H3C Access Points Comware 7 Configuration Examples-6W100
HomeSupportResource CenterH3C Access Points Comware 7 Configuration Examples-6W100
03-H3C Access Points Comware 7 NAT Configuration Examples
H3C Access Points
Document version: 6W100-20201125
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring NAT.
This document applies to Comware 7-based fat APs. Procedures and information in the examples might be slightly different depending on the software or hardware version of the fat APs.
This document assumes that you have basic knowledge of NAT.
Example: Configuring NAT
As shown in Figure 1, the wireless clients access the network through the fat AP. The fat AP obtains an IP address through a DHCP server in the IP network.
To allow the internal wireless clients to access the external network, it is required to perform the following configuration:
·     Configure the fat AP to act as the DHCP server to assign IP addresses to the wireless clients.
·     Configure outbound NAT on the fat AP to perform address translation for wireless clients.
Figure 1 Network diagram
By default, the device uses the default service template (template 1) with SSID H3C to provide wireless services. To use user-defined wireless service settings, disable or delete the default service template. In this example, the service template is disabled.
Procedures
Configuring fat AP
1.     Configure VLANs and VLAN interfaces on the fat AP:
# Create VLAN 100 and VLAN interface, and assign an IP address to the VLAN interface.
<FAT AP> system-view
[FAT AP] vlan 100
[FAT AP-vlan100] quit
[FAT AP] interface vlan-interface 100
[FAT AP-Vlan-interface100] ip address 192.1.0.1 24
[FAT AP-Vlan-interface100] quit
# Configure the upstream interface VLAN-interface 1 to obtain an IP address through DHCP.
[FAT AP-Vlan-interface1] undo ip address
[FAT AP-Vlan-interface1] ip address dhcp-alloc
[FAT AP-Vlan-interface1] quit
2.     Configure the wireless service template:
# Enter the view of service template 1 and disable the template.
[FAT AP] wlan service-template 1
[FAT AP-wlan-st-1] undo service-template enable
[FAT AP-wlan-st-1] quit
# Create service template service and enter its view.
[FAT AP] wlan service-template service
# Configure service as the SSID.
[FAT AP-wlan-st-service] ssid service
# Assign clients coming online through service template 100 to VLAN 100.
[FAT AP-wlan-st-service] vlan 100
# Enable the service template.
[FAT AP-wlan-st-service] service-template enable
[FAT AP-wlan-st-service] quit
# Enter interface view of WLAN-Radio 1/0/1.
[FAT AP] interface wlan-radio 1/0/1
# Bind service template service to interface WLAN-Radio 1/0/1.
[FAT AP-WLAN-Radio1/0/1] service-template service
[FAT AP-WLAN-Radio1/0/1] quit
3.     Configure the DHCP server:
# Configure DHCP address pool 100 for address allocation to the wireless clients.
[FAT AP] dhcp server ip-pool 100
[FAT AP-dhcp-pool-100] network 192.1.0.0 mask 255.255.255.0
[FAT AP-dhcp-pool-100] gateway-list 192.1.0.1
[FAT AP-dhcp-pool-100] quit
# Enable the DHCP service.
[FAT AP] dhcp enable
4.     Configure NAT:
# Configure ACL 2000 to identify packets source from 192.1.0.0.
[FAT AP] acl basic 2000
[FAT AP-acl-ipv4-basic-2000] rule 0 permit source 192.1.0.0 0.0.0.255
[FAT AP-acl-ipv4-basic-2000] quit
# Configure an outbound dynamic PAT rule on VLAN-interface 1 to translate the source IP addresses permitted by ACL 2000
[FAT AP-Vlan-interface1] nat outbound 2000
# Display client information on the fat AP.
[FAT AP] display wlan client
Total number of clients: 1
MAC address    User name         AP name               RID  IP address      VLAN
bc6c-2213-7cb7 N/A               fatap                 1    192.1.0.2       100
# Verify that VLAN-interface 1 has obtained an IP address through DHCP.
[FAT AP] display dhcp client interface vlan-interface 1
Vlan-interface1 DHCP client information:
  Current state: BOUND
  Allocated IP: 2.2.2.2 255.255.255.0
  Allocated lease: 86400 seconds, T1: 36532 seconds, T2: 75600 seconds
  DHCP server: 2.2.2.1
# Ping the DHCP server at 2.2.2.1 from a client. On the fat AP, display NAT session information.
 [FAT AP] display nat session verbose
Initiator:
  Source      IP/port: 192.1.0.2/768
  Destination IP/port: 2.2.2.1/2048
  DS-Lite tunnel peer: -
  Protocol: ICMP(1)
  Inbound interface: Vlan-interface100
Responder:
  Source      IP/port: 2.2.2.1/1
  Destination IP/port: 2.2.2.2/0
  Protocol: ICMP(1)
State: ICMP_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Start time: 2016-01-01 05:27:35  TTL: 7s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 1
Configuration files
 sysname FAT AP
 dhcp enable
vlan 1
vlan 100
 ssid H3C
 ssid service
 vlan 100
interface Vlan-interface1
 nat outbound 2000
interface Vlan-interface100
 ip address 192.1.0.1 255.255.255.0
interface WLAN-Radio1/0/1
 service-template 1
interface WLAN-Radio1/0/2
 service-template 1
interface WLAN-Radio1/0/3
 service-template 1
acl basic 2000
return
Related documentation
·     Network Connectivity Command Reference in H3C Access Points Configuration Guides
·     Network Connectivity Configuration Guide in H3C Access Points Configuration Guides
·     WLAN Access Command Reference in H3C Access Points Configuration Guides
·     WLAN Access Configuration Guide in H3C Access Points Configuration Guides
