- H3C WX3800H Series Access Controllers Installation Guide-6W101
- 01-Preparing for installation
- 02-Installing the device
- 03-Troubleshooting
- 04-Hardware management and maintenance
- 05-Appendix A Chassis views and technical specifications
- 06-Appendix B LEDs
- 07-Appendix C Optional transceiver modules
Download Book (114.79 KB)Appendix C Optional transceiver modules·
Transceiver module, fiber connector, and optical fiber views
To connect a fiber port on the device, use an SFP or SFP+ transceiver module and an optical fiber with LC connectors.
Figure 1 SFP transceiver module
Figure 2 SFP+ transceiver module
Figure 3 Optical fiber with LC connectors
(1) LC connector |
(2) Optical fiber |
Transceiver module specifications
The transceiver modules that have MM and SM in their names support multi-mode optical fibers and single-mode optical fibers, respectively.
The WX3820 and WX3840H access controllers support the following transceiver modules:
· SFP-FE-SX-MM1310-A (see Table 1)
· SFP-FE-LX-SM1310-A (see Table 2)
· SFP-GE-SX-MM850-A (see Table 3)
· SFP-GE-LX-SM1310-A (see Table 4)
Table 1 SFP-FE-SX-MM1310-A specifications
Item |
Specification |
Central wavelength |
1310 nm |
Transmission distance |
2 km (1.24 miles) |
Transmission rate |
125 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–19 to –14 dBm |
Receive sensitivity |
≤ –30 dBm |
Saturation |
≤ –14 dBm |
Table 2 SFP-FE-LX-SM1310-A specifications
Item |
Specification |
1310 nm |
15 km (9.32 miles) |
Transmission rate |
125 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–15 to –8 dBm |
≤ –28 dBm |
Saturation |
≤ –7 dBm |
Table 3 SFP-GE-SX-MM850-A specifications
Item |
Specification |
850 nm |
550 m (1804.46 ft) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–9.5 to 0 dBm |
≤ –17 dBm |
Saturation |
≤ –3 dBm |
Table 4 SFP-GE-LX-SM1310-A specifications
Item |
Specification |
1310 nm |
10 km (6.21 miles) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–9.5 to –3 dBm |
≤ –20 dBm |
Saturation |
≤ –3 dBm |
