02-Layer 2-LAN Switching Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10102-Layer 2-LAN Switching Command Reference
04-MAC address table configuration commands
04-MAC address table configuration commands 113.29 KB
The MAC address table can contain only Layer 2 Ethernet ports and Layer 2 aggregate interfaces.
This document covers only the configuration of unicast MAC address entries, including static, dynamic, and blackhole MAC address entries. For information about configuring static multicast MAC address entries, see IP Multicast Configuration Guide.
display mac-address
Use display mac-address to display information about the MAC address table.
display mac-address [ mac-address [ vlan vlan-id ] | [ [ dynamic | static ] [ interface interface-type interface-number ] | blackhole ] [ vlan vlan-id ] [ count ] ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
blackhole: Displays blackhole MAC address entries, which do not age and can be added and deleted. Packets with a matching source or destination MAC address are discarded.
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094.
count: Displays the number of MAC address entries specified by related parameters in the command. When this keyword is used, the command displays only the number of specified MAC address entries, rather than related information about these MAC address entries.
mac-address: Displays MAC address entries of a specified MAC address, in the format of H-H-H.
dynamic: Displays dynamic MAC address entries, which can be aged.
static: Displays static MAC address entries, which do not age.
interface interface-type interface-number: Displays the MAC address learning status of the specified interface. The interface-type interface-number argument specifies an interface by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you execute this command without specifying any parameters, it displays information of all MAC address entries on the device, including unicast MAC address entries and static multicast MAC address entries.
If you execute this command using only the vlan keyword or the count keyword, or only these two keywords, it displays information of unicast MAC address entries and static multicast MAC address entries.
# Display the MAC address entry for MAC address 000f-e201-0101.
<Sysname> display mac-address 000f-e201-0101
MAC ADDR        VLAN ID    STATE            PORT INDEX              AGING TIME(s)
000f-e201-0101  1          Learned          GigabitEthernet1/0/1    AGING
  ---  1 mac address(es) found  ---
MAC ADDR
MAC address.
VLAN ID
ID of the VLAN to which the MAC address belongs.
STATE
State of a MAC address entry:
·       Config static—Static entry manually configured by the user.
·       Config dynamic—Dynamic entry manually configured by the user.
·       Learned—Entry learned by the device.
·       Blackhole—Blackhole entry.
·       Multicast—Static multicast MAC address entry manually configured by the user. For more information about static multicast MAC address entries, see IP Multicast Configuration Guide.
PORT INDEX
Outgoing port for packets that are destined for the MAC address. It is displayed as N/A for a blackhole MAC address entry.
AGING TIME(s)
Aging time:
·       AGING—The entry is aging.
·       NOAGED—The entry does not age.
Number of matching MAC address entries.
·           mac-address (system view)
·           mac-address (interface view)
·           mac-address timer
·           display mac-address multicast and display mac-address multicast count (IP Multicast Command Reference)
display mac-address aging-time
Use display mac-address aging-time to display the aging time of dynamic entries in the MAC address table.
display mac-address aging-time [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the aging time of dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The output shows that the aging time of dynamic entries in the MAC address table is 300 seconds.
·           mac-address timer
display mac-address mac-learning
Use display mac-address mac-learning to display the MAC address learning status of the specified or all Layer 2 Ethernet ports.
display mac-address mac-learning [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display MAC address learning status of all Ethernet ports.
<Sysname> display mac-address mac-learning
Mac address learning status of the switch: enable
PortName                  Learning Status
GigabitEthernet1/0/1              enable
GigabitEthernet1/0/2              enable
GigabitEthernet1/0/3              enable
GigabitEthernet1/0/4              enable
GigabitEthernet1/0/5              enable
GigabitEthernet1/0/6              enable
GigabitEthernet1/0/7              enable
GigabitEthernet1/0/8              enable
GigabitEthernet1/0/9              enable
GigabitEthernet1/0/10             enable
GigabitEthernet1/0/11             enable
GigabitEthernet1/0/12             enable
GigabitEthernet1/0/13             enable
GigabitEthernet1/0/14             enable
GigabitEthernet1/0/15             enable
GigabitEthernet1/0/16             enable
GigabitEthernet1/0/17             enable
GigabitEthernet1/0/18             enable
GigabitEthernet1/0/19             enable
GigabitEthernet1/0/20             enable
GigabitEthernet1/0/21             enable
GigabitEthernet1/0/22             enable
GigabitEthernet1/0/23             enable
GigabitEthernet1/0/24             enable
GigabitEthernet1/0/33             enable
Ten-GigabitEthernet1/0/25         enable
Ten-GigabitEthernet1/0/26         enable
Ten-GigabitEthernet1/0/27         enable
Ten-GigabitEthernet1/0/28         enable
Ten-GigabitEthernet1/0/29         enable
Ten-GigabitEthernet1/0/30         enable
Ten-GigabitEthernet1/0/31         enable
Ten-GigabitEthernet1/0/32         enable
Mac-address learning status of the switch
Global MAC address learning status (enabled or disabled).
PortName
Port name.
Learning Status
MAC address learning status (enabled or disabled) for a port.
display mac-address statistics
Use display mac-address statistics to display the statistics of the MAC address table.
display mac-address statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the statistics of the MAC address table.
<Sysname> display mac-address statistics
MAC TYPE            LEARNED    USER-DEFINED  SYSTEM-DEFINED IN-USE    AVAILABLE
Dynamic   Unicast   26         0             1              27
Static    Unicast   0          1             8              9         1024
Total     Unicast                                           36        32768
Dynamic Multicast   0          0             0              0
Static  Multicast   0          13            12             25        256
Total   Multicast                                           25        256
MAC TYPE
MAC address type:
·       Dynamic Unicast.
·       Static Unicast.
·       Total Unicast.
·       Dynamic Multicast.
·       Static Multicast.
·       Total Multicast.
LEARNED
Dynamically learned MAC addresses.
USER-DEFINED
User defined MAC addresses (dynamic and static).
SYSTEM-DEFINED
MAC addresses generated by the system (for example, 802.1x and MAC authentication).
IN-USE
Number of existing MAC addresses of a specific type.
AVAILABLE
Maximum number of MAC addresses supported by the system.
Use mac-address to add or modify a MAC address entry on the specified interface.
Use undo mac-address to remove a MAC address entry on the specified interface.
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
No MAC address entry is configured.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
2: System level
dynamic: Specifies dynamic MAC address entries. These entries can age.
static: Specifies static MAC address entries. They do not age, but you can add or remove them.
mac-address: Specifies a MAC address in the format of H-H-H, where 0s at the beginning of each H (16-bit hexadecimal digit) can be omitted. For example, enter "f-e2-1" for "000f-00e2-0001."
vlan vlan-id: Specifies an existing VLAN to which the Ethernet interface belongs. The value range for the vlan-id argument is 1 to 4094.
The MAC address entries configuration cannot survive a reboot unless you save them. However, the dynamic MAC address entries are lost at next reboot regardless of whether you save the configuration or not.
# Add a static entry for MAC address 000f-e201-0101 on port GigabitEthernet 1/0/1 that belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address static 000f-e201-0101 vlan 2
# Add a static entry for MAC address 000f-e201-0102 on port Bridge-Aggregation 1 that belongs to VLAN 1.
[Sysname-Bridge-Aggregation1] mac-address static 000f-e201-0102 vlan 1
display mac-address
Use mac-address to add or modify a MAC address entry.
Use undo mac-address to remove one or all MAC address entries.
undo mac-address [ { dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
2: System level
blackhole: Specifies blackhole MAC address entries. These entries do not age, but you can add or remove them. The packets whose source or destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Specifies an existing VLAN to which the Ethernet interface belongs, where vlan-id is the specified VLAN ID, ranging from 1 to 4094.
dynamic: Specifies dynamic MAC address entries, which can be aged.
static: Specifies static MAC address entries. These entries do not age, but you can add or remove them.
interface interface-type interface-number: Specifies an outbound interface by its type and number.
A static or blackhole MAC address entry will not be overwritten by a dynamic MAC address entry. A dynamic MAC address entry can be overwritten by a static or blackhole MAC address entry.
If you execute the undo mac-address command without specifying any parameters, this command deletes all unicast MAC address entries and static multicast MAC address entries.
You can delete all the MAC address entries (including unicast MAC address entries and static multicast MAC address entries) of a VLAN, or you can choose to delete a specific type (dynamic, static, or blackhole) of MAC address entries only. You can single out certain ports and delete the corresponding unicast MAC address entries, but you cannot do the same to the corresponding static multicast MAC address entries.
# Add a static entry for MAC address 000f-e201-0101. All frames destined to this MAC address are sent out of port GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface gigabitethernet 1/0/1 vlan 2
display mac-address
mac-address mac-learning disable
Use mac-address mac-learning disable to disable MAC address learning on a VLAN.
Use undo mac-address mac-learning disable to enable MAC address learning on a VLAN.
MAC address learning is enabled.
VLAN view
2: System level
You might need to disable MAC address learning to prevent the MAC address table from being saturated. For example, when your device is being attacked by many packets with different source MAC addresses, it affects the update of the MAC address table.
When MAC address learning is disabled, the learned MAC addresses remain valid until they age out.
# Disable MAC address learning on VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] mac-address mac-learning disable
mac-address max-mac-count
Use mac-address max-mac-count count to configure the maximum number of MAC addresses that can be learned on a port.
Use undo mac-address max-mac-count to restore the default maximum number of MAC addresses that can be learned on an Ethernet port.
No MAC learning limit is configured.
Layer 2 Ethernet interface view, port group view
2: System level
count: Sets the maximum number of MAC addresses that can be learned on a port. The value is in the range of 0 to 4096. When the argument takes 0, the port is not allowed to learn MAC addresses.
If the command is executed in interface view, the configuration takes effect on the interface. If the command is executed in port group view, the configuration takes effect on all ports belonging to the port group.
# Set the maximum number of MAC addresses that can be learned on port GigabitEthernet 1/0/1 to 600.
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count 600
·           mac-address timer
mac-address timer
Use mac-address timer to configure the aging timer for dynamic MAC address entries.
Use undo mac-address timer to restore the default.
undo mac-address timer aging
The default setting is 300 seconds.
2: System level
aging seconds: Sets an aging timer (in seconds) for dynamic MAC address entries. The value is in the range of 10 to 1000000.
no-aging: Sets dynamic MAC address entries not to age.
Follow these guidelines to set the aging timer appropriately:
·           A long aging interval might cause the MAC address table to retain outdated entries and fail to accommodate the latest network changes.
·           A short aging interval might result in removal of valid entries and unnecessary broadcasts that may affect the performance of the device.
# Set the aging timer for dynamic MAC address entries to 500 seconds.
MAC Information applies only to Layer 2 Ethernet interfaces.
mac-address information enable (interface view)
Use mac-address information enable to enable MAC Information on the Layer 2 Ethernet interface.
Use undo mac-address information enable to restore the default.
undo mac-address information enable { added | deleted }
MAC Information is disabled on a Layer 2 Ethernet interface.
1: Monitor level
added: Enables the device to record security information when a new MAC address is learned on the Ethernet port.
deleted: Enables the device to record security information when an existing MAC address is deleted.
This command is not supported on aggregate interfaces.
Before you enable MAC Information on an Ethernet interface, enable MAC Information globally.
# Enable MAC Information on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-address information enable added
mac-address information enable (system view)
Use mac-address information enable to enable MAC Information globally.
MAC Information is disabled globally.
2: System level
# Enable MAC Information globally.
[Sysname] mac-address information enable
mac-address information interval
Use mac-address information interval to set the interval for sending syslog or trap messages.
Use undo mac-address information interval to restore the default.
mac-address information interval interval-time
The interval for sending syslog or trap messages is 1 second.
2: System level
interval-time: Sets the interval for sending syslog or trap messages, in the range of 1 to 20000 seconds.
# Set the interval for sending syslog or trap messages to 200 seconds.
[Sysname] mac-address information interval 200
mac-address information mode
Use mac-address information mode to set the MAC Information mode (to use syslog messages or trap messages) to inform the remote network management device of MAC address changes.
Use undo mac-address information mode to restore the default.
undo mac-address information mode { syslog | trap }
Trap messages are sent to inform the remote network management device of MAC address changes.
2: System level
syslog: Specifies that the device sends syslog messages to inform the remote network management device of MAC address changes.
trap: Specifies that the device sends trap messages to inform the remote network management device of MAC address changes.
# Configure the device to send trap messages to inform the remote network management device of MAC address changes.
[Sysname] mac-address information mode trap
mac-address information queue-length
Use mac-address information queue-length to set the MAC Information queue length.
Use undo mac-address information queue-length to restore the default.
The MAC Information queue length is 50.
2: System level
value: Specifies the MAC Information queue length, in the range of 0 to 1000.
# Set the MAC Information queue length to 600.
[Sysname] mac-address information queue-length 600
