02-Layer 2-LAN Switching Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10102-Layer 2-LAN Switching Command Reference
10-GVRP configuration commands
10-GVRP configuration commands 110.83 KB
display garp statistics
Use display garp statistics to display the GARP statistics of the specified ports. If no ports are specified, this command displays the GARP statistics for all ports.
display garp statistics [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
interface interface-list: Displays the GARP statistics of one or multiple ports. You can specify up to 10 port lists. By using each port list, you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end port number specified by interface-number2 must be greater than the start port number specified by interface-number1.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
This command displays the statistics about GVRP PDUs received, transmitted, and dropped on GVRP-enabled ports. When the system is restarted or after you use the reset garp statistics command, the existing packet statistics are cleared and the system starts to collect new GARP statistics. With the statistics, you can judge whether a GVRP-enabled port is operating normally.
·           If the number of received and transmitted GVRP PDUs on the port is the same as the remote port, it indicates that the two ends are transmitting and receiving GVRP PDUs normally and no registration information is lost.
·           If the port drops GVRP PDUs, you should check its registration mode. GVRP PDUs are likely to be dropped if the registration mode is fixed or forbidden, because dynamic VLANs cannot be registered in these two modes.
# Display GARP statistics on ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
<Sysname> display garp statistics interface gigabitethernet 1/0/1 to gigabitethernet 1/0/2
         GARP statistics on port GigabitEthernet1/0/1
         Number of GVRP Frames Received          : 5
         Number of GVRP Frames Transmitted       : 2
         Number of Frames Discarded              : 1
         GARP statistics on port GigabitEthernet1/0/2
         Number of GVRP Frames Received          : 3
         Number of GVRP Frames Transmitted       : 4
         Number of Frames Discarded              : 2
display garp timer
Use display garp timer to display GARP timers on specific ports. If no ports are specified, this command displays the GARP timers on all ports.
display garp timer [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-list: Displays the GARP timer settings of one or multiple ports. You can specify up to 10 port lists. By using each port list, you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end port number specified by interface-number2 must be greater than the start port number specified by interface-number1.
# Display GARP timers on port GigabitEthernet 1/0/1.
<Sysname> display garp timer interface gigabitethernet 1/0/1
         GARP timers on port GigabitEthernet1/0/1
                 Garp Join Time          : 20 centiseconds
                 Garp Leave Time         : 60 centiseconds
                 Garp LeaveAll Time      : 1000 centiseconds
                 Garp Hold Time          : 10 centiseconds
·           garp timer hold
·           garp timer join
·           garp timer leave
·           garp timer leaveall
display gvrp local-vlan
Use display gvrp local-vlan to display the local VLAN information maintained by GVRP on the specified port.
display gvrp local-vlan interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
0: Visit level
# Display the local VLAN information maintained by GVRP on GigabitEthernet 1/0/1.
<Sysname> display gvrp local-vlan interface gigabitethernet 1/0/1
 Following VLANs exist in GVRP local database:
  1(default),2-500
display gvrp state
Use display gvrp state to display GVRP state machines in a specified VLAN on a port.
display gvrp state interface interface-type interface-number vlan vlan-id [ | { begin | exclude | include } regular-expression ]
0: Visit level
vlan vlan-id: Specifies a VLAN ID, ranging from 1 to 4094.
# Display GVRP state machines in VLAN 2 on port GigabitEthernet 1/0/1.
<Sysname> display gvrp state interface gigabitethernet 1/0/1 vlan 2
        GVRP state of VLAN 2 on port GigabitEthernet1/0/1
                 Applicant state machine      : VP
                 Registrar state machine      : MTR
Information about the GVRP state machines in VLAN 2 on port GigabitEthernet 1/0/1.
Applicant state machine handles attribute declarations. Its state can be VA, AA, QA, LA, VP, AP, QP, VO, AO, QO, LO, VON, AON, and QON. Each state consists of two or three letters with the following meanings:
·       The first letter indicates the state: V for Very anxious, A for Anxious, Q for Quiet, and L for Leaving.
·       The second letter indicates the membership state: A for Active member, P for Passive member, and O for Observer.
·       The third letter N, if any, stands for Non-participant.
For example, VP indicates "Very anxious, Passive member."
Registrar state machine records the registration of attributes declared by other participants. Its state can be INN, LV, L3, L2, L1, MT, INR, LVR, L3R, L2R, L1R, MTR, INF, LVF, L3F, L2F, L1F, and MTF. Each state consists of two or three letters or numbers with the following meanings:
·       The first two letters or numbers indicate the state: IN stands for In; LV, L3, L2, and L1 all stand for Leaving, and L3, L2, L1 are three sub-states of LV; MT stands for Empty.
·       The third letter indicates the registration mode: N, if any, stands for Normal registration, R stands for Registration fixed, and F stands for Registration forbidden.
For example, MTR stands for "Empty, Registration fixed" and indicates the fixed registration mode in Empty state.
display gvrp statistics
Use display gvrp statistics to display the GVRP statistics of the specified trunk ports. If no ports are specified, this command displays the GVRP statistics for all trunk ports.
display gvrp statistics [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-list: Displays the GVRP statistics of one or multiple Ethernet ports. You can specify up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1.
# Display GVRP statistics for trunk port GigabitEthernet 1/0/1.
<Sysname> display gvrp statistics interface gigabitethernet 1/0/1
         GVRP statistics on port GigabitEthernet1/0/1
                 GVRP Status                     : Enabled
                 GVRP Running                    : YES
                 GVRP Failed Registrations       : 0
                 GVRP Last Pdu Origin            : 0000-0000-0000
                 GVRP Registration Type          : Normal
GVRP Status
Indicates whether GVRP is enabled or disabled.
GVRP Running
Indicates whether GVRP is running.
Indicates the number of GVRP registration failures.
Indicates the source MAC address in the last GVRP PDU.
Indicates the GVRP registration mode (fixed, forbidden, or normal) on the port.
display gvrp status
Use display gvrp status to display the global GVRP state.
display gvrp status [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the global GVRP state.
<Sysname> display gvrp status
                 GVRP is enabled
display gvrp vlan-operation
Use display gvrp vlan-operation to display information about dynamic VLAN operations on a port.
display gvrp vlan-operation interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
0: Visit level
# Display information about dynamic VLAN operations on GigabitEthernet 1/0/1.
<Sysname> display gvrp vlan-operation interface gigabitethernet 1/0/1
         Dynamic VLAN operations on port GigabitEthernet1/0/1
                 Operations of creating VLAN              :  2-100
                 Operations of deleting VLAN              :  none
                 Operations of adding VLAN to TRUNK       :  2-100
                 Operations of deleting VLAN from TRUNK   :  none
garp timer hold
Use garp timer hold to set the GARP Hold timer for an Ethernet port, Layer 2 aggregate interface, or all ports in a port group.
Use undo garp timer hold to restore the default of the GARP Hold timer. This may fail if the default is beyond the valid value range for the Hold timer.
garp timer hold timer-value
The Hold timer is 10 centiseconds.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
2: System level
timer-value: Specifies the Hold timer (in centiseconds), which must be a multiple of 5 and range from 10 (inclusive) to half the Join timer (inclusive).
# Set the GARP Hold timer to 15 centiseconds, assuming that the Join timer is 30 centiseconds.
[Sysname-GigabitEthernet1/0/1] garp timer hold 15
·           display garp timer
·           garp timer join
garp timer join
Use garp timer join to set the GARP Join timer for an Ethernet port, Layer 2 aggregate interface, or all ports in a port group.
Use undo garp timer join to restore the default of the GARP Join timer. This may fail if the default is beyond the valid value range for the Join timer.
garp timer join timer-value
The Join timer is set to 20 centiseconds.
2: System level
timer-value: Specifies the Join timer (in centiseconds), which must be a multiple of 5 and range from twice the Hold timer (inclusive) and half the Leave timer (inclusive).
# Set the GARP Join timer to 25 centiseconds, assuming that both the Hold timer and the Leave timer are using the default.
[Sysname-GigabitEthernet1/0/1] garp timer join 25
·           garp timer hold
·           garp timer leave
garp timer leave
Use garp timer leave to set the GARP Leave timer for an Ethernet port, Layer 2 aggregate interface, or all ports in a port group.
Use undo garp timer leave to restore the default of the GARP Leave timer. This may fail if the default is beyond the valid value range for the Leave timer.
garp timer leave timer-value
The Leave timer is set to 60 centiseconds.
2: System level
timer-value: Specifies the Leave timer (in centiseconds), which must be a multiple of 5 and range from twice the Join timer (exclusive) to the LeaveAll timer (exclusive).
# Set the GARP Leave timer to 100 centiseconds, assuming that both the Join timer and the LeaveAll timer are using the default.
[Sysname-GigabitEthernet1/0/1] garp timer leave 100
·           garp timer join
garp timer leaveall
Use garp timer leaveall to set the GARP LeaveAll timer.
Use undo garp timer leaveall to restore the default. This may fail if the default is beyond the valid value range for the LeaveAll timer.
garp timer leaveall timer-value
The LeaveAll timer is 1000 centiseconds.
2: System level
timer-value: Specifies the Leaveall timer (in centiseconds), which must be a multiple of 5 and range from the maximum Leave timer on the device (exclusive) to 32765 (inclusive).
To keep the dynamic VLANs learned through GVRP stable, do not set the LeaveAll timer smaller than its default value.
# Set the leaveall timer to 2000 centiseconds, assuming that the Leave timer on every port is set to 60 centiseconds.
[Sysname] garp timer leaveall 2000
·           garp timer leave
gvrp
Use gvrp to enable GVRP.
Use undo gvrp to disable GVRP.
gvrp
undo gvrp
GVRP is disabled.
System view, Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
2: System level
Settings in system view take effect globally. Settings in Layer 2 Ethernet view or Layer 2 aggregate interface take effect only on the current interface. Settings in port group view take effect on all ports in the port group.
To enable GVRP on a port, enable GVRP globally before you enable it on the port.
In interface view, you can use this command on trunk ports only.
You cannot change the link type of a GVRP-enabled trunk port.
# Enable GVRP globally.
[Sysname] gvrp
GVRP is enabled globally.
display gvrp status
gvrp registration
Use gvrp registration to configure the GVRP registration mode.
Use undo gvrp registration to restore the default.
gvrp registration { fixed | forbidden | normal }
The GVRP registration mode is normal.
2: System level
fixed: Sets the GVRP registration mode to fixed.
forbidden: Sets the GVRP registration mode to forbidden.
normal: Sets the GVRP registration mode to normal.
Settings in system view take effect globally. Settings in Ethernet view or Layer 2 aggregate interface take effect on the current interface. Settings in port group view take effect on all ports in the port group.
This command is only available on trunk ports.
# Set the GVRP registration mode to fixed on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] gvrp registration fixed
Use reset garp statistics to clear the GARP statistics on the specified ports. If no ports are specified, this command clears the GARP statistics on all ports.
reset garp statistics [ interface interface-list ]
2: System level
interface interface-list: Clears the GARP statistics of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end port number specified by interface-number2 must be greater than the start port number specified by interface-number1.
The cleared statistics include the statistics about GVRP PDUs sent, received, and dropped.
# Clear the GARP statistics on all ports.
<Sysname> reset garp statistics
