MPLS TE tunnel over an explicit-path SRLSP
Configuring an explicit path for the MPLS TE tunnel
Configuring an MPLS TE tunnel over the explicit path
Configuring an MPLS TE tunnel over a PCE-calculated SRLSP
Configuring an MPLS TE tunnel interface to use PCE to calculate the SRLSP
Configuring IGP SR and LDP interworking
Restrictions and guidelines for IGP SR and LDP interworking
Prerequisites for MPLS SR and LDP internetworking
Enabling advertisement of locally configured prefix-SID mappings
Configuring prefix-SID mappings
Enabling reception of advertised prefix-SID mappings
Configuring BGP SR and LDP interworking
Restrictions and guidelines for BGP SR and LDP interworking
Restrictions and guidelines for TI-LFA FRR
Disabling an interface from participating in TI-LFA calculation
Configuring microloop avoidance
Display and maintenance commands for MPLS SR
MPLS SR configuration examples
Example: Configuring MPLS SR based on static segments
Example: Configuring MPLS SR based on ISIS-advertised SIDs
Example: Configuring MPLS SR based on OSPF-advertised SIDs
Example: Configuring an SR-based MPLS TE tunnel over an explicit path
Example: Configuring an MPLS TE tunnel over a PCE-calculated SRLSP
Example: Configuring MPLS SR inter-AS option B
Example: Configuring MPLS SR inter-AS option C (I)
Example: Configuring MPLS SR inter-AS option C (II)
Example: Configuring MPLS SR inter-AS option C (III)
Example: Configuring MPLS SR to LDP (IS-IS)
Example: Configuring MPLS SR to LDP (OSPF)
Example: Configuring MPLS SR to LDP (BGP)
Example: Configuring MPLS SR over LDP
Example: Configuring IS-IS TI-LFA FRR
Configuring MPLS SR
About MPLS SR
Segment Routing (SR) is a source routing technology. The source node selects a path for the packets, and then encodes the path in the packet header as an ordered list of segments. Each segment is identified by a label called the segment identifier (SID). The SR nodes along the path forward the packets based on the SIDs in the packets. Only the source node needs to maintain the path status.
SR can operate with MPLS. In an MPLS network, SR uses MPLS labels as SIDs to forward packets on an LSP.
MPLS SR characteristics
MPLS SR has the following characteristics:
· MPLS SR forwards packets based on the existing MPLS infrastructure. No infrastructure modifications are needed to implement SR on an MPLS network. For more information about the MPLS infrastructure, see MPLS basics configuration in MPLS Configuration Guide.
· MPLS SR expands and optimizes existing IGPs and BGP and uses the IGPs and BGP to distribute labels.
· MPLS SR implements network features such as MPLS TE in a simpler way, eliminating issues such as heavy and complicated routing protocol deployment.
Basic concepts
· SR node—A node enabled with the MPLS SR feature. The ingress node (source node) adds labels to packets. The transit nodes forward packets based on labels. The egress node removes labels and forwards packets to the destination networks. SR nodes form an SR domain.
· Segment—An instruction an SR node executes on the incoming packet.
· SID—Segment ID, which is MPLS label in MPLS SR.
· Segment type—The following types of segments are available:
¡ Prefix segment—SIDs are assigned to nodes based on destination address prefix. The nodes create prefix-specific forwarding entries.
¡ Adjacency segment—SIDs are assigned to nodes based on adjacency.
· SRLSP—Segment routing label switched path, an LSP along which SR uses MPLS labels as SIDs to forward packets.
· SRGB—Segment routing global block, a range of global labels dedicated for MPLS SR prefix SIDs. Different nodes can have different SRGBs. The minimum label value of an SRGB label range is referred to as the base value of the SRGB.
· SRLB—Segment routing local block, a range of local labels dedicated for MPLS SR adjacency SIDs. All nodes share the same SRLB. The minimum label value of the SRLB label range is referred to as the base value of the SRLB.
How MPLS SR works
MPLS SR involves the following steps:
1. Label allocation for all nodes and links along the packet forwarding paths.
The following methods are available:
¡ Static segment configuration
¡ Dynamic SID allocation through an IGP
¡ Dynamic SID allocation through BGP
¡ SID allocation through BGP EPE
2. Label forwarding entry installation based on SIDs. All MPLS SR devices in the SR domain use the allocated labels to create label forwarding entries.
3. SRLSP setup. You can manually configure SRLSPs, or use an IGP, BGP, or a controller to dynamically create SRLSPs.
When the ingress node of an SRLSP receives a packet, it adds labels to the packet and forwards the packet to the egress node through the SRLSP. After receiving a packet from the SRLSP, the egress node removes the label and forwards the packet based on the routing table.
You can bind a higher layer application (for example, MPLS TE) to an SRLSP to forward traffic of the application through the SRLSP.
Static MPLS SR provides the following methods for configuring static segments for a destination:
· Prefix segment method—Manually configure the incoming label, outgoing label, and next hop for the destination address prefix on each SR node.
· Adjacency segment method—Manually configure the incoming label and next hop for the adjacency to the neighbor on each SR node.
MPLS SR expands IGP protocols such as IS-IS and OSPF to advertise SIDs in IGP protocol packets. MPLS SR provides the following methods for dynamically allocating and advertising SIDs:
· Prefix SID.
· Adjacency SID.
Prefix SID
After you configure an SID for the loopback address on each SR node, the SIDs uniquely identify the SR nodes. All SR nodes in the SR domain use an IGP to advertise their own prefix SIDs. After receiving advertised prefix SIDs, each SR node calculates the prefix SIDs to the advertisers.
The prefix SID advertisement can be one of the following types:
· Absolute value advertisement—Each SR node advertises the prefix SID absolute value and the SRGB.
· Index value advertisement—Each SR node advertises the prefix SID index and the SRGB.
Each SR node is assigned a globally unique index value for the node's prefix. The prefix SID an SR node allocates to a prefix equals the SRBG base of the SR node plus the index for that prefix.
NOTE: The device supports only the index value advertisement in the current software release. |
Adjacency SID
SR nodes use an IGP to advertise SIDs allocated to the IGP adjacencies (that is, the links to its IGP neighbors). The SIDs are used to identify the links.
The adjacency SIDs can be allocated automatically or manually.
· Automatic adjacency SID allocation—SR nodes allocate labels in SRLBs to the IGP adjacencies as SIDs.
· Manual adjacency SID allocation—You can assign adjacency SID by using absolute values or index values. If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
MPLS SR expands BGP to advertise prefix SIDs in BGP protocol packets. BGP uses routing policies to assign SIDs to prefixes when redistributing routes. The SIDs uniquely identify the SR nodes. All SR nodes in the SR domain use BGP to advertise their own prefix SIDs, including the SIDs and SID index values. From received advertisement packets, each SR node derives the prefix SIDs for the advertisers.
BGP prefix SIDs can be exchanged between BGP peers only through IPv4 unicast routes.
Dynamic SID allocation through BGP applies to MPLS VPN inter-AS option C networks.
The BGP Egress Peer Engineering (BGP EPE) feature assigns labels to BGP peers to steer traffic across ASs to specific BGP neighbors or links.
After you configure BGP EPE on a device, the device assigns SIDs to connected BGP peers or peer groups to identify the BGP neighbors or links. These SIDs are called BGP peering SIDs or BGP peering segments.
BGP peering segments or SIDs fall into the following types:
· Peer Node Segment (Peer Node SID)—Node type, typically assigned to a BGP neighbor that has used a directly connected interface to establish a BGP session with the device.
· Peer Adjacency Segment (Peer Adjacency SID)—Adjacency type, typically assigned to a BGP neighbor that uses a loopback interface to establish a BGP session with the device.
· Peer Set Segment (Peer Set SID)—Set type, typically assigned to links when multiple equal cost multi-path (ECMP) paths exist between the device and a BGP neighbor.
SIDs that BGP EPE assigns are locally significant. These SIDs are not advertised to other devices and are not affected by route types exchanged between BGP peers.
SID allocation through BGP EPE is typically used for MPLS VPN inter-AS option B.
Label forwarding entry installation based on IGP prefix SIDs
Label forwarding entries based on prefix SIDs can be static or dynamic.
· Static label forwarding entries—The device creates local label forwarding entries based on manually configured incoming labels, outgoing labels, and next hops.
· Dynamic label forwarding entries—The device uses the IGP to flood in the SR domain the local SRGB and the index of the prefix SID for the local loopback interface. Based on the flooded information, the other devices in the domain calculates their local label forwarding entries by using the following rules:
¡ Incoming label = Local SRGB base value + Index
¡ Outgoing label = SRGB base value of the next hop + Index
Figure 1 Creating label forwarding entries based on IGP prefix SIDs
Figure 1 shows how dynamic label forwarding entries are created. After you assign index value 201 to loopback address 1.1.1.1/32 on Device C, Device C uses an IGP packet to advertise the index value and its local SRGB. Then, the devices calculate incoming and outgoing labels according to the previously mentioned label calculation rules.
· Devices C calculates its incoming label, which is 18201.
· Device B calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 17201. The outgoing label is 18201. The next hop is Device C.
· Device A calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 17201. The next hop is Device B.
Label forwarding entry installation based on BGP prefix SIDs
The device redistributes routes to BGP and assigns prefix SIDs to redistributed routes based on routing policies. Then, the device uses BGP to flood in the SR domain the prefix SIDs and the indexes of the prefix SIDs. Based on the flooded information, the other devices in the domain calculates their local label forwarding entries by using the following rules:
· Incoming label = Local SRGB base value + Index
· Outgoing label = Received SID
Figure 2 Creating label forwarding entries based on BGP prefix SIDs
Figure 2 shows how label forwarding entries are created. After you assign index value 201 to loopback address 1.1.1.1/32 on Device D, Device D redistributes the route of the address and assigns it an SID (16201 in this example). Then, the device uses a BGP packet to advertise the SID and index value. The devices in the SR domain calculate incoming and outgoing labels according to the previously mentioned label calculation rules and create label forwarding entries.
· Devices D calculates its incoming label, which is 16201.
· Device C calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 16201. The next hop is Device D.
· Device B calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 16201. The next hop is Device C.
· Device A calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 16201. The next hop is Device B.
Label forwarding entry installation based on BGP EPE
Configure BGP EPE on border routers to assign SIDs to specific peers or peer groups.
Figure 3 Creating label forwarding entries by using BGP EPE
As shown in Figure 3, you can configure BGP EPE on Device B to assign BGP peering SIDs to EBGP neighbors Device C and Device D. BGP peering SIDs are locally significant and are not advertised to neighbors.
Label forwarding entry installation based on adjacency SIDs
When using adjacency SIDs, each device allocates a static or dynamic incoming label to the link to its neighbor. The label has local significance. Multiple devices can use the same adjacency SID.
Figure 4 Creating label forwarding entries based on adjacency SIDs
As shown in Figure 4, the devices are running the same IGP. After IGP adjacencies are established between the devices, Device A, Device B, and Device C allocates labels and creates label forwarding entries as follows:
· Device A allocates label 203 to the link to its neighbor Device B.
· Device B allocates label 202 to the link to its neighbor Device C.
· Device C allocates label 201 to the link to its neighbor Device D.
· Device A creates a label forwarding entry with incoming label 203 and next hop Device B.
· Device B creates a label forwarding entry with incoming label 202 and next hop Device C.
· Device C creates a label forwarding entry with incoming label 201 and next hop Device D.
SRLSP setup
You can use the following methods to create SRLSPs:
· Manually configure an SRLSP.
To configure an SRLSP, you must specify the label stack for packets to be forwarded along the SRLSP on the ingress node. Each label in the stack corresponds to a prefix SID or adjacency SID. The system can look for the outgoing label and next hop based on the prefix SID or adjacency SID.
· Configure SR nodes to use BGP or an IGP to dynamically establish an SRLSP.
SR nodes follow these steps to establish SRLSPs:
a. Use BGP or an IGP to collect prefix SID information from the MPLS SR network.
b. Calculate the shortest paths to other SR nodes based on the collected prefix SID information and the BGP or IGP network topology.
c. Establish SRLSPs based on the shortest paths.
· Configure a controller to deploy SRLSP configuration to the device so the device creates SRLSPs.
For more information about controller configuration, see the user guide for the controller.
Packet forwarding in MPLS SR
Based on the SID allocation method, MPLS SR uses one of the following packet forwarding methods:
· Prefix SID-based packet forwarding—The ingress node encapsulates the prefix SID for the egress node to a packet. The transit nodes forward the packet based on label forwarding entries.
· Adjacency SID-based packet forwarding—The ingress node encapsulates the label stack that contains the adjacency SIDs of all links along the forwarding path to a packet. Each transit node uses the top label in the label stack to determine the next hop and pops the top label before forwarding the packet to the next hop.
· Prefix and adjacency SID-based packet forwarding—The nodes use prefix SID-based packet forwarding in combination with adjacency-based packet forwarding.
Prefix SID-based packet forwarding within the same AS
Figure 5 shows how a packet is forwarded along the SRLSP from Device A to Device E based on prefix SIDs. In this example, the outgoing label for the packet is 21201 on Device A.
1. Ingress node Device A searches for a forwarding entry for label 21201, adds outgoing label 20201 to the packet and sends the packet to the next hop (Device B).
2. When transit node Device B receives the packet, it searches for a label forwarding entry that matches the label in the packet. Then, Device B uses the outgoing label of the matched entry (19201) to replace the label in the packet and forwards the packet to the next hop (Device C).
3. Transit nodes Device C and Device D process the packet in the same way Device B does.
4. When egress node Device E receives the packet, it removes the label and forwards the packet by IP address.
Figure 5 Prefix SID-based packet forwarding within the same AS
Prefix SID-based packet forwarding across ASs
Figure 6 shows how a packet is forwarded along the SRLSP from Device A to Device D based on prefix SIDs. In this example, the outgoing label for the packet is 16201 on Device A.
1. Ingress node Device A searches for a forwarding entry for label 16201, adds outgoing label 16201 to the packet, and sends the packet to the next hop (Device B).
2. When transit node Device B receives the packet, it searches for a label forwarding entry that matches the label in the packet (16201). Then, Device B uses the outgoing label of the matched entry (16201) to replace the label in the packet and forwards the packet to the next hop (Device C).
3. Transit nodes Device C processes the packet in the same way Device B does.
4. When egress node Device D receives the packet, it removes the label and forwards the packet by IP address.
Figure 6 Prefix SID-based packet forwarding across ASs
BGP EPE-based packet forwarding across ASs
As shown in Figure 7, you can configure BGP EPE and an SRLSP used for the MPLS TE tunnel on Device B to steer packets to travel through Device C or Device D to Device E. In this example, packets travel from Device A through Device B and Device D to Device E. Device B uses BGP EPE to assign SID 6000 to Device D. A static SRLSP is established between Device B and Device D for the MPLS TE tunnel and Device B also assigns SID 6000 to the SRLSP.
1. Within AS 100, source node Device A adds label 17204 to the packet according to the SRLSP, and sends the packet to Device B.
2. When Device B receives the packet, it searches for a label forwarding entry and finds that it should forward the packet through the MPLS TE tunnel. Then, Device B removes label 17204 from the packet, and forwards the packet through the MPLS TE tunnel to Device D.
3. Within AS 200, Device D searches for a label forwarding entry based on the SRLSP, adds label 18201 to the packet, and sends the packet to Device E.
4. When egress node Device E receives the packet, it removes label 18201 and forwards the packet by IP address.
Figure 7 BGP EPE-based packet forwarding across ASs
Figure 8 shows how a packet is forwarded along the SRLSP from Device A to Device E based on adjacency SIDs. In this example, the label stack for the packet is configured as (200, 201, 202, and 203) on Device A.
1. Ingress node Device A searches for a forwarding entry for the top label (200) to determine the next hop. Then, Device A adds label stack (201, 202, and 203) to the packet, and forwards the packet to the next hop (Device B).
2. When transit node Device B receives the packet, it searches for a forwarding entry for the top label (201) to determine the next hop. Then, Device B removes the top label from the stack and forwards the packet to the next hop (Device C).
3. When transit node Device C receives the packet, it searches for a forwarding entry for the top label (202) to determine the next hop. Then, Device C removes the top label from the stack and forwards the packet to the next hop (Device D).
4. When transit node Device D receives the packet, it searches for a forwarding entry for the label (203) to determine the next hop. Then, Device D removes the label stack from the packet and forwards the packet to the next hop (Device E).
5. When egress node Device E receives the packet, it forwards the packet by IP address.
Figure 8 Adjacency SID-based packet forwarding
Figure 9 shows how a packet is forwarded along the SRLSP from Device A to Device E based on prefix SIDs and adjacency SIDs. In this example, the index value for the prefix SID of Device C is 1. The prefix SIDs for Device A, Device B, and Device C are 18001, 17001, and 16001, respectively. The Adjacency SIDs that Device C and Device D allocate to the adjacencies are 16 and 17, respectively. On Device A, the label stack for the packet is (18001, 16, 17).
1. Ingress node Device A searches for a forwarding entry for label 18001 to determine the outgoing label (17001) and next hop (Device B). Device A swaps label 18001 with 17001. Then, it adds label stack (17001, 16, 17) to the packet and sends the packet to the next hop (Device B).
2. When transit node Device B receives the packet, it searches for a label forwarding entry that matches the top label in the label stack (17001). Then, Device B uses the outgoing label of the matched entry (16001) to replace the top label and forwards the packet to the next hop (Device C).
3. When transit node Device C receives the packet, it removes the top label 16001 and searches for a forwarding entry for the next label (16) to determine the next hop. Then, Device C removes label 16 from the stack and forwards the packet to the next hop (Device D).
4. When transit node Device D receives the packet, it searches for a forwarding entry for the label (17) to determine the next hop. Then, Device D removes the label stack from the packet and forwards the packet to the next hop (Device E).
Figure 9 Prefix and adjacency SID-based packet forwarding
IGP SR and LDP interworking enables MPLS SR networks that use an IGP for SID advertisement to communicate and cooperate with MPLS LDP networks.
IGP SR and LDP interworking supports the following modes:
· SR to LDP—Maps prefixes on an LDP network to MPLS SR SIDs to forward traffic from an MPLS SR network to an MPLS LDP network.
· LDP to SR—Uses an IGP protocol to advertise SIDs and associates SIDs with LDP labels to forward traffic from an MPLS LDP network to an MPLS SR network.
· SR over LDP—Enables MPLS SR networks to communicate through an LDP network.
SR to LDP
The SR to LDP mode defines the following roles:
· Segment Routing Mapping Server (SRMS)—Advertises prefix-SID mappings on behalf of SR-incapable devices (LDP devices). You must configure prefix-SID mappings on the SRMS.
· Segment Routing Mapping Client (SRMC)—Receives prefix-SID mappings advertised by the SRMS and creates MPLS SR label forwarding entries.
As shown in Figure 10, Device A and Device B are running MPLS SR, and Device B, Device C, and Device D are running LDP. After Device D assigns a label for destination address 3.3.3.3/32, Device B and Device C each install an LDP label forwarding entry.
The following steps establish a mapping between the SRLSP and the LDP LSP:
1. Device B acts as an SRMS. It assigns SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32), and then advertises an IP prefix-SID mapping TLV to Device A.
2. Device A acts as an SRMC. After receiving the advertised mapping TLV, it creates an MPLS SR label forwarding entry.
A mapping is established between the SRLSP and the LDP LSP.
Figure 10 SR to LDP packet forwarding
If Device A uses an SRLSP to send a packet to Device D, the packet is forwarded as follows:
1. Ingress node Device A adds label 18201 to the packet and then sends the packet to transit node Device B.
2. When transit node Device B receives the packet, it searches for a label forwarding entry that matches incoming label 18201. Because the entry does not have an outgoing label, Device B searches for a valid LDP outgoing label for destination address 3.3.3.3/32. Then, Device B adds the LDP label (20) to the packet as the SR outgoing label and forwards the packet to the next hop (Device C).
3. When transit node Device C receives the packet, it searches for an LDP label forwarding entry for incoming label 20. Then, it removes the label from the packet and forwards the packet to egress node Device D.
4. The egress node forwards the packet by IP address.
LDP to SR
As shown in Figure 11, Device C and Device D are running MPLS SR, and Device A, Device B, and Device C are running LDP. Each device running LDP assigns a label to destination address 3.3.3.3/32 and then installs an LDP label forwarding entry.
The following steps establish an association between the MPLS SR label and the LDP label:
1. After you assign SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32), Device D sends an IGP protocol packet to advertise the index value and the local SRGB.
2. After receiving the packet, Device C creates an MPLS SR label forwarding entry.
The MPLS SR label and the LDP label are associated on Device C.
Figure 11 LDP to SR packet forwarding
A packet from Device A to Device D is forwarded as follows:
1. Ingress node Device A adds an LDP label (20) to the packet and forwards the packets to the next hop (Device B).
2. Device B searches for an LDP label forwarding entry, uses 30 as the outgoing label, and forwards the packet to the next hop (Device C).
3. Device C searches for an LDP label forwarding entry for incoming label 30 and finds no outgoing label. Because valid MPLS SR outgoing label 16201 exists for the destination address 3.3.3.3.32, Device C uses the label (16201) as the outgoing label and forwards the packet to Device D.
4. Egress node Device D deletes label 16201 from the packet and forwards the packet by IP address.
SR over LDP
For MPLS SR networks to communicate across an LDP network, the SR/LDP border devices must be able to connect the SR LSP and the LDP LSP as follows:
· MPLS SR to LDP interwoking—The border device installs SR-to-LDP label forwarding entries. For a packet from the MPLS SR network to the LDP network, the MPLS SR label forwarding entry on the border device does not have an outgoing label. The border device uses the outgoing label of the LDP label forwarding entry for the same destination address as the outgoing label of the packet.
· LDP to MPLS SR interwoking—The border device installs LDP-to-SR label forwarding entries. For a packet from the LDP network to the MPLS SR network, the LDP forwarding entry on the border device does not have an outgoing label. The border device must use the outgoing label of the MPLS SR forwarding entry for the same destination address as the outgoing label of the packet.
As shown in Figure 12, Device A, Device B, Device D, and Device E are running MPLS SR. After you assign index value 201 to loopback interface address 3.3.3.3/32 on Device E, Device E will advertise the index value and the local SRGB. After Device A, Device B, and Device D receive the message, they will install their respective MPLS SR label forwarding entries. Device B, Device C, and Device D are running LDP. They allocate labels to destination address 3.3.3.3/32 to generate the LDP label forwarding entries.
A packet that Device A sends to Device E will be forwarded as follows:
1. Ingress node Device A encapsulates label 18201 to the packet and forwards the packet to transit node Device B.
2. Transit node Device B searches for an MPLS SR label forwarding entry for incoming label 18201 and finds that the entry does not have an outgoing label. Because an LDP label forwarding entry with outgoing label 20 exists for the destination address (3.3.3.3/32), Device B encapsulates outgoing label 20 in the packet. Then Device B sends the packet to transit node Device C.
3. Device C forwards the packet to Device D based on its LDP label forwarding entries. The outgoing label is 30.
4. Device D searches for an LDP label forwarding entry for incoming label 30 and finds that the entry does not have an outgoing label. Because an MPLS SR label forwarding entry with outgoing label 16201 exists for the destination address (3.3.3.3/32), Device B encapsulates outgoing label 16201 in the packet. Then Device D sends the packet to egress node Device E.
5. Egress node Device E deletes the incoming label and forwards the packet by IP address.
BGP SR and LDP interworking enables MPLS SR networks that use BGP for SID advertisement to communicate and cooperate with MPLS LDP networks.
To support assigning SIDs to SR-incapable devices in the LDP network, BGP SR and LDP interworking defines the following roles:
BGP SR and LDP interworking supports the following modes:
· SR to LDP—Uses BGP IPv4 unicast routes to map prefixes on an LDP network to MPLS SR SIDs to forward traffic from an MPLS SR network to an MPLS LDP network.
· LDP to SR—Uses BGP to advertise SIDs and associates SIDs with LDP labels to forward traffic from an MPLS LDP network to an MPLS SR network.
SR to LDP
When the device uses BGP to implement SR to LDP, it assigns SIDs to the SR-incapable devices in the LDP network according to the locally configured prefix-SID mappings. A node enabled with both MPLS SR and LDP must act as both an SRMS and an SRMC.
As shown in Figure 13, Device A and Device B are running BGP SR, and Device B, Device C, and Device D are running LDP. After Device D assigns a label for destination address 3.3.3.3/32, Device B, Device C, and Device D each install an LDP label forwarding entry.
1. Acting as an SRMS, Device B assigns SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32).
2. Acting as an SRMC, Device B installs an SR label forwarding entry based on the locally configured prefix-SID mapping.
3. Device B establishes a mapping between the SRLSP and the LDP LSP.
4. Device B advertises the prefix SID for 3.3.3.3/32 to Device A through BGP packets. Device A installs an SR label forwarding entry based on the received BGP packets.
Figure 13 BGP SR to LDP packet forwarding
2. When transit node Device B receives the packet, it searches for an SR label forwarding entry that matches incoming label 18201. Because the entry does not have an outgoing label, Device B searches for a valid LDP outgoing label for destination address 3.3.3.3/32. Then, Device B adds the LDP label (600127) to the packet as the SR outgoing label and forwards the packet to the next hop (Device C).
3. When transit node Device C receives the packet, it searches for an LDP label forwarding entry for incoming label 600127. Then, it removes the label from the packet and forwards the packet to egress node Device D.
LDP to SR
As shown in Figure 14, Device C and Device D are running MPLS SR, and Device A, Device B, and Device C are running LDP. Each device running LDP assigns a label through LDP to destination address 3.3.3.3/32 and installs an LDP label forwarding entry.
1. After you assign SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32), Device D uses a BGP IPv4 unicast route to advertise the index value.
2. After receiving the packet, Device C installs an SR label forwarding entry.
The SR label and the LDP label are associated on Device C.
Figure 14 LDP to BGP SR packet forwarding
TI-LFA FRR
Topology-Independent Loop-Free Alternate Fast Re-Route (TI-LFA FRR) provides link and node protection. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
TI-LFA FRR advantages
SR-based TI-LFA FRR has the following advantages:
· It satisfies the basic requirements for IP FRR fast convergence.
· Traffic protection is not affected by the network environment.
· The algorithm is not too complicated.
· It uses the converged route as the backup path. All devices have finished route convergence before the forward process begins.
TI-LFA FRR concepts
· P space—Use the source node of the protected link as the root to establish a shortest path tree. All nodes that are reachable from the source node without passing the protected link form the P space. Nodes in the P space are called P nodes.
· Extended P space—Use the source node of the protected link and its neighbors as the roots to establish shortest path trees. All nodes that are reachable from the source node or one of its neighbors without passing the protected link form the extended P space. The P space is a subset of the extended P space.
· Q space—Use the destination node of the protected link as the root to establish a reverse shortest path tree. All nodes that are reachable from the root node without passing the protected link form the Q space. Nodes in the Q space are called Q nodes.
· TI-LFA algorithm—In real networks, the P space and Q space do not have common nodes or directly connected nodes. The device cannot calculate the backup path and cannot meet the high availability requirement. The TI-LFA algorithm can calculate the extended P space, Q space, converged shortest path tree, repair list, and backup output interface for the protected link to get the backup next hop.
· Repair list—A constraint path used to indicate how a P node reaches a Q node when the P space and Q space do not have common nodes. The repair list contains the following labels (SIDs):
¡ Labels of P nodes.
¡ Adjacency SIDs from P nodes to Q nodes.
TI-LFA FRR protection types
The following TI-LFA traffic protection types are available:
· Link protection—Protects traffic that traverses a specific link.
· Node protection—Protects traffic that traverses a specific node.
Node protection takes precedence over link protection.
TI-LFA FRR path calculation
As shown in Figure 15, PE 1 is the source node. P 1 is the faulty node. PE 2 is the destination node. The numbers on links represent the link costs. A data flow traverses PE 1, P 1, and PE 2. To protect data against P 1 failure, TI-LFA FRR calculates the extended P space, Q space, shortest path tree converged after P 1 fails, repair list, and backup output interface, and creates the backup forwarding entry.
TI-LFA FRR calculates the backup path by using the following steps:
1. Calculates the extended P space: P 2.
2. Calculates the Q space: PE 2 and P 4.
3. Calculates the shortest path tree converged after P 1 fails: PE 1 --> P 2 --> P 4 --> PE 2.
4. Calculates the repair list: Node label of P 2 (16030), adjacency SID of P 2 to P 3 (2168), and adjacency SID of P 3 to P 4 (2178).
5. Calculates the backup output interface, that is, the output interface to the next hop after the link from PE 1 to P 1 fails.
TI-LFA FRR forwarding process
After TI-LFA FRR finishes backup path calculation, traffic will be switched to the backup path in response to a primary path failure.
As shown in Figure 16, P 2 is a P node and P 4 is a Q node. When the next hop on the primary path (P 1) fails, TI-LFA FRR switches the traffic to the backup path. The following are the detailed steps:
1. PE 1 encapsulates a label stack to a packet according to the repair list. The labels, from the outmost to inmost, are as follows:
¡ Node label of P node P2 (16030), which equals the SRGB base value of P 2 plus the SID index value of P 2.
¡ Adjacency SIDs from P node P2 to Q node P 4, which are 2168 and 2178.
¡ The destination's node label 17010, which equals the SRGB base value of Q node P 4 plus the SID index value of destination node PE 2.
2. P2 receives the packet, searches for a label forwarding entry based on the outmost label, pops label 2168, and forwards the packet to P 3.
3. P3 receives the packet, searches for a label forwarding entry based on the outmost label, pops label 2178, and forwards the packet to P 4.
4. P4 receives the packet, and searches for a label forwarding entry based on the outmost label. Because the outgoing label is 18010 and the next hop is PE 2, P 4 encapsulates 18010 as the outmost label and forwards the packet to PE 2.
Figure 16 Data forwarding over the TI-LFA FRR backup path
As shown in Figure 17, when Device B fails, traffic to Device C will be switched to the backup path calculated by TI-LFA. After Device A finishes route convergence, traffic will be switched to the post-convergence path. If Device D and Device F have not finished route convergence and still forward traffic along the pre-convergence path, a loop is formed between Device A and Device F. The loop exists until Device D and Device F finish route convergence.
FRR microloop avoidance and SR microloop avoidance can resolve this issue. After you configure TI-LFA, Device A first switches traffic to the backup path calculated by TI-LFA when Device B fails. Then, Device A waits for Device D and Device F to finish route convergence before starting route convergence. After Device A also finishes route convergence, Device A switches the traffic to the converged route.
Figure 17 Diagram for microloop avoidance after a network failure
As shown in Figure 18, before the link between Device B and Device C recovers, traffic traverses along the backup path. After the link recovers, Device A will forward the traffic to Device B if Device A finishes route convergence before Device B. Before Device B also finishes route convergence, Device B still forwards the traffic along the backup path. A loop is formed between Device A and Device B.
SR microloop avoidance can resolve this issue. After the link recovers, SR microloop avoidance automatically calculates the optimal path from Device A to Device C and forwards traffic along the path. To forward a packet along the newly calculated path, Device A adds, for example, the adjacency SID from Device B to Device C to the packet and then sends the packet to Device B. Then, Device B forwards the packet to Device C based on the path information.
When the microloop avoidance RIB-update-delay timer expires, Device B should have finished route convergence. Device A does not add path information to packets anymore, and it forwards packets to Device C as usual.
Figure 18 Diagram for microloop avoidance after a failure recovery
Protocols and standards
· draft-bashandy-rtgwg-segment-routing-ti-lfa-04
· draft-ietf-spring-segment-routing-mpls-00
· draft-ietf-spring-segment-routing-02
· draft-ietf-isis-segment-routing-extensions-06
· draft-ietf-spring-segment-routing-11
· draft-ietf-ospf-segment-routing-extensions-17
· 3draft-ietf-idr-bgpls-segment-routing-epe-15
· draft-ietf-idr-bgp-prefix-sid-19
· RFC 7684, OSPFv2 Prefix/Link Attribute Advertisement
· RFC 7752, North-Bound Distribution of Link-State and Traffic Engineering (TE) Information Using BGP
For BGP-based SR, the SRGB range is fixed (16000 through 24000). To use both BGP and an IGP to advertise prefix SIDs, set the SRGB range for MPLS to 16000 through 24000.
MPLS SR tasks at a glance
To forward IP traffic over SRLSPs, perform the following configuration tasks:
1. Configuring segments
Select one of the following tasks:
¡ Configuring IGP-based SID advertisement
2. (Optional.) Configuring the SRLSP establishment triggering policy
3. (Optional.) Configuring the device to prefer SRLSPs in traffic forwarding
4. (Optional.) Configuring MPLS SR and LDP interworking
¡ Configuring IGP SR and LDP interworking
¡ Configuring BGP SR and LDP interworking
5. (Optional.) Configuring TI-LFA FRR
To forward MPLS TE traffic over static SRLSPs, perform the following configuration tasks:
¡ Configuring BGP-based SID advertisement
¡ Configuring BGP EPE-based SID allocation
2. Configuring an MPLS TE tunnel over a static SRLSP
3. (Optional.) Configuring MPLS SR and LDP interworking
4. (Optional.) Configuring TI-LFA FRR
To forward MPLS TE traffic over explicit paths, perform the following configuration tasks:
1. Configuring IGP-based SID advertisement
2. Configuring an MPLS TE tunnel over an explicit-path SRLSP
To forward MPLS TE traffic over PCE-calculated SRLSPs, perform the following configuration tasks:
1. Configuring an MPLS TE tunnel over a PCE-calculated SRLSP
2. (Optional.) Configuring MPLS SR and LDP interworking
3. (Optional.) Configuring TI-LFA FRR
Configuring MPLS SRGBs
The global MPLS SRGB is used for prefix segments and BGP prefix SIDs. If no MPLS SRGB is configured for a protocol process, the process uses the global MPLS SRGB.
If you have configured prefix SIDs when you configure an SRGB, the SRGB must contain the configured prefix SIDs.
In the following situations, a configured SRGB takes effect after a device reboot:
· The SRGB contains a label that is already used by another protocol. For example, the SRGB contains a label that is already used by LDP.
· The SRGB overlaps with the label range of another protocol. For example, the SRGB for OSPF process 1 overlaps with the SRGB for IS-IS process 1.
Configuring the global MPLS SRGB
1. Enter system view.
2. Enter segment routing view.
segment-routing
3. Configure the global MPLS SRGB.
global-block minivalue maxivalue
By default, the global MPLS SRGB is from 16000 to 24000.
Configuring the MPLS SRGB for IS-IS
2. Enter IS-IS view.
isis process-id
3. Configure the MPLS SRGB.
segment-routing global-block minivalue maxivalue
By default, the MPLS SRGB is from 16000 to 24000.
Configuring the MPLS SRGB for OSPF
2. Enter OSPF view.
ospf process-id
Configuring the MPLS SRLB
The segment routing local block (SRLB) is the range of local labels dedicated for MPLS SR adjacency SIDs.
Before configuring the MPLS SRLB, use the display mpls label command to display MPLS label usage information. Make sure that all labels in the specified range are idle. If a label in the range is not idle, the configured MPLS SRLB takes effect only after you save the running configuration and reboot the device. For more information about the display mpls label command, see MPLS Command Reference.
segment-routing
3. Configure the MPLS SRLB.
local-block minimum-value maximum-value
By default, the MPLS SRLB is from 15000 to 15999.
Configuring static segments
Before you configure static segments for a static SRLSP, perform the following tasks:
· Determine the ingress node, transit nodes, and egress node of the static SRLSP.
· Determine the incoming label for the adjacency segment from a node to next hop of the node. Determine the incoming label of the prefix segment for the destination IP address on each node. On a device, a static SRLSP, a static LSP, and a static CRLSP cannot use the same incoming label. For more information about CRLSP, see MPLS TE configuration in MPLS Configuration Guide.
· Enable MPLS on all nodes and interfaces that will participate in MPLS forwarding. For information about enabling MPLS, see basic MPLS configuration in MPLS Configuration Guide.
This task is required on all nodes of a static SRLSP.
Multiple static SRLSPs can share an adjacency segment.
If you specify the next hop address for a static adjacency segment, make sure the following requirements are met:
· The device has a route to the next hop address.
· MPLS is enabled on the output interface of the route.
If you specify an output interface for a static adjacency segment, make sure the following requirements are met:
· The interface is up.
· The interface can receive direct routes.
· MPLS is enabled on the interface.
A static adjacency segment must use a different incoming label than existing static LSPs, static PWs, and static CRLSPs. If not, the configured adjacency segment is unavailable. The adjacency segment cannot become available even if you change the incoming label of the static LSP, static PW, or static CRLSP. To resolve this problem, you must delete the existing adjacency segment and configure a new one with a different incoming label.
2. Configure a static adjacency segment.
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
The next hop address for a static adjacency segment cannot be a local public IP address.
Multiple static SRLSPs to the same destination can share a prefix segment.
A prefix segment must use the next hop or output interface of the optimal route to the destination address of the prefix segment. You can configure multiple prefix segments to the destination address for load sharing if the optimal route has more than one next hop or output interface. To avoid configuration failure, make sure all prefix segments use the same prefix segment name and incoming label.
2. Configure a static prefix segment.
static-sr-mpls prefix prefix-path-name destination ip-address { mask-length | mask } in-label in-label-value [ { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
The next hop address for a static prefix segment cannot be a local public IP address.
Perform the following tasks on each node along an SRLSP:
1. Configuring the IGP to support MPLS SR
2. Enabling MPLS SR adjacency SID allocation for the IGP
3. (Optional.) Assigning adjacency SIDs
You can assign adjacency SIDs to adjacencies manually.
Before you configure IGP-based SID advertisement, perform the following tasks:
· Determine the ingress node, transit nodes, and egress node of an SRLSP.
· Determine the SIDs, MPLS SRGBs, and MPLS SRLBs for nodes.
For MPLS SR to take effect, perform the following tasks before configuring the IGP to support MPLS SR:
· If the IGP is IS-IS, set the cost style to wide, compatible, or wide-compatible. For more information about the cost style, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
· If the IGP is OSPF, enable opaque LSA reception and advertisement capability. For more information about the capability, see OSPF configuration in Layer 3—IP Routing Configuration Guide.
Configuring IS-IS to support MPLS SR
isis process-id
3. Enter IS-IS IPv4 unicast address family view.
address-family ipv4
4. Enable MPLS SR.
segment-routing mpls
By default, MPLS SR is disabled.
Configuring OSPF to support MPLS SR
2. Enter OSPF view.
ospf process-id
3. Enable MPLS SR.
Configuring prefix SIDs
Configuring a prefix SID in lookback interface view binds the SID with the IP address of the loopback interface.
To configure a prefix SID, use one of the following methods:
· Specify an absolute value. The absolute value is used as the prefix SID. The prefix SID takes effect only if the absolute value is in the SRGB of the node.
· Specify an index value. The sum of the index value and the SRGB base value is used as the prefix SID. The prefix SID takes effect only if it is in the SRGB.
To use a prefix SID for a group of SR nodes in anycast scenarios, specify the n-flag-clear keyword to set the Node-SID flag bit of the prefix SID to 0.
To configure an IS-IS prefix SID, you must enable an IS-IS process on the loopback interface.
A configured OSPF prefix SID takes effect only if the OSPF process enabled on the loopback interface is the same as the OSPF process associated with the prefix SID.
Configuring an IS-IS prefix SID
2. Enter loopback interface view.
interface loopback interface-number
3. Configure an IS-IS prefix SID.
isis [ process-id process-id ] prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
By default, no IS-IS prefix SID is configured.
Configuring an OSPF prefix SID
3. Configure an OSPF prefix SID.
ospf process-id prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
By default, no OSPF prefix SID is configured.
For this feature to take effect, you must enable MPLS SR.
Enabling MPLS SR adjacency SID allocation for IS-IS
isis process-id
address-family ipv4
4. Enable MPLS SR adjacency SID allocation.
segment-routing adjacency enable
By default, MPLS SR adjacency SID allocation is disabled.
Enabling MPLS SR adjacency SID allocation for OSPF
2. Enter OSPF view.
ospf process-id
3. Enable MPLS SR adjacency SID allocation.
After you enable MPLS SR adjacency SID allocation, the device randomly allocates adjacency SIDs to the links to its IGP neighbors. If the link to an IGP neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this feature to assign a specific adjacency SID to the link.
If you assign the same adjacency SID to the adjacencies on multiple interfaces, multiple forwarding paths are available for adjacency SID-based forwarding. By default, packets are assigned to the adjacencies evenly. If the adjacencies have different bandwidths, you can set the load balancing weights for the adjacencies to avoid congestion. The traffic ratio on an adjacency will be its load balancing weight divided by the total load balancing weights of the adjacencies with the same adjacency SID.
To assign adjacency SIDs by using absolute values, make sure the SIDs are in the label range of the SRLB. To assign adjacency SIDs by using index values, make sure the index values plus the base value of the SRLB are in the label range of the SRLB.
The assigned adjacency SIDs take effect after you enable MPLS SR and MPLS SR adjacency SID allocation.
Before assigning adjacency SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as adjacency SIDs. Make sure the labels are in Idle state.
A label that is not in Idle state is being used by another protocol. If you assign it to a link as an adjacency SID, the adjacency SID is not available even if the status of the label changes to Idle later. To use the adjacency SID, you must remove the adjacency SID assignment and assign the adjacency SID again.
You can assign the same adjacency SID on multiple interfaces.
Assigning adjacency SIDs to IS-IS adjacencies
2. Enter interface view.
3. Assign an adjacency SID to an IS-IS adjacency.
isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
By default, an IS-IS adjacency does not have an adjacency SID.
Assigning adjacency SIDs to OSPF adjacencies
3. Assign an adjacency SID to an OSPF adjacency.
ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
By default, an OSPF adjacency does not have an adjacency SID.
1. Configuring BGP to support MPLS SR
2. Configuring BGP prefix SIDs
3. (Optional.) Specifying the type of label to advertise to the penultimate hop
Before you configure BGP-based SID advertisement, perform the following tasks:
· Determine the index value for the prefix SID of each node:
2. Enable BGP and enter BGP instance view.
3. Create the BGP IPv4 unicast address family and enter its view.
4. Enable MPLS SR.
To configure a BGP prefix SID, use the following methods:
· Instead of specifying a routing policy for route redistribution, use the SID advertised by the IGP as the BGP prefix SID.
· Specify a routing policy for route redistribution. Set the index value for the prefix SID in the routing policy to define the binding between the SID and the prefix.
To use BGP routes to exchange prefix SIDs, you must enable BGP peers to exchange labeled routes.
Configuring the device to use the SIDs advertised by the IGP
1. Configure the IGP to support MPLS SR.
For more information, see "Configuring the IGP to support MPLS SR."
2. Configure prefix SIDs.
For more information, see "Configuring prefix SIDs."
3. Enter system view.
4. Enter BGP instance view.
5. Enter BGP IPv4 unicast address family view.
6. Redistribute routes from IS-IS or OSPF.
import-route { isis | ospf } process-id
Specifying a routing policy for route redistribution
2. Enter BGP instance view.
3. Enter BGP IPv4 unicast address family view.
4. Redistribute routes from IS-IS or OSPF and apply a routing policy to the redistributed routes.
import-route { isis | ospf } process-id route-policy route-policy-name
5. Set the index value for the prefix SID:
a. Return to BGP instance view.
b. Return to system view.
c. Enter the routing policy view.
d. Specify a label index value.
apply label-index index-value
By default, a routing policy does not have a label index value.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels. In this case, the egress node assigns an SID to the penultimate hop based on the prefix SID information in the BGP IPv4 unicast route.
If you change the type of label for the device to advertise to the penultimate hop, the device will close all SRLSPs established based on BGP IPv4 unicast routes. Then, the device will re-establish SRLSPs, using the new label type.
4. Specify the type of label for the device to advertise to the penultimate hop when the device acts as the egress in an MPLS SR network.
segment-routing label-advertise { explicit-null | non-null }
By default, the device advertises an implicit null label of 3 to the penultimate hop when it acts as the egress in an MPLS SR network.
When you configure BGP EPE, follow these restrictions and guidelines:
· By default, a BGP peering SID is node type.
· If you do not specify a routing policy when enabling BGP EPE, the system will assign labels to BGP peers randomly.
· BGP EPE requires that the MPLS TE tunnel use a static SRLSP. The outgoing label of the static SRLSP must be the same as the label specified during BGP EPE configuration.
When you use BGP EPE to apply a routing policy to a peer or peer group, follow these restrictions and guidelines:
· You cannot assign the same label to multiple BGP peers or peer groups.
· You can specify the same routing policy only when you assign a set type label to BGP peers or peer groups.
· You can use if-match interface as a filtering condition only if the EBGP session is established by using loopback interfaces.
3. Enable BGP EPE and specify a routing policy for the peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ adjacency | set ] [ route-policy policy-name ]
By default, BGP EPE is disabled.
4. Return to system view.
5. Enter the routing policy view.
6. Specify a label value.
apply label-value label-value
By default, no label value is specified.
To save system resources, you can configure the SRLSP establishment triggering policy to allow only certain FECs to trigger SRLSP establishment.
2. Enter OSPF view.
ospf process-id
segment-routing lsp-trigger { host | none | prefix-list prefix-name }
By default, the device allows all FECs to trigger SRLSP establishment.
This feature enables the device to preferentially use SRLSPs to forward traffic when both SRLSPs and LDP LSPs are available for traffic forwarding. If you do not configure this feature, the device prefers to use LDP LSPs for traffic forwarding.
This feature takes effect only when MPLS SR is enabled and SRLSPs use prefix SIDs.
Configuring the device to prefer SRLSPs established by IS-IS in traffic forwarding
isis process-id
address-family ipv4
4. Configure the device to prefer SRLSPs in traffic forwarding.
segment-routing sr-prefer [ prefix-list prefix-list-name ]
By default, the device prefers LDP LSPs to SRLSPs.
Configuring the device to prefer SRLSPs established by OSPF in traffic forwarding
2. Enter OSPF view.
ospf process-id
3. Configure the device to prefer SRLSPs in traffic forwarding.
Tasks at a glance
1. Enable MPLS TE.
Perform this task on all nodes that the MPLS TE tunnel traverses. For more information, see MPLS TE configuration in MPLS Configuration Guide.
Perform this task on the ingress node of the MPLS TE tunnel.
3. Create the tunnel interface and specify the destination address of the tunnel.
Perform this task on the ingress node of the MPLS TE tunnel. For more information, see MPLS TE configuration in MPLS Configuration Guide.
4. Binding a static SRLSP to an MPLS TE tunnel interface
5. Configure static routes or policy-based routing to direct traffic to the MPLS TE tunnel.
Configuring a static SRLSP
2. Configure a static SRLSP.
static-sr-mpls lsp lsp-name out-label out-label-value&<1-n>
2. Enter MPLS TE tunnel interface view.
interface tunnel tunnel-number [ mode mpls-te ]
3. Set the MPLS TE tunnel establishment mode to static.
mpls te signaling static
By default, MPLS TE uses RSVP-TE to establish a tunnel.
For more information about this command, see MPLS Command Reference.
4. Bind a static SRLSP to the MPLS TE tunnel interface.
mpls te static-sr-mpls lsp-name [ backup ]
By default, an MPLS TE tunnel does not use a static SRLSP.
The specified SRLSP must be already created by using the static-sr-mpls lsp command.
You can specify the backup keyword to bind a backup static SRLSP only if both the main and backup SRLSPs are established by using the adjacency segment method.
Tasks at a glance
Perform the following tasks on the ingress node of the MPLS TE tunnel:
1. Configuring an explicit path for the MPLS TE tunnel
2. Creating an MPLS TE tunnel interface and specifying the destination address.
3. Configuring an MPLS TE tunnel over the explicit path
Before you configure an MPLS TE tunnel over an explicit-path SRLSP, perform the following tasks:
· Determine the ingress node of the SRLSP.
· Determine the SIDs of the nodes along the SRLSP.
2. Create an explicit path and enter its view.
explicit-path path-name
3. Add or modify a node in the explicit path.
¡ Specify a node by its label.
nextsid [ index index-number ] label label-value type { adjacency | binding-sid | prefix }
For an adjacency or prefix SID node, specify the label assigned to the next hop for the label-value argument. For a node that uses a BSID, specify the BSID for the MPLS TE tunnel.
¡ Specify a node by its IP address.
nexthop [ index index-number ] ip-address [ exclude | include [ loose | strict ] ]
By default, an explicit path does not include any node.
interface tunnel tunnel-number mode mpls-te
3. Set the MPLS TE tunnel establishment mode to SR.
mpls te signaling segment-routing
4. Configure the MPLS TE tunnel interface to use an explicit path.
mpls te path preference value explicit-path path-name [ no-cspf ]
By default, MPLS TE uses the calculated path to establish an SRLSP.
5. (Optional.) Configure the tunnel interface to perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
mpls te path-selection adjacency-sid
By default, a tunnel interface does not perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
Tasks at a glance
1. Enabling MPLS TE
2. Configuring PCE discovery
Perform this task on all nodes that the MPLS TE tunnel traverses. You can manually specify PCEs or configure dynamic PCE discovery. For more information, see MPLS TE configuration in MPLS Configuration Guide.
3. Establishing a PCEP session that supports SR.
Perform this task on all nodes that the MPLS TE tunnel traverses. Set the PCEP device type to active stateful. For more information, see MPLS TE configuration in MPLS Configuration Guide.
4. Creating an MPLS TE tunnel interface and specifying the destination address.
5. Configuring an MPLS TE tunnel interface to use PCE to calculate the SRLSP
4. Configure the MPLS TE tunnel interface to use PCE to calculate the SRLSP.
¡ Establish an SRLSP by using the path calculated by PCEs.
mpls te path preference value dynamic [ pce [ ip-address ]&<0-8> ]
By default, the automatically calculated path is used to establish an SRLSP.
¡ Establish an SRLSP by using SRLSP delegation.
mpls te delegation
By default, SRLSP delegation is disabled.
To configure IGP SR and LDP interworking, make sure the SRLSP uses prefix SIDs.
SR to LDP tasks at a glance
SRMS tasks at a glance
Perform the following tasks on an SRMS:
1. Enabling MPLS SR on the SRMS:
a. Configuring the IGP to support MPLS SR
d. Enabling advertisement of locally configured prefix-SID mappings
2. Configuring prefix-SID mappings
SRMC tasks at a glance
Perform the following tasks on each SRMC:
1. Enabling MPLS SR on the SRMC:
2. Enabling reception of advertised prefix-SID mappings
LDP to SR tasks at a glance
SR over LDP tasks at a glance
Before you configure MPLS SR and LDP internetworking, perform the following tasks:
· Determine the index value for the prefix SID of each node.
Configure this feature on the device that acts as the SRMS.
Configuring IS-IS to advertise locally configured prefix-SID mappings
isis process-id
address-family ipv4
4. Enable advertisement of locally configured prefix-SID mappings.
segment-routing mapping-server advertise-local
By default, advertisement is disabled for locally configured prefix-SID mappings.
Configuring OSPF to advertise locally configured prefix-SID mappings
2. Enter OSPF view.
ospf process-id
3. Enable advertisement of locally configured prefix-SID mappings.
The specified prefixes must not belong to any existing prefix-SID mappings.
Before you configure prefix-SID mappings in bulk, plan the number of mappings carefully.
2. Enable SR and enter segment routing view.
segment-routing
3. Configure a prefix-SID mapping.
mapping-server prefix-sid-map ip-address mask-length start-value [ range range-value ] [ attached ]
By default, no prefix-SID mappings exist.
If you specify a value greater than 65535 for the range-value argument, the prefix-SID mappings cannot be advertised through IS-IS or OSPF.
Configure this feature on the devices that act as the SRMCs.
Configuring IS-IS to receive advertised prefix-SID mappings
isis process-id
address-family ipv4
4. Enable reception of prefix-SID mappings.
segment-routing mapping-server receive
By default, reception of prefix-SID mappings is enabled.
Configuring OSPF to receive advertised prefix-SID mappings
2. Enter OSPF view.
ospf process-id
3. Enable reception of prefix-SID mappings.
Restrictions and guidelines for BGP SR and LDP interworking
To configure BGP SR and LDP interworking, make sure the SRLSP uses prefix SIDs.
An SR network node that is enabled with both MPLS SR and LDP must act as both an SRMS and an SRMC.
1. Configuring BGP SR:
¡ Configuring BGP to support MPLS SR
2. Enabling prefix-SID mappings
3. Configuring prefix-SID mappings
Perform this task on SRMSs.
4. Enable prefix-SID mappings.
segment-routing prefix-sid-map
By default, prefix-SID mappings are disabled.
Restrictions and guidelines for TI-LFA FRR
TI-LFA FRR is not supported on static SR networks.
In MPLS SR and LDP interworking scenarios, you must configure the device to prefer the IS-IS or OSPF SRLSP to the LDP LSP. This rule ensures the effectiveness of the TI-LFA FRR backup next hop.
TI-LFA FRR tasks at a glance
2. (Optional.) Disabling an interface from participating in TI-LFA calculation
On the source node, disable TI-LFA on the route's output interface to the next hop on the primary path.
3. (Optional.) Configuring microloop avoidance
Enabling TI-LFA FRR
Enabling TI-LFA FRR for IS-IS
isis process-id
address-family ipv4
4. Enable LFA FRR for IS-IS.
fast-reroute lfa [ level-1 | level-2 ]
By default, LFA FRR is disabled for IS-IS.
5. Enable TI-LFA FRR for IS-IS.
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
By default, TI-LFA FRR is disabled for IS-IS.
Enabling TI-LFA FRR for OSPF
2. Enter OSPF view.
ospf process-id
3. Enable LFA FRR for OSPF.
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
By default, LFA FRR is disabled for OSPF.
4. Enable TI-LFA FRR for OSPF.
By default, TI-LFA FRR is disabled for OSPF.
Disabling an IS-IS interface from participating in TI-LFA calculation
2. Enter the view of IS-IS interface.
3. Disable the interface from participating in TI-LFA calculation.
isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
By default, an IS-IS interface participates in TI-LFA calculation.
Disabling an OSPF interface from participating in TI-LFA calculation
2. Enter the view of OSPF interface.
ospf fast-reroute ti-lfa disable
By default, an OSPF interface participates in TI-LFA calculation.
The following microloop avoidance methods are available:
· FRR microloop avoidance—Provides microloop avoidance after a network failure.
On a network deployed with TI-LFA FRR, when a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. If devices on the backup path have not finished route convergence, a loop is formed between the source node (failed node or the previous node along the link) and a device on the backup path. The loop exists until the devices on the backup path finish route convergence.
To resolve this issue, FRR microloop avoidance first switches traffic to the backup path calculated by TI-LFA after the node or link failure. Then, the source node waits for the nodes on the backup path to finish route convergence before starting route convergence.
· SR microloop avoidance—Provides microloop avoidance both after a network failure and after a failure recovery.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
To leave sufficient time for IGP to finish route convergence, set the SR microloop avoidance RIB-update-delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, IGP route convergence should have finished and traffic will traverse along the IGP-calculated path.
If you configure both FRR microloop avoidance and SR microloop avoidance, SR microloop avoidance takes effect.
Configuring FRR microloop avoidance for IS-IS
isis process-id
address-family ipv4
4. Enable FRR microloop avoidance for IS-IS.
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
By default, FRR microloop avoidance is disabled for IS-IS.
5. (Optional.) Set the FRR microloop avoidance RIB-update-delay time.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the FRR microloop avoidance RIB-update-delay time is 5000 ms.
Configuring FRR microloop avoidance for OSPF
2. Enter OSPF view.
ospf process-id
3. Enable FRR microloop avoidance for OSPF.
By default, FRR microloop avoidance is disabled for OSPF.
4. (Optional.) Set the FRR microloop avoidance RIB-update-delay time.
Configuring SR microloop avoidance for IS-IS
isis process-id
address-family ipv4
4. Enable SR microloop avoidance for IS-IS.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
By default, SR microloop avoidance is disabled for IS-IS.
5. (Optional.) Set the SR microloop avoidance RIB-update-delay time.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the SR microloop avoidance RIB-update-delay time is 5000 ms.
Configuring SR microloop avoidance for OSPF
2. Enter OSPF view.
ospf process-id
3. Enable SR microloop avoidance for OSPF.
By default, SR microloop avoidance is disabled for OSPF.
4. (Optional.) Set the SR microloop avoidance RIB-update-delay time for OSPF.
Display and maintenance commands for MPLS SR
Task |
Command |
display bgp [ instance instance-name ] egress-engineering ipv4 [ ipv4-address ] |
Display BGP SR label ranges. |
display bgp [ instance instance-name ] segment-routing label-range |
Display BGP SR prefix-SID mappings. |
display bgp [ instance instance-name ] segment-routing prefix-sid-map [ ip-address mask-length | verbose ] |
Display IS-IS SR adjacency SID information. |
display isis [ process-id ] segment-routing adjacency [ sid sid-value | vpn-instance vpn-instance-name ] * |
Display IS-IS SRGB information. |
display isis segment-routing global-block [ level-1 | level-2 ] [ process-id ] |
Display IS-IS SR prefix-SID mappings. |
display isis segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ] |
Display IS-IS SR routing information. |
display isis segment-routing routing-table [ vpn-instance vpn-instance-name ] [ ip ip-address { mask-length | mask } ] |
Display static SRLSP and adjacency segment information. |
display mpls static-sr-mpls { lsp [ lsp-name ] | adjacency [ adjacency-path-name ] } |
Display static prefix segment information. |
display mpls static-sr-mpls prefix [ path lsp-name | destination ip-address [ mask | mask-length ] ] |
Display information about the most recent five SRLSP down events for MPLS TE tunnels. |
display mpls te tunnel lsp-down-info [ tunnel number ] |
Display OSPF SR adjacency SID information. |
display ospf [ process-id ] segment-routing adjacency [ sid sid-value ] [ vpn-instance vpn-instance-name ] |
Display OSPF SRGB information. |
display ospf [ process-id ] [ area area-id ] segment-routing global-block |
Display OSPF SR prefix-SID mappings. |
display ospf segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ] |
Display OSPF SR routing information. |
display ospf segment-routing routing-table [ vpn-instance vpn-instance-name ] [ ip ip-address { mask-length | mask } ] |
Display SR label block information. |
display segment-routing label–block [ protocol { isis | ospf } ] |
Display prefix-SID mappings. |
display segment-routing mapping-server prefix-sid-map [ ip-address mask-length | verbose ] |
MPLS SR configuration examples
Example: Configuring MPLS SR based on static segments
As shown in Figure 19, Router A, Router B, Router C, Router D, and Router E are running IS-IS.
Establish an MPLS TE tunnel over a static SRLSP from Router A to Router D to transmit data between the IP networks. The static SRLSP traverses three adjacency segments: Router A—Router B, Router B—Router C, and Router C—Router D.
Establish an MPLS TE tunnel over a static SRLSP from Router A to Router E to transmit data between the IP networks. The static SRLSP traverses three segments: Router A—Router B (adjacency segment), Router B—Router C (prefix segment), and Router C—Router E (adjacency segment).
Device |
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.9/32 |
Router B |
Loop0 |
2.2.2.9/32 |
GE1/2/0/1 |
100.1.1.1/24 |
GE1/2/0/1 |
10.1.1.2/24 |
GE1/2/0/2 |
10.1.1.1/24 |
GE1/2/0/2 |
20.1.1.1/24 |
GE1/2/0/3 |
60.1.1.1/24 |
Router C |
Loop0 |
3.3.3.9/32 |
Router D |
Loop0 |
4.4.4.9/32 |
GE1/2/0/1 |
30.1.1.1/24 |
GE1/2/0/1 |
100.1.2.1/24 |
GE1/2/0/2 |
20.1.1.2/24 |
GE1/2/0/2 |
30.1.1.2/24 |
GE1/2/0/3 |
50.1.1.1/24 |
GE1/2/0/4 |
60.1.1.2/24 |
Router E |
Loop0 |
5.5.5.9/32 |
GE1/2/0/1 |
200.1.2.1/24 |
GE1/2/0/2 |
50.1.1.2/24 |
1. Configure IP addresses and masks for interfaces. (Details not shown.)
2. Configure IS-IS to advertise interface addresses, including the loopback interface addresses. (Details not shown.)
3. Execute the display ip routing-table command on each router to verify that the routers have learned the routes to one another, including the routes to the loopback interfaces. (Details not shown.)
4. Configure Router A:
# Configure the LSR ID, and enable MPLS and MPLS TE.
[RouterA] mpls lsr-id 1.1.1.9
[RouterA] mpls te
[RouterA-te] quit
[RouterA] interface gigabitethernet 1/2/0/2
[RouterA-GigabitEthernet1/2/0/2] mpls enable
[RouterA-GigabitEthernet1/2/0/2] quit
# Create adjacency segment adjacency-1, and bind incoming label 16 to next hop address 10.1.1.2.
[RouterA] static-sr-mpls adjacency adjacency-1 in-label 16 nexthop 10.1.1.2
# Configure a static SRLSP (static-sr-lsp-1) to Router D, setting the label stack to [16, 21, 30].
[RouterA] static-sr-mpls lsp static-sr-lsp-1 out-label 16 21 30
# Configure a static SRLSP (static-sr-lsp-2) to Router E, setting the label stack to [16, 16000, 31].
[RouterA] static-sr-mpls lsp static-sr-lsp-2 out-label 16 16000 31
# Establish static MPLS TE tunnel 1 to Router D. Specify the LSR ID of Router D as the tunnel destination address and bind static SRLSP static-sr-lsp-1 to MPLS TE tunnel interface 1.
[RouterA] interface tunnel 1 mode mpls-te
[RouterA-Tunnel1] ip address 6.1.1.1 255.255.255.0
[RouterA-Tunnel1] destination 4.4.4.9
[RouterA-Tunnel1] mpls te signaling static
[RouterA-Tunnel1] mpls te static-sr-mpls static-sr-lsp-1
[RouterA-Tunnel1] quit
# Establish static MPLS TE tunnel 2 to Router E. Specify the LSR ID of Router E as the tunnel destination address and bind static SRLSP static-sr-lsp-2 to MPLS TE tunnel interface 2.
[RouterA] interface tunnel 2 mode mpls-te
[RouterA-Tunnel2] ip address 7.1.1.1 255.255.255.0
[RouterA-Tunnel2] destination 5.5.5.9
[RouterA-Tunnel2] mpls te signaling static
[RouterA-Tunnel2] mpls te static-sr-mpls static-sr-lsp-2
[RouterA-Tunnel2] quit
# Configure two static routes to direct traffic destined for 100.1.2.0/24 and 200.1.2.0/24 to MPLS TE tunnel 1 and tunnel 2, respectively.
[RouterA] ip route-static 100.1.2.0 24 tunnel 1 preference 1
[RouterA] ip route-static 200.1.2.0 24 tunnel 2 preference 1
5. Configure Router B:
<RouterB> system-view
[RouterB] mpls lsr-id 2.2.2.9
[RouterB] mpls te
[RouterB-te] quit
[RouterB] interface gigabitethernet 1/2/0/1
[RouterB-GigabitEthernet1/2/0/1] mpls enable
[RouterB-GigabitEthernet1/2/0/1] quit
[RouterB] interface gigabitethernet 1/2/0/2
[RouterB-GigabitEthernet1/2/0/2] mpls enable
[RouterB-GigabitEthernet1/2/0/2] quit
[RouterB] interface gigabitethernet 1/2/0/3
[RouterB-GigabitEthernet1/2/0/3] mpls enable
[RouterB-GigabitEthernet1/2/0/3] quit
# Create adjacency segment adjacency-2, and bind incoming label 21 to next hop address 20.1.1.2.
[RouterB] static-sr-mpls adjacency adjacency-2 in-label 21 nexthop 20.1.1.2
# Create prefix segments prefix-1 to destination IP address 5.5.5.9. Bind incoming label 16000 to next hop addresses 20.1.1.2 and 60.1.1.2, and specify outgoing label 16001. Load balancing will occur between Router B and Router C.
[RouterB] static-sr-mpls prefix prefix-1 destination 5.5.5.9 32 in-label 16000 nexthop 20.1.1.2 out-label 16001
[RouterB] static-sr-mpls prefix prefix-1 destination 5.5.5.9 32 in-label 16000 nexthop 60.1.1.2 out-label 16001
6. Configure Router C:
<RouterC> system-view
[RouterC] mpls lsr-id 3.3.3.9
[RouterC] mpls te
[RouterC-te] quit
[RouterC] interface gigabitethernet 1/2/0/1
[RouterC-GigabitEthernet1/2/0/1] mpls enable
[RouterC-GigabitEthernet1/2/0/1] quit
[RouterC] interface gigabitethernet 1/2/0/2
[RouterC-GigabitEthernet1/2/0/2] mpls enable
[RouterC-GigabitEthernet1/2/0/2] quit
[RouterC] interface gigabitethernet 1/2/0/3
[RouterC-GigabitEthernet1/2/0/3] mpls enable
[RouterC-GigabitEthernet1/2/0/3] quit
[RouterC] interface gigabitethernet 1/2/0/4
[RouterC-GigabitEthernet1/2/0/4] mpls enable
[RouterC-GigabitEthernet1/2/0/4] quit
# Create adjacency segment adjacency-1, and bind incoming label 30 to next hop address 30.1.1.2. Create adjacency segment adjacency-2, and bind incoming label 31 to next hop address 50.1.1.2.
[RouterC] static-sr-mpls adjacency adjacency-1 in-label 30 nexthop 30.1.1.2
[RouterC] static-sr-mpls adjacency adjacency-2 in-label 31 nexthop 50.1.1.2
# Create prefix segment prefix-1 to destination IP address 5.5.5.9, and specify incoming label 16001.
[RouterC] static-sr-mpls prefix prefix-1 destination 5.5.5.9 32 in-label 16001
7. Configure Router D:
<RouterD> system-view
[RouterD] mpls lsr-id 4.4.4.9
[RouterD] mpls te
[RouterD-te] quit
[RouterD] interface gigabitethernet 1/2/0/2
[RouterD-GigabitEthernet1/2/0/2] mpls enable
[RouterD-GigabitEthernet1/2/0/2] quit
8. Configure Router E:
<RouterE> system-view
[RouterE] mpls lsr-id 5.5.5.9
[RouterE] mpls te
[RouterE-te] quit
[RouterE] interface gigabitethernet 1/2/0/2
[RouterE-GigabitEthernet1/2/0/2] mpls enable
[RouterE-GigabitEthernet1/2/0/2] quit
# Display static SRLSP establishment on each router by using the display mpls lsp or display mpls static-sr-mpls command.
[RouterA] display mpls lsp
FEC Proto In/Out Label Out Inter/NHLFE/LSINDEX
1.1.1.9/0/46565 StaticCR -/21 GE1/2/0/2
30
1.1.1.9/1/46565 StaticCR -/16000 GE1/2/0/2
31
- StaticCR 16/- GE1/2/0/2
10.1.1.2 Local -/- GE1/2/0/2
Tunnel0 Local -/- NHLFE1
Tunnel1 Local -/- NHLFE2
[RouterB] display mpls lsp
5.5.5.9/32 StaticCR 16000/16001 GE1/2/0/2
5.5.5.9/32 StaticCR 16000/16001 GE1/2/0/3
- StaticCR 21/- GE1/2/0/2
20.1.1.2 Local -/- GE1/2/0/2
60.1.1.2 Local -/- GE1/2/0/3
[RouterC] display mpls lsp
5.5.5.9/32 StaticCR 16001/- -
- StaticCR 30/- GE1/2/0/1
- StaticCR 31/- GE1/2/0/3
30.1.1.2 Local -/- GE1/2/0/3
50.1.1.2 Local -/- GE1/2/0/3
Example: Configuring MPLS SR based on ISIS-advertised SIDs
As shown in Figure 20, Router A, Router B, Router C, and Router D are running IS-IS.
Configure dynamic SID allocation on loopback interfaces of the routers. Then, establish an SRLSP from Router A to Router D based on the allocated SIDs and configure an MPLS TE tunnel over the SRLSP to transmit data.
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
GE1/2/0/2 |
11.0.0.1/24 |
Router C |
Loop1 |
3.3.3.3/32 |
Router D |
Loop1 |
4.4.4.4/32 |
GE1/2/0/1 |
11.0.0.2/24 |
GE1/2/0/1 |
12.0.0.2/24 |
GE1/2/0/2 |
12.0.0.1/24 |
GE1/2/0/2 |
100.1.2.1/24 |
2. Configure Router A:
# Configure IS-IS and set the IS-IS cost style to wide.
[RouterA] isis 1
[RouterA-isis-1] network-entity 00.0000.0000.0001.00
[RouterA-isis-1] cost-style wide
[RouterA-isis-1] quit
[RouterA] interface gigabitethernet 1/2/0/1
[RouterA-GigabitEthernet1/2/0/1] isis enable 1
[RouterA-GigabitEthernet1/2/0/1] quit
[RouterA] interface loopback 1
[RouterA-LoopBack1] isis enable 1
[RouterA-LoopBack1] quit
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls te
[RouterA-te] quit
[RouterA-GigabitEthernet1/2/0/1] mpls enable
# Configure the SRGB and enable MPLS SR.
[RouterA] isis 1
[RouterA-isis-1] segment-routing global-block 16000 16999
[RouterA-isis-1] address-family ipv4
[RouterA-isis-1-ipv4] segment-routing mpls
[RouterA-isis-1-ipv4] quit
# Configure the IS-IS prefix SID.
[RouterA-LoopBack1] isis prefix-sid index 10
# Configure a static SRLSP (static-sr-lsp-1) to Router D, setting the outgoing label to the prefix label that Router A allocated to Router D (16040).
[RouterA] static-sr-mpls lsp static-sr-lsp-1 out-label 16040
[RouterA-Tunnel1] destination 4.4.4.4
# Configure a static route to direct traffic destined for 100.1.2.0/24 to MPLS TE tunnel 1.
3. Configure Router B:
[RouterB] isis 1
[RouterB-isis-1] network-entity 00.0000.0000.0002.00
[RouterB-isis-1] cost-style wide
[RouterB-isis-1] quit
[RouterB-GigabitEthernet1/2/0/1] isis enable 1
[RouterB-GigabitEthernet1/2/0/2] isis enable 1
[RouterB] interface loopback 1
[RouterB-LoopBack1] isis enable 1
[RouterB-LoopBack1] quit
[RouterB] mpls lsr-id 2.2.2.2
[RouterB] mpls te
[RouterB-te] quit
[RouterB] isis 1
[RouterB-isis-1] segment-routing global-block 17000 17999
[RouterB-isis-1] address-family ipv4
[RouterB-isis-1-ipv4] segment-routing mpls
[RouterB-isis-1-ipv4] quit
[RouterB-LoopBack1] isis prefix-sid index 20
4. Configure Router C:
[RouterC] isis 1
[RouterC-isis-1] network-entity 00.0000.0000.0003.00
[RouterC-isis-1] cost-style wide
[RouterC-isis-1] quit
[RouterC-GigabitEthernet1/2/0/1] isis enable 1
[RouterC-GigabitEthernet1/2/0/2] isis enable 1
[RouterC] interface loopback 1
[RouterC-LoopBack1] isis enable 1
[RouterC-LoopBack1] quit
[RouterC] mpls lsr-id 3.3.3.3
[RouterC] mpls te
[RouterC-te] quit
[RouterC] isis 1
[RouterC-isis-1] segment-routing global-block 18000 18999
[RouterC-isis-1] address-family ipv4
[RouterC-isis-1-ipv4] segment-routing mpls
[RouterC-isis-1-ipv4] quit
[RouterC-LoopBack1] isis prefix-sid index 30
5. Configure Router D:
[RouterD] isis 1
[RouterD-isis-1] network-entity 00.0000.0000.0004.00
[RouterD-isis-1] cost-style wide
[RouterD-isis-1] quit
[RouterD] interface gigabitethernet 1/2/0/1
[RouterD-GigabitEthernet1/2/0/1] isis enable 1
[RouterD-GigabitEthernet1/2/0/1] quit
[RouterD-GigabitEthernet1/2/0/2] isis enable 1
[RouterD] interface loopback 1
[RouterD-LoopBack1] isis enable 1
[RouterD-LoopBack1] quit
[RouterD] mpls lsr-id 4.4.4.4
[RouterD] mpls te
[RouterD-te] quit
[RouterD-GigabitEthernet1/2/0/1] mpls enable
[RouterD] isis 1
[RouterD-isis-1] segment-routing global-block 19000 19999
[RouterD-isis-1] address-family ipv4
[RouterD-isis-1-ipv4] segment-routing mpls
[RouterD-isis-1-ipv4] quit
[RouterD-LoopBack1] isis prefix-sid index 40
# Display MPLS LSP information on Router A.
10.0.0.2 Local -/- GE1/2/0/1
1.1.1.1/32 ISIS 16010/- -
2.2.2.2/32 ISIS 16020/3 GE1/2/0/1
2.2.2.2/32 ISIS -/3 GE1/2/0/1
3.3.3.3/32 ISIS 16030/17030 GE1/2/0/1
3.3.3.3/32 ISIS -/17030 GE1/2/0/1
4.4.4.4/32 ISIS 16040/17040 GE1/2/0/1
4.4.4.4/32 ISIS -/17040 GE1/2/0/1
Example: Configuring MPLS SR based on OSPF-advertised SIDs
As shown in Figure 21, Router A, Router B, Router C, and Router D are running OSPF.
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
GE1/2/0/2 |
11.0.0.1/24 |
Router C |
Loop1 |
3.3.3.3/32 |
Router D |
Loop1 |
4.4.4.4/32 |
GE1/2/0/1 |
11.0.0.2/24 |
GE1/2/0/1 |
12.0.0.2/24 |
GE1/2/0/2 |
12.0.0.1/24 |
GE1/2/0/2 |
100.1.2.1/24 |
# Configure OSPF to achieve network level connectivity.
[RouterA] ospf 1 router-id 1.1.1.1
[RouterA-ospf-1] quit
[RouterA-GigabitEthernet1/2/0/1] ospf 1 area 0
[RouterA-LoopBack1] ospf 1 area 0
[RouterA] mpls te
[RouterA-te] quit
[RouterA] ospf 1
[RouterA-ospf-1] segment-routing global-block 16000 16999
[RouterA-ospf-1] segment-routing mpls
# Configure the OSPF prefix SID by specifying a relative value.
[RouterA-LoopBack1] ospf 1 prefix-sid index 10
[RouterB] ospf 1 router-id 2.2.2.2
[RouterB-ospf-1] quit
[RouterB-GigabitEthernet1/2/0/1] ospf 1 area 0
[RouterB-GigabitEthernet1/2/0/2] ospf 1 area 0
[RouterB-LoopBack1] ospf 1 area 0
[RouterB] mpls te
[RouterB-te] quit
[RouterB] ospf 1
[RouterB-ospf-1] segment-routing global-block 17000 17999
[RouterB-ospf-1] segment-routing mpls
[RouterB-LoopBack1] ospf 1 prefix-sid index 20
[RouterC] ospf 1 router-id 3.3.3.3
[RouterC-ospf-1] quit
[RouterC-GigabitEthernet1/2/0/1] ospf 1 area 0
[RouterC-GigabitEthernet1/2/0/2] ospf 1 area 0
[RouterC-LoopBack1] ospf 1 area 0
[RouterC] mpls te
[RouterC-te] quit
[RouterC] ospf 1
[RouterC-ospf-1] segment-routing global-block 18000 18999
[RouterC-ospf-1] segment-routing mpls
[RouterC-LoopBack1] ospf 1 prefix-sid index 30
[RouterD] ospf 1 router-id 4.4.4.4
[RouterD-ospf-1] quit
[RouterD-GigabitEthernet1/2/0/1] ospf 1 area 0
[RouterD-GigabitEthernet1/2/0/2] ospf 1 area 0
[RouterD-LoopBack1] ospf 1 area 0
[RouterD] mpls te
[RouterD-te] quit
[RouterD] ospf 1
[RouterD-ospf-1] segment-routing global-block 19000 19999
[RouterD-ospf-1] segment-routing mpls
[RouterD-LoopBack1] ospf 1 prefix-sid index 40
1.1.1.1/32 OSPF 16010/- -
2.2.2.2/32 OSPF 16020/3 GE1/2/0/1
2.2.2.2/32 OSPF -/3 GE1/2/0/1
3.3.3.3/32 OSPF 16030/17030 GE1/2/0/1
3.3.3.3/32 OSPF -/17030 GE1/2/0/1
4.4.4.4/32 OSPF 16040/17040 GE1/2/0/1
4.4.4.4/32 OSPF -/17040 GE1/2/0/1
Example: Configuring an SR-based MPLS TE tunnel over an explicit path
As shown in Figure 22, Router A, Router B, Router C, and Router D are running IS-IS.
Configure dynamic SID allocation on loopback interfaces of the routers. Then, create an explicit path from Router A to Router D and configure the MPLS TE tunnel interface to use SR to establish an MPLS TE tunnel over the explicit path.
Table 4 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
GE1/2/0/2 |
11.0.0.1/24 |
Router C |
Loop1 |
3.3.3.3/32 |
Router D |
Loop1 |
4.4.4.4/32 |
GE1/2/0/1 |
11.0.0.2/24 |
GE1/2/0/1 |
12.0.0.2/24 |
GE1/2/0/2 |
12.0.0.1/24 |
GE1/2/0/2 |
100.1.2.1/24 |
# Configure IS-IS to achieve network level connectivity and set the IS-IS cost style to wide.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] mpls te enable
[RouterA] mpls te
[RouterA-te] quit
[RouterA] isis 1
# Create an explicit path to Router D and specify the nodes by their prefix labels.
[RouterA] explicit-path 1
[RouterA-explicit-path-1] nextsid label 16020 type prefix
[RouterA-explicit-path-1] nextsid label 17030 type prefix
[RouterA-explicit-path-1] nextsid label 18040 type prefix
[RouterA-explicit-path-1] quit
# Configure MPLS TE tunnel interface Tunnel 1.
[RouterA-Tunnel1] ip address unnumbered interface loopBack 1
# Set the tunnel destination address to the IP address of the loopback interface on Router D.
# Configure the MPLS TE tunnel interface to use SR to establish a tunnel over the explicit path.
[RouterA-Tunnel1] mpls te signaling segment-routing
[RouterA-Tunnel1] mpls te path preference 1 explicit-path 1
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] mpls te enable
[RouterB] mpls te
[RouterB-te] quit
# Configure the SRGB and enable MPLS SR on the routers.
[RouterB] isis 1
[RouterC] isis 1
[RouterC-isis-1] is-level level-1
[RouterC-isis-1] mpls te enable
[RouterC] mpls te
[RouterC-te] quit
[RouterC] isis 1
[RouterD] isis 1
[RouterD-isis-1] is-level level-1
[RouterD-isis-1] mpls te enable
[RouterD] mpls te
[RouterD-te] quit
[RouterD] isis 1
Tunnel1 Local -/- NHLFE6
1.1.1.1/1/17700 SR-TE -/17030 GE1/2/0/1
18040
# Display the NHLFE entry information.
[RouterA] display mpls forwarding nhlfe
Total NHLFE entries: 3
Flags: T - Forwarded through a tunnel
N - Forwarded through the outgoing interface to the nexthop IP address
B - Backup forwarding information
A - Active forwarding information
M - P2MP forwarding information
NID Tnl-Type Flag OutLabel Forwarding Info
5 LOCAL NA - GE1/2/0/1 10.0.0.2
6 SRLSP NA 17030 GE1/2/0/1 10.0.0.2
18040
268435457 TE TA - 6
The output shows that there are two tiers of outgoing labels to the destination. The traffic is forwarded through the explicit path.
Example: Configuring an MPLS TE tunnel over a PCE-calculated SRLSP
As shown in Figure 23, Router A, Router B, Router C, and Router D are running IS-IS.
Configure Router B, Router C, and Router D as PCEs. Configure Router A as a PCC and specify the PCEs for the PCC. Configure Router A to request the PCEs to calculate the path to Router D.
Table 5 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
GE1/2/0/2 |
11.0.0.1/24 |
Router C |
Loop1 |
3.3.3.3/32 |
Router D |
Loop1 |
4.4.4.4/32 |
GE1/2/0/1 |
11.0.0.2/24 |
GE1/2/0/1 |
12.0.0.2/24 |
GE1/2/0/2 |
12.0.0.1/24 |
GE1/2/0/2 |
100.1.2.1/24 |
[RouterA] isis 1
[RouterA] mpls te
[RouterA-te] quit
[RouterA-GigabitEthernet1/2/0/1] mpls te enable
# Enable MPLS SR.
[RouterA] isis 1
# Configure Router A as a PCC and specify the PCEs.
[RouterA] mpls te
[RouterA-te] pcep type active-stateful
[RouterA-te] pce static 2.2.2.2
[RouterA-te] pce static 3.3.3.3
[RouterA-te] pce static 4.4.4.4
[RouterA-te] quit
[RouterA-Tunnel1] ip address unnumbered interface LoopBack1
# Configure the MPLS TE tunnel interface to use SR and stateful PCE to establish the tunnel over the SRLSP calculated in PCE delegation mode.
[RouterA-Tunnel1] mpls te delegation
[RouterB] isis 1
[RouterB] mpls te
[RouterB-te] quit
[RouterB-GigabitEthernet1/2/0/1] mpls te enable
[RouterB-GigabitEthernet1/2/0/2] mpls te enable
# Enable MPLS SR.
[RouterB] isis 1
# Configure Router B as a PCE.
[RouterB] mpls te
[RouterB-te] pce address 2.2.2.2
[RouterC] isis 1
[RouterC] mpls te
[RouterC-te] quit
[RouterC-GigabitEthernet1/2/0/1] mpls te enable
[RouterC-GigabitEthernet1/2/0/2] mpls te enable
# Enable MPLS SR.
[RouterC] isis 1
# Configure Router C as a PCE.
[RouterC] mpls te
[RouterC-te] pce address 3.3.3.3
[RouterD] isis 1
[RouterD] mpls te
[RouterD-te] quit
[RouterD-GigabitEthernet1/2/0/1] mpls te enable
# Enable MPLS SR.
[RouterD] isis 1
# Configure Router D as a PCE.
[RouterD] mpls te
[RouterD-te] pce address 4.4.4.4
# Display discovered PCEs on each router. This example uses Router A.
[RouterA] display mpls te pce discovery verbose
PCE address: 2.2.2.2
Discovery methods: Static
Path scopes:
Path scope Preference
Compute intra-area paths 7
Act as PCE for inter-area TE LSP computation 6
Capabilities:
Bidirectional path computation
Support for request prioritization
Support for multiple requests per message
PCE address: 3.3.3.3
Path scopes:
Capabilities:
PCE address: 4.4.4.4
Path scopes:
Capabilities:
# Verify that PCEP sessions have been established on each router. This example uses Router A.
[RouterA] display mpls te pce peer verbose
Peer address: 2.2.2.2
TCP connection : 1.1.1.1:36818 -> 2.2.2.2:4189
Peer type : PCE
Session type : Stateless
Session state : UP
Mastership : Normal
Role : Active
Session up time : 0000 days 00 hours 15 minutes
Session ID : Local 0, Peer 0
Keepalive interval : Local 30 sec, Peer 30 sec
Recommended DeadTimer : Local 120 sec, Peer 120 sec
Tolerance:
Min keepalive interval : 10 sec
Max unknown messages : 5
Request timeout : 10 sec
Capability for Initiate : No
Capability for Segment-Routing: No
Peer address: 3.3.3.3
TCP connection : 1.1.1.1:36821 -> 3.3.3.3:4189
Peer type : PCE
Session state : UP
Mastership : Normal
Role : Active
Session up time : 0000 days 00 hours 13 minutes
Session ID : Local 1, Peer 0
Tolerance:
Peer address: 4.4.4.4
TCP connection : 1.1.1.1:36822 -> 4.4.4.4:4189
Peer type : PCE
Session state : UP
Mastership : Normal
Role : Active
Session ID : Local 2, Peer 0
Tolerance:
Example: Configuring MPLS SR inter-AS option B
As shown in Figure 24, complete the following tasks:
· Start OSPF and enable OSPF-based MPLS SR on the PEs in the same AS.
· Establish an MPLS TE tunnel between ASBR-PEs in different ASs and enable BGP EPE.
· Configure PE 1 and ASBR-PE 1 to exchange VPNv4 routes through MP IBGP.
· Configure PE 2 and ASBR-PE 2 to exchange VPNv4 routes through MP IBGP.
· Establish an MP-EBGP peer relationship between ASBR-PE 1 and ASBR-PE 2 to exchange VPNv4 routes.
· Disable route target-based filtering of received VPNv4 routes on ASBR-PE 1 and ASBR-PE 2.
· Configure dynamic SID allocation on loopback interfaces of the devices. Then, establish an SRLSP based on the allocated SIDs and configure an MPLS TE tunnel over the SRLSP to transmit data.
Device |
IP address |
Device |
IP address |
PE 1 |
Loop1 |
2.2.2.9/32 |
PE 2 |
Loop1 |
5.5.5.9/32 |
GE1/2/0/1 |
30.0.0.1/24 |
GE1/2/0/1 |
20.0.0.1/24 |
GE1/2/0/5 |
1.1.1.2/8 |
GE1/2/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop1 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop1 |
4.4.4.9/32 |
GE1/2/0/5 |
1.1.1.1/8 |
GE1/2/0/5 |
9.1.1.1/8 |
GE1/2/0/4 |
11.0.0.2/8 |
GE1/2/0/4 |
11.0.0.1/8 |
2. Configure PE 1:
# Start OSPF on PE 1, set the LSR ID, and enable MPLS and MPLS TE.
<PE1> system-view
[PE1] ospf 1 router-id 2.2.2.9
[PE1-ospf-1] quit
[PE1] interface gigabitethernet 1/2/0/5
[PE1-GigabitEthernet1/2/0/5] ip address 1.1.1.2 255.0.0.0
[PE1-GigabitEthernet1/2/0/5] ospf 1 area 0
[PE1-GigabitEthernet1/2/0/5] mpls enable
[PE1-GigabitEthernet1/2/0/5] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 2.2.2.9 32
[PE1-LoopBack1] ospf 1 area 0
[PE1-LoopBack1] quit
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls te
[PE1-te] quit
# Enable MPLS SR in OSPF view and configure an OSPF prefix SID.
[PE1] ospf 1
[PE1-ospf-1] segment-routing mpls
[PE1-ospf-1] quit
[PE1-LoopBack1] ospf 1 prefix-sid index 20
# Create VPN instance vpn1, and configure the RD and route target attributes.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] quit
# Associate GigabitEthernet 1/2/0/1 with VPN instance vpn1, and assign an IP address to the interface.
[PE1] interface gigabitethernet 1/2/0/1
[PE1-GigabitEthernet1/2/0/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet1/2/0/1] ip address 30.0.0.1 24
[PE1-GigabitEthernet1/2/0/1] quit
# Start BGP on PE 1.
[PE1] bgp 100
# Configure peer 3.3.3.9 as a VPNv4 peer.
[PE1-bgp-default] peer 3.3.3.9 connect-interface loopback 1
[PE1-bgp-default-vpnv4] quit
# Redistribute direct routes to the VPN routing table of vpn1.
[PE1-bgp-default-ipv4-vpn1] import-route direct
3. Configure ASBR-PE 1:
# Start OSPF on ASBR-PE 1, set the LSR ID, and enable MPLS and MPLS TE.
<ASBR-PE1> system-view
[ASBR-PE1] ospf 1 router-id 3.3.3.9
[ASBR-PE1-ospf-1] quit
[ASBR-PE1] interface gigabitethernet 1/2/0/4
[ASBR-PE1-GigabitEthernet1/2/0/4] mpls enable
[ASBR-PE1-GigabitEthernet1/2/0/4] quit
[ASBR-PE1] interface gigabitethernet 1/2/0/5
[ASBR-PE1-GigabitEthernet1/2/0/5] ospf 1 area 0
[ASBR-PE1-GigabitEthernet1/2/0/5] mpls enable
[ASBR-PE1-GigabitEthernet1/2/0/5] quit
[ASBR-PE1] interface loopback 1
[ASBR-PE1-LoopBack1] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack1] ospf 1 area 0
[ASBR-PE1-LoopBack1] quit
[ASBR-PE1] mpls te
[ASBR-PE1-te] quit
[ASBR-PE1] ospf 1
[ASBR-PE1-ospf-1] segment-routing mpls
[ASBR-PE1-LoopBack1] ospf 1 prefix-sid index 30
# Create a routing policy to assign a label.
[ASBR-PE1] route-policy epe permit node 1
[ASBR-PE1-route-policy-epe-1] apply label-value 5555
[ASBR-PE1-route-policy-epe-1] quit
# Start BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 1
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface gigabitethernet 1/2/0/4
# Disable route target-based filtering of received VPNv4 routes.
# Configure IBGP peer 2.2.2.9 and EBGP peer 11.0.0.1 as a VPNv4 peer.
# Enable BGP EPE for EBGP neighbor 11.0.0.1 and specify a routing policy to assign a label to the neighbor.
[ASBR-PE1-bgp-default] peer 11.0.0.1 egress-engineering route-policy epe
[ASBR-PE1-bgp-default] quit
[ASBR-PE1-bgp] quit
4. Configure ASBR-PE 2:
# Start OSPF on ASBR-PE 2, set the LSR ID, and enable MPLS and MPLS TE.
<ASBR-PE2> system-view
[ASBR-PE2] ospf 1 router-id 4.4.4.9
[ASBR-PE2-ospf-1] quit
[ASBR-PE2] interface gigabitethernet 1/2/0/4
[ASBR-PE2-GigabitEthernet1/2/0/4] mpls enable
[ASBR-PE2-GigabitEthernet1/2/0/4] quit
[ASBR-PE2] interface gigabitethernet 1/2/0/5
[ASBR-PE2-GigabitEthernet1/2/0/5] ospf 1 area 0
[ASBR-PE2-GigabitEthernet1/2/0/5] mpls enable
[ASBR-PE2-GigabitEthernet1/2/0/5] quit
[ASBR-PE2] interface loopback 1
[ASBR-PE2-LoopBack1] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack1] ospf 1 area 0
[ASBR-PE2-LoopBack1] quit
[ASBR-PE2] mpls te
[ASBR-PE2-te] quit
[ASBR-PE1] ospf 1
[ASBR-PE1-LoopBack1] ospf 1 prefix-sid index 40
[ASBR-PE2] route-policy epe permit node 1
[ASBR-PE2-route-policy-epe-1] apply label-value 6666
[ASBR-PE2-route-policy-epe-1] quit
# Start BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 1
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface gigabitethernet 1/2/0/4
# Configure IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as a VPNv4 peer.
# Enable BGP EPE for EBGP neighbor 11.0.0.2 and specify a routing policy to assign a label to the neighbor.
[ASBR-PE2-bgp-default] peer 11.0.0.2 egress-engineering route-policy epe
5. Configure PE 2:
# Start OSPF on PE 2, set the LSR ID, and enable MPLS and MPLS TE.
<PE2> system-view
[PE2] ospf 1 router-id 5.5.5.9
[PE2-ospf-1] quit
[PE2] interface gigabitethernet 1/2/0/1
[PE2-GigabitEthernet1/2/0/1] ospf 1 area 0
[PE2-GigabitEthernet1/2/0/1] mpls enable
[PE2-GigabitEthernet1/2/0/1] quit
[PE2] interface gigabitethernet 1/2/0/5
[PE2-GigabitEthernet1/2/0/5] ospf 1 area 0
[PE2-GigabitEthernet1/2/0/5] mpls enable
[PE2-GigabitEthernet1/2/0/5] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 5.5.5.9 32
[PE2-LoopBack1] ospf 1 area 0
[PE2-LoopBack1] quit
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls te
[PE2-te] quit
[PE2] ospf 1
[PE2-ospf-1] segment-routing mpls
[PE2-LoopBack1] ospf 1 prefix-sid index 50
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-vpn-instance-vpn1] quit
[PE2-GigabitEthernet1/2/0/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet1/2/0/1] ip address 20.0.0.1 24
# Start BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv4 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 1
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default-ipv4-vpn1] import-route direct
6. Configuring an MPLS TE tunnel:
# Configure ASBR-PE 1 as the ingress node of static SRLSP static-sr-lsp-1 and specify the label that ASBR-PE 1 allocated to ASBR-PE 2 (5555) as the outgoing label.
[ASBR-PE1] static-sr-mpls lsp static-sr-lsp-1 out-label 5555
# On ASBR-PE 1, establish static MPLS TE tunnel 1 to ASBR-PE 2. Specify the IP address (11.0.0.1) of the directly connected interface on ASBR-PE 2 as the tunnel destination address. Bind static SRLSP static-sr-lsp-1 to MPLS TE tunnel interface 1.
[ASBR-PE1] interface tunnel 1 mode mpls-te
[ASBR-PE1-Tunnel1] ip address 6.1.1.1 255.255.255.0
[ASBR-PE1-Tunnel1] destination 11.0.0.1
[ASBR-PE1-Tunnel1] mpls te signaling static
[ASBR-PE1-Tunnel1] mpls te static-sr-mpls static-sr-lsp-1
[ASBR-PE1-Tunnel1] quit
# Configure ASBR-PE 2 as the ingress node of static SRLSP static-sr-lsp-2 and specify the label that ASBR-PE 2 allocated to ASBR-PE 1 (6666) as the outgoing label.
[ASBR-PE2] static-sr-mpls lsp static-sr-lsp-2 out-label 6666
# On ASBR-PE 2, establish static MPLS TE tunnel 1 to ASBR-PE 1. Specify the IP address (11.0.0.2) of the directly connected interface on ASBR-PE 1 as the tunnel destination address. Bind static SRLSP static-sr-lsp-2 to MPLS TE tunnel interface 1.
[ASBR-PE2] interface tunnel 1 mode mpls-te
[ASBR-PE2-Tunnel1] ip address 7.1.1.1 255.255.255.0
[ASBR-PE2-Tunnel1] destination 11.0.0.2
[ASBR-PE2-Tunnel1] mpls te signaling static
[ASBR-PE2-Tunnel1] mpls te static-sr-mpls static-sr-lsp-2
[ASBR-PE2-Tunnel1] quit
# Execute the display ip routing-table command on CE 1 and CE 2 to verify that they have a route to each other. (Details not shown.)
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
# Display MPLS LSP information on ASBR-PE1.
[ASBR-PE1] display mpls lsp
3.3.3.9/1/53168 StaticCR -/- NHLFE1
11.0.0.1 BGP -/- GE1/2/0/4
2.2.2.9/1151 BGP 1151/1151 -
11.0.0.1/1149 BGP 1150/1149 -
11.0.0.1 BGP 5555/- NHLFE1
1.1.1.2 Local -/- GE1/2/0/5
11.0.0.1 Local -/- GE1/2/0/4
Tunnel1 Local -/- NHLFE4
2.2.2.9/32 OSPF 16020/3 GE1/2/0/5
2.2.2.9/32 OSPF -/3 GE1/2/0/5
3.3.3.9/32 OSPF 16030/- -
Example: Configuring MPLS SR inter-AS option C (I)
As shown in Figure 25, complete the following tasks:
· Configure PE 1 and ASBR-PE 1 to exchange labeled IPv4 routes through IBGP.
· Configure PE 2 and ASBR-PE 2 to exchange labeled IPv4 routes through IBGP.
· Establish an MP-EBGP peer relationship between PE 1 and PE 2 to exchange VPNv4 routes.
· Configure ASBR-PE 1 and ASBR-PE 2 to exchange labeled IPv4 routes through EBGP. Enable BGP-based MPLS SR.
Table 7 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop1 |
2.2.2.9/32 |
PE 2 |
Loop1 |
5.5.5.9/32 |
GE1/2/0/1 |
30.0.0.1/24 |
GE1/2/0/1 |
20.0.0.1/24 |
GE1/2/0/5 |
1.1.1.2/8 |
GE1/2/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop1 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop1 |
4.4.4.9/32 |
GE1/2/0/5 |
1.1.1.1/8 |
GE1/2/0/5 |
9.1.1.1/8 |
GE1/2/0/4 |
11.0.0.2/8 |
GE1/2/0/4 |
11.0.0.1/8 |
CE 1 |
GE1/2/0/1 |
30.0.0.2/24 |
CE 2 |
GE1/2/0/1 |
20.0.0.2/24 |
2. Configure CE 1:
# Assign an IP address to interface GigabitEthernet 1/2/0/1.
<CE1> system-view
[CE1] interface gigabitethernet 1/2/0/1
[CE1-GigabitEthernet1/2/0/1] ip address 30.0.0.2 24
[CE1-GigabitEthernet1/2/0/1] quit
# Configure PE 1 as an EBGP peer and redistribute the VPN route.
[CE1] bgp 65001
[CE1-bgp-default] peer 30.0.0.1 as-number 100
[CE1-bgp-default-ipv4] peer 30.0.0.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
3. Configure PE 1:
<PE1> system-view
[PE1-ospf-1] quit
[PE1-GigabitEthernet1/2/0/1] mpls enable
[PE1] mpls te
[PE1-te] quit
[PE1] ospf 1
[PE1-ospf-1] quit
# Create VPN instance vpn1. Configure an RD and both import and export route targets for the VPN instance.
# Bind VPN instance vpn1 to interface GigabitEthernet 1/2/0/1 and assign an IP address to the interface.
[PE1] bgp 100
# Enable the capability to exchange labeled routes with IBGP peer 3.3.3.9.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
# Enable MPLS SR.
[PE1-bgp-default-ipv4] segment-routing mpls
[PE1-bgp-default-ipv4] quit
# Configure the maximum number of hops from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 1
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-default-vpnv4] peer 5.5.5.9 enable
# Configure CE 1 as an EBGP peer of PE 1 and install the learned BGP routes in the routing table of the VPN instance.
4. Configure ASBR-PE 1:
[ASBR-PE1] mpls te
[ASBR-PE1-te] quit
[ASBR-PE1] ospf 1
# Create a routing policy and specify a label index value.
[ASBR-PE1]ip prefix-list 1 permit 2.2.2.9 32
[ASBR-PE1]route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] if-match ip address prefix-list 1
[ASBR-PE1-route-policy-policy1-1] apply label-index 20
[ASBR-PE1-route-policy-policy1-1] quit
# Start BGP on ASBR-PE 1. Enable the capability to exchange labeled routes with IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from OSPF process 1 to BGP and apply the routing policy.
[ASBR-PE1-bgp-default-ipv4] import-route ospf 1 route-policy policy1
# Enable MPLS SR.
[ASBR-PE1-bgp-default-ipv4] segment-routing mpls
[ASBR-PE1-bgp-default-ipv4] quit
# Enable the capability to exchange labeled routes with EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
5. Configure ASBR-PE 2:
[ASBR-PE2] mpls te
[ASBR-PE2-te] quit
[ASBR-PE2] ospf 1
[ASBR-PE2-ospf-1] segment-routing mpls
[ASBR-PE2-LoopBack1] ospf 1 prefix-sid index 40
[ASBR-PE2]ip prefix-list 1 permit 5.5.5.9 32
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] if-match ip address prefix-list 1
[ASBR-PE2-route-policy-policy1-1] apply label-index 50
[ASBR-PE2-route-policy-policy1-1] quit
# Start BGP on ASBR-PE 2. Enable the capability to exchange labeled routes with IBGP peer 5.5.5.9.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
[ASBR-PE2-bgp-default-ipv4] import-route ospf 1 route-policy policy1
# Enable MPLS SR.
[ASBR-PE2-bgp-default-ipv4] segment-routing mpls
[ASBR-PE2-bgp-default-ipv4] quit
# Enable the capability to exchange labeled routes with EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
6. Configure PE 2:
<PE2> system-view
[PE2-ospf-1] quit
[PE2] mpls te
[PE2-te] quit
[PE2] ospf 1
[PE2-ospf-1] quit
[PE2] bgp 600
# Enable the capability to exchange labeled routes with IBGP peer 4.4.4.9.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
# Enable MPLS SR.
[PE2-bgp-default-ipv4] segment-routing mpls
[PE2-bgp-default-ipv4] quit
# Configure the maximum number of hops from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 1
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
# Configure CE 2 as an EBGP peer and install the learned BGP route in the routing table of the VPN instance.
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 20.0.0.2 enable
7. Configure CE 2:
<CE2> system-view
[CE2] interface gigabitethernet 1/2/0/1
[CE2-GigabitEthernet1/2/0/1] ip address 20.0.0.2 24
[CE2-GigabitEthernet1/2/0/1] quit
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 20.0.0.1 as-number 600
[CE2-bgp-default-ipv4] peer 20.0.0.1 enable
[CE2-bgp-default-ipv4] import-route direct
# Display MPLS LSP information on PE 1.
[PE1] display mpls lsp
2.2.2.9/32 BGP -/16020 NHLFE1
5.5.5.9/32 BGP -/16050 NHLFE1
5.5.5.9 BGP -/- GE1/2/0/5
1.1.1.1 Local -/- GE1/2/0/5
2.2.2.9/32 OSPF 16020/- -
3.3.3.9/32 OSPF 16030/3 GE1/2/0/5
3.3.3.9/32 OSPF -/3 GE1/2/0/5
Example: Configuring MPLS SR inter-AS option C (II)
As shown in Figure 26, complete the following tasks:
· Configure PE 1 and ASBR-PE 1 to exchange labeled IPv4 routes through IBGP. Enable BGP-based MPLS SR.
· Configure PE 2 and ASBR-PE 2 to exchange labeled IPv4 routes through IBGP. Enable BGP-based MPLS SR.
Table 8 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop1 |
2.2.2.9/32 |
PE 2 |
Loop1 |
5.5.5.9/32 |
GE1/2/0/1 |
30.0.0.1/24 |
GE1/2/0/1 |
20.0.0.1/24 |
GE1/2/0/5 |
1.1.1.2/8 |
GE1/2/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop1 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop1 |
4.4.4.9/32 |
GE1/2/0/5 |
1.1.1.1/8 |
GE1/2/0/5 |
9.1.1.1/8 |
GE1/2/0/4 |
11.0.0.2/8 |
GE1/2/0/4 |
11.0.0.1/8 |
CE 1 |
GE1/2/0/1 |
30.0.0.2/24 |
CE 2 |
GE1/2/0/1 |
20.0.0.2/24 |
2. Configure CE 1:
<CE1> system-view
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
3. Configure PE 1:
<PE1> system-view
[PE1-ospf-1] quit
[PE1-GigabitEthernet1/2/0/1] ospf 1 area 0
[PE1] mpls te
[PE1-te] quit
# Assign an IP address to GigabitEthernet 1/2/0/5. Start OSPF and enable MPLS on the interface.
[PE1] ospf 1
[PE1-ospf-1] quit
[PE1] route-policy policy1 permit node 1
[PE1-route-policy-policy1-1] apply label-index 20
[PE1-route-policy-policy1-1] quit
[PE1] bgp 100
# Enable MPLS SR.
# Redistribute the route of loopback interface 1 to BGP and apply the routing policy.
[PE1-bgp-default-ipv4] network 2.2.2.9 32 route-policy policy1
[PE1-bgp-default-vpn1] peer 30.0.0.2 as-number 65001
[PE1-bgp-default-ipv4-vpn1] peer 30.0.0.2 enable
[ASBR-PE1] mpls te
[ASBR-PE1-te] quit
[ASBR-PE1] ospf 1
[ASBR-PE1] bgp 100
# Enable MPLS SR.
[ASBR-PE2] mpls te
[ASBR-PE2-te] quit
[ASBR-PE2] ospf 1
[ASBR-PE2] bgp 600
# Enable MPLS SR.
6. Configure PE 2:
<PE2> system-view
[PE2-ospf-1] quit
[PE2] mpls te
[PE2-te] quit
[PE2-GigabitEthernet1/2/0/5] ip address 9.1.1.2 255.0.0.0
[PE2] ospf 1
[PE2-ospf-1] quit
[PE2] route-policy policy1 permit node 1
[PE2-route-policy-policy1-1] apply label-index 50
[PE2-route-policy-policy1-1] quit
# Start BGP on PE 2. Enable the capability to exchange labeled routes with IBGP peer 4.4.4.9.
[PE2] bgp 600
# Enable MPLS SR.
[PE2-bgp-default-ipv4] network 5.5.5.9 32 route-policy policy1
# Configure CE 2 as an EBGP peer of PE 2 and install the learned BGP routes in the routing table of the VPN instance.
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65001
7. Configure CE 2:
<CE2> system-view
[CE2] bgp 65002
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Display MPLS LSP information on PE1.
2.2.2.9/32 BGP 3/- -
Example: Configuring MPLS SR inter-AS option C (III)
As shown in Figure 27, complete the following tasks:
· Configure PE 1, ASBR-PE 1, and ASBR-PE 2 to exchange labeled IPv4 routes through IBGP.
· Configure PE 2, ASBR-PE 3, and ASBR-PE 4 to exchange labeled IPv4 routes through IBGP.
· Configure ASBR-PE 1 and ASBR-PE 3 to use their loopback interfaces to establish an EBGP relationship to exchange labeled IPv4 routes. Enable BGP-based MPLS SR.
· Configure ASBR-PE 2 and ASBR-PE 4 to use their loopback interfaces to establish an EBGP relationship to exchange labeled IPv4 routes. Enable BGP-based MPLS SR.
· Configure dynamic SID allocation on loopback interfaces of the devices. Then, establish SRLSPs based on the allocated SIDs and configure a multisegmented MPLS TE tunnel over the SRLSPs to transmit data.
Table 9 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE1 |
Loop0 |
1.1.1.1/32 |
PE2 |
Loop0 |
6.6.6.1/32 |
GE1/2/0/1 |
11.0.0.1/24 |
GE1/2/0/1 |
21.0.0.1/24 |
GE1/2/0/2 |
12.0.0.1/24 |
GE1/2/0/2 |
22.0.0.1/24 |
ASBR-PE1 |
Loop0 |
2.2.2.1/32 |
ASBR-PE3 |
Loop0 |
4.4.4.1/32 |
GE1/2/0/1 |
11.0.0.2/24 |
GE1/2/0/1 |
21.0.0.2/24 |
GE1/2/0/3 |
13.0.0.1/24 |
GE1/2/0/3 |
23.0.0.1/24 |
GE1/2/0/4 |
14.0.0.1/24 |
GE1/2/0/4 |
14.0.0.2/24 |
ASBR-PE2 |
Loop0 |
3.3.3.1/32 |
ASBR-PE4 |
Loop0 |
5.5.5.1/32 |
GE1/2/0/2 |
12.0.0.2/24 |
GE1/2/0/2 |
22.0.0.2/24 |
GE1/2/0/3 |
13.0.0.2/24 |
GE1/2/0/3 |
23.0.0.2/24 |
GE1/2/0/4 |
24.0.0.1/24 |
GE1/2/0/4 |
24.0.0.2/24 |
2. Configure PE 1:
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ospf 1 area 100
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls te
[PE1-te] quit
[PE1-GigabitEthernet1/2/0/1] ospf 1 area 100
[PE1-GigabitEthernet1/2/0/1] mpls te enable
[PE1] interface gigabitethernet 1/2/0/2
[PE1-GigabitEthernet1/2/0/2] ospf 1 area 100
[PE1-GigabitEthernet1/2/0/2] mpls enable
[PE1-GigabitEthernet1/2/0/2] mpls te enable
[PE1-GigabitEthernet1/2/0/2] quit
[PE1] ospf 1
[PE1-ospf-1] quit
[PE1-LoopBack0] ospf 1 prefix-sid index 10
[PE1] bgp 100
# Configure IBGP peer group 1, add peers 2.2.2.1 and 3.3.3.1 to the group, and enable the capability to exchange labeled routes for the group.
[PE1-bgp-default] group 1
[PE1-bgp-default] peer 1 connect-interface loopback 0
[PE1-bgp-default] peer 2.2.2.1 group 1
[PE1-bgp-default] peer 3.3.3.1 group 1
[PE1-bgp-default-ipv4] peer 1 enable
[PE1-bgp-default-ipv4] peer 1 label-route-capability
[ASBR-PE1-LoopBack0] ip address 2.2.2.1 32
[ASBR-PE1-LoopBack0] ospf 1 area 100
[ASBR-PE1-LoopBack0] quit
[ASBR-PE1] mpls lsr-id 2.2.2.1
[ASBR-PE1] mpls te
[ASBR-PE1-te] quit
[ASBR-PE1] interface gigabitethernet 1/2/0/1
[ASBR-PE1-GigabitEthernet1/2/0/1] ospf 1 area 100
[ASBR-PE1-GigabitEthernet1/2/0/1] mpls enable
[ASBR-PE1-GigabitEthernet1/2/0/1] mpls te enable
[ASBR-PE1-GigabitEthernet1/2/0/1] quit
[ASBR-PE1] interface gigabitethernet 1/2/0/3
[ASBR-PE1-GigabitEthernet1/2/0/3] ospf 1 area 100
[ASBR-PE1-GigabitEthernet1/2/0/3] mpls enable
[ASBR-PE1-GigabitEthernet1/2/0/3] mpls te enable
[ASBR-PE1-GigabitEthernet1/2/0/3] quit
[ASBR-PE1-GigabitEthernet1/2/0/4] mpls te enable
[ASBR-PE1] ospf 1
[ASBR-PE1-LoopBack0] ospf 1 prefix-sid index 20
[ASBR-PE1]ip prefix-list 1 permit 1.1.1.1 32
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply label-index 10
[ASBR-PE1] bgp 100
# Configure IBGP peer group 1, add peers 1.1.1.1 and 3.3.3.1 to the group, and enable the capability to exchange labeled routes for the group.
[ASBR-PE1-bgp-default] group 1
[ASBR-PE1-bgp-default] peer 1 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 1.1.1.1 group 1
[ASBR-PE1-bgp-default] peer 3.3.3.1 group 1
[ASBR-PE1-bgp-default-ipv4] peer 1 enable
[ASBR-PE1-bgp-default-ipv4] peer 1 label-route-capability
# Enable MPLS SR.
# Configure directly connected peer 14.0.0.2 as an EBGP peer. Advertise only the route of local loopback interface 0 to the peer.
[ASBR-PE1-bgp-default] peer 14.0.0.2 as-number 600
[ASBR-PE1-bgp-default-ipv4] network 2.2.2.1 32 route-policy policy2
[ASBR-PE1-bgp-default-ipv4] peer 14.0.0.2 enable
[ASBR-PE1-bgp-default-ipv4] peer 14.0.0.2 route-policy policy2 export
# Create a multihop EBGP neighbor relationship with ASBR-PE 3 by using the loopback interfaces. Enable the capability to exchange labeled routes with peer 4.4.4.1. Set the preferred value to 100 for routes received from peer 4.4.4.1.
[ASBR-PE1-bgp-default] peer 4.4.4.1 as-number 600
[ASBR-PE1-bgp-default] peer 4.4.4.1 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 4.4.4.1 ebgp-max-hop 10
[ASBR-PE1-bgp-default-ipv4] peer 4.4.4.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 4.4.4.1 label-route-capability
[ASBR-PE1-bgp-default-ipv4] peer 4.4.4.1 preferred-value 100
# Enable BGP EPE for neighbor 4.4.4.1 and specify a routing policy to assign a label to the neighbor.
[ASBR-PE1-bgp-default] peer 4.4.4.1 egress-engineering route-policy epe
[ASBR-PE1-bgp] quit
# Create routing policy policy2 and epe to assign label index 20 and label 5555.
[ASBR-PE1]ip prefix-list 2 permit 2.2.2.1 32
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match ip address prefix-list 2
[ASBR-PE1-route-policy-policy2-1] apply label-index 20
[ASBR-PE1-route-policy-policy2-1] quit
# Configure ASBR-PE 2 in the same way you configure ASBR-PE 1. (Details not shown.)
5. Configure ASBR-PE 3:
# Start OSPF on ASBR-PE 3, set the LSR ID, and enable MPLS and MPLS TE.
<ASBR-PE3> system-view
[ASBR-PE3] interface loopback 0
[ASBR-PE3-LoopBack0] ip address 4.4.4.1 32
[ASBR-PE3-LoopBack0] ospf 1 area 200
[ASBR-PE3-LoopBack0] quit
[ASBR-PE3] mpls lsr-id 4.4.4.1
[ASBR-PE3] mpls te
[ASBR-PE3-te] quit
[ASBR-PE3] interface gigabitethernet 1/2/0/1
[ASBR-PE3-GigabitEthernet1/2/0/1] ospf 1 area 200
[ASBR-PE3-GigabitEthernet1/2/0/1] mpls enable
[ASBR-PE3-GigabitEthernet1/2/0/1] mpls te enable
[ASBR-PE3-GigabitEthernet1/2/0/1] quit
[ASBR-PE3] interface gigabitethernet 1/2/0/3
[ASBR-PE3-GigabitEthernet1/2/0/3] ospf 1 area 200
[ASBR-PE3-GigabitEthernet1/2/0/3] mpls enable
[ASBR-PE3-GigabitEthernet1/2/0/3] mpls te enable
[ASBR-PE3-GigabitEthernet1/2/0/3] quit
[ASBR-PE3] interface gigabitethernet 1/2/0/4
[ASBR-PE3-GigabitEthernet1/2/0/4] mpls enable
[ASBR-PE3-GigabitEthernet1/2/0/4] mpls te enable
[ASBR-PE3-GigabitEthernet1/2/0/4] quit
[ASBR-PE3] ospf 1
[ASBR-PE3-ospf-1] segment-routing mpls
[ASBR-PE3-ospf-1] quit
[ASBR-PE3-LoopBack0] ospf 1 prefix-sid index 40
[ASBR-PE3]ip prefix-list 1 permit 6.6.6.1 32
[ASBR-PE3] route-policy policy1 permit node 1
[ASBR-PE3-route-policy-policy1-1] if-match ip address prefix-list 1
[ASBR-PE3-route-policy-policy1-1] apply label-index 60
[ASBR-PE3-route-policy-policy1-1] quit
# Start BGP on ASBR-PE 3.
[ASBR-PE3] bgp 600
# Configure IBGP peer group 1, add peers 5.5.5.1 and 6.6.6.1 to the group, and enable the capability to exchange labeled routes for the group.
[ASBR-PE3-bgp-default] group 1
[ASBR-PE3-bgp-default] peer 1 connect-interface loopback 0
[ASBR-PE3-bgp-default] peer 5.5.5.1 group 1
[ASBR-PE3-bgp-default] peer 6.6.6.1 group 1
[ASBR-PE3-bgp-default] address-family ipv4 unicast
[ASBR-PE3-bgp-default-ipv4] peer 1 enable
[ASBR-PE3-bgp-default-ipv4] peer 1 label-route-capability
[ASBR-PE3-bgp-default-ipv4] import-route ospf 1 route-policy policy1
# Enable MPLS SR.
[ASBR-PE3-bgp-default-ipv4] segment-routing mpls
[ASBR-PE3-bgp-default-ipv4] quit
# Configure directly connected peer 14.0.0.1 as an EBGP peer. Advertise only the route of local loopback interface 0 to the peer.
[ASBR-PE3-bgp-default] peer 14.0.0.1 as-number 100
[ASBR-PE3-bgp-default-ipv4] network 4.4.4.1 32 route-policy policy2
[ASBR-PE3-bgp-default-ipv4] peer 14.0.0.1 enable
[ASBR-PE3-bgp-default-ipv4] peer 14.0.0.1 route-policy policy2 export
# Create a multihop EBGP neighbor relationship with ASBR-PE 1 by using the loopback interfaces. Enable the capability to exchange labeled routes with peer 2.2.2.1. Set the preferred value to 100 for routes received from peer 2.2.2.1.
[ASBR-PE3-bgp-default] peer 2.2.2.1 as-number 100
[ASBR-PE3-bgp-default] peer 2.2.2.1 connect-interface loopback 0
[ASBR-PE3-bgp-default] peer 2.2.2.1 ebgp-max-hop 10
[ASBR-PE3-bgp-default-ipv4] peer 2.2.2.1 enable
[ASBR-PE3-bgp-default-ipv4] peer 2.2.2.1 label-route-capability
[ASBR-PE3-bgp-default-ipv4] peer 2.2.2.1 preferred-value 100
# Enable BGP EPE for EBGP neighbor 2.2.2.1 and specify a routing policy to assign a label to the neighbor.
[ASBR-PE3-bgp-default] peer 2.2.2.1 egress-engineering route-policy epe
[ASBR-PE3-bgp-default] quit
[ASBR-PE3-bgp] quit
# Create routing policies policy2 and epe to assign label index 40 and label 6666, respectively.
[ASBR-PE3]ip prefix-list 2 permit 4.4.4.1 32
[ASBR-PE3] route-policy policy2 permit node 1
[ASBR-PE3-route-policy-policy2-1] if-match ip address prefix-list 2
[ASBR-PE3-route-policy-policy2-1] apply label-index 40
[ASBR-PE3-route-policy-policy2-1] quit
[ASBR-PE3] route-policy epe permit node 1
[ASBR-PE3-route-policy-epe-1] apply label-value 6666
[ASBR-PE3-route-policy-epe-1] quit
6. Configure ASBR-PE 4:
# Configure ASBR-PE 4 in the same way you configure ASBR-PE 3. (Details not shown.)
7. Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 6.6.6.1 32
[PE2-LoopBack0] ospf 1 area 200
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 6.6.6.1
[PE2] mpls te
[PE2-te] quit
[PE2-GigabitEthernet1/2/0/1] ospf 1 area 200
[PE2-GigabitEthernet1/2/0/1] mpls te enable
[PE2] interface gigabitethernet 1/2/0/2
[PE2-GigabitEthernet1/2/0/2] ospf 1 area 200
[PE2-GigabitEthernet1/2/0/2] mpls enable
[PE2-GigabitEthernet1/2/0/2] mpls te enable
[PE2-GigabitEthernet1/2/0/2] quit
[PE2] ospf 1
[PE2-ospf-1] quit
[PE2-LoopBack0] ospf 1 prefix-sid index 60
[PE2] bgp 600
# Configure IBGP peer group 1, add peers 4.4.4.1 and 5.5.5.1 to the group, and enable the capability to exchange labeled routes for the group.
[PE2-bgp-default] group 1
[PE2-bgp-default] peer 1 connect-interface loopback 0
[PE2-bgp-default] peer 4.4.4.1 group 1
[PE2-bgp-default] peer 5.5.5.1 group 1
[PE2-bgp-default-ipv4] peer 1 enable
[PE2-bgp-default-ipv4] peer 1 label-route-capability
8. Configuring a multisegmented MPLS TE tunnel:
# On PE 1, configure an MPLS TE tunnel to ASBR-PE 1 and an MPLS TE tunnel to ASBR-PE 2.
[PE1] static-sr-mpls lsp sr-lsp-20 out-label 16020
[PE1] static-sr-mpls lsp sr-lsp-30 out-label 16030
[PE1] interface tunnel 0 mode mpls-te
[PE1-Tunnel0] ip address unnumbered interface LoopBack0
[PE1-Tunnel0] destination 2.2.2.1
[PE1-Tunnel0] mpls te signaling static
[PE1-Tunnel0] mpls te static-sr-mpls sr-lsp-20
[PE1-Tunnel0] quit
[PE1] interface tunnel 1 mode mpls-te
[PE1-Tunnel1] ip address unnumbered interface LoopBack0
[PE1-Tunnel1] destination 3.3.3.1
[PE1-Tunnel1] mpls te signaling static
[PE1-Tunnel1] mpls te static-sr-mpls sr-lsp-30
[PE1-Tunnel1] quit
# On ASBR-PE 1, configure an MPLS TE tunnel to PE 1 and an MPLS TE tunnel to ASBR-PE 3.
[ASBR-PE1] static-sr-mpls lsp sr-lsp-10 out-label 16010
[ASBR-PE1] static-sr-mpls lsp sr-lsp-40 out-label 5555
[ASBR-PE1] interface tunnel 0 mode mpls-te
[ASBR-PE1-Tunnel0] ip address unnumbered interface LoopBack0
[ASBR-PE1-Tunnel0] destination 1.1.1.1
[ASBR-PE1-Tunnel0] mpls te signaling static
[ASBR-PE1-Tunnel0] mpls te static-sr-mpls sr-lsp-10
[ASBR-PE1-Tunnel0] quit
[ASBR-PE1-Tunnel1] ip address unnumbered interface LoopBack0
[ASBR-PE1-Tunnel1] destination 4.4.4.1
[ASBR-PE1-Tunnel1] mpls te static-sr-mpls sr-lsp-40
# On ASBR-PE 3, configure an MPLS TE tunnel to PE 2 and an MPLS TE tunnel to ASBR-PE 1.
[ASBR-PE3] static-sr-mpls lsp sr-lsp-60 out-label 16060
[ASBR-PE3] static-sr-mpls lsp sr-lsp-40 out-label 6666
[ASBR-PE3] interface tunnel 0 mode mpls-te
[ASBR-PE3-Tunnel0] ip address unnumbered interface LoopBack0
[ASBR-PE3-Tunnel0] destination 6.6.6.1
[ASBR-PE3-Tunnel0] mpls te signaling static
[ASBR-PE3-Tunnel0] mpls te static-sr-mpls sr-lsp-60
[ASBR-PE3-Tunnel0] quit
[ASBR-PE3] interface tunnel 1 mode mpls-te
[ASBR-PE3-Tunnel1] ip address unnumbered interface LoopBack0
[ASBR-PE3-Tunnel1] destination 2.2.2.1
[ASBR-PE3-Tunnel1] mpls te signaling static
[ASBR-PE3-Tunnel1] mpls te static-sr-mpls sr-lsp-40
[ASBR-PE3-Tunnel1] quit
# Configure MPLS TE tunnels on PE 2, ASBR-PE 2, and ASBR-PE 4 in the same way you configure MPLS TE tunnels on PE 1, ASBR-PE 1, and ASBR-PE 3. (Details not shown.)
# Execute the display ip routing-table command on PE 1 and PE 2 to verify that they have a route to each other. (Details not shown.)
# Verify that PE 1 and PE 2 can ping each other. (Details not shown.)
1.1.1.1/0/35940 StaticCR -/3 GE1/2/0/1
1.1.1.1/1/35940 StaticCR -/3 GE1/2/0/1
1.1.1.1/32 BGP -/16010 NHLFE4
4.4.4.1/32 BGP -/16040 NHLFE4
5.5.5.1/32 BGP -/16050 NHLFE4
6.6.6.1/32 BGP -/16060 NHLFE4
11.0.0.2 Local -/- GE1/2/0/1
12.0.0.3 Local -/- GE1/2/0/2
Tunnel0 Local -/- NHLFE4
Tunnel1 Local -/- NHLFE8
2.2.2.1/32 OSPF 16020/3 GE1/2/0/1
2.2.2.1/32 OSPF -/3 GE1/2/0/1
3.3.3.1/32 OSPF 16030/3 GE1/2/0/2
3.3.3.1/32 OSPF -/3 GE1/2/0/2
Example: Configuring MPLS SR to LDP (IS-IS)
As shown in Figure 28, complete the following tasks so Router A and Router C can communicate with each other:
· Configure Router A, Router B, and Router C to run IS-IS.
· Configure Router A and Router B to run MPLS SR and establish an SRLSP between Router A and Router B.
· Configure Router B and Router C to run LDP to establish a dynamic LDP LSP between them.
· Configure Router B as the SRMS, map the prefix address of the LDP network to an SID, and advertise the mapping to Router A.
Table 10 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
Router C |
Loop1 |
3.3.3.3/32 |
GE1/2/0/2 |
11.0.0.1/24 |
GE1/2/0/1 |
11.0.0.2/24 |
[RouterA] isis 1
# Configure the LSR ID.
# Enable MPLS SR.
[RouterA] isis 1
# Configure the SRGB.
[RouterB] isis 1
# Configure LDP.
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterB-GigabitEthernet1/2/0/2] mpls ldp enable
# Enable MPLS SR.
[RouterB] isis 1
# Configure the IGP to advertise locally configured prefix-SID mappings.
[RouterB-isis-1-ipv4] segment-routing mapping-server advertise-local
# Configure a prefix-SID mapping.
[RouterB] segment-routing
[RouterB-segment-routing] mapping-server prefix-sid-map 3.3.3.3 32 100
[RouterB-segment-routing] quit
[RouterC] isis 1
# Configure LDP.
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC-GigabitEthernet1/2/0/1] mpls ldp enable
# Display IS-IS SRLSP information on Router A.
[RouterA] display mpls lsp protocol isis
3.3.3.3/32 ISIS 16100/17100 GE1/2/0/1
3.3.3.3/32 ISIS -/17100 GE1/2/0/1
The output shows that the outgoing label of the IS-IS SRLSP entry for Router C is using the SID assigned to Router C.
Example: Configuring MPLS SR to LDP (OSPF)
As shown in Figure 29, complete the following tasks so Router A and Router C can communicate with each other:
· Configure Router A, Router B, and Router C to run OSPF.
Table 11 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
Router C |
Loop1 |
3.3.3.3/32 |
GE1/2/0/2 |
11.0.0.1/24 |
GE1/2/0/1 |
11.0.0.2/24 |
# Enable MPLS SR.
[RouterA] ospf 1
# Configure LDP.
[RouterB] mpls ldp
[RouterB-ldp] quit
# Enable MPLS SR.
[RouterB] ospf 1
[RouterB-ospf-1] segment-routing mapping-server advertise-local
# Configure LDP.
[RouterC] mpls ldp
[RouterC-ldp] quit
# Display OSPF SRLSP information on Router A.
[RouterA] display mpls lsp protocol ospf
3.3.3.3/32 OSPF 16100/17100 GE1/2/0/1
3.3.3.3/32 OSPF -/17100 GE1/2/0/1
The output shows that the outgoing label of the OSPF SRLSP entry for Router C is using the SID assigned to Router C.
Example: Configuring MPLS SR to LDP (BGP)
As shown in Figure 30, complete the following tasks so Router A and Router C can communicate with each other:
· Configure Router A and Router B to use EBGP to exchange labeled IPv4 routes.
· Configure Router B and Router C to use IBGP to exchange labeled IPv4 routes.
· Configure Router A and Router B as both SRMSs and SRMCs so they assign SIDs to LDP network prefixes.
Table 12 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
Router C |
Loop1 |
3.3.3.3/32 |
GE1/2/0/2 |
11.0.0.1/24 |
GE1/2/0/1 |
11.0.0.2/24 |
# Set the LSR ID, and enable MPLS.
# Configure a routing policy and assign an SID.
[RouterA] route-policy sr permit node 1
[RouterA-route-policy-sr-1] apply label-index 100
[RouterA-route-policy-sr-1] quit
# Configure BGP to exchange labeled routes with EBGP peer 10.0.0.2.
[RouterA] bgp 200
[RouterA-bgp-default] peer 10.0.0.2 as-number 100
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 10.0.0.2 enable
[RouterA-bgp-default-ipv4] peer 10.0.0.2 label-route-capability
# Advertise local network 1.1.1.1/32, and assign SID index 100 to 1.1.1.1/32 by using the routing policy.
[RouterA-bgp-default-ipv4] network 1.1.1.1 32 route-policy sr
# Enable MPLS SR.
[RouterA-bgp-default-ipv4] segment-routing mpls
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
# Configure OSPF to achieve network level connectivity, set the LSR ID, and enable MPLS.
# Configure LDP.
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterB-segment-routing] mapping-server prefix-sid-map 3.3.3.3 32 200
# Configure a routing policy and assign MPLS labels to routes.
[RouterB] route-policy srldp permit node 0
[RouterB-route-policy-srldp-0] apply mpls-label
[RouterB-route-policy-srldp-0] quit
# Configure BGP to exchange labeled routes with EBGP peer 10.0.0.1.
[RouterB] bgp 100
[RouterB-bgp-default] peer 10.0.0.1 as-number 200
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 10.0.0.1 enable
[RouterB-bgp-default-ipv4] peer 10.0.0.1 label-route-capability
[RouterB-bgp-default-ipv4] quit
# Configure BGP to exchange labeled routes with IBGP peer 3.3.3.3.
[RouterB-bgp-default] peer 3.3.3.3 as-number 100
[RouterB-bgp-default] peer 3.3.3.3 connect-interface loopBack1
[RouterB-bgp-default-ipv4] peer 3.3.3.3 enable
[RouterB-bgp-default-ipv4] peer 3.3.3.3 route-policy srldp export
[RouterB-bgp-default-ipv4] peer 3.3.3.3 label-route-capability
# Enable MPLS SR.
[RouterB-bgp-default-ipv4] segment-routing mpls
# Enable prefix-SID mappings.
[RouterB-bgp-default-ipv4] segment-routing prefix-sid-map
[RouterB-bgp-default] quit
# Configure LDP.
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC] route-policy ldpsr permit node 0
[RouterC-route-policy-ldpsr-0] apply mpls-label
[RouterC-route-policy-ldpsr-0] quit
# Configure BGP to exchange labeled routes with IBGP peer 2.2.2.2.
[RouterC] bgp 100
[RouterC-bgp-default] peer 2.2.2.2 as-number 100
[RouterC-bgp-default] peer 2.2.2.2 connect-interface LoopBack1
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 2.2.2.2 enable
[RouterC-bgp-default-ipv4] peer 2.2.2.2 route-policy ldpsr export
[RouterC-bgp-default-ipv4] peer 2.2.2.2 label-route-capability
# Advertise local network 3.3.3.3.
[RouterC-bgp-default-ipv4] network 3.3.3.3 32
[RouterC-bgp-default-ipv4] quit
[RouterC-bgp-default] quit
# Verity that Router A and Router C can communicate. (Details not shown.)
# Display LSP information on Router B.
2.2.2.2/32 LDP 3/- -
3.3.3.3/32 LDP 1151/3 GE1/2/0/2
3.3.3.3/32 LDP -/3 GE1/2/0/2
1.1.1.1/32 BGP 16100/3 NHLFE6
1.1.1.1/32 BGP -/3 NHLFE6
3.3.3.3/32 BGP 16200/1274 NHLFE7
10.0.0.1 BGP -/- GE1/2/0/1
10.0.0.1 Local -/- GE1/2/0/1
11.0.0.2 Local -/- GE1/2/0/2
The output shows that the outgoing label of the LSP entry for Router C is using the SID assigned to Router C.
Example: Configuring MPLS SR over LDP
As shown in Figure 31, complete the following tasks so the two SR networks can communicate across the LDP network:
· Configure Router A, Router B, Router C, Router D, and Router E to run IS-IS.
· Configure Router B, Router C, and Router D to run LDP.
· Configure Router A, Router B, Router D, and Router E to run MPLS SR.
Table 13 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop1 |
1.1.1.1/32 |
Router B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
10.0.0.1/24 |
GE1/2/0/1 |
10.0.0.2/24 |
Router C |
Loop1 |
3.3.3.3/32 |
GE1/2/0/2 |
11.0.0.1/24 |
GE1/2/0/1 |
11.0.0.2/24 |
Router D |
Loop1 |
4.4.4.4/32 |
GE1/2/0/2 |
12.0.0.1/24 |
GE1/2/0/1 |
12.0.0.2/24 |
Router E |
Loop1 |
5.5.5.5/32 |
GE1/2/0/2 |
13.0.0.1/24 |
GE1/2/0/1 |
13.0.0.2/24 |
[RouterA] isis 1
# Enable MPLS SR.
[RouterA] isis 1
[RouterB] isis 1
# Configure LDP.
[RouterB] mpls ldp
[RouterB-ldp] quit
# Enable MPLS SR.
[RouterB] isis 1
[RouterC] isis 1
# Configure LDP.
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC-GigabitEthernet1/2/0/2] mpls ldp enable
[RouterD] isis 1
# Configure LDP.
[RouterD] mpls ldp
[RouterD-ldp] quit
[RouterD-GigabitEthernet1/2/0/1] mpls ldp enable
# Enable MPLS SR.
[RouterD] isis 1
[RouterD-isis-1] segment-routing global-block 18000 18999
6. Configure Router E:
[RouterE] isis 1
[RouterE-isis-1] network-entity 00.0000.0000.0005.00
[RouterE-isis-1] cost-style wide
[RouterE-isis-1] quit
[RouterE] interface gigabitethernet 1/2/0/1
[RouterE-GigabitEthernet1/2/0/1] isis enable 1
[RouterE-GigabitEthernet1/2/0/1] quit
[RouterE] interface loopback 1
[RouterE-LoopBack1] isis enable 1
[RouterE-LoopBack1] quit
[RouterE] mpls lsr-id 5.5.5.5
# Enable MPLS SR.
[RouterE] isis 1
[RouterE-isis-1] address-family ipv4
[RouterE-isis-1-ipv4] segment-routing mpls
[RouterE-isis-1-ipv4] quit
[RouterE-isis-1] segment-routing global-block 19000 19999
[RouterE-LoopBack1] isis prefix-sid index 50
# Display LDP LSP information on Router B.
[RouterB] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 5 Ingress: 3 Transit: 3 Egress: 2
FEC In/Out Label Nexthop OutInterface
1.1.1.1/32 2173/-
-/2173(L)
2.2.2.2/32 3/-
-/2175(L)
3.3.3.3/32 -/3 11.0.0.2 GE1/2/0/2
2175/3 11.0.0.2 GE1/2/0/2
4.4.4.4/32 -/2174 11.0.0.2 GE1/2/0/2
2174/2174 11.0.0.2 GE1/2/0/2
5.5.5.5/32 -/2172 11.0.0.2 GE1/2/0/2
2172/2172 11.0.0.2 GE1/2/0/2
# Display IS-IS SRLSP information on Router B.
[RouterB] display mpls lsp protocol isis
1.1.1.1/32 ISIS 17010/3 GE1/2/0/1
1.1.1.1/32 ISIS -/3 GE1/2/0/1
2.2.2.2/32 ISIS 17020/- -
4.4.4.4/32 ISIS 17040/2174 GE1/2/0/2
4.4.4.4/32 ISIS -/2174 GE1/2/0/2
5.5.5.5/32 ISIS 17050/2172 GE1/2/0/2
5.5.5.5/32 ISIS -/2172 GE1/2/0/2
The output shows that the IS-IS SRLSP entries for Router D and Router E are using LDP outgoing labels.
Example: Configuring IS-IS TI-LFA FRR
As shown in Figure 32, complete the following tasks to implement TI-LFA FRR:
· Configure IS-IS on Device A, Device B, and Device C to achieve network level connectivity.
· Configure MPLS SR on Device A, Device B, and Device C.
· Configure TI-LFA FRR to remove the loop that exists on Link B and to implement fast traffic switchover to Link B when Link A fails.
Table 14 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Device A |
Loop1 |
1.1.1.1/32 |
Device B |
Loop1 |
2.2.2.2/32 |
GE1/2/0/1 |
12.12.12.1/24 |
GE1/2/0/1 |
24.24.24.1/24 |
GE1/2/0/2 |
13.13.13.1/24 |
GE1/2/0/2 |
13.13.13.2/24 |
Device C |
Loop1 |
3.3.3.3/32 |
GE1/2/0/1 |
12.12.12.2/24 |
GE1/2/0/2 |
24.24.24.2/24 |
1. Configure IP addresses and masks for interfaces. (Details not shown.)
2. Configure Device A:
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] quit
[DeviceA] interface gigabitethernet 1/2/0/1
[DeviceA-GigabitEthernet1/2/0/1] isis enable 1
[DeviceA-GigabitEthernet1/2/0/1] isis cost 10
[DeviceA-GigabitEthernet1/2/0/1] quit
[DeviceA] interface gigabitethernet 1/2/0/2
[DeviceA-GigabitEthernet1/2/0/2] isis enable 1
[DeviceA-GigabitEthernet1/2/0/2] isis cost 10
[DeviceA-GigabitEthernet1/2/0/2] quit
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis enable 1
[DeviceA-LoopBack1] quit
# Enable MPLS SR and MPLS SR adjacency SID allocation.
[DeviceA] isis 1
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] segment-routing mpls
[DeviceA-isis-1-ipv4] segment-routing adjacency enable
[DeviceA-isis-1-ipv4] quit
[DeviceA-isis-1] segment-routing global-block 16000 16999
[DeviceA-LoopBack1] isis prefix-sid index 10
# Configure TI-LFA FRR.
[DeviceA] isis 1
[DeviceA-isis-1-ipv4] fast-reroute lfa
[DeviceA-isis-1-ipv4] fast-reroute ti-lfa
3. Configure Device B:
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] quit
[DeviceB] interface gigabitethernet 1/2/0/1
[DeviceB-GigabitEthernet1/2/0/1] isis enable 1
[DeviceB-GigabitEthernet1/2/0/1] isis cost 20
[DeviceB-GigabitEthernet1/2/0/1] quit
[DeviceB] interface gigabitethernet 1/2/0/2
[DeviceB-GigabitEthernet1/2/0/2] isis enable 1
[DeviceB-GigabitEthernet1/2/0/2] isis cost 10
[DeviceB-GigabitEthernet1/2/0/2] quit
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis enable 1
[DeviceB-LoopBack1] quit
[DeviceB] isis 1
[DeviceB-isis-1] address-family ipv4
[DeviceB-isis-1-ipv4] segment-routing mpls
[DeviceB-isis-1-ipv4] segment-routing adjacency enable
[DeviceB-isis-1-ipv4] quit
[DeviceB-isis-1] segment-routing global-block 17000 17999
[DeviceB-LoopBack1] isis prefix-sid index 20
[DeviceB] isis 1
[DeviceB-isis-1-ipv4] fast-reroute lfa
[DeviceB-isis-1-ipv4] fast-reroute ti-lfa
4. Configure Device C:
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] quit
[DeviceC] interface gigabitethernet 1/2/0/1
[DeviceC-GigabitEthernet1/2/0/1] isis enable 1
[DeviceC-GigabitEthernet1/2/0/1] isis cost 10
[DeviceC-GigabitEthernet1/2/0/1] quit
[DeviceC] interface gigabitethernet 1/2/0/2
[DeviceC-GigabitEthernet1/2/0/2] isis enable 1
[DeviceC-GigabitEthernet1/2/0/2] isis cost 20
[DeviceC-GigabitEthernet1/2/0/2] quit
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis enable 1
[DeviceC-LoopBack1] quit
[DeviceC] isis 1
[DeviceC-isis-1] address-family ipv4
[DeviceC-isis-1-ipv4] segment-routing mpls
[DeviceC-isis-1-ipv4] segment-routing adjacency enable
[DeviceC-isis-1-ipv4] quit
[DeviceC-isis-1] segment-routing global-block 18000 18999
[DeviceC-LoopBack1] isis prefix-sid index 30
[DeviceC] isis 1
[DeviceC-isis-1-ipv4] fast-reroute lfa
[DeviceC-isis-1-ipv4] fast-reroute ti-lfa
# Display IPv4 IS-IS routing information for 2.2.2.2/32.
[DeviceA] display isis route ipv4 2.2.2.2 32 verbose level-1 1
Level-1 IPv4 Forwarding Table
IPv4 Dest : 2.2.2.2/32 Int. Cost : 10 Ext. Cost : NULL
Admin Tag : - Src Count : 1 Flag : R/L/-
InLabel : 16020 InLabel Flag: -/N/-/-/-/-
NextHop : Interface : ExitIndex :
13.13.13.2 GE1/2/0/2 0x00000103
Nib ID : 0x14000005 OutLabel : 17020 OutLabelFlag: I
LabelSrc : SR Delay Flag : N/A
TI-LFA:
Interface : GE1/2/0/1
BkNextHop : 12.12.12.2 LsIndex : 0x00000002
Backup label stack(top->bottom): {18030, 2175}
Route label: 17020
InLabel flags: R-Readvertisement, N-Node SID, P-no PHP
E-Explicit null, V-Value, L-Local
OutLabelFlags: E-Explicit null, I-Implicit null, N-Nomal, P-SR label prefer
The output shows TI-LFA backup next hop information.
