H3C Access Points Comware 7 Configuration Examples-6W100
HomeSupportResource CenterH3C Access Points Comware 7 Configuration Examples-6W100
10-H3C Access Points Comware 7 Layer 3 IPv6 Multicast Configuration Examples
H3C Access Points
Document version: 6W100-20201125
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring Layer 3 IPv6 multicast.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of Layer 3 multicast.
Example: Configuring Layer 3 IPv6 multicast
As shown in Figure 1:
·     OSPFv3 and IPv6 PIM-DM run on the network.
·     VOD streams are multicast to receiver hosts. Receiver hosts of different organizations form stub networks N1 and N2. Host A and Host C are multicast receiver hosts in N1 and N2, respectively.
·     MLDv1 runs between Router A and N1, and also between Router B and N2.
·     Router A acts as the MLD querier in N1. Router B acts as the MLD querier in N2 because it has a lower IPv6 address.
Configure the routers and the fat APs to meet the following requirements:
·     The hosts in N1 can join only IPv6 multicast group FF1E::101.
·     The hosts in N2 can join any IPv6 multicast groups.
Figure 1 Network diagram
Analysis
To implement Layer 3 IPv6 multicast, enable MLD globally and in the VLAN to which the hosts belong.
Make sure the devices on the network can reach each other.
Procedures
Configuring Router A
# Enable IPv6 multicast routing.
[RouterA-mrib6] quit
# Enable MLD on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] mld enable
# Enable IPv6 PIM-DM on GigabitEthernet 1/0/2.
[RouterA-GigabitEthernet1/0/2] ipv6 pim dm
# Configure an IPv6 multicast group policy on Router A so that the hosts connected to GigabitEthernet 1/0/2 can join only IPv6 multicast group FF1E::101.
[RouterA] acl ipv6 basic 2001
[RouterA-acl-ipv6-basic-2001] rule permit source ff1e::101 128
[RouterA-acl-ipv6-basic-2001] quit
[RouterA-GigabitEthernet1/0/2] mld group-policy 2001
Configuring Router B
<RouterB> system-view
[RouterB] ipv6 multicast routing
[RouterB-mrib6] quit
[RouterB-GigabitEthernet1/0/1] mld enable
[RouterB-GigabitEthernet1/0/2] ipv6 pim dm
Configuring fat AP 1
1.     Configure wireless services:
# Create VLAN 100.
<AP1> system-view
[AP1] Vlan 100
[AP1-vlan100] quit
# Create service template service1 and enter its view.
[AP1] wlan service-template 1
# Configure the SSID as service1.
[AP1-wlan-st-1] ssid service1
# Specify VLAN 100 for clients to access the WLAN defined by the service template.
[AP1-wlan-st-1] vlan 100
# Enable the service template.
[AP1-wlan-st-1] service-template enable
[AP1-wlan-st-1] quit
# Bind the service template to interface WLAN-Radio 1/0/1.
[AP1] interface WLAN-Radio 1/0/1
[AP1-WLAN-Radio1/0/1] service-template 1
[AP1-WLAN-Radio1/0/1] quit
2.     Configure MLD:
# Enable MLD globally.
[AP1] mld
[AP1-mld] quit
# Enable MLD on VLAN 100.
[AP1] vlan 100
[AP1-vlan100] mld enable
[AP1-vlan100] quit
3.     Configure GigabitEthernet 1/0/1 on the AP as a trunk port, and assign the port to VLAN 100.
[AP1] interface GigabitEthernet 1/0/1
[AP1-GigabitEthernet1/0/1] port link-type trunk
[AP1-GigabitEthernet1/0/1] port trunk permit vlan 100
[AP1-GigabitEthernet1/0/1] quit
Configuring fat AP 2
# Create VLAN 100.
<AP2> system-view
[AP2] Vlan 100
[AP2-vlan100] quit
# Create service template service2 and enter its view.
[AP2] wlan service-template 2
# Configure the SSID as service2.
[AP2-wlan-st-1] ssid service2
[AP2-wlan-st-1] vlan 100
[AP2-wlan-st-1] service-template enable
[AP2-wlan-st-1] quit
[AP2] interface WLAN-Radio 1/0/1
[AP2-WLAN-Radio1/0/1] service-template 2
[AP2-WLAN-Radio1/0/1] quit
2.     Configure MLD:
[AP] mld
[AP2-mld] quit
[AP2] vlan 100
[AP2-vlan100] mld enable
[AP2-vlan100] quit
[AP2] interface GigabitEthernet 1/0/1
[AP2-GigabitEthernet1/0/1] port link-type trunk
[AP2-GigabitEthernet1/0/1] port trunk permit vlan 100
[AP2-GigabitEthernet1/0/1] quit
# Display MLD information for VLAN-interface 200 on fat AP 2.
[AP2] display mld interface
 (FE80::200:5EFF:FE66:5100):
   MLD is enabled.
   MLD version: 1
   Query interval for MLD: 125s
   Other querier present time for MLD: 255s
   Maximum query response time for MLD: 10s
   Querier for MLD: FE80::200:5EFF:FE66:5100 (this router)
  MLD groups reported in total: 1
Configuration files
·     Router A:
 mld enable
 ipv6 pim dm
acl ipv6 basic 2001
interface
·     Router B:
 mld enable
 ipv6 pim dm
·     Fat AP 1:
vlan 100
 ssid service1
 vlan 100
 service-template 1
mld
vlan 100
 mld enable
·     Fat AP 2:
vlan 100
 ssid service2
 vlan 100
 service-template 2
mld
vlan 100
 mld enable
Related documentation
·     IP Multicast Command Reference in H3C Access Points Command References
·     IP Multicast Configuration Guide in H3C Access Points Configuration Guides
·     WLAN Command Reference in H3C Access Points Command References
·     WLAN Configuration Guide in H3C Access Points Configuration Guides
