03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10103-Layer 2 Command Reference
09-Ethernet Link Aggregation Commands
09-Ethernet Link Aggregation Commands 109.16 KB
The device supports only Layer 2 aggregation groups and aggregate interfaces.
The following matrix shows the feature and hardware compatibility:
Hardware series
Model
Ethernet link aggregation compatibility
WA4300 series
WA4320-ACN
No
WA4320-ACN-PI
No
WA4320H-ACN
No
WA4320i-ACN
Yes
WA4600 series
WA4620i-ACN/WA4620E-ACN
Yes
default
Use default to restore the default settings for an aggregate interface.
default
Default command level
2: System level
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you perform it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can identify these commands by using the display this command in interface view, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to set a description for an interface. For example, you can include information such as the purpose of the interface for the ease of management.
Use undo description to restore the default setting.
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation1 is Bridge-Aggregation1 Interface.
2: System level
text: Specifies the interface description, a string of 1 to 80 characters.
# Set the description of Layer 2 aggregate interface Bridge-Aggregation 1 to connect to the lab.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface bridge-aggregation [ interface-number ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
bridge-aggregation: Displays information about Layer 2 aggregate interfaces.
interface-number: Specifies an aggregate interface number. The value for the interface-number argument can only be 1.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
 Bridge-Aggregation1 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e207-f2e0
 Description: Bridge-Aggregation1 Interface
 PVID: 1
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Last clearing of counters:  Never
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
The brief information of interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
BAGG1                DOWN auto    A      A    1
# Display information about all Layer 2 aggregate interfaces in DOWN state.
<Sysname> display interface bridge-aggregation brief down
BAGG1                DOWN Not connected
Layer 2 aggregate interface status:
·         DOWN (Administratively)—The interface is administratively shut down with the shutdown command.
·         DOWN—The interface is administratively up but physically down (possibly because no physical link is present or the link is faulty).
·         UP—The interface is both administratively and physically up.
The interface speed and duplex mode are unknown.
PVID
Port VLAN ID.
Time when the reset counters interface command was last used to clear the interface statistics.
Never indicates the reset counters interface command has never been used on the interface after the device's startup.
Brief information about Layer 2 aggregate interfaces.
Link status:
·         ADM—The interface has been administratively shut down. To recover its physical layer state, execute the undo shutdown command.
·         Stby—The interface is operating as a backup interface.
If the speed of an interface is automatically negotiated, its speed attribute includes the auto negotiation flag, letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the auto negotiation flag, letter a in parentheses or a capital A. Letter H indicates the half duplex mode, and letter F indicates the full duplex mode.
Link type options for Ethernet interfaces.
Abbreviated interface name.
Link
Physical link state of the interface.
Speed
Interface speed, in bps.
Cause
Cause of a DOWN physical link.
display link-aggregation load-sharing mode
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing criteria.
display link-aggregation load-sharing mode [ interface [ bridge-aggregation interface-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
bridge-aggregation: Displays the load sharing criteria of the aggregation group corresponding to the specified Layer 2 aggregate interface.
To display the global link-aggregation load sharing criteria, run the command without the interface keyword.
To display all group-specific load sharing criteria, run the command with the interface keyword, but do not specify a particular interface.
To display the load sharing criteria of a particular aggregation group, use the command with the aggregate interface specified.
The bridge-aggregation keyword is available only when Layer 2 aggregate interfaces exist on the device.
# Display the default global link-aggregation load sharing criteria.
<Sysname> display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
Layer 2 traffic: destination-mac address, source-mac address
# Display the configured global link-aggregation load sharing criteria.
# Display the default link-aggregation load sharing criteria of the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
Bridge-Aggregation1 Load-Sharing Mode:
# Display the configured link-aggregation load sharing criteria of the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 1.
Global link-aggregation load sharing criteria.
·         By default, the link-aggregation load sharing criteria for Layer 2 traffic are displayed.
·         If you have configured the global link-aggregation load sharing criteria, the configured criteria are displayed.
Link-aggregation load sharing criteria of the aggregation group corresponding to the aggregate interface Bridge-Aggregation 1.
·         By default, the global link-aggregation load sharing criteria are displayed.
·         If you have configured link-aggregation load sharing criteria especially for this aggregation group, the configured criteria are displayed.
Default link-aggregation load sharing criteria for Layer 2 traffic. In this sample output, the criteria are the source and destination MAC addresses of packets.
User-configured link-aggregation load sharing criteria. In this sample output, the criteria are the source and destination MAC addresses of packets.
display link-aggregation member-port
Use display link-aggregation member-port to display detailed link aggregation information for the specified member ports. If no port is specified, this command displays detailed link aggregation information for all member ports.
display link-aggregation member-port [ interface-list ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ], where interface-type interface-number specifies an interface by its type and number.
Only the port number and operational key of a member port in a static aggregation group are displayed, because the aggregation group is not aware of the partner's information.
# Display detailed link aggregation information for GigabitEthernet 1/0/1, a member port of a static aggregation group.
<Sysname> display link-aggregation member-port GigabitEthernet 1/0/1
GigabitEthernet1/0/1:
Aggregation Interface: Bridge-Aggregation1
Port Number: 1
Port Priority: 32768
Oper-Key: 1
Aggregate interface to which the member port belongs.
Port Priority
Aggregation priority of the port.
Oper-key
Operational key.
display link-aggregation summary
Use display link-aggregation summary to display the summary information for all aggregation groups.
display link-aggregation summary [ | { begin | exclude | include } regular-expression ]
1: Monitor level
The information about the remote system for a static link aggregation group may be displayed as none or may not be displayed, because the aggregation group is not aware of the partner's information.
# Display the summary information for all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation
AGG         Select Unselect   Share
Interface   Ports  Ports      Type
BAGG1       1      1          Shar
Aggregate interface type. BAGG indicates Layer 2 aggregate interface.
Loadsharing Type
Load sharing type:
·         Shar—Load sharing.
·         NonS—Non-load sharing.
AGG Interface
Type and number of the aggregate interface.
Select Ports
Total number of Selected ports.
Unselect Ports
Total number of Unselected ports.
Share Type
Load sharing type.
display link-aggregation verbose
Use display link-aggregation verbose to display detailed information about the aggregation groups corresponding to the aggregate interfaces.
display link-aggregation verbose [ bridge-aggregation [ interface-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
bridge-aggregation: Displays detailed information about the Layer 2 aggregation groups corresponding to Layer 2 aggregate interfaces.
To display the information about a specific Layer 2 aggregation group, use the display link-aggregation verbose bridge-aggregation interface-number command.
To display the information about all Layer 2 groups, use the display link-aggregation verbose bridge-aggregation command.
To display the information about all aggregation groups, use the display link-aggregation verbose command.
# Display detailed information about the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 1, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 1
Port Status: S -- Selected, U -- Unselected
Aggregation Mode: Static
  Port             Status  Priority  Oper-Key
  GE1/0/1          U       32768     1
  GE1/0/2          U       32768     1
Table 5 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·         S—Selected.
·         U—Unselected.
Name of the aggregate interface.
Aggregation Mode
Mode of the aggregation group.
Port
Port type and number.
Status
Port state: Selected or Unselected.
Priority
Port aggregation priority.
Oper-Key
Operational key.
enable snmp trap updown
Use enable snmp trap updown to enable linkUp/linkDown trap generation for the aggregate interface.
Use undo enable snmp trap updown to disable linkUp/linkDown trap generation for the aggregate interface.
LinkUp/linkDown trap generation is enabled for an aggregate interface.
2: System level
For an aggregate interface to generate linkUp/linkDown traps when its link state changes, you must enable linkUp/linkDown trap generation globally with the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command.
For more information about the snmp-agent trap enable command, see Network Management and Monitoring Command Reference.
# Enable linkUp/linkDown trap generation on Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] enable snmp trap updown
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter the Layer 2 aggregate interface view.
Use undo interface bridge-aggregation to remove a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
2: System level
interface-number: Specifies a Layer 2 aggregate interface number. The value for the interface-number argument can only be 1.
When you create a Layer 2 aggregate interface, a Layer 2 aggregation group with the same number is automatically created. If you remove the Layer 2 aggregate interface, you also remove the Layer 2 aggregation group, and any member ports will leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1 and enter its view.
Use link-aggregation load-sharing mode to configure the global or group-specific link-aggregation load sharing criteria.
Use undo link-aggregation load-sharing mode to restore the default setting.
link-aggregation load-sharing mode { destination-ip | destination-mac | source-ip | source-mac }
The global and group-specific link-aggregation load sharing criteria are source and destination MAC addresses.
System view, Layer 2 aggregate interface view
2: System level
destination-ip: Performs load sharing in link aggregation groups based on destination IP address.
destination-mac: Performs load sharing in link aggregation groups based on destination MAC address.
source-ip: Performs load sharing in link aggregation groups based on source IP address.
source-mac: Performs load sharing in link aggregation groups based on source MAC address.
The load sharing criteria that you configure will overwrite the previous criteria.
If unsupported load sharing criteria are configured, an error prompt will appear.
# Configure the source MAC address and destination MAC address as the global link-aggregation load sharing criteria.
[Sysname] link-aggregation load-sharing mode source-mac destination-mac
# Configure the destination MAC address as the load sharing criterion specific to the link aggregation group of aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
link-aggregation port-priority
Use link-aggregation port-priority to set the aggregation priority of a port.
Use undo link-aggregation port-priority to restore the default setting.
link-aggregation port-priority port-priority
The aggregation priority of a port is 32768.
Ethernet interface view
2: System level
port-priority: Specifies a port aggregation priority, ranging from 0 to 65535. The smaller the value, the higher the port aggregation priority.
When the number of ports eligible for becoming Selected ports exceeds the maximum number of Selected ports allowed in an aggregation group, changing the aggregation priority of a port may affect the aggregation state of the ports in the aggregation group.
# Set the aggregation priority of port GigabitEthernet 1/0/1 to 64.
[Sysname-GigabitEthernet1/0/1] link-aggregation port-priority 64
port link-aggregation group
Use port link-aggregation group to assign the Ethernet interface to the specified aggregation group.
Use undo port link-aggregation group to remove the Ethernet interface from the aggregation group to which it belongs.
port link-aggregation group number
2: System level
number: Specifies the number of the aggregate interface corresponding to an aggregation group. The value for the number argument can only be 1.
A Layer 2 Ethernet interface can be assigned to a Layer 2 aggregation group only.
An Ethernet interface can belong to only one aggregation group.
# Assign Layer 2 Ethernet interface GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
Use reset counters interface to clear the statistics of the specified aggregate interface or interfaces.
reset counters interface [ bridge-aggregation [ interface-number ] ]
2: System level
bridge-aggregation: Clears statistics for Layer 2 aggregate interfaces.
interface-number: Specifies an aggregate interface number. The range for the interface-number argument can only be 1.
Before collecting statistics for a Layer 2 aggregate interface within a specific period, clear the existing statistics of the interface.
·          If no keyword or argument is specified, the command clears the statistics of all interfaces in the system.
·          If only the bridge-aggregation keyword is specified, the command clears the statistics of all Layer 2 aggregate interfaces.
·          If the bridge-aggregation interface-number option is specified, the command clears the statistics of the specified Layer 2 aggregate interface.
·          The bridge-aggregation keyword is available only when Layer 2 aggregate interfaces exist on the device.
# Clear the statistics of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
shutdown
Use shutdown to shut down an aggregate interface.
Use undo shutdown to bring up an aggregate interface.
shutdown
Aggregate interfaces are up.
2: System level
# Shut down Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] shutdown
