- H3C WX3800H Series Access Controllers Installation Guide-6W101
- 01-Preparing for installation
- 02-Installing the device
- 03-Troubleshooting
- 04-Hardware management and maintenance
- 05-Appendix A Chassis views and technical specifications
- 06-Appendix B LEDs
- 07-Appendix C Optional transceiver modules
06-Appendix B LEDs
Download Book (84.33 KB)Appendix B LEDs
LEDs
(1) 100/1000BASE-T autosensing Ethernet copper port status LEDs |
(2) 100BASE-FX/1000BASE-X SFP port status LEDs |
(3) 10GBASE-R SFP+ port status LEDs |
(4) Power module 1 status LED (PWR1) |
(5) Power module 2 status LED (PWR2) |
(6) System status LED (SYS) |
(7) Status LED for the module in the reserved slot (MOD) |
Figure 2 WX3840H LEDs
(4) 100/1000BASE-T out-of-band management Ethernet port status LED (LINK/ACT) |
(5) Power module 1 status LED (PWR1) |
(6) Power module 2 status LED (PWR2) |
(7) System status LED (SYS) |
(8) Status LED for the module in the reserved slot (MOD) |
LED description
LED |
Mark |
Status |
Power module 1 status LED |
PWR1 |
Steady green |
Power module 1 is operating correctly. |
Steady yellow |
Power module 1 is faulty. |
Off |
No power module is present. |
Power module 2 status LED |
PWR2 |
Steady green |
Power module 2 is operating correctly. |
Steady yellow |
Power module 2 is faulty. |
Off |
System status LED |
SYS |
Steady green |
The system is starting up. |
Flashing green |
The system is operating correctly. |
Flashing green |
The system is downloading files. |
Steady yellow |
The system has failed POST, or a critical fault has been detected. |
Off |
No power is present. |
Status LED for the module in the reserved slot |
MOD |
Steady green |
The module is present. |
Flashing green |
The module is reading or writing data. |
Steady yellow |
A failure has occurred on the module. |
Off |
No module is present. |
100/1000BASE-T out-of-band management Ethernet port status LED |
LINK/ACT |
Off |
No link is present. |
Steady green |
A link is present. |
Flashing green |
The port is receiving or transmitting data. |
100/1000BASE-T autosensing Ethernet copper port status LED |
N/A |
Steady yellow |
A 100 Mbps link is present on the port. |
Flashing yellow |
The port is receiving or transmitting data at 100 Mbps. |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 1000 Mbps. |
Off |
No link is present on the port. |
100BASE-FX/1000BASE-X SFP port status LED |
N/A |
Steady yellow |
Flashing yellow |
Steady green |
Flashing green |
Off |
10GBASE-R SFP+ port status LED |
N/A |
Steady green |
A link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 10 Gbps. |
Off |
