02-Layer 2-LAN Switching Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10102-Layer 2-LAN Switching Command Reference
00-Preface
00-Preface 84.54 KB
Preface
The H3C WX5540E Access Controller Switching Engine documentation set describes the commands and command syntax options available for the H3C WX5540E Access Controller Switching Engine.
The Layer 2-LAN Switching Command Reference describes the configuration commands for flow control, load sharing, VLAN user isolation, loop elimination, VLAN division, customer network packet transmission in public network, and VLAN tag modification.
This preface includes:
·           Audience
·           Conventions
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the WX5540E Access Controller Switching Engine
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
We appreciate your comments.
