02-Layer 2-LAN Switching Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10102-Layer 2-LAN Switching Command Reference
11-LLDP configuration commands
11-LLDP configuration commands 157.43 KB
display lldp local-information
Use display lldp local-information to display the LLDP information to be sent. This information, contained in the LLDP TLVs, is sent to neighbor devices.
display lldp local-information [ global | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
global: Displays the global LLDP information to be sent.
interface interface-type interface-number: Displays the LLDP information to be sent out of the interface specified by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no keyword or argument is specified, this command displays all LLDP information to be sent. This information includes the global LLDP information and the LLDP information about the LLDP-enabled ports in up state.
# Display all LLDP information to be sent.
<Sysname> display lldp local-information
  Chassis ID         : 00e0-fc00-5800
  System name        : WX5540E_LSW
  System description : H3C Comware Platform Software, Software Version 5.20, Alp
ha 2607P01 H3C WX5540E-LSW Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
  System capabilities supported : Bridge,Router
  System capabilities enabled   : Bridge,Router
  MED information
  Device class: Connectivity device
  (MED inventory information of master board)
  HardwareRev               : Ver.A
  FirmwareRev               : 1.01
  SoftwareRev               : V200R006B09D011
  SerialNum                 : DPPMWWB123456
  Manufacturer name         : H3C
  Model name                : H3C WX5540E-LSW
  Asset tracking identifier : Unknown
LLDP local-information of port 1[GigabitEthernet1/0/1]:
  Port ID subtype  : Interface name
  Port ID          : GigabitEthernet1/0/1
  Port description : GigabitEthernet1/0/1 Interface
  Management address type           : ipv4
  Management address                : 192.168.11.55
  Management address interface ID   : 35
  Management address OID            : 0
  Port VLAN ID(PVID): 1
  Port and protocol VLAN ID(PPVID) : 0
  Port and protocol VLAN supported : Yes
  Port and protocol VLAN enabled   : No
  VLAN name of VLAN 1: VLAN 0001
  Auto-negotiation enabled   : Yes
  OperMau                    : speed(100)/duplex(Full)
  PoE supported: No
  Link aggregation enabled   : No
  Aggregation port ID        : 0
  Maximum frame Size: 10000
  MED information
  Media policy type        : Unknown
  Unknown Policy           : Yes
  VLAN tagged              : No
  Media policy VlanID      : 0
  Media policy L2 priority : 0
  Media policy Dscp        : 0
LLDP local-information of port 29[Ten-GigabitEthernet1/0/29]:
  Port ID          : Ten-GigabitEthernet1/0/29
  Port description : Ten-GigabitEthernet1/0/29 Interface
  OperMau                    : speed(10000)/duplex(Full)
  PoE supported: No
  Link aggregation enabled   : Yes
  Aggregation port ID        : 31
  MED information
  VLAN tagged              : No
LLDP local-information of port 30[Ten-GigabitEthernet1/0/30]:
  Port ID          : Ten-GigabitEthernet1/0/30
  Port description : Ten-GigabitEthernet1/0/30 Interface
  PoE supported: No
  Aggregation port ID        : 32
  MED information
  VLAN tagged              : No
LLDP local-information of port 31[Ten-GigabitEthernet1/0/31]:
  Port ID          : Ten-GigabitEthernet1/0/31
  Port description : Ten-GigabitEthernet1/0/31 Interface
  PoE supported: No
  Aggregation port ID        : 33
  MED information
  VLAN tagged              : No
LLDP local-information of port 32[Ten-GigabitEthernet1/0/32]:
  Port ID          : Ten-GigabitEthernet1/0/32
  Port description : Ten-GigabitEthernet1/0/32 Interface
  PoE supported: No
  Aggregation port ID        : 34
  MED information
  VLAN tagged              : No
Global LLDP information to be sent.
Chassis ID
Bridge MAC address of the device.
Supported capabilities:
·       Bridge—Switching is supported.
·       Router—Routing is supported.
Enabled capabilities:
·       Bridge—Switching is enabled.
·       Router—Routing is enabled.
Device class
MED device class:
·       Connectivity device—Network device.
·       Class I—Normal terminal device. It requires the basic LLDP discovery services.
·       Class II—Media terminal device. It supports media streams and can also function as a normal terminal device.
·       Class III—Communication terminal device. It supports the IP communication systems of end users and can also function as a normal terminal device or media terminal device.
MED asset information of the main processing unit.
HardwareRev
Hardware version.
FirmwareRev
Firmware version.
SoftwareRev
Software version.
SerialNum
Serial number.
Manufacturer name
Device manufacturer.
Model name
Device model.
LLDP information to be sent out of port 1.
Port ID subtype
Port ID type: MAC address or interface name.
Port ID
Port ID, the value of which depends on the port ID subtype.
Numbering type of the interface identified by the management address.
Index of the interface identified by the management address.
Management address object ID.
Port protocol VLAN ID.
Indicates whether protocol VLAN is supported on the port.
Indicates whether protocol VLAN is enabled on the port.
VLAN name of VLAN 1
Name of VLAN 1.
Indicates whether auto-negotiation is supported on the port.
Indicates whether auto-negotiation is enabled on the port.
OperMau
Speed and duplex state of the port.
PoE supported
Indicates whether PoE is supported on the port. The WX5540E switch engine does not support PoE.
Indicates whether link aggregation is supported.
Indicates whether link aggregation is enabled.
Aggregation port ID
Aggregation group ID, which is 0 when link aggregation is disabled.
MED information
MED LLDP information.
Media policy type
Media policy type:
·       unknown.
·       voice.
·       voiceSignaling.
·       guestVoice.
·       guestVoiceSignaling.
·       softPhoneVoice.
·       videoconferencing.
·       streamingVideo.
·       videoSignaling.
Unknown Policy
Indicates whether the media policy is unknown.
VLAN tagged
Indicates whether packets of the media VLAN are tagged.
Media Policy VlanID
ID of the media VLAN.
Media Policy L2 priority
Layer 2 priority.
Media Policy Dscp
DSCP precedence.
display lldp neighbor-information
Use display lldp neighbor-information to display the LLDP information carried in LLDP TLVs sent from the neighboring devices.
display lldp neighbor-information [ brief | interface interface-type interface-number [ brief ] | list [ system-name system-name ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
brief: Displays the summary of LLDP information sent from the neighboring devices. If this keyword is not specified, this command displays detailed LLDP information sent from the neighboring devices.
interface interface-type interface-number: Displays the LLDP information sent from the neighboring devices received through a port specified by its type and number. If this option is not specified, this command displays the LLDP information sent from the neighboring devices received through all ports.
list: Displays the LLDP information sent from the neighboring devices in the form of a list.
system-name system-name: Displays the LLDP information sent from a neighboring device specified by its system name. The system-name argument is a character string of 1 to 255 characters. If this option is not specified, this command displays the LLDP information sent from all neighboring devices in a list.
After the device is enabled with CDP compatibility, this command can display CDP information sent from CDP neighbors.
# Display the LLDP information sent from the neighboring devices received through all ports.
<Sysname> display lldp neighbor-information
LLDP neighbor-information of port 12[GigabitEthernet1/0/12]:
  Neighbor index   : 1
  Update time      : 7 days,16 hours,22 minutes,38 seconds
  Chassis type     : MAC address
  Chassis ID       : 00e0-fc00-3623
  Port ID type     : Interface name
  System name        : H3C
  System description : H3C Switch WX3024E-LSW Software Version 5.20, Release 3308P22
Copyright(c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
  Management address                : 140.100.1.100
  Management address interface ID   : 33
  OperMau                    : speed(1000)/duplex(Full)
  Power port class          : PSE
  PSE power supported       : Yes
  PSE power enabled         : Yes
  PSE pairs control ability : No
  Power pairs               : Signal
  Port power classification : Class 0
  Maximum frame Size: 10240
# Display the LLDP information sent from all neighboring devices in a list.
System Name          Local Interface   Chassis ID      Port ID
System1              GE1/0/1           000f-e25d-ee91  GigabitEthernet1/0/5
System2              GE1/0/2           000f-e25d-ee92  GigabitEthernet1/0/6
System3              GE1/0/3           000f-e25d-ee93  GigabitEthernet1/0/7
Information about LLDP neighbors:
LLDP information received through port 1.
Neighbor index
Index of the LLDP neighboring device.
Update time
Time when LLDP information about a neighboring device was last updated.
Chassis type
Chassis ID type of the LLDP neighboring device:
·       Chassis component.
·       Interface alias.
·       Port component.
·       MAC address.
·       Network address (ipv4).
·       Interface name.
·       Locally assigned—Locally-defined chassis type other than those listed above.
Chassis ID
Chassis ID of the LLDP neighboring device, whose value type is the chassis ID type.
Port ID type
ID type of the port that connects the LLDP neighboring device to the local device:
·       Interface alias.
·       Port component.
·       MAC address.
·       Interface name.
·       Agent circuit ID.
·       Locally assigned—Locally-defined port ID type other than those listed above.
Port ID
ID of the port that connects the LLDP neighboring device to the local device, whose type is the port ID type.
Port description
Description of the port that connects the LLDP neighboring device to the local device.
System name
System name of the LLDP neighboring device.
If the system name of a neighboring device cannot be identified by the local device, this field displays a hyphen (-). In this case, you cannot display information about the neighboring device by using the display lldp neighbor-information list system-name system-name command.
System description
System description of the LLDP neighboring device.
Capabilities supported on the LLDP neighboring device:
·       Repeater—Signal repeating is supported.
Capabilities enabled on the LLDP neighboring device:
·       Repeater—Signal repeating is enabled.
Management address type of the port that connects the LLDP neighboring device to the local device.
Management address
Management address of the port that connects the LLDP neighboring device to the local device.
Management address interface type of the port that connects the LLDP neighboring device to the local device.
Management address interface ID of the port that connects the LLDP neighboring device to the local device.
Management address object ID of the port that connects the LLDP neighboring device to the local device.
Port VLAN ID
Port VLAN ID of the port that connects the LLDP neighboring device to the local device.
Port protocol VLAN ID of the port that connects the LLDP neighboring device to the local device.
Indicates whether protocol VLAN is supported on the port that connects the LLDP neighboring device to the local device.
Indicates whether protocol VLAN is enabled on the port that connects the LLDP neighboring device to the local device.
VLAN name of VLAN 1
Name of VLAN 1.
Indicates whether auto-negotiation is supported on the port that connects the LLDP neighboring device to the local device.
Indicates whether auto-negotiation is enabled on the port that connects the LLDP neighboring device to the local device.
OperMau
Speed and duplex state on the port that connects the LLDP neighboring device to the local device.
Power port class
PoE device type of the LLDP neighboring device:
·       PSE—The LLDP neighboring device is a PSE device.
·       PD—The LLDP neighboring device is a powered device (a PD device or non-PSE device).
PSE power supported
Indicates whether the LLDP neighboring device can operate as a PSE device.
PSE power enabled
Indicates whether the LLDP neighboring device is operating as a PSE device.
Indicates whether the PSE-PD pair control is available on the LLDP neighboring device.
Power pairs
PoE mode of the LLDP neighboring device:
·       Signal—PoE via signal lines.
·       Spare—PoE via spare lines.
Port power classification of the PD of the LLDP neighboring device:
·       Class 0.
·       Class 1.
·       Class 2.
·       Class 3.
·       Class 4.
Indicates whether link aggregation is supported on the port that connects the LLDP neighboring device to the local device.
Aggregation port ID
Maximum frame size
Maximum frame size of the port that connects the LLDP neighboring device to the local device.
Location format
Location information format of the neighboring device which is a communication terminal with the MED device type being Class III, for example, an IP phone:
·       Invalid—The format of the location information is invalid.
·       Coordinate-based LCI—The location information is coordinate-based.
·       Civic Address LCI—Typical address information.
·       ECS ELIN—Telephone for urgencies.
Location information of the neighboring device which is a communication terminal with the MED device type being Class III, for example, an IP phone.
PoE PSE power source
PSE power type of an LLDP neighboring device which is a PSE device:
·       Unknown—Unknown power supply.
·       Primary—Primary power supply.
·       Backup—Backup power supply.
PoE PD power source
PD power type of an LLDP neighboring device which is a PD device:
·       PSE—PSE power supply.
·       Local—Local power supply.
·       PSE and local—PSE and local power supplies.
Port PSE Priority
PoE power supply priority of ports on an LLDP neighboring device which is a PSE device:
·       Unknown.
·       Critical.
·       High.
·       Low.
Port PD Priority
PoE power receiving priority of ports on an LLDP neighboring device which is a PD device:
·       Unknown.
·       Critical.
·       High.
·       Low.
Port available power value
·       Power supplied to the port when the LLDP neighboring device is a PSE device, in watts.
·       Power supplied by the port when the LLDP neighboring device is a PD device, in watts.
TLV type
This field appears only when the device receives unknown basic TLVs.
Unknown basic TLV type.
TLV information
Information contained in the unknown basic TLV type.
Unknown organizationally-defined TLV
This field appears only when the device receives unknown organizationally specific TLVs.
Unknown organizationally specific TLV.
TLV OUI
OUI of the unknown organizationally specific TLV.
TLV subtype
Unknown organizationally specific TLV subtype.
Index
Unknown organization index.
TLV information
Information contained in unknown organizationally specific TLV.
Local Interface
Local port that receives the LLDP information.
Information about CDP neighbors:
CDP neighbor-information of port 2
CDP information received through port 2.
CDP neighbor index
Index of the CDP neighboring device.
Chassis ID
Name of the CDP neighboring device.
Address
IPv4 address of the port that connects the CDP neighboring device to the local device.
Port ID
ID of the port that connects the CDP neighboring device to the local device.
Software version
Software version of the CDP neighboring device.
Platform
Model of the CDP neighboring device.
Duplex
Duplex state of the port that connects the CDP neighboring device to the local device.
display lldp statistics
Use display lldp statistics to display the global LLDP statistics or the LLDP statistics of a port.
display lldp statistics [ global | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
global: Displays the global LLDP statistics.
interface interface-type interface-number: Specifies a port by its type and number.
If no keyword or argument is specified, this command displays the global LLDP statistics and the LLDP statistics of all ports.
# Display the global LLDP statistics and the LLDP statistics of all ports.
LLDP statistics global Information:
LLDP neighbor information last change time:0 days,0 hours,4 minutes,40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
Detailed terminal display is not shown.
LLDP statistics global information
Global LLDP statistics.
Time the neighbor information was last updated.
Number of times of adding neighbor information.
Number of times of removing neighbor information.
Number of times of dropping neighbor information due to lack of available memory space.
display lldp status
Use display lldp status to display LLDP status information of a port.
display lldp status [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If no port is specified, this command displays the global LLDP status and the LLDP status information for all ports.
# Display the global LLDP status and the LLDP status information of all ports.
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
LLDP neighbor information last changed time: 0 days,0 hours,4 minutes,40 seconds
Transmit interval              : 30s
Hold multiplier                : 4
Reinit delay                   : 2s
Transmit delay                 : 2s
Trap interval                  : 5s
Fast start times               : 3
Port 1 [GigabitEthernet1/0/1]:
Port status of LLDP            : Enable
Admin status                   : Tx_Rx
Trap flag                      : No
Polling interval               : 0s
Number of neighbors            : 0
Number of MED neighbors        : 0
Number of CDP neighbors        : 0
Number of sent optional TLV    : 23
Number of received unknown TLV : 0
Indicates whether LLDP is globally enabled.
Time when the neighbor information was last updated.
Transmit interval
LLDPDU transmit interval.
Hold multiplier
TTL multiplier.
Reinit delay
LLDP re-initialization delay.
Transmit delay
LLDPDU transmit delay.
Trap interval
Trap transmit interval.
Fast start times
Number of LLDPDUs sent each time fast LLDPDU transmission is triggered.
Port 1
LLDP status of port 1.
Port status of LLDP
Indicates whether LLDP is enabled on the port.
Admin status
LLDP mode of the port:
·       TxRx—The port sends and receives LLDPDUs.
·       Rx_Only—The port only receives LLDPDUs.
·       Tx_Only—The port only sends LLDPDUs.
·       Disable—The port does not send or receive LLDPDUs.
Trap Flag
Indicates whether trapping is enabled.
Polling interval
LLDP polling interval, which is 0 when LLDP polling is disabled.
Number of neighbors
Number of LLDP neighbors connecting to the port.
Number of MED neighbors connecting to the port.
Number of CDP neighbors connecting to the port.
Number of optional TLVs contained in an LLDPDU sent through the port.
Number of unknown TLVs contained in all received LLDPDUs.
display lldp tlv-config
Use display lldp tlv-config to display the types of advertisable optional LLDP TLVs of a port.
display lldp tlv-config [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If no port is specified, this command displays the types of advertisable optional TLVs of each port.
# Display the types of advertisable optional LLDP TLVs of interface GigabitEthernet 1/0/1.
<Sysname> display lldp tlv-config interface gigabitethernet 1/0/1
LLDP tlv-config of port 1[GigabitEthernet1/0/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
Port Description TLV              YES       YES
System Name TLV                   YES       YES
System Description TLV            YES       YES
System Capabilities TLV           YES       YES
Management Address TLV            YES       YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV                  YES       YES
Port And Protocol VLAN ID TLV     YES       YES
VLAN Name TLV                     YES       YES
IEEE 802.3 extend TLV:
MAC-Physic TLV                    YES       YES
Power via MDI TLV                 YES       YES
Link Aggregation TLV              YES       YES
Maximum Frame Size TLV            YES       YES
LLDP-MED extend TLV:
Network Policy TLV                YES        YES
Location Identification TLV       NO         NO
Extended Power via MDI TLV        YES        YES
Inventory TLV                     YES        YES
Table 5 Command output
Advertisable optional TLVs of port 1.
NAME
TLV type.
STATUS
Indicates whether a specific type of TLV is sent through a port.
DEFAULT
Indicates whether a specific type of TLV is sent through a port by default.
Basic optional TLV
Basic TLVs:
·       Port description TLV.
·       System name TLV.
·       System description TLV.
·       System capabilities TLV.
·       Management address TLV.
IEEE 802.1 extended TLV
IEEE 802.1 organizationally specific TLVs:
·       Port VLAN ID TLV.
·       Port and protocol VLAN ID TLV.
·       VLAN name TLV.
IEEE 802.3 extended TLV
IEEE 802.3 organizationally specific TLVs:
·       MAC-Physic TLV.
·       Power via MDI TLV.
·       Link aggregation TLV.
·       Maximum frame size TLV.
LLDP-MED extend TLV
LLDP-MED TLVs:
·       Capabilities TLV.
·       Network Policy TLV.
·       Extended Power-via-MDI TLV.
·       Location Identification TLV.
·       Inventory TLV: hardware revision TLV, firmware revision TLV, software revision TLV, serial number TLV, manufacturer name TLV, model name TLV, and asset ID TLV.
lldp admin-status
Use lldp admin-status to specify the LLDP operating mode for a port or all ports in a port group.
Use undo lldp admin-status to restore the default LLDP operating mode.
lldp admin-status { disable | rx | tx | txrx }
The LLDP operating mode is TxRx.
Layer 2 Ethernet interface view, port group view
2: System level
disable: Specifies the Disable mode. A port in this mode does not send or receive LLDPDUs.
rx: Specifies the Rx mode. A port in this mode only receives LLDPDUs.
tx: Specifies the Tx mode. A port in this mode only sends LLDPDUs.
txrx: Specifies the TxRx mode. A port in this mode sends and receives LLDPDUs.
# Configure the LLDP operating mode as Rx for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp admin-status rx
lldp check-change-interval
Use lldp check-change-interval to enable LLDP polling and to set the polling interval.
Use undo lldp check-change-interval to restore the default.
lldp check-change-interval interval
2: System level
interval: Sets the LLDP polling interval, ranging from 1 to 30 seconds.
# Enable LLDP polling on GigabitEthernet 1/0/1, setting the polling interval to 30 seconds.
[Sysname-GigabitEthernet1/0/1] lldp check-change-interval 30
lldp compliance admin-status cdp
Use lldp compliance admin-status cdp to configure the operating mode of CDP-compatible LLDP on a port or all ports in a port group.
Use undo lldp compliance admin-status cdp to restore the default.
lldp compliance admin-status cdp { disable | txrx }
CDP-compatible LLDP operates in disable mode.
2: System level
disable: Specifies the disable mode, where CDP-compatible LLDP cannot receive or transmit CDP packets.
txrx: Specifies the TxRx mode, where CDP-compatible LLDP can send and receive CDP packets.
For your device to work with Cisco IP phones, you must enable CDP-compatible LLDP globally, and then configure CDP-compatible LLDP to operate in TxRx mode on the specified ports.
# Configure CDP-compatible LLDP to operate in TxRx mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp compliance admin-status cdp txrx
lldp compliance cdp
lldp compliance cdp
Use lldp compliance cdp to enable global CDP compatibility.
Use undo lldp compliance cdp to restore the default.
lldp compliance cdp
CDP compatibility is globally disabled.
2: System level
Because the maximum TTL allowed by CDP is 255 seconds, the TTL configuration must be no more than 255 seconds for CDP-compatible LLDP to operate with Cisco IP phones. The TTL configuration is the product of the TTL multiplier and the LLDPDU transmit interval.
# Enable LLDP to be compatible with CDP globally.
[Sysname] lldp compliance cdp
·           lldp hold-multiplier
·           lldp timer tx-interval
lldp enable
Use lldp enable to enable LLDP.
Use undo lldp enable to disable LLDP.
lldp enable
undo lldp enable
LLDP is enabled both globally and on ports.
System view, Layer 2 Ethernet interface view, port group view
2: System level
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
# Disable LLDP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo lldp enable
lldp encapsulation snap
Use lldp encapsulation snap to configure the encapsulation format for LLDPDUs as SNAP on a port or a group of ports.
Use undo lldp encapsulation to restore the default encapsulation format for LLDPDUs.
Ethernet II is the encapsulation format for LLDPDUs.
2: System level
The command does not apply to LLDP-CDP packets, which use only SNAP encapsulation.
# Configure the encapsulation format for LLDPDUs as SNAP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp encapsulation snap
lldp fast-count
Use lldp fast-count to set the number of the LLDPDUs sent each time fast LLDPDU transmission is triggered.
Use undo lldp fast-count to restore the default.
lldp fast-count count
The number is 3.
2: System level
count: Sets the number of the LLDPDUs sent each time fast LLDPDU transmission is triggered. The argument ranges from 1 to 10.
# Configure the device to send four LLDPDUs each time fast LLDPDU transmission is triggered.
[Sysname] lldp fast-count 4
Use lldp hold-multiplier to set the TTL multiplier.
Use undo lldp hold-multiplier to restore the default.
lldp hold-multiplier value
The TTL multiplier is 4.
2: System level
value: Sets the TTL multiplier, ranging from 2 to 10.
You can set the TTL of the local device information by configuring the TTL multiplier.
The TTL configuration of a device is determined by the expression:
TTL multiplier × LLDPDU transmit interval
The TTL can be up to 65535 seconds. Longer TTLs is rounded off to 65535 seconds.
# Set the TTL multiplier to 6.
lldp management-address-format string
Use lldp management-address-format string to encapsulate the management address in the form of strings in TLVs.
Use undo lldp management-address-format to restore the default.
The management address is encapsulated in the form of numbers in TLVs.
2: System level
# Configure GigabitEthernet 1/0/1 to encapsulate the management address in the form of strings in management address TLVs.
[Sysname-GigabitEthernet1/0/1] lldp management-address-format string
lldp management-address-tlv
Use lldp management-address-tlv to enable management address advertising and set the management address.
Use undo lldp management-address-tlv to disable management address advertising in LLDPDUs.
lldp management-address-tlv [ ip-address ]
The management address is advertised through LLDPDUs. For a Layer 2 Ethernet port, the management address is the main IP address of the lowest-ID VLAN carried on the port. If none of the carried VLANs is assigned an IP address, no management addresses are advertised.
2: System level
ip-address: Specifies a management address to be advertised in LLDPDUs.
An LLDPDU carries only one management address TLV. If you set mutliple management addresses,  the most recent setting takes effect.
In Layer 2 Ethernet interface view, if you use the lldp management-address-tlv command without specifying the ip-address argument, the advertised management address is the main IP address of the lowest-ID VLAN carried on the interface. If none of the carried VLANs is assigned an IP address, no management addresses are advertised.
# Set the management address to 192.6.0.1 for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp management-address-tlv 192.6.0.1
lldp notification remote-change enable
Use lldp notification remote-change enable to enable LLDP trapping for a port or all ports in a port group.
Use undo lldp notification remote-change enable to disable LLDP trapping.
LLDP trapping is disabled on ports.
2: System level
# Enable LLDP trapping for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp notification remote-change enable
lldp timer notification-interval
Use lldp timer notification-interval to set the LLDP trap transmit interval.
Use undo lldp timer notification-interval to restore the default.
The LLDP trap transmit interval is 5 seconds.
2: System level
interval: Sets the LLDP trap transmit interval, ranging from 5 to 3600 seconds.
# Set the LLDP trap transmit interval to 8 seconds.
lldp timer reinit-delay
Use lldp timer reinit-delay to set the LLDP re-initialization delay.
Use undo lldp timer reinit-delay to restore the default.
lldp timer reinit-delay delay
The LLDP re-initialization delay is 2 seconds.
2: System level
delay: Sets the LLDP re-initialization delay, ranging from 1 to 10 seconds.
# Set the LLDP re-initialization delay to 4 seconds.
lldp timer tx-delay
Use lldp timer tx-delay to set the LLDPDU transmit delay.
Use undo lldp timer tx-delay to restore the default.
lldp timer tx-delay delay
The LLDPDU transmit delay is 2 seconds.
2: System level
delay: Sets the LLDPDU transmit delay, ranging from 1 to 8192 seconds.
It is a good practice to set the LLDPDU transmit delay to be no greater than a quarter of the LLDPDU transmit interval.
If the LLDPDU transmit delay is greater than the LLDPDU transmit interval, the device uses the LLDPDUs transmit delay as the transmit interval.
# Set the LLDPDU transmit delay to 4 seconds.
[Sysname] lldp timer tx-delay 4
Use lldp timer tx-interval to set the LLDPDU transmit interval.
Use undo lldp timer tx-interval to restore the default.
The LLDPDU transmit interval is 30 seconds.
2: System level
interval: Sets the LLDPDU transmit interval, ranging from 5 to 32768 seconds.
It is a good practice to set the LLDPDU transmit interval to be no less than four times the LLDPDU transmit delay.
If the LLDPDU transmit interval is less than the LLDPDU transmit delay, the device uses the LLDPDUs transmit delay as the transmit interval.
# Set the LLDPDU transmit interval to 20 seconds.
lldp timer tx-delay
lldp tlv-enable
Use lldp tlv-enable to configure the types of advertisable TLVs for a port or all ports in a port group.
Use undo lldp tlv-enable to disable the advertising of specific types of TLVs.
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | network-policy | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id | vlan-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | network-policy | power-over-ethernet } }
The device can advertise on a Layer 2 Ethernet port all types of LLDP TLVs, except location identification TLVs.
2: System level
all: Advertises all basic LLDP TLVs, IEEE 802.1 organizationally specific LLDP TLVs, or IEEE 802.3 organizationally specific LLDP TLVs when the all keyword is specified for basic-tlv, dot1-tlv, or dot3-tlv in Layer 2 Ethernet interface view; or advertises all LLDP-MED TLVs except location identification TLVs when the all keyword is specified for med-tlv in Layer 2 Ethernet interface view.
basic-tlv: Advertises basic LLDP TLVs.
port-description: Advertises port description TLVs.
system-capability: Advertises system capabilities TLVs.
system-description: Advertises system description TLVs.
system-name: Advertises system name TLVs.
dot1-tlv: Advertises IEEE 802.1 organizationally specific LLDP TLVs.
port-vlan-id: Advertises port VLAN ID TLVs.
protocol-vlan-id [ vlan-id ]: Advertises port and protocol VLAN ID TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised, ranges from 1 to 4094, and defaults to the lowest VLAN ID on the port.
vlan-name [ vlan-id ]: Advertises VLAN name TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised, ranges from 1 to 4094, and defaults to the lowest VLAN ID on the port.
dot3-tlv: Advertises IEEE 802.3 organizationally specific LLDP TLVs.
link-aggregation: Advertises link aggregation TLVs.
mac-physic: Advertises MAC/PHY configuration/status TLVs.
max-frame-size: Advertises maximum frame size TLVs.
power: Advertises power via MDI TLVs and power stateful control TLVs.
med-tlv: Advertises LLDP-MED TLVs.
capability: Advertises LLDP-MED capabilities TLVs.
inventory: Advertises the following TLVs: hardware revision, firmware revision, software revision, serial number, manufacturer name, model name, and asset ID.
location-id: Advertises location identification TLVs.
civic-address: Inserts the normal address information about the network device in location identification TLVs .
device-type: Sets a device type value, ranging from 0 to 2. Value 0 specifies a DHCP server. Value 1 specifies a switch. Value 2 specifies an LLDP-MED endpoint.
country-code: Sets a country code, corresponding to ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information, where ca-type represents the address information type, ranging from 0 to 255, ca-value represents address information, a string of 1 to 250 characters, and &<1-10> indicates that you can enter up to 10 parameters.
elin-address: Inserts telephone numbers for emergencies in location identification TLVs.
tel-number: Sets the telephone number for emergencies, a string of 10 to 25 characters.
network-policy: Advertises network policy TLVs.
power-over-ethernet: Advertises extended power-via-MDI TLVs.
To enable the device to advertise LLDP-MED TLVs, you must first enable it to advertise LLDP-MED capabilities TLVs.
To disable the device from advertising LLDP-MED capabilities TLVs, you must first disable it from advertising other LLDP-MED TLVs.
To disable the device from advertising MAC/PHY configuration/status TLVs, you must first disable it from advertising LLDP-MED capabilities TLVs.
If you enable the device to advertise LLDP-MED capabilities TLVs, you also enable it to advertise MAC/PHY configuration/status TLVs.
To enable the device to advertise multiple types of TLVs, you can execute the lldp tlv-enable command repeatedly without the all keyword specified.
# Enable the device to advertise link aggregation TLVs of the IEEE 802.3 organizationally specific TLVs on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp tlv-enable dot3-tlv link-aggregation
voice vlan track lldp
Use voice vlan track lldp to enable LLDP to automatically discover IP phones.
Use undo voice vlan track lldp to disable LLDP from automatically discovering IP phones.
LLDP is disabled from automatically discovering IP phones.
View
Default level
2: System level
None
# Enable the switch to automatically discover IP phones through LLDP.
[Sysname] voice vlan track lldp
