03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10103-Layer 2 Command Reference
08-PPP Commands
08-PPP Commands 109.15 KB
ip address ppp-negotiate
Use ip address ppp-negotiate to enable IP address negotiation on the local interface, so that the local interface can accept the IP address allocated by the peer end.
Use undo ip address ppp-negotiate to disable IP address negotiation.
IP address negotiation is disabled.
Dialer interface view
Default command level
2: System level
# Enable IP address negotiation on the interface Dialer 1.
[Sysname] interface Dialer 1
[Sysname-Dialer1] ip address ppp-negotiate
·          ppp ipcp remote-address forced
·          remote address
ip pool
Use ip pool to configure an address pool for assigning IP addresses to PPP users.
Use undo ip pool to remove an address pool.
ip pool pool-number low-ip-address [ high-ip-address ]
undo ip pool pool-number
No IP address pool is configured for PPP users.
System view, ISP domain view
2: System level
pool-number: Number of the address pool, in the range of 0 to 99.
low-ip-address: Start address of the address pool.
high-ip-address: End IP address of the address pool. An address pool can contain up to 1024 IP addresses. If the end IP address is not specified, the address pool has only one IP address, the start IP address.
IP address pools configured in system view are for PPP users that do not need authentication. To configure an IP address pool for the peer PPP users, use the remote address command in a specified interface view.
IP address pools configured in ISP domain view are for PPP users that need authentication in the specified ISP domain. These IP address pools apply to the interfaces that connect to a larger number of PPP users than those the interfaces can assign IP addresses to.
# Configure IP address pool 0, with the IP addresses ranging from 129.102.0.1 to 129.102.0.10.
[Sysname] domain test
[Sysname-isp-test] ip pool 0 129.102.0.1 129.102.0.10
remote address
link-protocol ppp
Use link-protocol ppp to enable PPP encapsulation on an interface.
link-protocol ppp
PPP encapsulation is enabled on all the interfaces except for Ethernet and VLAN interfaces.
2: System level
# Enable PPP encapsulation on the interface Dialer 1.
[Sysname-Dialer1] link-protocol ppp
ppp account-statistics enable
Use ppp account-statistics enable to enable PPP traffic statistics collection.
Use undo ppp account-statistics enable to disable PPP traffic statistics collection.
ppp account-statistics enable [ acl { acl-number | name acl-name } ]
PPP traffic statistics collection is disabled.
2: System level
acl: Generates PPP accounting statistics for traffic that matches the configured ACL. If no ACL is configured, the device generates PPP accounting statistics for all traffic.
acl-number: ACL number, in the range of 2000 to 3999, where:
·          2000 to 2999 are numbers for basic IPv4 ACLs.
·          3000 to 3999 are numbers for advanced IPv4 ACLs.
name acl-name: Specifies an ACL by its name. The acl-name represents the name of an IPv4 ACL, a case-sensitive string that starts with an English letter and contains 1 to 63 characters. To avoid confusion, do not use the English word all as an IPv4 ACL name.
# Enable PPP traffic statistics collection on the interface Dialer 1.
[Sysname-Dialer1] ppp account-statistics enable
ppp authentication-mode
Use ppp authentication-mode to configure the PPP authentication mode.
Use undo ppp authentication-mode to disable PPP authentication.
ppp authentication-mode { chap | ms-chap | ms-chap-v2 | pap } * [ [ call-in ] domain isp-name ]
PPP authentication is disabled.
2: System level
chap: Uses CHAP authentication.
ms-chap: Uses MS-CHAP authentication.
ms-chap-v2: Uses MS-CHAP-V2 authentication.
pap: Uses PAP authentication.
call-in: Authenticates the call-in users only.
domain isp-name: Specifies the domain name for authentication, a case-insensitive string of 1 to 24 characters.
If you run the ppp authentication-mode command with the domain keyword specified, you must configure an address pool in the corresponding domain. You can use the display domain command to display the domain configuration.
If you configure the ppp authentication-mode command without specifying the domain name, the system checks the username for domain information. If the username contains a domain name, the domain will be used for authentication. If the domain does not exist, the user's access request will be denied. If the username does not contain a domain name, the default domain is used. You can use the domain default command to configure the default domain. If no default domain is configured, the default domain system is used by default.
PPP authentication falls into the following categories:
·          PAP—Two-way handshake authentication. The password used is in plain text.
·          CHAP—Three-way handshake authentication. The password is in cipher text.
·          MS-CHAP—Three-way handshake authentication. The password is in cipher text.
·          MS-CHAP-V2—Three-way handshake authentication. The password is in cipher text.
You can configure several authentication modes simultaneously. In addition, you can also use the AAA authentication algorithm list (if defined) to authenticate users.
In any PPP authentication mode, AAA determines whether a user can pass the authentication through a local authentication database or an AAA server. For more information about AAA authentication, see Security Configuration Guide.
# Configure the interface Dialer 1 to authenticate the peer device by using PAP.
[Sysname-Dialer1] ppp authentication-mode pap domain system
# Configure the interface Dialer 2 to authenticate the peer device by using PAP, CHAP, and MS-CHAP.
[Sysname] interface Dialer 2
[Sysname-Dialer2] ppp authentication-mode pap chap ms-chap domain system
·          domain default (Security Command Reference)
·          local-user (Security Command Reference)
·          ppp chap password
·          ppp chap user
·          ppp pap local-user
ppp chap password
Use ppp chap password to set the password for CHAP authentication.
Use undo ppp chap password to cancel the configuration.
ppp chap password { cipher | simple } password
2: System level
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies the password string for CHAP authentication. This argument is case sensitive. If simple is specified, it must be a string of 1 to 48 characters. If cipher is specified, it must be a ciphertext string of 1 to 97 characters.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
# Set the password for CHAP authentication to a plaintext password sysname.
[Sysname-Dialer1] ppp chap password simple sysname
ppp authentication-mode chap
ppp chap user
Use ppp chap user to set the username for CHAP authentication.
Use undo ppp chap user to cancel the configuration.
ppp chap user username
undo ppp chap user
The username for CHAP authentication is null.
2: System level
username: Username for CHAP authentication, a case-sensitive string of 1 to 80 characters. The username is sent to the peer device for the local device to be authenticated.
To pass CHAP authentication, the username/password of one side must be the local username/password of the peer.
# Set the username for CHAP authentication as Root on the interface Dialer 1.
[Sysname-Dialer1] ppp chap user Root
Use ppp ipcp remote-address forced to configure a device to assign an IP address to the peer by force. This command also disables the peer from using a locally configured IP address.
Use undo ppp ipcp remote-address forced to cancel the configuration.
The peer is allowed to use its locally configured IP address. The local end assigns an IP address to the peer only when being explicitly requested to do so. When the peer already has an IP address, the local end will not assign one to the peer.
2: System level
To disable the peer from using a locally configured IP address, configure the ppp ipcp remote-address forced command.
# Configure an optional IP address 10.0.0.1 on the interface Dialer 1 for the peer.
[Sysname-Dialer1] remote address 10.0.0.1
# Configure IP address 10.0.0.1 on the interface Dialer 2 for the peer and assign the IP address to the peer by force.
[Sysname-Dialer2] remote address 10.0.0.1
[Sysname-Dialer2] ppp ipcp remote-address forced
remote address
ppp pap local-user
Use ppp pap local-user to set the local username and password for PAP authentication.
Use undo ppp pap local-user to cancel the local username and password configured.
ppp pap local-user username password { cipher | simple } password
The username and the password for PAP authentication are not set.
2: System level
username: Username of the local device for PAP authentication, a case-sensitive string of 1 to 80 characters.
password: Specifies the password string for PAP authentication. If simple is specified, it must be a string of 1 to 48 characters. If cipher is specified, it must be a ciphertext string of 1 to 97 characters.
For the local device to pass PAP authentication on the remote device, make sure the same username and password configured for the local device are also configured on the remote device with the commands local-user username and password { cipher | simple } password.
# Configure the local username and password for PAP authentication to plaintext passwords user1 and pass1.
[Sysname-Dialer1] ppp pap local-user user1 password simple pass1
·          password (Security Command Reference)
ppp timer negotiate
Use ppp timer negotiate to set the PPP negotiation timeout time.
Use undo ppp timer negotiate to restore the default.
ppp timer negotiate seconds
The PPP negotiation timeout time is three seconds.
2: System level
seconds: Negotiation timeout time to be set, in the range of 1 to 10 (in seconds). In PPP negotiation, if the local device receives no response from the peer during this period after it sends a packet, the local device sends the last packet again.
# Set the PPP negotiation timeout time to five seconds.
[Sysname-Dialer1] ppp timer negotiate 5
remote address
Use remote address to set the IP address to be assigned to the peer device, or to specify the address pool used for assigning an IP address to the peer device.
Use undo remote address to cancel the IP address configured to be assigned to the peer device.
remote address { ip-address | pool [ pool-number ] }
undo remote address
An interface does not assign IP addresses to the peer device.
2: System level
ip-address: IP address to be assigned to the peer device.
pool [ pool-number ]: Specifies the number of the address pool used for assigning an IP address to the peer. The pool-number argument ranges from 0 to 99 and defaults to 0.
The remote address command can be used when the local device is configured with an IP address, but the peer has no IP address. To enable the peer device to accept the IP address assigned to it by the local device, you must configure the ip address ppp-negotiate command on the peer device in addition to configuring the remote address command on the local device.
The IP address assigned to the peer device by the local device is not mandatory on the peer device, or the peer device can still use a locally configured IP address even if the local device assigned one to it. To make the IP address assigned by the local device mandatory, you must configure the ppp ipcp remote-address forced command.
After you use the remote address command to assign an IP address for the peer device, you cannot configure the remote address/undo remote address command for the peer again unless the peer releases the assigned IP address. Shut down the port to release the assigned IP address before you configure the remote address/undo remote address command for the peer. However, after you use the command to assign an IP address to the peer from the address pool of the specified domain through AAA authentication, you can configure the command for the peer again. In this case, the original assigned IP address can still work, and the newly assigned IP address is used when the original one is released or used by a new PPP access.
This command does not take effect until the next IPCP negotiation. To make the remote address command take effect, configure the remote address command before the ip address command.
# Specify the IP address to be assigned to the peer device through the interface Dialer 1 as 10.0.0.1.
·          ip address ppp-negotiate
timer hold
Use timer hold to set the interval for sending keepalive packets.
Use undo timer hold to restore the default, or 10 seconds.
timer hold seconds
undo timer hold
2: System level
seconds: Interval (in seconds) for sending keepalive packets, in the range 0 to 32767. A value of 0 disables keepalive packet sending.
Because a slow link takes a long period of time to transmit large packets, the sending and receiving of keepalives may be delayed so long that one end cannot receive keepalive packets from the peer for a specific number of keepalive periods and shuts down the link. To prevent this, set the interval for sending keepalive packets to a relatively longer length of time.
# Set the interval for sending keepalive packets to 20 seconds on the interface Dialer 1.
[Sysname-Dialer1] timer hold 20
display pppoe-client session
Use display pppoe-client session to display information about a PPPoE session.
display pppoe-client session { packet | summary } [ dial-bundle-number number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
packet: Displays the packet statistics on PPPoE sessions.
summary: Displays PPPoE session summary.
dial-bundle-number number: Displays the statistics on a PPPoE session. The number argument ranges from 1 to 255. If this option is not specified, this command displays the statistics on all the PPPoE sessions.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display PPPoE session summary.
<Sysname> display pppoe-client session summary
PPPoE Client Session:
ID   Bundle  Dialer  Intf             RemMAC        LocMAC        State
0    1       NULL    VLAN2            000000000000  006a7d539600  IDLE
0    2       NULL    VLAN2            000000000000  006a7d539600  IDLE
ID
PPPoE session ID.
Bundle
Dialer bundle to which a PPPoE session belongs.
Dialer
Dialer interface corresponding to a PPPoE session.
Intf
VLAN interface where the PPPoE session is present.
RemMAC
Remote MAC address.
LocMAC
Local MAC address.
PPPoE session state. PPPoE session state is the PPP protocol state. PPPUP indicates that PPP negotiation is successful.
# Display the packet statistics on PPPoE sessions.
<Sysname> display pppoe-client session packet
  ID: 0                            Interface: Vlan2
  InPackets: 0                     OutPackets: 0
  InBytes:   0                     OutBytes:   0
  InDrops:   0                     OutDrops:   0
ID
PPPoE session ID.
VLAN interface corresponding to a PPPoE session.
InPackets
Number of packets received.
InBytes
Size of received packets (in bytes).
InDrops
Number of discarded incoming packets.
OutPackets
Number of packets sent.
OutBytes
Size of sent packets (in bytes).
OutDrops
Number of discarded outgoing packets.
pppoe-client
Use pppoe-client to establish a PPPoE session and specify the dialer bundle corresponding to the session.
Use undo pppoe-client to remove a PPPoE session.
pppoe-client dial-bundle-number number [ no-hostuniq ] [ diagnose [ interval seconds ] | idle-timeout seconds [ queue-length packets ] ]
undo pppoe-client dial-bundle-number number
The Host-Uniq field is carried.
No PPPoE session is established.
VLAN interface view
2: System level
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session, in the range of 1 to 255. A dialer bundle number uniquely identifies a PPPoE session, it can also be used as a PPPoE session ID.
no-hostuniq: Specifies the client not to carry the Host-Uniq field. diagnose: Specifies the operating mode of the PPPoE session to diagnostic.
interval seconds: Specifies the interval (in seconds) between two diagnostic PPPoE sessions. The seconds argument ranges from 5 to 65535. The default value is 120.
idle-timeout seconds: Specifies the PPPoE session idle time. The seconds argument ranges from 1 to 65535. If this option is specified, the PPPoE session operates in packet-triggered mode; if this option and the diagnose keyword are not specified, the PPPoE session established operates in permanent mode.
queue-length packets: Specifies the number of the packets that can be cached before the PPPoE session is established. The packets argument ranges from 1 to 100 and defaults to 10. This option becomes valid only when the idle-timeout keyword is configured.
You can establish multiple PPPoE sessions on a VLAN interface, or a VLAN interface can belong to multiple dialer bundles. However, a dialer bundle can correspond to only one VLAN interface. Each PPPoE session uniquely corresponds to a dialer bundle. If a VLAN interface in a dialer bundle of a dialer interface is used to establish a PPPoE session, you cannot add any interfaces to the dialer bundle.
A PPPoE session operates in one of these three modes:
·          Permanent mode—If you configure the pppoe-client command without specifying the idle-timeout seconds option or the diagnose keyword, the device initiates a PPPoE call to establish a PPPoE session immediately if the physical line is up. After the PPPoE session is established, it can only be terminated by the undo pppoe-client command.
·          Packet-triggered mode—If you configure the pppoe-client command with the idle-timeout seconds option specified, the device tries to establish the PPPoE session only when it has data to transmit. For a PPPoE session operating in this mode, if no data is transmitted across it within the period specified by the seconds argument, the PPPoE session is terminated automatically.
·          Diagnostic mode—If you configure the pppoe-client command with the diagnose keyword specified, the device initiates a PPPoE call to establish a PPPoE session immediately after this command is configured, and terminates the current PPPoE session and then establishes another PPPoE session each time the interval specified by interval seconds expires. By periodically establishing and terminating PPPoE sessions, this function can be used to detect whether the PPPoE link is normal. Only one diagnostic PPPoE session can be established on each device.
The difference between the reset pppoe-client command and the undo pppoe-client command lies in that the former only temporarily terminates a PPPoE session, but the latter permanently removes a PPPoE session.
After you configure the undo pppoe-client command, the PPPoE session identified by the number argument is removed permanently, regardless of the operating mode of the PPPoE session. To use the PPPoE session again, you must establish it from scratch.
# Establish a PPPoE session on VLAN-interface 1.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] pppoe-client dial-bundle-number 1
reset pppoe-client
reset pppoe-client
Use reset pppoe-client to reset a PPPoE session corresponding to a dialer bundle for the PPPoE session to be initiated again.
reset pppoe-client { all | dial-bundle-number number }
2: System level
all: Clears all the PPPoE sessions.
dial-bundle-number number: Specifies a dialer bundle by its number. The number argument ranges from 1 to 255.
A PPPoE session in permanent mode and terminated by this command will be established again in 16 seconds. A PPPoE session in packet-triggered mode and terminated by this command will be established again only when there is a need for data transmission.
The difference between the reset pppoe-client command and the undo pppoe-client command lies in: the former only temporarily terminates a PPPoE session, but the latter permanently removes a PPPoE session.
# Reset all the PPPoE sessions.
<Sysname> reset pppoe-client all
pppoe-client
