03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10103-Layer 2 Command Reference
07-Layer 2 Forwarding Commands
07-Layer 2 Forwarding Commands 53.13 KB
Layer 2 forwarding configuration commands
The following information describes normal Layer 2 forwarding configuration commands.
display mac-forwarding statistics
Use display mac-forwarding statistics to display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
interface interface-type interface-number: Displays the statistics of an interface specified by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no parameter is specified, Layer 2 forwarding statistics for all interfaces is displayed.
# Display the Layer 2 forwarding statistics for all interfaces.
<Sysname> display mac-forwarding statistics
Total received:  888
Filtered:111      STP discarded:0
Broadcast:0       Multicast:0
Unknown Unicast:0 Invalid Tag:0
Total deliver to up:  111
L2 protocol:11  Local MAC address:100
Blackhole dropped:0
Total sent:  666
Filtered:0      STP discarded:0
# Display forwarding statistics of GigabitEthernet 1/0/1.
<Sysname> display mac-forwarding statistics interface GigabitEthernet 1/0/1
GigabitEthernet1/0/1:
Input frames:4687    Input bytes:639888
Output frames:2271   Output bytes:1614471
Filtered:0          Invalid Tag:0
Total received
Total number of received Ethernet frames.
Filtered
Number of frames filtered out by 802.1Q Tagged VLAN inbound filtering rules.
STP discarded
Number of Ethernet frames dropped on the ingress ports blocked by STP.
Broadcast
Number of received broadcast frames.
Multicast
Number of received multicast frames.
Unknown unicast
Number of received unknown unicast frames.
Invalid Tag
Number of Ethernet frames dropped because of invalid tags.
At present, Ethernet frames with the VLAN ID as 0 or 0xFFF are dropped.
Total deliver to up
Number of Ethernet frames delivered to upper layer protocols.
L2 protocol
Number of Layer 2 protocol frames delivered to the upper layer.
Local MAC address
Number of Ethernet frames with the destination being the MAC addresses of local Layer 3 interfaces.
Blackhole dropped
Number of frames dropped as they are destined to blackhole MAC addresses.
Total sent
Total number of sent Ethernet frames.
Filtered
Number of frames filtered out by the VLAN egress traffic filtering rule.
STP discarded
Number of Ethernet frames dropped on egress ports blocked by STP.
Input frames
Number of received Ethernet frames on the interface.
Output frames
Number of Ethernet frames sent from the interface.
Input bytes
Number of received bytes on the interface.
Output bytes
Number of bytes sent out of the interface.
Filtered
Number of Ethernet frames filtered out because they are from other VLANs.
reset mac-forwarding statistics
Use reset mac-forwarding statistics to clear all Layer 2 forwarding statistics.
1: Monitor level
# Clear all Layer 2 forwarding statistics.
<Sysname> reset mac-forwarding statistics
