- H3C Access Points Comware 7 Configuration Examples-6W100
- 01-H3C Access Points Comware 7 WPA2-PSK Encryption Configuration Examples
- 02-H3C Access Points Comware 7 Client Rate Limiting Configuration Examples
- 03-H3C Access Points Comware 7 NAT Configuration Examples
- 04-H3C Access Points Comware 7 PPPoE Configuration Examples
- 05-H3C Access Points Comware 7 Mesh WDS Configuration Examples
- 06-H3C Access Points Comware 7 Local MAC Authentication (IPv6) Configuration Examples
- 07-H3C Access Points Comware 7 IPv6 Configuration Examples
- 08-H3C Access Points Comware 7 Remote 802.1X Authentication (IPv6) Configuration Examples
- 09-H3C Access Points Comware 7 Layer 2 IPv6 Multicast Configuration Examples
- 10-H3C Access Points Comware 7 Layer 3 IPv6 Multicast Configuration Examples
09-H3C Access Points Comware 7 Layer 2 IPv6 Multicast Configuration Examples | 154.17 KB |
H3C Access Points |
Comware 7 Layer 2 IPv6 Multicast |
Document version: 6W100-20201125
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring Layer 2 IPv6 multicast.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of Layer 2 multicast.
Example: Configuring Layer 2 IPv6 multicast
As shown in Figure 1:
· The source sends IPv6 multicast traffic to IPv6 multicast group FF1E::1.
· The client is a receiver host of the IPv6 multicast group.
· The source and the client can reach each other.
Configure Layer 2 IPv6 multicast on the fat AP so that the client can receive the IPv6 multicast traffic from the source.
Analysis
To implement Layer 2 IPv6 multicast, enable MLD snooping globally and in the VLAN to which the client belongs.
Make sure the devices on the network can reach each other.
Procedures
Configuring the router
# Enable IP multicast routing.
[RouterA-mrib] quit
# Enable IPv6 PIM-DM on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] pim ipv6 dm
# Enable MLD on GigabitEthernet 1/0/2.
[RouterA-GigabitEthernet1/0/2] mld enable
Configuring the fat AP
1. Configure wireless services:
# Create VLAN 100.
<AP> system-view
[AP] Vlan 100
[AP-vlan100] quit
# Create service template service1 and enter its view.
[AP] wlan service-template 1
# Configure the SSID as service.
[AP-wlan-st-1] ssid service
# Specify VLAN 100 for clients to access the WLAN defined by the service template.
[AP-wlan-st-1] vlan 100
# Enable the service template.
[AP-wlan-st-1] service-template enable
[AP-wlan-st-1] quit
# Bind the service template to interface WLAN-Radio 1/0/1.
[AP] interface WLAN-Radio 1/0/1
[AP-WLAN-Radio1/0/1] service-template 1
[AP-WLAN-Radio1/0/1] quit
2. Configure MLD snooping:
# Enable MLD snooping globally.
[AP] mld-snooping
[AP-mld-snooping] quit
# Enable MLD snooping on VLAN 100.
[AP] vlan 100
[AP-vlan100] mld-snooping enable
[AP-vlan100] quit
3. Configure GigabitEthernet 1/0/1 on the AP as a trunk port, and assign the port to VLAN 100.
[AP] interface GigabitEthernet 1/0/1
[AP-GigabitEthernet1/0/1] port link-type trunk
[AP-GigabitEthernet1/0/1] port trunk permit vlan 100
[AP-GigabitEthernet1/0/1] quit
4. Configure the client to access the WLAN service with the SSID service and request multicast traffic for IPv6 multicast group FF1E::1. (Details not shown.)
# Display detailed information about dynamic MLD snooping group entries for VLAN 100 on the AP.
[AP]display mld-snooping group vlan 100 verbose
Total 1 entries.
VLAN 100: Total 1 entries.
(::,FF1E::101)
Attribute: local port
FSM information: normal
Host slots (0 in total):
Host ports (1 in total):
WLAN-BSS1/0/20 (00:03:23)
The output shows that WLAN-BSS 1/0/20 on the AP has joined the IPv6 multicast group FF1E::1.
Configuration files
· Router:
pim ipv6 dm
mld enable
· Fat AP:
vlan 100
ssid service
vlan 100
service-template 1
mld-snooping
vlan 100
mld-snooping enable
Related documentation
· IP Multicast Command Reference in H3C Access Points Command References
· IP Multicast Configuration Guide in H3C Access Points Configuration Guides
· WLAN Command Reference in H3C Access Points Command References
· WLAN Configuration Guide in H3C Access Points Configuration Guides
