03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10103-Layer 2 Command Reference
10-DCC Commands
10-DCC Commands 100.91 KB
bandwidth
Use bandwidth to set the intended bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
Dialup interface (physical interface or dialer interface) view
Default command level
2: System level
bandwidth-value: Specifies the intended bandwidth for the interface, ranging from 1 to 4294967295 kbps.
You can get the intended bandwidth of an interface by querying the ifspeed value of the MIB node with third-party software.
The intended bandwidth is used for bandwidth monitoring of the network management. It does not affect the actual bandwidth of the interface.
# Set the intended bandwidth to 1000 kbps for interface Dialer 1.
[Sysname] interface dialer 1
[Sysname-Dialer1] bandwidth 1000
dialer bundle
Use dialer bundle to associate a dialer bundle with a dialer interface in RS-DCC.
Use undo dialer bundle to remove the association.
dialer bundle number
undo dialer bundle
Dialer interfaces are not associated with any dialer bundle in RS-DCC.
Dialer interface view
2: System level
number: Specifies the dialer bundle number, in the range of 1 to 255.
This command applies only to dialer interfaces. In addition, a dialer interface can be associated with only one dialer bundle.
# Associate dialer bundle 3 with interface Dialer 1.
[Sysname-Dialer1] dialer bundle 3
dialer disconnect
Use dialer disconnect to clear the dialup link on an interface or all dialup links if no interface is specified.
dialer disconnect [ interface interface-type interface-number ]
1: Monitor level
interface interface-type interface-number: Disconnects the dialup link on an interface specified by its type and number.
# Clear the dialup link on interface Dialer 1.
<Sysname> dialer disconnect interface dialer 1
dialer queue-length
Use dialer queue-length to set the buffer queue length on the dialup interface.
Use undo dialer queue-length to restore the default.
dialer queue-length packets
No packets are buffered.
Dialup interface view
2: System level
packets: Number of packets that can be buffered on the interface, in the range of 1 to 100.
If no connection is available yet when a dialup interface without a buffer queue receives a packet, it will drop the packet. Configured with a buffer queue, the dialup interface will buffer the packet until a connection is available for packet sending.
# Set the buffer queue length to 10 on interface  Dialer 1.
[Sysname-Dialer1] dialer queue-length 10
dialer timer enable
Use dialer timer enable to set the link holddown timer.
Use undo dialer timer enable to restore the default.
dialer timer enable seconds
The link holddown timer is five seconds.
2: System level
seconds: Holddown timer value, setting the interval for originating a call to bring up a link after it is disconnected. It ranges from 5 to 65535 seconds.
A holddown timer starts upon disconnection of a link. The call attempt to bring up this link can be made only after the timer expires. This is to prevent a remote PBX from being overloaded.
# Set the interval for DCC to make the next call attempt to 15 seconds.
[Sysname-Dialer1] dialer timer enable 15
dialer timer idle
Use dialer timer idle to set the link idle-timeout timer.
Use undo dialer timer idle to restore the default.
dialer timer idle seconds
The link idle-timeout timer is 120 seconds.
2: System level
seconds: Link idle-timeout timer, setting the time that a link is allowed to be idle. It ranges from 0 to 65535 seconds.
A link idle-timeout timer starts upon setup of a link. If no interesting packets are present before the timer expires, DCC disconnects the link.
If the timer is set to 0, the link will never be disconnected, regardless of whether there are interesting packets on the link or not.
# Set the link idle-timeout timer to 50 seconds on interface  Dialer1.
[Sysname-Dialer1] dialer timer idle 50
dialer timer wait-carrier
Use dialer timer wait-carrier to set the wait-carrier timer.
Use undo dialer timer wait-carrier to restore the default.
dialer timer wait-carrier seconds
The wait-carrier timer is 60 seconds.
2: System level
seconds: Wait-carrier timer value, setting the time waiting for call setup. This argument ranges from 0 to 65535 seconds.
Sometimes, the time that DCC waits for a connection to be established may vary call by call. To handle this situation, you may use a wait-carrier timer. A wait-carrier timer starts when a call is placed. If the connection is not established upon expiration of the timer, DCC terminates the call.
# Set the wait-carrier timer to 100 seconds on interface Dialer1.
[Sysname-Dialer1] dialer timer wait-carrier 100
dialer user
Use dialer user to add a remote username for authenticating incoming calls.
Use undo dialer user to remove the remote username.
dialer user username
undo dialer user [ username ]
No remote username is set.
2: System level
username: Remote username for PPP authentication, a string of 1 to 80 characters.
This command is only valid on dialer interfaces in RS-DCC.
On a dialer interface encapsulated with PPP, DCC identifies which dialer interface is to be used for receiving calls based on the remote username obtained through PPP authentication.
You may configure multiple dialer users (up to 255) on a dialer interface. This allows DCC to provide accesses to multiple dialup interfaces by using one dialer interface.
Use this command on a C-DCC enabled dialer interface with caution. It enables RS-DCC and can remove the C-DCC configurations on the interface.
Executing the undo dialer user command on a dialer interface can clear all configurations on it.
# Add a remote username routerb.
[Sysname-Dialer1] dialer user routerb
·          ppp chap user
·          ppp pap local-user
dialer-group
Use dialer-group to assign the interface to a dialer access group.
Use undo dialer-group to remove the interface from the dialer access group.
dialer-group group-number
undo dialer-group
An interface is not assigned to any dialer access groups.
2: System level
group-number: Number of a dialer access group, in the range of 1 to 255. You may define it with the dialer-rule command.
A DCC dialup interface can belong to only one dialer access group. Configuring this command can overwrite the previous dialer access group setting for the interface, if any.
You must configure this command for DCC to send packets.
# Add interface Dialer1 to dialer access group 1.
[Sysname] dialer-rule 1 acl 3101
[Sysname-Dialer1] dialer-group 1
dialer-rule
dialer-rule
Use dialer-rule to set the condition for a DCC call to be placed for a dialer access group either by directly configuring a rule or by referencing an ACL.
Use undo dialer-rule to remove the setting.
dialer-rule group-number { protocol-name { deny | permit } | acl { acl-number | name acl-name } }
undo dialer-rule group -number
No condition is set for a DCC call to be placed for a dialer access group.
2: System level
group-number: Number of a dialer access group, the same as the group-number argument in the dialer-group command. It ranges from 1 to 255.
protocol-name: Network protocol, which can take ip or bridge.
deny: Denies packets of the specified protocol.
permit: Permits packets of the specified protocol.
acl-number: Specifies an ACL by its ACL number. The acl-number argument ranges from 2000 to 3999. An ACL number in the range of 2000 to 2999 identifies a basic ACL. An ACL number in the range of 3000 to 3999 identifies an advanced ACL.
name acl-name: Specifies an ACL by its name.
You may configure a dial ACL to filter traffic that traverses a dialup interface. Packets fall into two categories, depending on whether they are in compliance with the permit or deny statements in the dial ACL.
·          Packets that match a permit statement or that do not match any deny statements. When receiving such a packet, DCC either sends it out if a link is present and resets the idle-timeout timer or originates a new call to set up a link if no link is present.
·          Packets that do not match any permit statements or that match a deny statement. When receiving such a packet, DCC either sends it out without resetting the idle-timeout timer if a link is present, or drops it without originating calls for link setup if no link is present.
For DCC to send packets normally, you must configure a dial ACL and associate it with the concerned dialup interface by using the dialer-group command.
If no dial ACL is configured for the dialer access group associated with a dialup interface, DCC will drop received packets on the interface as uninteresting ones.
# Define dialer-rule 1 and apply it to interface Dialer1.
[Sysname] dialer-rule 1 ip permit
dialer-group
display dialer
Use display dialer to display the DCC-related information about an interface. If no interface is specified, this command displays the DCC-related information about all the interfaces.
display dialer [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the DCC-related information about all the DCC interfaces.
<Sysname> display dialer
Dialer0 - dialer type = Dialer
   Dialer Route:
   NextHop_address          Dialer_Numbers
   Dialer number            003
   Dialer Timers(Secs):
   Auto-dial:300    Enable:5
   Idle:120    Wait-for-Carrier:60
   Total Channels:1  Free Channels:1
dialer type
Type of dialup interface, dialer or physical.
NextHop address
Remote address on the interface.
Dialer_Numbers
Dial strings for the remote IP addresses.
Dialer number
Dial string for a remote IP address.
Dialer Timers(Secs)
DCC timers.
Auto-dial
Timer set by the dialer timer autodial command.
Enable
Timer set by the dialer timer enable command.
Idle
Timer set by the dialer timer idle command.
Wait-for-carrier
Timer set by the dialer timer wait-carrier command.
Total Channels
Total number of channels on the interface.
Free Channels
Number of free channels.
display interface dialer
Use display interface dialer to display the information about a dialer interface.
display interface dialer number [ brief ] [ | { begin | exclude | include } regular-expression ]
display interface [ dialer ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
number: Dialer interface number.
down: Displays information about interfaces in the DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
If you do not specify the dialer keyword, this command displays information about all interfaces on the device.
If you specify the dialer keyword without the number argument, this command displays information about all the dialer interfaces.
# Display detailed information about interface Dialer 1.
<Sysname> display interface dialer 1
Dialer1 current state: UP
Line protocol current state: UP (spoofing)
Description: Dialer1 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Internet protocol processing : disabled
Link layer protocol is PPP
LCP initial
Physical is Dialer, baudrate: 64000 bps
Output queue : (Urgent queuing : Length)  50
Output queue : (Protocol queuing : Length)  500
Output queue : (FIFO queuing : Length)  75
Last clearing of counters:  Never
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
# Display brief information about interface Dialer 1.
<Sysname> display interface dialer 1 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Dia1                 UP   UP(s)    --
# Display brief information about all Dialer interfaces in DOWN state.
<Sysname> display interface dialer brief down
Dia1                 ADM  Administratively
current state
Physical state of a dialer interface:
·         UPThe dialer interface is physically up.
·         DOWN (Administratively)The dialer interface was shut down with the shutdown command. To re-enable it, you must use the undo shutdown command on it.
Data link layer protocol state of the dialer interface: Up or Down.
Interface description.
MTU of the dialer interface.
Network layer protocol state of the dialer interface: enabled or disabled.
Current data link layer protocol.
LCP initial
LCP is initialized.
Physical is Dialer
The physical interface is a dialer interface.
Statistics on the packets in the urgent output queue.
Statistics on the packets in the protocol output queue.
Statistics on the packets in the FIFO output queue.
Time when statistics on the dialer interfaces were last cleared. Never indicates the statistics were never cleared.
Input interface data rate during the latest 300 seconds.
Output interface data rate during the latest 300 seconds.
Statistics on the packets reaching the interface.
Statistics on the packets sent through the interface.
Brief information about Layer 3 interfaces.
Link status:
·         ADM—The interface has been administratively shut down. To recover its physical state, execute the undo shutdown command.
·         Stby—The interface is operating as a backup interface. To see the primary interface, use the display standby state command (High Availability Command Reference).
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses).
Abbreviated interface name.
Link
Physical link state of the interface:
·         UP—The link is up.
·         ADM—The link has been administratively shut down. To recover its physical state, execute the undo shutdown command.
Protocol
Protocol connection state of the interface: UP, DOWN, or UP(s).
Main IP
Main IP address of the interface.
Description of the interface.
Cause
Cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command.
interface dialer
Use interface dialer to create a dialer interface. In C-DCC, this equals creating a dialer circular group.
Use undo interface dialer to remove a dialer interface.
undo interface dialer number
No dialer interface is created.
2: System level
number: Dialer interface number. The value range for this argument is 1 to 16.
The dialer interface has a fixed baudrate of 64000 bps.
In RS-DCC, any dialer interface can use the services provided by multiple physical interfaces, and individual physical interfaces can provide services for multiple dialer interfaces at the same time. Therefore, authentication must be configured on these physical interfaces, so as to use the username of a dial-in party to locate the corresponding dialer interface for the call. In this mode, physical interfaces and dialer interfaces are dynamically bound. Furthermore, a dialer interface can only call a destination address as specified in the dialer number command.
The physical interfaces in DCC use the network addresses of their associated dialer interface rather than being assigned separate addresses.
# Create dialer interface Dialer 1.
reset counters interface
Use reset counters interface to clear the statistics of a dialer interface.
reset counters interface [ dialer [ number ] ]
2: System level
number: Dialer interface number. The value of this argument can be the number of any existing dialer interface.
Before sampling network traffic within a specific period of time on an interface, you must clear the existing statistics.
If neither dialer nor the number is specified, this command clears the statistics of all the interfaces.
If only dialer is specified, this command clears the statistics of all dialer interfaces.
If both dialer and the number are specified, this command clears the statistics of the specified dialer interface.
# Clear the statistics of Dialer 1.
<Sysname> reset counters interface dialer 1
