03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10103-Layer 2 Command Reference
01-Ethernet Interface Commands
01-Ethernet Interface Commands 145.44 KB
broadcast-suppression
Use broadcast-suppression to set the broadcast suppression threshold on an Ethernet interface or a group of Ethernet interfaces.
Use undo broadcast-suppression to restore the default broadcast suppression threshold.
broadcast-suppression { ratio | pps max-pps }
Ethernet interfaces do not suppress broadcast traffic.
Layer 2 Ethernet interface view, port group view
Default command level
2: System level
ratio: Sets the broadcast suppression threshold as a percentage of the maximum interface rate. The smaller the percentage, the less broadcast traffic is allowed to be received. This argument ranges from 1 to 100.
pps max-pps: Specifies the maximum number of broadcast packets that the Ethernet interface can receive per second. The max-pps argument ranges from 1 to 1488100 pps.
·          When the pps keyword is specified, and a suppression granularity larger than 1 is specified on the device, the value of the pps keyword must be no smaller than, and an integer multiple of, the granularity. The broadcast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual broadcast suppression threshold value on an Ethernet interface, use the display interface command.
·          When the pps keyword is not specified, or the suppression granularity is set to 1, the value of the pps keyword must be no smaller than 1, and the broadcast suppression threshold value is the one that actually takes effect on the Ethernet interface.
In Ethernet interface view, the configuration takes effect only on the interface. In port group view, the configuration takes effect on all the ports in the port group.
When the received broadcast traffic exceeds the broadcast suppression threshold, the interface discards broadcast packets until broadcast traffic drops below the threshold.
If you set different broadcast suppression thresholds in Ethernet interface view or port group view multiple times, the one configured last takes effect.
# Set the broadcast suppression threshold to 20% on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression 20
# Set the broadcast suppression threshold to 20% on all ports in the manual port group named group1.
[Sysname] port-group manual group1
[Sysname-port-group-manual-group1] group-member GigabitEthernet 1/0/1
[Sysname-port-group-manual-group1] group-member GigabitEthernet 1/0/2
[Sysname-port-group-manual-group1] broadcast-suppression 20
default
Use default to restore the default settings for an Ethernet interface.
default
2: System level
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can identify these commands by using the display this command in interface view, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings for interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to change the description of the interface.
The default description of an interface is the interface name plus Interface. For example, GigabitEthernet1/0/1 Interface.
2: System level
text: Specifies the interface description, a string of 1 to 80 characters. The string can include case-sensitive letters, digits, special characters such as tilde (~), exclamation point (!), at sign (@), pound sign (#), dollar sign ($), percent sign (%), caret (^), ampersand sign (&), asterisk (*), left brace({), right brace (}), left parenthesis ((), right parenthesis ()), left bracket ([), right bracket (]), left angle bracket (<), right angle bracket (>), hyphen (-), underscore(_), plus sign (+), equal sign (=), vertical bar (|), back slash (\), colon (:), semi-colon (;) quotation marks ("), apostrophe ('), comma (,), dot (.), and slash (/), spaces, and other Unicode characters and symbols.
When you specify a description, follow these guidelines:
·          Each Unicode character takes the space of two regular characters.
·          To use Unicode characters or symbols in an interface description, install the specific input method editor and log in to the device through remote login software that supports the character type.
·          When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character in half. This might result in garbled characters at the end of a line.
# Change the description of interface GigabitEthernet 1/0/1 to lanswitch-interface.
[Sysname-GigabitEthernet1/0/1] description lanswitch-interface
display interface
display interface
Use display interface to display Ethernet interface information.
display interface [ interface-type ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface interface-type interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
down: Displays information about interfaces in the down state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no interface type is specified, this command displays information about all interfaces.
If an interface type is specified but no interface number is specified, this command displays information about all interfaces of the specified type.
# Display detailed information about Layer 2 interface GigabitEthernet 1/0/1.
<Sysname> display interface GigabitEthernet 1/0/1
GigabitEthernet1/0/1 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 006a-07dd-9600
 Description: lanswitch-interface
 Loopback is not set
 Media type is twisted pair, promiscuous mode set
 100Mbps-speed mode, full-duplex mode
 Flow-control is not enabled
 The Maximum Frame Length is 1600
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 PVID: 1
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Port priority: 0
 Last clearing of counters:  Never
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
 Input (total):  1945 packets, 247903 bytes
          1156 unicasts, 688 broadcasts, 101 multicasts, - pauses
 Input (normal):  1945 packets, 247903 bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, - parity errors
 Output (total): 1116 packets, 76088 bytes
          975 unicasts, 141 broadcasts, 0 multicasts, - pauses
 Output (normal): 1116 packets, 76088 bytes
 Output: 0 output errors, 0 underruns, 0 buffer failures
          - lost carrier, 0 no carrier
Physical state of the Ethernet interface. For more information, see Table 2.
Ethernet framing format on the interface.
Loopback
Loopback testing status of the interface.
100Mbps-speed mode
The interface is operating at 100 Mbps.
This field displays Unknown-speed mode when the interface is disconnected from the peer that it will automatically negotiate a port speed with.
full-duplex mode
The interface is operating in full-duplex mode.
The interface will negotiate a speed with its peer.
The interface will negotiate a duplex mode with its peer.
Maximum Ethernet frame length allowed on the interface.
Broadcast MAX-ratio
Broadcast suppression threshold as a percentage of the maximum interface rate. When the threshold is exceeded, the interface drops broadcast packets.
Unicast MAX-ratio
Unknown unicast suppression threshold as a percentage of the maximum interface rate. When the threshold is exceeded, the interface drops unknown unicast packets.
Multicast MAX-ratio
Multicast suppression threshold as a percentage of the maximum interface rate. When the threshold is exceeded, the interface drops multicast packets.
PVID
Port VLAN ID.
Port link-type
Link type of the interface, which can be access, trunk, or hybrid.
Tagged   VLAN ID
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLAN ID
VLANs for which the interface sends packets after removing VLAN tags.
Time when the reset counters interface command was last used to clear statistics on the interface. Never indicates that the reset counters interface command was never used since the device was started.
Average rate of input and output traffic in the last 300 seconds, in pps and Bps.
The statistics polling interval, 300 seconds in this example, can be configured by using the flow-interval command.
Inbound traffic statistics (in packets and bytes) for the interface. All inbound normal and abnormal packets (including unicast, broadcast, and multicast), and pause frames were counted.
Inbound normal traffic (including unicast, broadcast, and multicast) and pause frame statistics (in packets and bytes) for the interface.
Inbound packets with errors.
runts
Inbound frames that are shorter than 64 bytes, that are in correct format, and that contain valid CRCs.
giants
Inbound frames larger than the maximum frame length supported on the interface.
·         For an Ethernet interface that does not permit jumbo frames, giants refer to frames larger than 1536 bytes (without VLAN tags) or 1540 bytes (with VLAN tags).
·         For an Ethernet interface that permits jumbo frames, giants refer to frames larger than 9212 bytes (without VLAN tags) or 9216 bytes (with VLAN tags).
- throttles
Number of times that the port shut down because of buffer or CPU overload.
CRC
Total number of inbound frames that had a normal length, but contained checksum errors.
frame
Total number of inbound frames that contained checksum errors and a non-integer number of bytes.
- overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·         Fragment frames—CRC error frames shorter than 64 bytes. The length can be an integer or non-integer value.
·         Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integer or non-integer length). For an Ethernet interface that does not permit jumbo frames, jabber frames refer to CRC error frames greater than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, jabber frames refer to CRC error frames greater than the maximum size of Ethernet frames that are allowed to pass through the interface (which is configured when you configure jumbo frame support on the interface).
·         Symbol error frames—Frames that contained at least one undefined symbol.
·         Unknown operation code frames—Non-pause MAC control frames.
·         Length error frames—Frames whose 802.3 length fields did not accord with the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
- parity errors
Total number of frames with parity errors.
Outbound traffic statistics (in packets and bytes) for the port. All outbound normal and abnormal packets (including unicast, broadcast, and multicast), and pause frames were counted.
Outbound normal traffic (including unicast, broadcast, and multicast) and pause frame statistics (in packets and bytes) for the interface.
Outbound packets with errors.
- underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
- buffer failures
Number of packets dropped because the transmit buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits, because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter applies to serial WAN interfaces.
- no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter applies to serial WAN interfaces.
If an output field is not available, a hyphen (-) is displayed.
Table 2 Description on the possible physical states of a Layer 2 Ethernet interface
UP
The interface is physically up.
DOWN
The interface is physically down, because no physical connection exists (possibly because the network cable is disconnected or faulty).
DOWN ( Administratively )
The interface is physically down because it was shut down with the shutdown command. To restore its physical state, use the undo shutdown command.
DOWN ( Link-Aggregation interface down )
The interface is physically down, because the aggregate interface corresponding to the aggregation group to which it belongs was shut down with the shutdown command.
DOWN ( Loopback detection-protected )
The interface is shut down because a loop is detected on it.
# Display brief information about all interfaces.
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
NULL0                UP   UP(s)    --
Vlan1                UP   UP       192.168.100.134
Vlan2                DOWN DOWN     --
WLAN-Radio1/0/1      ADM  DOWN     --
WLAN-Radio1/0/2      ADM  DOWN     --
The brief information of interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
BAGG1                UP   1G(a)   F(a)   A    1    connect to the lab
GE1/0/1              DOWN auto    A      A    1    lanswitch-interface
GE1/0/2              UP   1G(a)   F(a)   A    1
WLAN-BSS2            DOWN --      --     A    1
WLAN-BSS32           DOWN --      --     H    1
WLAN-BSS33           DOWN --      --     H    1
WLAN-BSS34           DOWN --      --     A    1
# Filter the brief interface information to display the line starting with the (s) string and all subsequent lines.
<Sysname> display interface brief | begin (s)
NULL0                UP   UP(s)    --
Vlan2                DOWN DOWN     --
# Display brief information about all UP interfaces.
<Sysname> display interface brief | include UP
NULL0                UP   UP(s)    --
# Display the brief information about all but Ethernet interfaces.
<Sysname> display interface brief | exclude GE
NULL0                UP   UP(s)    --
Vlan2                DOWN DOWN     --
# Display information about interfaces in the down state and the relevant causes.
Vlan2                DOWN Not connected
WLAN-Radio1/0/1      ADM  Administratively
WLAN-Radio1/0/2      ADM  Administratively
GE1/0/1              DOWN Not connected
WLAN-BSS2            DOWN Not connected
WLAN-BSS32           DOWN Not connected
WLAN-BSS33           DOWN Not connected
WLAN-BSS34           DOWN Not connected
The command displays brief information about Layer 3 interfaces.
Link layer state of the interface:
·         ADM—The interface has been shut down by the network administrator. To recover its physical layer state, use the undo shutdown command.
·         Stby—The interface is a standby interface. You can use the display standby state command to check the corresponding primary interface.
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag, (a letter "s" in parentheses). This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·         UP—The link is up.
·         DOWN—The link is physically down.
·         ADM—The link has been administratively shut down. To recover its physical state, use the undo shutdown command.
Protocol
Protocol connection state of the interface, which can be UP, DOWN, or UP(s).
Interface description.
Information displayed in this field is restricted by space. To view the complete interface description, use the display interface command without specifying the brief keyword.
Brief information about Layer 2 interfaces.
If the speed of an interface is automatically negotiated, its speed attribute includes the auto negotiation flag, letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the following options:
·         (a)/A—Auto negotiation.
·         H—Half negotiation.
·         F—Full negotiation.
Link type options for Ethernet interfaces.
Speed
Interface rate, in bps.
Duplex
Duplex mode of the interface:
·         A—Auto negotiation.
·         F—Full duplex.
·         F(a)—Auto-negotiated full duplex.
·         H—Half duplex.
·         H(a)—Auto-negotiated half duplex.
Link type of the interface:
·         A—Access.
·         H—Hybrid.
·         T—Trunk.
PVID
Port VLAN ID.
Cause
Causes for the physical state of an interface to be DOWN. For more information, see Table 4.
Table 4 Causes for the physical state of an interface to be DOWN
Not connected
No physical connection exists (possibly because the network cable is disconnected or faulty).
Administratively
The port was shut down with the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
The aggregate interface corresponding to the aggregation group to which the interface belongs was shut down with the shutdown command.
interface
display loopback-detection
Use display loopback-detection to display the status of the loopback detection function.
display loopback-detection [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If loopback detection is enabled, this command also displays the detection interval and all ports in a loop condition.
# Display information about loopback detection.
<Sysname> display loopback-detection
 Loopback detection is running.
 Detection interval is 30 seconds.
 No port is detected with loopback.
Table 5 Command output
Detection interval time is 30 seconds.
Loopback detection interval is 30 seconds.
No loops are detected on any port.
display port-group manual
Use display port-group manual to display information about port groups.
display port-group manual [ all | name port-group-name ] [ | { begin | exclude | include } regular-expression ]
2: System level
all: Displays information about all port groups.
name port-group-name: Specifies the name of a port group, a string of 1 to 32 characters.
If the all keyword is specified, this command displays the name and member Ethernet interfaces of each port group on the device.
If a port group is specified, this command displays its name and member Ethernet interfaces.
If you do not specify the all keyword or any port group name, the command displays the name of each port group on the device.
# Display the names of all port groups.
<Sysname> display port-group manual
The following manual port group exist(s):
group1                                    group2
# Display detailed information about all port groups.
<Sysname> display port-group manual all
Member of group1:
    GigabitEthernet1/0/1     GigabitEthernet1/0/2
Member of group2:
None
# Display detailed information about the port group named group1.
<Sysname> display port-group manual name group1
Member of group1:
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default duplex mode of the Ethernet interface.
duplex { auto | full | half }
undo duplex
An Ethernet interfaces operate in auto negotiation mode.
2: System level
auto: Sets the interface to operate in auto negotiation mode.
full: Sets the interface to operate in full duplex mode.
half: Sets the interface to operate in half-duplex mode.
# Configure interface GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
flow-control
Use flow-control to enable TxRx mode generic flow control on an Ethernet interface.
Use undo flow-control to disable generic flow control on the Ethernet interface.
flow-control
undo flow-control
Generic flow control on an Ethernet interface is disabled.
2: System level
TxRx mode flow control allows an Ethernet interface to receive common pause frames from its peer, and send common pause frames to notify its peer of congestion.
With the flow-control command configured, an interface can both send and receive flow control frames:
·          When congested, the interface sends a flow control frame to its peer.
·          Upon receiving a flow control frame from its peer, the interface suspends sending packets.
To implement flow control on a link, enable the generic flow control function at both ends of the link.
# Enable TxRx mode generic flow control on the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-interval
Use flow-interval to set the interface statistics polling interval.
Use undo flow-interval to restore the default interval.
flow-interval interval
undo flow-interval
The interface statistics polling interval is 300 seconds.
2: System level
interval: Sets the statistics polling interval, in seconds. It ranges from 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds for all Ethernet interfaces.
[Sysname] flow-interval 100
group-member
Use group-member to assign Ethernet interfaces to a port group.
Use undo group-member to remove Ethernet interfaces from the port group.
group-member interface-list
undo group-member interface-list
A port group does not contain any member ports.
Port group view
2: System level
interface-list: Specifies an Ethernet interface list, in the form of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 interfaces or interface ranges.
If you use the group-member interface-type interface-start-number to interface-type interface-end-number command to add multiple ports in batch to the specified port group, make sure all these ports are of the same type and on the same interface card, and the interface-end-number argument must be greater than the interface-start-number argument.
# Assign GigabitEthernet 1/0/1 to the port group named group1.
interface
Use interface to enter interface view.
2: System level
# Enter the view of the interface GigabitEthernet 1/0/1.
loopback
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
undo loopback
Loopback testing is disabled on Ethernet interfaces.
2: System level
external: Enables external loopback testing for all on-chip functions related to Ethernet interfaces.
internal: Enables internal loopback testing for the hardware of Ethernet interfaces.
Enable loopback testing for troubleshooting purposes, such as identifying an Ethernet problem.
You cannot perform internal or external loopback testing on an administratively down (ADM DOWN) port. On a physically down (DOWN) port, you can perform only internal loopback testing.
During loopback testing, the speed, duplex, mdi, and shutdown commands are not available. In addition, the port is operating in full duplex mode, regardless of its duplex configuration. After loopback testing is disabled, the duplex configuration of the port is restored.
# Enable internal loopback testing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
loopback-detection control enable
Use loopback-detection control enable to enable loopback detection control on trunk or hybrid ports.
Use undo loopback-detection control enable to restore the default.
Loopback detection control is disabled on trunk and hybrid ports.
2: System level
When a hybrid or trunk port detects a loop condition, it sends traps, whether loopback detection control is enabled or not. However, the port performs the protective action that you configure with the loopback-detection action command only after loopback detection control is enabled.
This command is not applicable to access ports.
# Enable loopback detection control on the trunk port GigabitEthernet 1/0/1.
[Sysname] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection control enable
Use loopback-detection enable to enable loopback detection globally in system view or on interfaces in Ethernet interface or port group view. To use loopback detection on an Ethernet interface, you must enable the function both globally and on the port.
Use undo loopback-detection enable to disable loopback detection globally or on Ethernet interfaces.
Loopback detection is disabled on all Ethernet interfaces.
System view, Layer 2 Ethernet interface view, port group view
2: System level
The undo loopback-detection enable command in system view disables loopback detection on all interfaces.
If an interface receives a packet that it sent out, a loop has occurred. Loops might cause broadcast storms, which degrade network performance. You can enable loopback detection to detect loops on an interface and, if the interface supports the loopback-detection action command, configure the protective action to take (for example, shut down the port) when a loop is detected.
In addition to the configured protective action, the device also performs other actions to alleviate the impact of the loops. For more information, see Table 6.
Table 6 Actions to take upon detection of a loop condition
Port type
Actions
Access port
·         Place the interface in controlled mode. The interface discards all incoming packets, but still forwards outgoing traffic.
·         Generate traps.
·         Delete all MAC address entries of the interface.
Hybrid or trunk port
·         Generate traps.
·         If loopback detection control is enabled, set the interface to controlled mode. The interface discards all incoming packets, but still forwards outgoing packets.
# Enable loopback detection on GigabitEthernet 1/0/1.
loopback-detection interval-time
Use loopback-detection interval-time to set the loopback detection interval.
Use undo loopback-detection interval-time to restore the default loopback detection interval.
loopback-detection interval-time time
The loopback detection interval is 30 seconds.
2: System level
time: Specifies the loopback detection interval, ranging from 5 to 300 seconds.
# Set the loopback detection interval to 10 seconds.
[Sysname] loopback-detection interval-time 10
multicast-suppression
Use multicast-suppression to set the multicast suppression threshold on an Ethernet interface or a group of Ethernet interfaces.
Use undo multicast-suppression to restore the default multicast suppression threshold.
multicast-suppression { ratio | pps max-pps }
Ethernet interfaces do not suppress multicast traffic.
2: System level
ratio: Sets the multicast suppression threshold as a percentage of the maximum interface rate, ranging from 1 to 100. The smaller the percentage, the less multicast traffic is allowed to be received.
pps max-pps: Specifies the maximum number of multicast packets that the Ethernet interface can receive per second. The max-pps argument ranges from 1 to 1488100 pps.
·          When the pps keyword is specified, and a suppression granularity larger than 1 is specified on the device, the value of the pps keyword must be no smaller than, and an integer multiple of, the granularity. The multicast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual multicast suppression threshold value on an Ethernet interface, use the display interface command.
·          When the pps keyword is not specified, or the suppression granularity is set to 1, the value of the pps keyword must be no smaller than 1, and the multicast suppression threshold value is the one that actually takes effect on the Ethernet interface.
In Ethernet interface view, the configurations take effect only on the interface. In port group view, the configurations take effect on all ports in the port group.
When the received multicast traffic exceeds the threshold, the system discards multicast packets until multicast traffic drops below the threshold.
If you set different multicast suppression thresholds in Ethernet interface view or port group view multiple times, the one configured last takes effect.
# Set the multicast threshold to 20% on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression 20
# Set the multicast threshold to 20% on all ports in the port group named group1.
[Sysname-port-group-manual-group1] multicast-suppression 20
port-group manual
Use port-group manual to create a port group and enter port group view.
Use undo port-group manual to remove a port group.
port-group manual port-group-name
undo port-group manual port-group-name
No port groups exist.
2: System level
port-group-name: Sets the port group name, a string of 1 to 32 characters.
# Create port group group1.
Use reset counters interface to clear the Ethernet interface statistics.
reset counters interface [ interface-type [ interface-number ] ]
2: System level
Clear old statistics on the interface before collecting new traffic statistics for a specific period of time.
·          If no interface type is specified, this command clears statistics for all interfaces on the device.
·          If only the interface type is specified, this command clears statistics for all interfaces of the specified type.
·          If both the interface type and number are specified, this command only clears statistics for the specified interface.
# Clear the statistics of GigabitEthernet 1/0/1.
<Sysname> reset counters interface GigabitEthernet 1/0/1
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
Ethernet interfaces are up.
2: System level
You may need to shut down and then bring up an Ethernet interface to activate configuration changes such as speed or duplex mode changes.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
# Shut down all member ports in the port group named group1.
[Sysname-port-group-manual-group1] shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | auto }
undo speed
An Ethernet interface automatically negotiates a speed with its peer port.
2: System level
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
# Configure GigabitEthernet 1/0/1 to operate at 100 Mbps.
[Sysname-GigabitEthernet1/0/1] speed 100
unicast-suppression
Use unicast-suppression to set the unknown unicast suppression threshold on an Ethernet interface or a group of Ethernet interfaces.
Use undo unicast-suppression to restore the default.
unicast-suppression { ratio | pps max-pps }
Ethernet interfaces do not suppress unknown unicast traffic.
2: System level
ratio: Sets the unknown unicast suppression threshold as a percentage of the maximum interface rate, ranging from 1 to 100. The smaller the percentage, the less unknown unicast traffic is allowed to be received.
pps max-pps: Specifies the maximum number of unknown unicast packets that the Ethernet interface can receive per second. The max-pps argument ranges from 1 to 1488100 pps.
·          When the pps keyword is specified, and a suppression granularity larger than 1 is specified on the device, the value of the pps keyword must be no smaller than, and an integer multiple of, the granularity. The unknown unicast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual unknown unicast suppression threshold value on an Ethernet interface, use the display interface command.
·          When the pps keyword is not specified, or the suppression granularity is set to 1, the value of the pps keyword must be no smaller than 1, and the unknown unicast suppression threshold value is the one that actually takes effect on the Ethernet interface.
In Ethernet interface view, the configuration will take effect only on the interface. In port group view, the configuration will take effect on all ports in the port group.
When the received unknown unicast traffic exceeds the threshold, the system discards unknown unicast packets until unknown unicast traffic drops below the threshold.
If you set different unknown unicast suppression thresholds in Ethernet interface view or port group view multiple times, the one configured last takes effect.
# Set the unknown unicast threshold to 20% on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] unicast-suppression 20
# Set the unknown unicast threshold to 20% on all ports of port group group1.
[Sysname-port-group-manual-group1] unicast-suppression 20
