02-WLAN Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WA Series Access Points Configuration Guides(R1507P09)-6W10102-WLAN Configuration Guide
00-Preface
00-Preface 99.74 KB
Preface
The H3C Access Points documentation set includes eight configuration guides. These guides describe the software features for the H3C Access Points and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The interface types and output information might vary by device model.
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators working with the H3C Access Points
Conventions
This section describes the conventions used in the documentation.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card.
We appreciate your comments.
