03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10103-Layer 2 Command Reference
03-MAC Address Table Commands
03-MAC Address Table Commands 88.82 KB
MAC address table configuration commands
The MAC address table configuration is supported only on Layer 2 Ethernet ports, WLAN-BSS interfaces, and Layer 2 aggregate interfaces.
This document covers only the configuration of MAC address entries, including static, dynamic, and destination blackhole MAC address entries.
display mac-address
Use display mac-address to display MAC address entries.
display mac-address [ mac-address [ vlan vlan-id ] | [ [ dynamic | static ] [ interface interface-type interface-number ] | blackhole ] [ vlan vlan-id ] [ count ] ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
blackhole: Displays destination blackhole MAC address entries. These entries do not age, but you can add or remove them. The packets whose destination MAC addresses match destination blackhole MAC address entries are dropped.
vlan vlan-id: Specifies a VLAN. The vlan-id argument ranges from 1 to 4094.
count: Displays the number of MAC address entries that match all entry attributes you specify in the command. When this keyword is used, the command displays only the number of specified MAC address entries, rather than related information about these MAC address entries.
mac-address: Specifies a MAC address in the format of H-H-H.
dynamic: Displays dynamic MAC address entries, which can be aged.
static: Displays static MAC address entries, which do not age.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the MAC address entry for MAC address 000f-e201-0101.
<Sysname> display mac-address 000f-e201-0101
MAC ADDR        VLAN ID    STATE            PORT INDEX              AGING TIME(s)
000f-e201-0101  1          Learned          GigabitEthernet1/0/1    AGING
  ---  1 mac address(es) found  ---
MAC ADDR
MAC address.
VLAN ID
ID of the VLAN to which the MAC address belongs.
STATE
State of a MAC address entry:
·         Config static—Static entry manually configured by the user.
·         Config dynamic—Dynamic entry manually configured by the user.
·         Learned—Entry learned by the device.
·         Blackhole—Destination blackhole entry.
·         AUTH—Entry generated after a user passes the MAC authentication. For more information about MAC authentication, see Security Configuration Guide.
·         802.1X—Entry generated after a user passes the 802.1X authentication. For more information about 802.1X authentication, see Security Configuration Guide.
PORT INDEX
Outgoing port for packets that are destined for the MAC address. This field displays N/A for a blackhole MAC address entry.
AGING TIME(s)
Aging time:
·         AGING—The entry is aging.
·         NOAGED—The entry does not age.
Number of matching MAC address entries.
·          mac-address (interface view)
·          mac-address (system view)
·          mac-address timer
display mac-address aging-time
Use display mac-address aging-time to display the aging timer for dynamic MAC address entries.
display mac-address aging-time [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the aging timer for dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The output shows that the aging timer for dynamic entries in the MAC address table is 300 seconds.
·          display mac-address
·          mac-address timer
display mac-address mac-learning
Use display mac-address mac-learning to display the MAC address learning status of the specified or all Layer 2 Ethernet ports.
display mac-address mac-learning [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display MAC address learning status of all Ethernet ports.
<Sysname> display mac-address mac-learning
Mac address learning status of the switch: enable
PortName                       Learning Status
Bridge-Aggregation1               disable
GigabitEthernet1/0/1              enable
GigabitEthernet1/0/2              enable
WLAN-BSS1                         disable
WLAN-BSS2                         enable
WLAN-BSS32                        enable
WLAN-BSS33                        enable
WLAN-BSS34                        enable
Mac-address learning status of the switch
Global MAC address learning status (enabled or disabled).
PortName
Port name.
Learning Status
MAC address learning status (enabled or disabled) for a port.
Use mac-address to add or modify a MAC address entry on a specified interface.
Use undo mac-address to remove a MAC address entry on the interface.
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
No MAC address entry is configured.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, WLAN-BSS interface view
2: System level
dynamic: Specifies dynamic MAC address entries. These entries can age.
static: Specifies static MAC address entries. They do not age, but you can add or remove them.
mac-address: Specifies a MAC address in the format of H-H-H, where 0s at the beginning of each H (16-bit hexadecimal digit) can be omitted. For example, entering "f-e2-1" indicates that the MAC address is "000f-00e2-0001."
vlan vlan-id: Specifies an existing VLAN to which the Ethernet interface belongs, where vlan-id is the specified VLAN ID, ranging from 1 to 4094.
The MAC address entries configuration cannot survive a reboot unless you save it. However, the dynamic MAC address entries are lost at next reboot regardless of whether you save the configuration or not.
# Add a static entry for MAC address 000f-e201-0101 on port GigabitEthernet 1/0/1 that belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address static 000f-e201-0101 vlan 2
# Add a static entry for MAC address 000f-e201-0102 on port Bridge-Aggregation 1 that belongs to VLAN 1.
[Sysname-Bridge-Aggregation1] mac-address static 000f-e201-0102 vlan 1
display mac-address
Use mac-address to add or modify a MAC address entry.
Use undo mac-address to remove one or all MAC address entries.
undo mac-address [ { dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
2: System level
blackhole: Specifies destination blackhole MAC address entries. These entries do not age, but you can add or remove them. The packets whose destination MAC addresses match destination blackhole MAC address entries are dropped.
dynamic: Specifies dynamic MAC address entries, which can be aged.
static: Specifies static MAC address entries. These entries do not age, but you can add or remove them.
interface interface-type interface-number: Specifies an outbound interface by its type and number.
A static or blackhole MAC address entry will not be overwritten by a dynamic MAC address entry. A dynamic MAC address entry can be overwritten by a static or blackhole MAC address entry.
If you execute the undo mac-address command without specifying any parameters, this command deletes all MAC address entries.
You can delete all the MAC address entries of a VLAN, or you can choose to delete a specific type (dynamic, static, or blackhole) of MAC address entries only.
# Add a static entry for MAC address 000f-e201-0101. All frames destined to this MAC address are sent out of port GigabitEthernet 1/0/1 which belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface gigabitethernet 1/0/1 vlan 2
display mac-address
mac-address mac-learning disable
Use mac-address mac-learning disable to disable MAC address learning globally or on interfaces.
Use undo mac-address mac-learning disable to enable MAC address learning globally or on interfaces.
MAC address learning is enabled.
System view, Layer 2 Ethernet interface view, WLAN-BSS interface view, port group view, Layer 2 aggregate interface view
2: System level
Follow these guidelines when you configure MAC address learning:
·          You may need to disable MAC address learning to prevent the MAC address table from being saturated. For example, when your device is being attacked by many packets with different source MAC addresses, it affects the update of the MAC address table.
·          Because disabling MAC address learning may result in broadcast storms, enable broadcast storm suppression after you disable MAC address learning on a port.
# Disable global MAC address learning.
[Sysname] mac-address mac-learning disable
# Disable MAC address learning on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-address mac-learning disable
# Disable MAC address learning on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] mac-address mac-learning disable
mac-address max-mac-count
Use mac-address max-mac-count count to configure the maximum number of MAC addresses that can be learned on a port.
Use mac-address max-mac-count disable-forwarding to disable the device from forwarding frames with unknown source MAC addresses after the number of learned MAC addresses reaches the upper limit.
Use undo mac-address max-mac-count to restore the default maximum number of MAC addresses that can be learned on an Ethernet port.
Use undo mac-address max-mac-count disable-forwarding to allow the device to forward frames received on an Ethernet port with unknown source MAC addresses after the number of learned MAC addresses reaches the upper limit.
mac-address max-mac-count { count | disable-forwarding }
undo mac-address max-mac-count [ disable-forwarding ]
A port can learn a maximum of 255 MAC addresses, and it forwards frames received on the port when the upper limit is reached.
2: System level
count: Sets the maximum number of MAC addresses that can be learned on a port. When the argument takes 0, the port is not allowed to learn MAC addresses. The value range for this argument is 0 to 256.
disable-forwarding: Disables the device from forwarding frames with unknown source MAC addresses after the number of learned MAC addresses reaches the upper limit. Frames with the source MAC addresses listed in the MAC address table are forwarded.
If the command is executed in interface view, the configuration takes effect on the interface. If the command is executed in port group view, the configuration takes effect on all ports belonging to the port group.
# Set the maximum number of MAC addresses that can be learned on port GigabitEthernet 1/0/1 to 200. After this upper limit is reached, frames received with unknown source MAC addresses on the port are not forwarded.
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count 200
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count disable-forwarding
·          mac-address timer
mac-address timer
Use mac-address timer to configure the aging timer for dynamic MAC address entries.
Use undo mac-address timer to restore the default.
undo mac-address timer aging
The default of this command is 300 seconds.
2: System level
aging seconds: Sets an aging timer (in seconds) for dynamic MAC address entries. The value range for the seconds argument is 10 to 630.
no-aging: Sets dynamic MAC address entries not to age.
Follow these guidelines to set the aging timer appropriately:
·          A long aging interval may cause the MAC address table to retain outdated entries and fail to accommodate the latest network changes.
·          A short aging interval may result in removal of valid entries and unnecessary broadcasts that may affect the performance of the device.
# Set the aging timer for dynamic MAC address entries to 500 seconds.
