04-Layer 3 Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Configuration Guide
09-Flow Classification Configuration
09-Flow Classification Configuration 29.91 KB
Configuring flow classification
Overview
Flow classification organizes packets with different characteristics into different classes by using certain match criteria. It is the basis for providing differentiated services.
For a multi-core device, the control plane and data plane run on different kernels and threads respectively. The data plane processes packets based on flows. A flow identifies packets with the same characteristics (identical quintuple) and processing procedure. The flow classification module marks every packet with a flow label before sending the packet to the data plane. When the data plane receives the first packet of a flow, a forwarding entry for the flow is created by the service module. Then, the subsequent packets can be forwarded based on the forwarding entry to improve forwarding efficiency.
Enabling flow classification
Step
Remarks
N/A
2.     Enable flow classification.
flow-classification enable
Optional.
Enabled by default.
Displaying and maintaining flow classification
Remarks
Display the current flow classification policy.
display forwarding policy [ | { begin | exclude | include } regular-expression ]
Available in any view.
