02-Layer 2-LAN Switching Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10102-Layer 2-LAN Switching Command Reference
06-Port isolation configuration commands
06-Port isolation configuration commands 64.92 KB
display port-isolate group
Use display port-isolate group to display port isolation group information.
display port-isolate group [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
This command displays information about the default isolation group (isolation group 1).
# Display port isolation group information.
<Sysname> display port-isolate group
Port-isolate group information:
 Uplink port support: NO
 Group ID: 1
 Group members:
GigabitEthernet1/0/2
Ten-GigabitEthernet1/0/29
Ten-GigabitEthernet1/0/30
Ten-GigabitEthernet1/0/31
Ten-GigabitEthernet1/0/32
Displays port isolation group information.
Uplink port support
Indicates whether the device supports configuring an uplink port in the port isolation group.
Group ID
Isolation group number.
Group members
Isolated ports (non-uplink ports) in the isolation group.
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from the isolation group.
port-isolate enable
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
2: System level
This command assigns a port to the default isolation group, called isolation group 1.
·           To assign Ethernet ports to the isolation group one by one, use the command in Layer 2 Ethernet interface view.
·           To bulk assign Ethernet ports to the isolation group, use the command in port group view.
·           To assign a Layer 2 aggregate interface to the isolation group, use the command in Layer 2 aggregate interface view. The configuration applies to the Layer 2 aggregate interface and all its member ports. If the device fails to apply the port-isolate enable command to a Layer 2 aggregate interface, it does not assign any member port of the aggregate interface to the isolation group. If the failure occurs on a member port, the device can still assign other member ports to the isolation group. For more information about Layer 2 aggregate interfaces, see "Ethernet link aggregation configuration commands."
You cannot assign the member ports of a service loopback group to an isolation group, and vice versa.
#Assign ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the isolation group.
[Sysname-GigabitEthernet1/0/1] port-isolate enable
[Sysname-GigabitEthernet1/0/2] port-isolate enable
# Assign all the ports in port group aa to the isolation group.
[Sysname] port-group manual aa
[Sysname-port-group-manual-aa] group-member gigabitethernet 1/0/1
[Sysname-port-group-manual-aa] group-member gigabitethernet 1/0/2
[Sysname-port-group-manual-aa] group-member gigabitethernet 1/0/3
[Sysname-port-group-manual-aa] group-member gigabitethernet 1/0/4
[Sysname-port-group-manual-aa] port-isolate enable
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 to the isolation group.
[Sysname-Bridge-Aggregation1] quit
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] quit
[Sysname-Bridge-Aggregation1] port-isolate enable
