09-Network Management Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10209-Network Management Configuration Guide
10-Flow Log Commands
10-Flow Log Commands 49.53 KB
Flow log configuration commands
display userlog export
Use display userlog export to display flow log configuration and statistics.
display userlog export [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
If no log servers are specified as the destination for flow log export, this command displays "No userlog export is enabled."
To specify a log server, use the userlog flow export host command.
# Display flow log configuration and statistics.
<Sysname> display userlog export
 nat:
 flow:
   Export Version 1 logs to log server : enabled
   Source address of exported logs   : 1.1.1.1
   Address of log server               : 2.2.3.3 (port: 2000)
   VPN-instance                          : -NA-
   Total logs/UDP packets exported   : 0/0
   Address of log server               : 2.2.4.3 (port: 2000)
   Logs in buffer                        : 0
nat
NAT log configuration and statistics.
No NAT log entries are sent to log servers. Possible reasons:
·     No log servers are specified as the destination for flow log export.
·     The userlog flow syslog command is configured and NAT log entries are sent to the information center.
flow
Flow log configuration and statistics.
No flow log entries are sent to log servers. Possible reasons:
·     The userlog flow syslog command is configured and flow log entries are sent to the information center.
Export flow log packets of version 1.0 to log servers.
Source IP address of the packets that contained the flow log entries (this field is not displayed if the source IP address is not configured).
IP address and port number of the log server.
Total number of exported flow log entries and total number of UDP packets used to export the flow log entries.
A UDP packet can contain multiple flow log entries.
Logs in buffer
Total number of flow logs in the buffer.
reset userlog flow export
Use reset userlog flow export to clear flow log statistics.
2: System level
# Clear flow log statistics.
<Sysname> reset userlog flow export
reset userlog flow logbuffer
Use reset userlog flow logbuffer to clear flow logs in the buffer.
2: System level
Flow log entries are saved in the buffer before being exported to the information center or log server.
# Clear flow log entries in the buffer.
<Sysname> reset userlog flow logbuffer
Use userlog flow export host to specify an IPv4 log server to receive flow log entries.
Use undo userlog flow export host to remove an IPv4 log server.
userlog flow export host ipv4-address udp-port
undo userlog flow export host ipv4-address
No IPv4 log servers are specified.
2: System level
ipv4-address: Specifies the IPv4 address of the log server.
udp-port: Specifies the UDP port number of the log server, in the range of 0 to 65535. To avoid collision with well-known UDP port numbers, H3C recommends that you use UDP port numbers in the range 1025 to 65535.
The device supports a maximum of two log servers (IPv4 or IPv6) as the destinations for flow log export. When the limit is reached, remove an existing log server and then specify a new one. If you specify a log server that has the same IP address but a different port number than an existing server, the new configuration overwrites the previous one.
# Export flow log entries to UDP port 2000 on the log server at 1.2.3.6.
[Sysname] userlog flow export host 1.2.3.6 2000
userlog flow export host ipv6
Use userlog flow export host to specify an IPv6 log server to receive flow log entries.
Use undo userlog flow export host to remove an IPv6 log server.
userlog flow export host ipv6 ipv6-address udp-port
undo userlog flow export host ipv6 ipv6-address
No IPv6 log servers are specified.
2: System level
ipv6-address: Specifies the IPv6 address of the log server.
# Export flow log entries to UDP port 2000 on the log server at the IPv6 address 1::1.
[Sysname] userlog flow export host ipv6 1::1 2000
userlog flow export source-ip
Use userlog flow export source-ip to specify a source IP address for flow log packets.
Use undo userlog flow export source-ip to restore the default.
userlog flow export source-ip ip-address
The source IP address of flow log packets is the IP address of their outgoing interface.
2: System level
ip-address: Specifies an IP address.
# Specify 1.2.1.2 as the source IP address for flow log packets.
[Sysname] userlog flow export source-ip 1.2.1.2
userlog flow export version
Use userlog flow export version to set the flow log version.
Use undo userlog flow export version to restore the default.
userlog flow export version version-number
The flow log version is 1.0.
2: System level
version-number: Specifies a flow log version. Available options are 1 and 3.
If you set the flow log version multiple times, the most recent setting takes effect.
# Set the flow log version to 3.0.
[Sysname] userlog flow export version 3
userlog flow syslog
Use userlog flow syslog to specify the information center as the destination for flow log export.
Use undo userlog flow syslog to restore the default.
userlog flow syslog
Flow log entries are not exported to the information center.
2: System level
You can export flow log entries to log servers or the information center, but not both. If both methods are configured, the system exports flow log entries to the information center.
Flow log entries are storage intensive. To export flow log entries to the information center, make sure the storage space is sufficient.
# Specify the information center as the destination for flow log export.
[Sysname] userlog flow syslog
