04-Layer 3 Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Configuration Guide
17-RIPng Configuration
17-RIPng Configuration 202.51 KB
Configuring RIPng
Overview
RIP next generation (RIPng) is an extension of RIP-2 for IPv4. Most RIP concepts are applicable in RIPng.
RIPng for IPv6 has the following basic differences from RIP:
·     UDP port number—RIPng uses UDP port 521 for sending and receiving routing information.
·     Multicast address—RIPng uses FF02:9 as the link-local-router multicast address.
·     Destination Prefix—128-bit destination address prefix.
·     Next hop—128-bit IPv6 address.
·     Source address—RIPng uses FE80::/10 as the link-local source address.
RIPng working mechanism
RIPng is a routing protocol based on the distance vector (D-V) algorithm. RIPng uses UDP packets to exchange routing information through port 521.
RIPng uses a hop count to measure the distance to a destination. The hop count is the metric or cost. The hop count from a router to a directly connected network is 0. The hop count between two directly connected routers is 1. When the hop count is greater than or equal to 16, the destination network or host is unreachable.
By default, the routing update is sent every 30 seconds. If the router receives no routing updates from a neighbor within 180 seconds, the routes learned from the neighbor are considered unreachable. If no routing update is received within another 240 seconds, the router removes these routes from the routing table.
RIPng supports split horizon and poison reverse to prevent routing loops and route redistribution.
Each RIPng router maintains a routing database, which includes route entries of all reachable destinations. A route entry contains the following information:
·     Destination address—IPv6 address of a host or a network.
·     Next hop address—IPv6 address of a neighbor along the path to the destination.
·     Egress interface—Outbound interface that forwards IPv6 packets.
·     Metric—Cost from the local router to the destination.
·     Route time—Time elapsed since a route entry was last changed. Each time a route entry is modified, the routing time is set to 0.
·     Route tag—Identifies the route used in a routing policy to control routing information.
RIPng packet format
Basic format
A RIPng packet consists of a header and multiple route table entries (RTEs). The maximum number of RTEs in a packet depends on the IPv6 MTU of the sending interface.
Figure 1 RIPng basic packet format
Packet header description:
·     Command—Type of message. 0x01 indicates Request, 0x02 indicates Response.
·     Version—Version of RIPng. It can only be 0x01.
·     RTE—Route table entry. It is 20 bytes for each entry.
RTE format
The following are types of RTEs in RIPng:
·     Next hop RTE—Defines the IPv6 address of a next hop.
·     IPv6 prefix RTE—Describes the destination IPv6 address, route tag, prefix length, and metric in the RIPng routing table.
Figure 2 Next hop RTE format
IPv6 next hop address is the IPv6 address of the next hop.
Figure 3 IPv6 prefix RTE format
IPv6 prefix RTE format description:
·     IPv6 prefix—Destination IPv6 address prefix
·     Route tag—Route tag
·     Prefix length—Length of the IPv6 address prefix
·     Metric—Cost of a route
RIPng packet processing procedure
Request packet
When a RIPng router first starts or must update entries in its routing table, it usually sends a multicast request packet to ask for needed routes from neighbors.
The receiving RIPng router processes RTEs in the request. If only one RTE exists with the IPv6 prefix and prefix length both being 0 and with a metric value of 16, the RIPng router responds with the entire routing table information in response messages. If multiple RTEs exist in the request message, the RIPng router examines each RTE, update its metric, and send the requested routing information to the requesting router in the response packet.
Response packet
The response packet containing the local routing table information is generated as follows:
·     A response to a request
·     An update periodically
·     A trigged update caused by route change
After receiving a response, a router checks the validity of the response before adding the route to its routing table, such as whether the source IPv6 address is the link-local address and whether the port number is correct. The response packet that failed the check is discarded.
Protocols and standards
·     RFC 2080, RIPng for IPv6
·     RFC 2081, RIPng Protocol Applicability Statement
RIPng configuration task list
Remarks
Configuring RIPng basic functions
Required
Configuring RIPng route control
Configuring an additional routing metric
Optional
Configuring RIPng route summarization
Optional
Advertising a default route
Optional
Configuring a RIPng route filtering policy
Optional
Configuring a priority for RIPng
Optional
Configuring RIPng route redistribution
Optional
Tuning and optimizing the RIPng network
Configuring RIPng timers
Optional
Configuring split horizon and poison reverse
Optional
Configuring zero field check on RIPng packets
Optional
Configuring the maximum number of ECMP routes
Optional
Applying IPsec policies for RIPng
Optional
This section presents the information to configure the basic RIPng features.
You must enable RIPng first before you configure other tasks, but it is not necessary for RIPng-related interface configurations, such as assigning an IPv6 address.
Configuration prerequisites
Before you configure RIPng basic functions, complete the following tasks:
·     Enable IPv6 packet forwarding.
·     Configure an IP address for each interface, and make sure all nodes are reachable to one another.
Configuration procedure
To configure the basic RIPng functions:
Step
Remarks
N/A
2.     Create a RIPng process and enter RIPng view.
ripng [ process-id ]
Not created by default.
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Enable RIPng on the interface.
ripng process-id enable
Disabled by default.
If RIPng is not enabled on an interface, the interface does not send or receive any RIPng route.
Before you configure RIPng, complete the following tasks:
·     Configure an IPv6 address on each interface, and make sure all nodes are reachable to one another.
·     Configure RIPng basic functions.
·     Define an IPv6 ACL before using it for route filtering. For related information, see ACL and QoS Configuration Guide.
·     Define an IPv6 address prefix list before using it for route filtering.
An additional routing metric can be added to the metric of an inbound or outbound RIP route.
The outbound additional metric is added to the metric of a sent route. The route's metric in the routing table is not changed.
The inbound additional metric is added to the metric of a received route before the route is added into the routing table, so the route's metric is changed.
To configure an inbound or outbound additional routing metric:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Specify an inbound routing additional metric.
ripng metricin value
Optional.
0 by default.
4.     Specify an outbound routing additional metric.
ripng metricout value
Optional.
1 by default.
Step
3.     Advertise a summary IPv6 prefix.
ripng summary-address ipv6-address prefix-length
With this feature enabled, a default route is advertised through the specified interface regardless of whether the default route is available in the local IPv6 routing table.
To advertise a default route:
Step
Remarks
N/A
N/A
3.     Advertise a default route.
ripng default-route { only | originate } [ cost cost ]
Not advertised by default.
You can reference a configured IPv6 ACL or prefix list to filter received or advertised routing information. You can also specify a routing protocol to filter outbound routes redistributed from the protocol.
To configure a RIPng route filtering policy:
Step
Remarks
N/A
2.     Enter RIPng view.
N/A
3.     Configure a filter policy to filter incoming routes.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
By default, RIPng does not filter incoming routing information.
4.     Configure a filter policy to filter outgoing routes.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
By default, RIPng does not filter outgoing routing information.
Routing protocols have their own protocol priorities used for optimal route selection. You can set a priority for RIPng manually. The smaller the value, the higher the priority.
To configure a RIPng priority:
Step
Remarks
N/A
N/A
3.     Configure a RIPng priority.
preference preference
Optional.
By default, the RIPng priority is 100.
Step
Remarks
N/A
N/A
3.     Configure a default routing metric for redistributed routes.
default cost cost
Optional.
The default metric of redistributed routes is 0.
4.     Redistribute routes from another routing protocol.
import-route protocol [ process-id ] [ cost cost ] *
No route redistribution is configured by default.
This section describes how to tune and optimize the performance of the RIPng network, as well as applications under special network environments. Before tuning and optimizing the RIPng network, complete the following tasks:
·     Configure a network layer address for each interface.
·     Configure the basic RIPng functions.
You can adjust RIPng timers to optimize the performance of the RIPng network.
When adjusting RIPng timers, consider the network performance, and perform unified configurations on routers running RIPng to avoid unnecessary network traffic or route oscillation.
To configure RIPng timers:
Step
Remarks
N/A
N/A
3.     Configure RIPng timers.
Optional.
The RIPng timers have the following defaults:
·     Update timer—30 seconds.
·     Timeout timer—180 seconds.
·     Suppress timer—20 seconds.
·     Garbage-collect timer—20 seconds.
If both split horizon and poison reverse are configured, only the poison reverse function takes effect.
The split horizon function disables a route learned from an interface from being advertised through the same interface to prevent routing loops between neighbors.
H3C recommends enabling split horizon to prevent routing loops.
In frame relay, X.25 and other non-broadcast multi-access (NBMA) networks, split horizon should be disabled if multiple VCs are configured on the primary interface and secondary interfaces to ensure route advertisement.
To configure split horizon:
Step
Remarks
N/A
N/A
3.     Enable the split horizon function.
ripng split-horizon
Optional.
Enabled by default.
Configuring the poison reverse function
The poison reverse function enables a route learned from an interface to be advertised through the interface. However, the metric of the route is set to 16, which means the route is unreachable.
To configure poison reverse:
Step
Remarks
N/A
N/A
3.     Enable the poison reverse function.
ripng poison-reverse
Some fields in the RIPng packet must be zero, which are called "zero fields." With zero field check on RIPng packets enabled, if such a field contains a non-zero value, the entire RIPng packet is discarded. If you are sure that all packets are reliable, disable the zero field check to reduce the CPU processing time.
To configure RIPng zero field check:
Step
Remarks
N/A
N/A
3.     Enable the zero field check.
checkzero
Optional.
Enabled by default.
Step
Remarks
N/A
N/A
3.     Configure the maximum number of ECMP RIPng routes for load balancing.
maximum load-balancing number
Optional.
By default, the maximum number of ECMP RIPng routes is 4.
To protect routing information and defend attacks, RIPng supports using an IPsec policy to authenticate protocol packets.
Outbound RIPng packets carry the Security Parameter Index (SPI) defined in the relevant IPsec policy. A device uses the SPI carried in a received packet to match against the configured IPsec policy. If they match, the device accepts the packet. Otherwise, it discards the packet and does not establish a neighbor relationship with the sending device.
You can configure an IPsec policy for a RIPng process or interface. The IPsec policy configured for a process applies to all packets in the process. The IPsec policy configured on an interface applies to packets on the interface. If an interface and its process each have an IPsec policy configured, the interface uses its own IPsec policy.
An IPsec policy used for RIPng can only be in manual mode. For more information, see Security Configuration Guide.
Before you apply an IPsec policy for RIPng, complete following tasks:
·     Create an IPsec proposal.
·     Create an IPsec policy.
For more information about IPsec policy configuration, see Security Configuration Guide.
To apply an IPsec policy in a process:
Step
Remarks
N/A
N/A
3.     Apply an IPsec policy in the process.
enable ipsec-policy policy-name
Not configured by default.
To apply an IPsec policy on an interface:
Step
Remarks
N/A
N/A
3.     Apply an IPsec policy on the interface.
ripng ipsec-policy policy-name
Displaying and maintaining RIPng
Remarks
Display configuration information of a RIPng process.
display ripng [ process-id ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display routes in the RIPng database.
display ripng process-id database [ | { begin | exclude | include } regular-expression ]
Display the routing information of a specified RIPng process.
display ripng process-id route [ | { begin | exclude | include } regular-expression ]
Display RIPng interface information.
display ripng process-id interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Reset a RIPng process.
reset ripng process-id process
Available in user view.
Clear statistics of a RIPng process.
reset ripng process-id statistics
RIPng configuration examples
Network requirements
As shown in Figure 4, all routers learn IPv6 routing information through RIPng. Configure the AC to filter the route (3::/64) learned from Switch B, which means the route is not added to the routing table of the AC, and the AC does not forward it to Switch A.
Figure 4 Network diagram
1.     Configure the IPv6 address for each interface. (Details not shown.)
2.     Configure basic RIPng functions:
# Configure Switch A.
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface100] ripng 1 enable
[SwitchA] interface vlan-interface 400
[SwitchA-Vlan-interface400] ripng 1 enable
[SwitchA-Vlan-interface400] quit
# Configure the AC.
<AC> system-view
[AC] ripng 1
[AC-ripng-1] quit
[AC-Vlan-interface100] ripng 1 enable
[AC-Vlan-interface100] quit
[AC-Vlan-interface200] ripng 1 enable
[AC-Vlan-interface200] quit
# Configure Switch B.
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface200] ripng 1 enable
[SwitchB] interface vlan-interface 500
[SwitchB-Vlan-interface500] ripng 1 enable
[SwitchB-Vlan-interface500] quit
[SwitchB] interface vlan-interface 600
[SwitchB-Vlan-interface600] ripng 1 enable
[SwitchB-Vlan-interface600] quit
# Display the routing table of the AC.
[AC] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::20F:E2FF:FE23:82F5  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 6 Sec
 Dest 2::/64,
 Peer FE80::20F:E2FF:FE00:100  on Vlan-interface200
 Dest 3::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 11 Sec
 Dest 4::/64,
 Dest 5::/64,
3.     Configure the AC to filter incoming and outgoing routes:
[AC] acl ipv6 number 2000
[AC-acl6-basic-2000] rule deny source 3::/64
[AC-acl6-basic-2000] rule permit
[AC-acl6-basic-2000] quit
[AC] ripng 1
[AC-ripng-1] filter-policy 2000 import
[AC-ripng-1] filter-policy 2000 export
# Display routing tables of the AC and Switch A.
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 2 Sec
 Dest 2::/64,
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 5 Sec
 Dest 5::/64,
[SwitchA] display ripng 1 route
 Peer FE80::20F:E2FF:FE00:1235  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE00:1235, cost  1, tag 0, A, 2 Sec
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:1235, cost  2, tag 0, A, 2 Sec
 Dest 5::/64,
·     The AC runs two RIPng processes. It communicates with Switch A through RIPng 100 and with Switch B through RIPng 200.
·     Configure route redistribution on the AC, allowing the two RIPng processes to redistribute routes from each other. Set the default cost of redistributed routes from RIPng 200 to 3.
Figure 5 Network diagram
1.     Configure IPv6 addresses for the interfaces. (Details not shown.)
2.     Configure RIPng basic functions:
# Enable RIPng 100 on Switch A.
[SwitchA] ripng 100
[SwitchA-ripng-100] quit
[SwitchA-Vlan-interface200] ripng 100 enable
[SwitchA-Vlan-interface100] ripng 100 enable
# Enable RIP 100 and RIP 200 on the AC.
<AC> system-view
[AC] ripng 100
[AC-ripng-100] quit
[AC-Vlan-interface100] ripng 100 enable
[AC] ripng 200
[AC-ripng-200] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ripng 200 enable
#  Enable RIPng 200 on Switch B.
[SwitchB] ripng 200
[SwitchB-ripng-200] quit
[SwitchB] interface vlan-interface 400
[SwitchB-Vlan-interface400] ripng 200 enable
[SwitchB- Vlan-interface400] quit
[SwitchB] interface vlan-interface 300
[SwitchB-Vlan-interface300] ripng 200 enable
[SwitchB-Vlan-interface300] quit
# Display the routing table of Switch A.
[RouterA] display ipv6 routing-table
Routing Table :
         Destinations : 6        Routes : 6
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 1::/64                                      Protocol  : Direct
NextHop    : 1::1                                        Preference: 0
Interface  : Vlan100                                     Cost      : 0
Destination: 1::1/128                                    Protocol  : Direct
Destination: 2::/64                                      Protocol  : Direct
NextHop    : 2::1                                        Preference: 0
Interface  : Vlan200                                     Cost      : 0
Destination: 2::1/128                                    Protocol  : Direct
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : NULL0                                       Cost      : 0
3.     Configure RIPng route redistribution:
# Configure route redistribution between the two RIPng processes on the AC.
[AC] ripng 100
[AC-ripng-100] default cost 3
[AC-ripng-100] import-route ripng 200
[AC-ripng-100] quit
[AC] ripng 200
[AC-ripng-200] import-route ripng 100
[AC-ripng-200] quit
[SwitchA] display ipv6 routing-table
Routing Table :
         Destinations : 7        Routes : 7
Destination: 4::/64                                      Protocol  : RIPng
NextHop    : FE80::200:BFF:FE01:1C02                     Preference: 100
Interface  : Vlan100                                     Cost      : 4
Configuring RIPng IPsec policies
As shown in the following figure,
·     Configure RIPng on the switches and AC.
·     Configure IPsec policies on the switches and AC to authenticate and encrypt protocol packets.
Figure 6 Network diagram
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
[SwitchA] ripng 1
# Configure the AC.
<AC> system-view
[AC] ripng 1
[AC-ripng-1] quit
[SwitchB] ripng 1
[SwitchB- Vlan-interface200] quit
3.     Configure RIPng IPsec policies:
# On Switch A, create an IPsec proposal named tran1, and set the encapsulation mode to transport mode, the security protocol to ESP, the encryption algorithm to DES, and authentication algorithm to SHA1. Create an IPsec policy named policy001, specify the manual mode for it, reference IPsec proposal tran1, set the SPIs of the inbound and outbound SAs to 12345, and the keys for the inbound and outbound SAs using ESP to abcdefg.
[SwitchA] ipsec transform-set tran1
[SwitchA-ipsec-transform-set-tran1] encapsulation-mode transport
[SwitchA-ipsec-transform-set-tran1] transform esp
[SwitchA-ipsec-transform-set-tran1] esp encryption-algorithm des
[SwitchA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[SwitchA-ipsec-transform-set-tran1] quit
[SwitchA] ipsec policy policy001 10 manual
[SwitchA-ipsec-policy-manual-policy001-10] transform-set tran1
[SwitchA-ipsec-policy-manual-policy001-10] sa spi outbound esp 12345
[SwitchA-ipsec-policy-manual-policy001-10] sa spi inbound esp 12345
[SwitchA-ipsec-policy-manual-policy001-10] sa string-key outbound esp abcdefg
[SwitchA-ipsec-policy-manual-policy001-10] sa string-key inbound esp abcdefg
[SwitchA-ipsec-policy-manual-policy001-10] quit
# On the AC, create an IPsec proposal named tran1, and set the encapsulation mode to transport mode, the security protocol to ESP, the encryption algorithm to DES, and authentication algorithm to SHA1. Create an IPsec policy named policy001, specify the manual mode for it, reference IPsec proposal tran1, set the SPIs of the inbound and outbound SAs to 12345, and the keys for the inbound and outbound SAs using ESP to abcdefg.
[AC] ipsec transform-set tran1
[AC-ipsec-transform-set-tran1] encapsulation-mode transport
[AC-ipsec-transform-set-tran1] transform esp
[AC-ipsec-transform-set-tran1] esp encryption-algorithm des
[AC-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[AC-ipsec-transform-set-tran1] quit
[AC] ipsec policy policy001 10 manual
[AC-ipsec-policy-manual-policy001-10] transform-set tran1
[AC-ipsec-policy-manual-policy001-10] sa spi outbound esp 12345
[AC-ipsec-policy-manual-policy001-10] sa spi inbound esp 12345
[AC-ipsec-policy-manual-policy001-10] sa string-key outbound esp abcdefg
[AC-ipsec-policy-manual-policy001-10] sa string-key inbound esp abcdefg
[AC-ipsec-policy-manual-policy001-10] quit
# On Switch B, create an IPsec proposal named tran1, and set the encapsulation mode to transport mode, the security protocol to ESP, the encryption algorithm to DES, and authentication algorithm to SHA1. Create an IPsec policy named policy001, specify the manual mode for it, reference IPsec proposal tran1, set the SPIs of the inbound and outbound SAs to 12345, and the keys for the inbound and outbound SAs using ESP to abcdefg.
[SwitchB] ipsec transform-set tran1
[SwitchB-ipsec-transform-set-tran1] encapsulation-mode transport
[SwitchB-ipsec-transform-set-tran1] transform esp
[SwitchB-ipsec-transform-set-tran1] esp encryption-algorithm des
[SwitchB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[SwitchB-ipsec-transform-set-tran1] quit
[SwitchB] ipsec policy policy001 10 manual
[SwitchB-ipsec-policy-manual-policy001-10] transform-set tran1
[SwitchB-ipsec-policy-manual-policy001-10] sa spi outbound esp 12345
[SwitchB-ipsec-policy-manual-policy001-10] sa spi inbound esp 12345
[SwitchB-ipsec-policy-manual-policy001-10] sa string-key outbound esp abcdefg
[SwitchB-ipsec-policy-manual-policy001-10] sa string-key inbound esp abcdefg
[SwitchB-ipsec-policy-manual-policy001-10] quit
4.     Apply the IPsec policies in the RIPng process:
[SwitchA] ripng 1
[SwitchA-ripng-1] enable ipsec-policy policy001
# Configure the AC.
[AC] ripng 1
[AC-ripng-1] enable ipsec-policy policy001
[AC-ripng-1] quit
[SwitchB] ripng 1
[SwitchB-ripng-1] enable ipsec-policy policy001
5.     Verify the configuration:
RIPng packets between Switch A, Switch B, and the AC are protected by IPsec.
