- 03-Layer 2 Configuration Guide
- 01-Ethernet Interface Configuration
- 02-Loopback and Null Interface Configuration
- 03-VLAN Configuration
- 04-MAC Address Table Configuration
- 05-Ethernet Link Aggregation Configuration
- 06-Spanning Tree Configuration
- 07-Layer 2 Forwarding Configuration
- 08-PPPoE Configuration
- 09-FPGA Fast Forwarding Configuration
- 10-QinQ Termination Configuration
| 00-Preface | 114.16 KB |
Preface
The Layer 2 Configuration Guide describes Ethernet interface, loopback and null interface, VLAN, MAC address table, Ethernet link aggregation, spanning tree, Layer 2 forwarding, PPPoE, FPGA fast forwarding, and QinQ termination configurations.
NOTE: Support of the H3C access controllers for features might vary by device model. For the feature matrixes, see About the H3C Access Controllers Configuration Guides. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
