- H3C WX Series Access Controllers Web-Based Configuration Guide(R3308 R2308)-6W107
- 01-About the WX Series Access Controllers Web Configuration Guide
- 02-Quick Start
- 03-Web Overview
- 04-Summary
- 05-Device
- 06-Network
- 07-AP Configuration
- 08-Wireless Service
- 09-WLAN Roaming Configuration
- 10-Radio Configuration
- 11-Authentication
- 12-Security
- 13-QoS configuration
- 14-Advanced Settings
- 15-Stateful Failover Configuration
| 00-Preface | 70.33 KB |
Preface
The H3C WX Series Access Controllers Web-Based Configuration Guide describes the web functions of the WX series, such as quick start, web overview, wireless service configuration, security and authentication related configurations, QoS configuration, and advanced settings.
NOTE: · Support of the H3C WX series access controllers for features may vary by device model. For the feature matrixes, see the chapter “Feature Matrixes”. · The interface types and output information may vary by device model. · The grayed-out functions and parameters on the web interface are unavailable or not configurable. |
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access controller, an access controller module, or a switching engine on a unified switch. |
Represents an access point. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Documentation feedback
We appreciate your comments.
