02-Layer 2-LAN Switching Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10102-Layer 2-LAN Switching Command Reference
08-BPDU tunneling configuration commands
08-BPDU tunneling configuration commands 56.19 KB
bpdu-tunnel dot1q
Use bpdu-tunnel dot1q to enable BPDU tunneling for a protocol on the ports.
Use undo bpdu-tunnel dot1q to disable BPDU tunneling for a protocol on the ports.
In Layer 2 Ethernet interface view or port group view:
bpdu-tunnel dot1q { cdp | dldp | eoam | gvrp | hgmp | lacp | lldp | pagp | pvst | stp | udld | vtp }
undo bpdu-tunnel dot1q { cdp | dldp | eoam | gvrp | hgmp | lacp | lldp | pagp | pvst | stp | udld | vtp }
In Layer 2 aggregate interface view:
bpdu-tunnel dot1q { cdp | gvrp | hgmp | pvst | stp | vtp }
undo bpdu-tunnel dot1q { cdp | gvrp | hgmp | pvst | stp | vtp }
BPDU tunneling for any protocol is disabled.
Layer 2 Ethernet interface view, port group view, Layer 2 aggregate interface view
Default command level
2: System level
cdp: Specifies CDP.
dldp: Specifies DLDP.
eoam: Specifies EOAM.
gvrp: Specifies GVRP.
hgmp: Specifies HGMP.
lacp: Specifies LACP.
lldp: Specifies LLDP.
pagp: Specifies PAGP.
pvst: Specifies PVST.
stp: Specifies STP.
udld: Specifies UDLD.
vtp: Specifies VTP.
Settings made in Layer 2 Ethernet interface view or Layer 2 aggregate interface view take effect only on the Ethernet interface or aggregate interface.
Settings made in port group view take effect on all member ports in the port group.
You cannot enable BPDU tunneling on a member port of a service loopback group.
Before you enable BPDU tunneling for DLDP, EOAM, GVRP, HGMP, LLDP, or STP on a port, disable the protocol on the port first.
To enable BPDU tunneling for PVST (a spanning tree protocol) on a port, disable STP first, and then enable BPDU tunneling for STP on the port.
Do not enable BPDU tunneling for DLDP, EOAM, LACP, LLDP, PAGP, or UDLD on the member port of a Layer 2 aggregation group.
# Disable STP on GigabitEthernet 1/0/1, and then enable BPDU tunneling for STP on the port.
[Sysname-GigabitEthernet1/0/1] undo stp enable
[Sysname-GigabitEthernet1/0/1] bpdu-tunnel dot1q stp
# Disable STP for port group 1, and then enable BPDU tunneling for STP in the port group.
[Sysname] port-group manual 1
[Sysname-port-group-manual-1] group-member gigabitethernet 1/0/1 to gigabitethernet 1/0/6
[Sysname-port-group-manual-1] undo stp enable
[Sysname-port-group-manual-1] bpdu-tunnel dot1q stp
# Disable STP on Layer 2 aggregate interface Bridge-Aggregation 1, and then enable BPDU tunneling for STP on the Layer 2 aggregate interface.
[Sysname-Bridge-Aggregation1] undo stp enable
[Sysname-Bridge-Aggregation1] bpdu-tunnel dot1q stp
bpdu-tunnel tunnel-dmac
Use bpdu-tunnel tunnel-dmac to configure the destination multicast MAC address for BPDUs.
Use undo bpdu-tunnel tunnel-dmac to restore the default value.
bpdu-tunnel tunnel-dmac mac-address
The destination multicast MAC address for BPDUs is 0x010F-E200-0003.
2: System level
mac-address: Specifies a destination multicast MAC address for BPDUs in the format of H-H-H. The allowed values are 0x0100-0CCD-CDD0, 0x0100-0CCD-CDD1, 0x0100-0CCD-CDD2, and 0x010F-E200-0003.
# Set the destination multicast MAC address for BPDUs to 0x0100-0CCD-CDD0.
[Sysname] bpdu-tunnel tunnel-dmac 0100-0ccd-cdd0
