| 01-WLAN Interface Configuration | 89.08 KB |
Configuring a WLAN-radio interface
Configuring a WLAN-BSS interface
Entering WLAN mesh interface view
Configuring a WLAN mesh interface
Displaying and maintaining a WLAN interface
WLAN-Radio interfaces are physical interfaces and are used for providing wireless access service. They can be configured but cannot be removed manually.
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter WLAN-radio interface view. |
interface wlan-radio interface-number |
N/A |
3. Set the description for the interface. |
description text |
Optional. By default, the description of an interface is its interface name followed by the Interface string. |
4. Restore the default settings of the WLAN-radio interface. |
default |
Optional. |
5. Shut down the WLAN-radio interface. |
shutdown |
Optional. By default, a WLAN-Radio interface is up. |
WLAN-BSS interfaces are virtual Layer 2 interfaces. They operate like Layer 2 Ethernet ports. A WLAN-BSS interface supports multiple Layer 2 protocols. On a fat AP, a WLAN-Radio interface bound to a WLAN-BSS interface operates as a Layer 2 interface.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter WLAN-BSS interface view. |
interface wlan-bss interface-number |
If the WLAN-BSS interface does not exist, this command creates the WLAN-BSS interface first. |
3. Set the description string for the interface. |
description text |
Optional. By default, the description string of an interface is interface-name + Interface. |
4. Specify the link type. |
port link-type { access | hybrid } |
Optional. The default is access. You can add the WLAN-BSS interface to specific VLANs depending on the link type. For more information, see Layer 2 Configuration Guide. |
5. Specify an authentication domain for MAC authentication users. |
mac-authentication domain domain-name |
By default, the default authentication domain is used for MAC authentication users. |
6. Set the maximum number of concurrent MAC authentication users on the interface. |
mac-authentication max-user user-number |
The default maximum number of concurrent MAC authentication users on a port is 128. |
7. Restore the default settings of the WLAN-BSS interface. |
default |
Optional. |
8. Shut down the WLAN-BSS interface. |
shutdown |
Optional. By default, a WLAN-BSS interface is up. |
For more information about the mac-authentication domain, and mac-authentication max-user commands, see Security Command Reference.
WLAN mesh interface
WLAN mesh interfaces are Layer 2 virtual interfaces. You can use them as configuration templates to make and save settings for WLAN mesh link interfaces. After a WLAN mesh link interface is created, you cannot change the settings on its associated WLAN mesh interface.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter WLAN mesh interface view. |
interface wlan-mesh interface-number |
If the specified WLAN mesh interface does not exist, this command creates the WLAN mesh interface first. |
3. Restore the default settings of the WLAN mesh interface. |
default |
Optional. |
Step |
Command |
1. Configure the description of the WLAN mesh interface. |
description |
2. Configure VLAN settings. |
· port link-type · port access · port trunk · port hybrid · port multicast-vlan |
3. Configure port security settings. |
· port-security max-mac-count · port-security port-mode · port-security preshared-key · port-security tx-key-type 11key |
WLAN mesh link interfaces are similar to Layer 2 virtual Ethernet interfaces and have the features of Layer 2 interfaces. They are dynamically created or deleted by the WLAN module and are responsible for local data forwarding on the mesh network.
WLAN mesh link interfaces use the settings you made on their corresponding WLAN mesh interfaces and are not configurable.
Task |
Command |
Remarks |
Display information about WLAN-Radio interfaces. |
display interface [ wlan-radio ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] display interface wlan-radio interface-number [ brief ] [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Display information about WLAN-BSS interfaces. |
display interface [ wlan-bss] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] display interface wlan-bss interface-number [ brief ] [ | { begin | exclude | include } regular-expression ] |
Display information about WLAN mesh interfaces. |
display interface [ wlan-mesh ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] display interface wlan-mesh interface-number [ brief ] [ | { begin | exclude | include } regular-expression ] |
Display information about WLAN mesh link interfaces. |
display interface [ wlan-meshlink ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] display interface wlan-meshlink interface-number [ brief ] [ | { begin | exclude | include } regular-expression ] |
