09-Network Management Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10209-Network Management Configuration Guide
02-NQA Commands
02-NQA Commands 216.46 KB
NQA configuration commands
NQA client configuration commands
data-fill
Use data-fill to configure the string to be filled in the payload of each probe packet.
Use undo data-fill to restore the default.
data-fill string
undo data-fill
The string is the hexadecimal number 00010203040506070809.
ICMP echo operation view, UDP echo operation view, UDP jitter operation view
Default command level
2: System level
string: Specifies a case-sensitive string of 1 to 200 characters.
If the payload length is smaller than the string length, only the first part of the string is filled. For example, if you configure the string as abcd and the payload size as 3 bytes, abc is filled.
If the payload length is greater than the string length, the system fills the payload with the string cyclically until the payload is full. For example, if you configure the string as abcd and the payload size as 6 bytes, abcdab is filled.
How the string is filled varies with operation types:
·     For an ICMP echo operation, the string fills the whole payload of ICMP echo requests.
·     For a UDP echo operation, the first 5 bytes of the payload of a UDP packet are for special purpose, so the string fills the remaining part of payload.
·     For a UDP jitter operation, the first 68 bytes of the payload of a UDP packet are for special purpose, so the string fills the remaining part of the payload.
# Configure string abcd to be filled in the payload of an ICMP echo request.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
data-size
Use data-size to configure the size of the payload in each ICMP echo request of the ICMP echo operation or in each UDP packet of the UDP echo, or UDP jitter operation.
Use undo data-size to restore the default.
data-size size
undo data-size
2: System level
size: Specifies the size of the payload in each probe packet in bytes. The value is in the range of 20 to 8100 for probe packets of the ICMP echo or UDP echo operation, and 68 to 8100 for probe packets of the UDP jitter operation.
Table 1 Default payload size of a probe packet
Test type
Codec type
Default value (in bytes)
ICMP echo
N/A
100
UDP echo
N/A
100
UDP jitter
N/A
100
Configure the size of the payload in each probe packet correctly. If the traffic amount is large in the network, configure a smaller payload size to reduce network burden. If runt packets are required to be transmitted in the network, configure a bigger payload size to avoid packet loss.
# Configure the size of the payload in each ICMP echo request as 80 bytes.
[Sysname-nqa-admin-test-icmp-echo] data-size 80
description (any NQA operation view)
Use description to configure a description for an NQA operation, such as the operation type or purpose.
Use undo description to remove the description.
No description is configured for an NQA operation.
Any NQA operation view
2: System level
text: Specifies a case-sensitive string of 1 to 200 characters.
# Configure the description for an NQA operation as icmp-probe.
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
destination ip
Use destination ip to configure the destination IP address for the operation.
Use undo destination ip to remove the destination IP address.
destination ip ip-address
undo destination ip
No destination IP address is configured for the operation.
FTP operation view, HTTP operation view, ICMP echo operation view, SNMP operation view, TCP operation view, UDP echo operation view, UDP jitter operation view
2: System level
ip-address: Specifies the destination IP address of the operation.
# Configure the destination IP address of the ICMP echo operation as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
destination port
Use destination port to configure the destination port number for the operation.
Use undo destination port to remove the destination port number.
destination port port-number
No destination port number is configured for the operation.
2: System level
port-number: Specifies the destination port number of the operation, in the range of 1 to 65535.
Do not perform the UDP jitter operation on any well-known port from 1 to 1023. Otherwise, the operation fails or the service on that port becomes unavailable.
# Configure the destination port number of the UDP echo operation as 9000.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
display nqa history
Use display nqa history to display the history records of the specified or all NQA operations.
display nqa history [ admin-name operation-tag ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
admin-name operation-tag: Displays the history records of an NQA operation. The admin-name argument represents the name of the administrator who creates the NQA operation, and is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the operation tag, and is a case-insensitive string of 1 to 32 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
The display nqa history command does not show the results of the UDP jitter operation. Use the display nqa result command to view the results, or use the display nqa statistics command to view the operation statistics.
# Display the history records of the NQA operation with the administrator name administrator and the operation tag test.
<Sysname> display nqa history administrator test
  NQA entry (admin administrator, tag test) history record(s):
    Index      Response     Status           Time
    10         329          Succeeded        2007-04-29 20:54:26.5
    9          344          Succeeded        2007-04-29 20:54:26.2
    8          328          Succeeded        2007-04-29 20:54:25.8
    7          328          Succeeded        2007-04-29 20:54:25.5
    6          328          Succeeded        2007-04-29 20:54:25.1
    5          328          Succeeded        2007-04-29 20:54:24.8
    4          328          Succeeded        2007-04-29 20:54:24.5
    3          328          Succeeded        2007-04-29 20:54:24.1
    2          328          Succeeded        2007-04-29 20:54:23.8
    1          328          Succeeded        2007-04-29 20:54:23.4
Index
History record number.
Response
Round-trip time if the operation succeeds, timeout time upon timeout, or 0 if the operation cannot be completed (in milliseconds).
Status
Status value of operation results:
·     Succeeded.
·     Unknown error.
·     Internal error.
·     Timeout.
Time
Time when the operation was completed.
display nqa reaction counters
Use display nqa reaction counters to display the current monitoring results of reaction entries.
display nqa reaction counters [ admin-name operation-tag [ item-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
admin-name operation-tag: Displays the current monitoring results of reaction entries in an NQA operation. If no operation is specified, the monitoring results of all reaction entries of all NQA operations are displayed. The admin-name argument represents the name of the administrator who creates the NQA operation, and is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the operation tag, and is a case-insensitive string of 1 to 32 characters.
item-number: Displays the current monitoring results of a specific reaction entry. If no reaction entry is provided, the results of all reaction entries are displayed. The item-number argument represents the reaction entry ID in the range of 1 to 10.
If the threshold type is average value, the monitoring results are invalid.
The monitoring results are accumulated after the NQA operation starts and are not cleared after the operation completes.
# Display the monitoring results of all reaction entries of the ICMP echo operation with the administrator name admin and the operation tag test.
<Sysname> display nqa reaction counters admin test
  NQA entry (admin admin, tag test) reaction counters:
    Index  Checked Element  Threshold Type  Checked Num  Over-threshold Num
    1      probe-duration   accumulate      12           4
    2      probe-duration   average         -            -
    3      probe-duration   consecutive     160          56
    4      probe-fail       accumulate      12           0
    5      probe-fail       consecutive     162          2
Index
ID of a reaction entry.
Checked Element
Monitored performance metric.
Threshold Type
Threshold type.
Checked Num
Number of targets that have been monitored for data collection.
Over-threshold Num
Number of threshold violations.
Table 4 Description of the threshold monitoring fields
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes after the group starts.
Number of finished probes after the operation starts.
Number of probes of which the duration exceeds the threshold after the operation starts.
average
N/A
N/A
N/A
consecutive
Probes after the operation starts.
probe-fail
accumulate
Number of probe failures after the operation starts.
consecutive
RTT
accumulate
Packets sent after the operation starts.
Number of packets sent after the operation starts.
Number of packets of which the round-trip time exceeds the threshold after the operation starts.
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets of which the one-way jitter exceeds the threshold after the operation starts.
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets of which the one-way delay exceeds the threshold after the operation starts.
packet-loss
accumulate
Total packet loss after the operation starts.
display nqa result
Use display nqa result to display the result of the specified NQA operation.
display nqa result [ admin-name operation-tag ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
admin-name operation-tag: Displays the results of the specified NQA operation. If no operation is specified, the results of all operations are displayed. The admin-name argument represents the name of the administrator who creates the NQA operation, and is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the operation tag, and is a case-insensitive string of 1 to 32 characters.
# Display the results of the UDP jitter operation.
<Sysname> display nqa result admin test
  NQA entry (admin admin, tag test) test results:
    Destination IP address: 192.168.1.42
      Send operation times: 10             Receive response times: 10
      Min/Max/Average round trip time: 15/46/26
      Square-Sum of round trip time: 8103
      Last succeeded probe time: 2008-05-29 10:56:38.7
    Extended results:
      Packet loss in test: 0%
      Failures due to timeout: 0
      Failures due to disconnect: 0
      Failures due to no connection: 0
      Failures due to sequence error: 0
      Failures due to internal error: 0
      Failures due to other errors: 0
      Packet(s) arrived late: 0
    UDP-jitter results:
     RTT number: 10
      Min positive SD: 8                     Min positive DS: 8
      Max positive SD: 18                    Max positive DS: 8
      Positive SD number: 5                  Positive DS number: 2
      Positive SD sum: 75                    Positive DS sum: 32
      Positive SD average: 15                Positive DS average: 16
      Positive SD square sum: 1189           Positive DS square sum: 640
      Min negative SD: 8                     Min negative DS: 1
      Max negative SD: 24                    Max negative DS: 30
      Negative SD number: 4                  Negative DS number: 7
      Negative SD sum: 56                    Negative DS sum: 99
      Negative SD average: 14                Negative DS average: 14
      Negative SD square sum: 946            Negative DS square sum: 1495
    One way results:
      Max SD delay: 22                       Max DS delay: 23
      Min SD delay: 7                        Min DS delay: 7
      Number of SD delay: 10                 Number of DS delay: 10
      Sum of SD delay: 125                   Sum of DS delay: 132
      Square sum of SD delay: 1805           Square sum of DS delay: 1988
      SD lost packet(s): 0                   DS lost packet(s): 0
      Lost packet(s) for unknown reason: 0
Table 5 Command output
IP address of the destination.
Number of operations.
Number of response times.
Minimum/maximum/average round-trip time in milliseconds.
Square sum of round-trip time.
Time when the last successful operation was finished.
Packet loss in test
Average packet loss ratio.
Min positive SD
Minimum positive jitter from source to destination.
Min positive DS
Minimum positive jitter from destination to source.
Max positive SD
Maximum positive jitter from source to destination.
Max positive DS
Maximum positive jitter from destination to source.
Positive SD number
Number of positive jitters from source to destination.
Positive DS number
Number of positive jitters from destination to source.
Positive SD sum
Sum of positive jitters from source to destination.
Positive DS sum
Sum of positive jitters from destination to source.
Positive SD average
Average positive jitter from source to destination.
Positive DS average
Average positive jitter from destination to source.
Square sum of positive jitters from source to destination.
Square sum of positive jitters from destination to source.
Min negative SD
Minimum absolute value among negative jitters from source to destination.
Min negative DS
Minimum absolute value among negative jitters from destination to source.
Max negative SD
Maximum absolute value among negative jitters from source to destination.
Max negative DS
Maximum absolute value among negative jitters from destination to source.
Negative SD number
Number of negative jitters from source to destination.
Negative DS number
Number of negative jitters from destination to source.
Negative SD sum
Sum of absolute values of negative jitters from source to destination.
Negative DS sum
Sum of absolute values of negative jitters from destination to source.
Negative SD average
Average absolute value of negative jitters from source to destination.
Negative DS average
Average absolute value of negative jitters from destination to source.
Square sum of negative jitters from source to destination.
Square sum of negative jitters from destination to source.
One way results
Unidirectional delay operation result. It is displayed for a UDP jitter operation.
Max SD delay
Maximum delay from source to destination.
Max DS delay
Maximum delay from destination to source.
Min SD delay
Minimum delay from source to destination.
Min DS delay
Minimum delay from destination to source.
Number of SD delay
Number of delays from source to destination.
Number of DS delay
Number of delays from destination to source.
Sum of SD delay
Sum of delays from source to destination.
Sum of DS delay
Sum of delays from destination to source.
Square sum of delays from source to destination.
Square sum of delays from destination to source.
SD lost packet(s)
Number of lost packets from the source to the destination.
DS lost packet(s)
Number of lost packets from the destination to the source.
Number of lost packets for unknown reasons.
Use display nqa statistics to display statistics for the specified or all operations.
display nqa statistics [ admin-name operation-tag ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
admin-name operation-tag: Displays the statistics of the specified NQA operation. If no operation is specified, the statistics of all operations are displayed. The admin-name argument represents the name of the administrator who creates the NQA operation, and is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the operation tag, and is a case-insensitive string of 1 to 32 characters.
The statistics are generated after the NQA operation completes. If you issue the display nqa statistics command before the operation completes, the statistics are displayed as all 0s.
If a reaction entry is configured, the command displays the monitoring results of the reaction entry in the period specified by the statistics internal command. If the threshold type is average value, the monitoring results are invalid.
# Display the statistics of the UDP jitter operation.
<Sysname> display nqa statistics admin test
  NQA entry (admin admin, tag test) test statistics:
    NO. : 1
    Destination IP address: 1.1.1.2
      Start time: 2007-01-01 09:33:22.3
      Life time: 23 seconds
      Send operation times: 100            Receive response times: 100
      Min/Max/Average round trip time: 1/11/5
      Square-Sum of round trip time: 24360
    Extended results:
    UDP-jitter results:
     RTT number: 550
      Min positive SD: 1                     Min positive DS: 1
      Max positive SD: 7                     Max positive DS: 1
      Positive SD number: 220                Positive DS number: 97
      Positive SD sum: 283                   Positive DS sum: 287
      Positive SD average: 1                 Positive DS average: 2
      Positive SD square sum: 709            Positive DS square sum: 1937
      Min negative SD: 2                     Min negative DS: 1
      Max negative SD: 10                    Max negative DS: 1
      Negative SD number: 81                 Negative DS number: 94
      Negative SD sum: 556                   Negative DS sum: 191
      Negative SD average: 6                 Negative DS average: 2
      Negative SD square sum: 4292           Negative DS square sum: 967
    One way results:
      Max SD delay: 5                        Max DS delay: 5
      Min SD delay: 1                        Min DS delay: 1
      Number of SD delay: 550                Number of DS delay: 550
      Sum of SD delay: 1475                  Sum of DS delay: 1201
      Square sum of SD delay: 5407           Square sum of DS delay: 3959
    Reaction statistics:
      1      jitter-DS        accumulate      90           25
      2      jitter-SD        average         -            -
      3      OWD-DS           -               100          24
      4      OWD-SD           -               100          13
      5      packet-loss      accumulate      0            0
      6      RTT              accumulate      100          52
Table 6 Command output
No.
Statistics group number.
Start time
Time when the operation started.
Life time
Operation duration in seconds.
Number of probe packets sent.
Number of response packets received.
Packet loss in test
Number of timeout occurrences in a test.
Number of disconnections by the peer.
Number of failures to connect with the peer.
Number of failures due to out-of-sequence packets.
Number of failures due to internal errors.
Failures due to other errors.
Number of response packets received after a probe times out.
UDP-jitter results
UDP jitter operation results. It is available only for UDP jitter operation.
RTT number
Min positive SD
Min positive DS
Max positive SD
Max positive DS
Positive SD number
Positive DS number
Positive SD sum
Positive DS sum
Positive SD average
Average of positive jitters from source to destination.
Positive DS average
Average of positive jitters from destination to source.
Min negative SD
Min negative DS
Max negative SD
Max negative DS
Negative SD number
Negative DS number
Negative SD sum
Negative DS sum
Negative SD average
Negative DS average
One way results
Unidirectional delay operation result. It is displayed on for a UDP Jitter operation.
Max SD delay
Max DS delay
Min SD delay
Min DS delay
Number of SD delay
Number of DS delay
Sum of SD delay
Sum of DS delay
SD lost packet(s)
DS lost packet(s)
Reaction statistics
Statistics about the reaction entry in the counting interval.
Index
Checked Element
Monitored element.
Threshold Type
Threshold type.
Checked Num
Over-threshold Num
Table 7 Description of the threshold monitoring fields
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes in the counting interval.
Number of finished probes in the counting interval.
Number of probes of which the duration exceeds the threshold in the counting interval.
average
N/A
N/A
N/A
consecutive
probe-fail
accumulate
Number of probe failures in the counting interval.
consecutive
RTT
accumulate
Packets sent in the counting interval.
Number of packets sent in the counting interval.
Number of packets of which the round-trip time exceeds the threshold in the counting interval.
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets of which the one-way jitter exceeds the threshold in the counting interval.
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets of which the one-way delay exceeds the threshold in the counting interval.
packet-loss
accumulate
Number of packet loss in the counting interval.
statistics interval
filename
Use filename to specify a file to be transferred between the FTP server and the FTP client.
Use undo filename to restore the default.
filename filename
undo filename
No file is specified.
FTP operation view
2: System level
filename: Specifies the name of a file, a case-sensitive string of 1 to 200 characters.
# Specify the file to be transferred between the FTP server and the FTP client as config.txt.
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
frequency
Use frequency to specify the interval at which the NQA operation repeats. If the operation is not completed when the interval is reached, the next operation does not start.
Use undo frequency to restore the default.
frequency interval
undo frequency
The interval between two consecutive operations is 0 milliseconds.
2: System level
interval: Specifies the interval in milliseconds between two consecutive operations, in the range of 0 to 604800000. An interval of 0 sets the operation to be performed only once, and to not collect any statistics.
# Configure the ICMP echo operation to repeat at an interval of 1000 milliseconds.
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
history-record enable
Use history-record enable to enable the saving of history records of an NQA operation.
Use undo history-record enable to disable the history records saving function.
The history records of an NQA operation are not saved.
2: System level
To view the history records of the NQA operation, use the display nqa history command.
If the history records saving function is disabled, the system does not save the history records of the NQA operation and the existing history records are also removed.
# Enable the history records saving function of an NQA operation.
[Sysname-nqa-admin-test-icmp-echo] history-record enable
display nqa history
history-record keep-time
Use history-record keep-time to set the lifetime of history records in the NQA operation.
Use undo history-record keep-time to restore the default.
history-record keep-time keep-time
The history records in an NQA operation are kept for 120 minutes.
2: System level
keep-time: Specifies how long the history records can be saved. The time is in the range of 1 to 1440 minutes.
When an NQA operation completes, the timer starts. All the records are removed when the lifetime is reached.
# Configure the lifetime of the history records in an NQA operation as 100 minutes.
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
history-record number
Use history-record number to configure the maximum number of history records that can be saved in an NQA operation.
Use undo history-record number to restore the default.
history-record number number
The maximum number of records that can be saved in an NQA operation is 50.
2: System level
number: Specifies the maximum number of history records that can be saved in an NQA operation. The value is in the range of 0 to 50.
If the number of history records in an NQA operation exceeds the maximum number, the earliest history record is removed.
# Configure the maximum number of history records that can be saved in an NQA operation as 10.
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
http-version
Use http-version to specify the HTTP version used in the HTTP operation.
Use undo http-version to restore the default.
http-version v1.0
undo http-version
HTTP 1.0 is used in the HTTP operation.
HTTP operation view
2: System level
v1.0: Uses HTTP version 1.0.
# Configure the HTTP operation to use the HTTP version 1.0.
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] http-version v1.0
mode
Use mode to set the data transmission mode for the FTP operation.
Use undo mode to restore the default.
mode { active | passive }
undo mode
The data transmission mode use by the FTP operation is active.
FTP operation view
2: System level
active: Sets the data transmission mode to active for the FTP operation. In this mode, the FTP server initiates a connection request.
passive: Sets the data transmission mode to passive for the FTP operation. In this mode, the FTP client initiates a connection request.
# Set the data transmission mode to passive for the FTP operation.
[Sysname-nqa-admin-test-ftp] mode passive
next-hop
Use next-hop to specify the next hop for the ICMP echo operation.
Use undo next-hop to remove the next hop IP address.
next-hop ip-address
undo next-hop
No next hop IP address is configured for the ICMP echo operation.
2: System level
ip-address: Specifies the IP address of the next hop.
If multiple paths exist between the source and destination devices, you can specify the device directly connected to the source device on one of the paths as the next hop for the ICMP echo operation.
# Configure the next hop IP address as 10.1.1.1 for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] next-hop 10.1.1.1
nqa
Use nqa to create an NQA operation and enter its view.
Use undo nqa to remove the operation.
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
No NQA operation is created.
2: System level
admin-name: Specifies the name of the administrator creating the NQA operation, a case-insensitive string of 1 to 32 characters excluding hyphens (-).
operation-tag: Specifies the tag of the operation, a case-insensitive string of 1 to 32 characters excluding hyphens (-).
all: Removes all NQA operations.
If the operation type has been configured for the operation, this command directly places you to NQA operation view.
You cannot enter the operation view or the operation view of a scheduled NQA operation.
# Create an NQA operation with administrator name admin and operation tag test, and enter NQA operation view.
nqa agent enable
Use nqa agent enable to enable the NQA client.
Use undo nqa agent enable to disable the NQA client and stop all the operations being performed.
nqa agent enable
The NQA client is enabled.
2: System level
# Enable the NQA client.
[Sysname] nqa agent enable
nqa server enable
nqa agent max-concurrent
Use nqa agent max-concurrent to configure the maximum number of operations that the NQA client can simultaneously perform.
Use undo nqa agent max-concurrent to restore the default.
nqa agent max-concurrent number
The NQA client can simultaneously perform a maximum of two operations.
2: System level
number: Specifies the maximum number of operations that the NQA client can simultaneously perform. The value range is 1 to 3.
# Configure the maximum number of operations that the NQA client can simultaneously perform as 3.
[Sysname] nqa agent max-concurrent 3
nqa schedule
Use nqa schedule to configure the scheduling parameters for an NQA operation.
Use undo nqa schedule to stop the operation.
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd ] | now } lifetime { lifetime | forever }
undo nqa schedule admin-name operation-tag
2: System level
admin-name: Specifies the administrator name, a case-insensitive string of 1 to 32 characters.
operation-tag: Specifies the operation tag, a case-insensitive string of 1 to 32 characters.
start-time: Specifies the start time and date of the NQA operation.
hh:mm:ss: Specifies the start time of an NQA operation.
yyyy/mm/dd: Specifies the start date of an NQA operation. The default value is the current system time, and yyyy is in the range of 2000 to 2035.
now: Starts the operation immediately.
lifetime: Specifies the duration of the operation.
lifetime: Specifies the duration of the operation in seconds, in the range of 1 to 2147483647.
forever: Performs the operation until you stop it with the undo nqa schedule command.
You cannot enter the operation view or operation view of a scheduled NQA operation.
To view the current system time, use the display clock command.
# Configure the scheduling parameters for the operation with the administrator name admin and operation tag test. The start time and duration of the operation are 08:08:08 2008/08/08 and 1000 seconds.
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000
display clock (Fundamentals Command Reference)
operation (FTP operation view)
Use operation to specify the operation type for the FTP operation.
Use undo operation to restore the default.
operation { get | put }
undo operation
The operation type is get.
FTP operation view
2: System level
get: Gets a file from the FTP server.
put: Transfers a file to the FTP server.
When you execute the put command, the NQA client creates a file named file-name of fixed size on the FTP server. The file-name argument does not represent any file on the NQA client. When you execute the get command, the client does not save the file obtained from the FTP server.
# Specify the operation type for the FTP operation as put.
[Sysname-nqa-admin-test-ftp] operation put
operation (HTTP operation view)
Use operation to specify the operation type for the HTTP operation.
operation { get | post }
undo operation
HTTP operation view
2: System level
get: Gets data from the HTTP server.
post: Transfers data to the HTTP server.
# Specify the operation type for the HTTP operation as post.
[Sysname-nqa-admin-test-http] operation post
operation interface
Use operation interface to specify the interface to perform the DHCP operation. The specified interface must be up. Otherwise, no probe packets can be sent out.
Use undo operation interface to restore the default.
operation interface interface-type interface-number
No interface is specified to perform the DHCP operation.
DHCP operation view
2: System level
The specified interface simulates the DHCP client to acquire an IP address and it does not change its IP address. When the DHCP operation completes, the NQA client sends a packet to release the obtained IP address.
# Specify the interface VLAN-interface 2 to perform the DHCP operation.
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] operation interface vlan-interface 2
password (FTP operation view)
Use password to configure a password used to log in to the FTP server.
Use undo password to remove the configured password.
password [ cipher | simple ] password
undo password
No password is configured for logging in to the FTP server.
FTP operation view
2: System level
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies the password used to log in to the FTP server. This argument is case sensitive. If simple is specified, it must be a plaintext string of 1 to 32 characters. If cipher is specified, it must be a ciphertext string of 1 to 73 characters. If neither cipher nor simple is specified, you set a plaintext password.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
# Configure the password used for logging in to the FTP server as ftpuser.
[Sysname-nqa-admin-test-ftp] password simple ftpuser
·     username
·     operation
probe count
Use probe count to specify the probe times.
Use undo probe count to restore the default.
probe count times
undo probe count
An operation performs one probe.
DHCP operation view, FTP operation view, HTTP operation view, ICMP echo operation view, SNMP operation view, TCP operation view, UDP echo operation view, UDP jitter operation view
2: System level
times: Specifies the probe times in the range of 1 to 15.
The following describes how different NQA operation types operate:
·     A TCP operation sets up a connection.
·     A UDP jitter operation sends a specific number of probe packets. The number of probe packets is configurable with the probe packet-number command.
·     An FTP operation uploads or downloads a file.
·     An HTTP operation gets a Web page.
·     A DHCP operation gets an IP address through DHCP.
·     An ICMP echo operation sends an ICMP echo request.
·     A UDP echo operation sends a UDP packet.
·     An SNMP operation sends one SNMPv1 packet, one SNMPv2c packet, and one SNMPv3 packet.
If an operation is to perform multiple probes, the system starts the next probe when it receives responses to packets sent in the first probe, or when the probe timeout time expires.
# Configure the ICMP echo operation to perform 10 probes.
[Sysname-nqa-admin-test-icmp-echo] probe count 10
probe packet-interval
Use probe packet-interval to configure the interval for sending packets in the probe.
Use undo probe packet-interval to restore the default.
probe packet-interval packet-interval
The interval is 20 milliseconds.
2: System level
packet-interval: Specifies the interval for sending packets, in the range of 10 to 60000 milliseconds.
# Configure the UDP jitter operation to send packets at an interval of 100 milliseconds.
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number
Use probe packet-number to configure the number of packets to be sent in one UDP jitter probe.
Use undo probe packet-number to restore the default.
probe packet-number packet-number
An UDP jitter probe sends 10 packets.
2: System level
packet-number: Specifies the number of packets to be sent per probe, in the range of 10 to 1000.
# Configure the UDP jitter probe to send 100 packets.
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout
Use probe packet-timeout to configure the timeout time for waiting for a response in the UDP jitter operation.
Use undo probe packet-timeout to restore the default.
probe packet-timeout packet-timeout
The response timeout time in the UDP jitter operation is 3000 milliseconds.
UDP jitter
2: System level
packet-timeout: Specifies the timeout time in milliseconds for waiting for a response in the UDP jitter operation. The value is in the range of 10 to 3600000.
# Configure the timeout time for waiting for a response in the UDP jitter operation as 100 milliseconds.
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout
Use probe timeout to specify the probe timeout time. If a probe does not complete within the period, the probe is timed out.
Use undo probe timeout to restore the default.
probe timeout timeout
undo probe timeout
The timeout time of a probe is 3000 milliseconds.
2: System level
timeout: Specifies the probe timeout time in milliseconds. The value is in the range of 10 to 86400000 for the FTP or HTTP operation, and 10 to 3600000 for the DHCP, ICMP echo, SNMP, TCP, or UDP echo operation.
This command is not available for the UDP jitter operation.
# Configure the probe timeout time for the DHCP operation as 10000 milliseconds.
[Sysname-nqa-admin-test-dhcp] probe timeout 10000
reaction checked-element { jitter-ds | jitter-sd }
Use reaction checked-element { jitter-ds | jitter-sd } to configure a reaction entry for monitoring one-way jitter in the NQA operation. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
Use undo reaction to delete the specified reaction entry.
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
No reaction entry for monitoring one-way jitter is configured.
2: System level
item-number: Specifies a reaction entry ID in the range of 1 to 10.
jitter-ds: Specifies the destination-to-source jitter of each probe packet as the monitored element (or performance metric).
jitter-sd: Specifies source-to-destination jitter of each probe packet as the monitored element.
threshold-type: Specifies a threshold type.
accumulate accumulate-occurrences: Specifies the total number of threshold violations in the operation, in the range of 1 to 14999.
average: Specifies to check the average one-way jitter.
threshold-value: Specifies threshold values in milliseconds.
upper-threshold: Specifies the upper threshold in the range of 0 to 3600000.
lower-threshold: Specifies the lower threshold in the range of 0 to 3600000. It must not be greater than the upper threshold.
action-type: Specifies an action to be triggered. The default action is none.
none: Specifies the action of only displaying results on the terminal display.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS.
Only successful probe packets are monitored. Failed probe packets are not counted.
# Create reaction entry 1 for monitoring the average destination-to-source jitter of UDP jitter packets. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average destination-to-source jitter is checked. If it exceeds the upper threshold, the state of the reaction entry is set to over-threshold. If it is below the lower threshold, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the destination-to-source jitter of UDP jitter probe packets. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the destination-to-source jitter is checked against the threshold range. If the total number of threshold violations exceeds 100 (included), the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction checked-element { owd-ds | owd-sd }
Use reaction checked-element { owd-ds | owd-sd } to configure a reaction entry for monitoring the one-way delay. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
No reaction entry for monitoring the one-way delay is configured.
2: System level
owd-ds: Specifies the destination-to-source delay of each probe packet as the monitored element.
owd-sd: Specifies the source-to-destination delay of each probe packet as the monitored element.
No actions can be configured for a reaction entry of monitoring one-way delays. The monitoring results and statistics can be displayed with the display nqa reaction counters and display nqa statistics commands.
# Create reaction entry 1 for monitoring the destination-to-source delay of every UDP jitter packet. Set the upper threshold to 50 milliseconds and lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. The destination-to-source delay is calculated after the response to the probe packet arrives. If the delay exceeds the upper threshold, the state of the reaction entry is set to over-threshold. If it is below the lower threshold, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
reaction checked-element packet-loss
Use reaction checked-element packet-loss to configure a reaction entry for monitoring packet loss in the NQA operation. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
No reaction entry for monitoring packet loss is configured.
2: System level
accumulate accumulate-occurrences: Specifies the total number of lost packets in the operation, in the range of 1 to 15000.
# Create reaction entry 1 for monitoring packet loss in the UDP jitter operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, lost packets are checked. If the total number of lost packets exceeds 100 (included), the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction checked-element probe-duration
Use reaction checked-element probe-duration to configure a reaction entry for monitoring the operation duration. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entry for monitoring the probe duration is configured.
2: System level
accumulate accumulate-occurrences: Specifies the total number of threshold violations. The value is in the range of 1 to 15.
average: Specifies to check the average operation duration.
consecutive consecutive-occurrences: Specifies the number of consecutive threshold violations after the NQA operation starts. The value is in the range of 1 to 16.
Only successful operations are monitored. Failed operations are not counted.
# Create reaction entry 1 for monitoring the average duration of ICMP echo operation. Set the upper threshold to 50 milliseconds and lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average probe duration is checked. If it exceeds the upper threshold, the state is set to over-threshold. If it is below the lower threshold, the state of the reaction entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the duration of ICMP echo operation. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the probe duration is checked against the threshold range. If the total number of threshold violations exceeds 10 (included), the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# Create reaction entry 3 for monitoring the duration time of ICMP echo operation. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the probe duration is checked against the threshold range. If the consecutive threshold violations exceed 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction checked-element probe-fail (for trap)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe results of the operation. If the number of consecutive probe failures reaches the threshold, collaboration with other modules is triggered. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
No reaction entry for monitoring probe failures is configured.
2: System level
accumulate accumulate-occurrences: Specifies the total number of probe failures. The value is in the range of 1 to 15.
consecutive consecutive-occurrences: Specifies the maximum number of consecutive probe failures. The value is in the range of 1 to 16.
# Create reaction entry 1 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures exceeds 10 (included), the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# Create reaction entry 2 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the number of consecutive probe failures exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction checked-element probe-fail (for trigger)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe failures. This command is applicable to trap messages only. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
Use undo reaction to remove the specified reaction entry.
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
No reaction entries are configured.
2: System level
consecutive consecutive-occurrences: Specifies the maximum number of consecutive probe failures, in the range of 1 to 16.
trigger-only: Triggers other modules to react to certain conditions.
The collaboration function is not supported by the UDP jitter operation.
# Create reaction entry 1. If the number of consecutive probe failures reaches 3, collaboration is triggered.
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
track (High Availability Command Reference)
reaction checked-element rtt
Use reaction checked-element rtt to configure a reaction entry for monitoring packet round-trip time. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete the entry first and then configure a new one.
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entry for monitoring packet round-trip time is configured.
2: System level
accumulate accumulate-occurrences: Specifies the total number of threshold violations, in the range of 1 to 15000.
average: Specifies to check the packet average round-trip time.
# Create reaction entry 1 for monitoring the average round-trip time of UDP jitter probe packets. Set the upper threshold to 50 milliseconds and lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average packet round-trip time is checked. If it exceeds the upper threshold, the state is set to over-threshold. If it is below the lower threshold, the state is set to below-threshold. Once the reaction entry state changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the round-trip time of UDP jitter probe packets. Set the upper threshold to 50 milliseconds, and lower threshold to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the packet round-trip time is checked. If the total number of threshold violations exceeds 100 (included), the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction trap
Use reaction trap to configure the sending of traps to the NMS under specified conditions.
Use undo reaction trap to restore the default.
reaction trap { probe-failure consecutive-probe-failures | test-complete | test-failure cumulate-probe-failures }
undo reaction trap { probe-failure | test-complete | test-failure }
No traps are sent to the NMS.
2: System level
probe-failure consecutive-probe-failures: Sends a trap to the NMS if the number of consecutive probe failures in an operation is greater than or equal to consecutive-probe-failures. The value for consecutive-probe-failures is in the range of 1 to 15. The system counts the number of consecutive probe failures for each operation, so multiple traps might be sent.
test-complete: Sends a trap to indicate that the operation is completed.
test-failure cumulate-probe-failures: Sends a trap if the total number of probe failures in an operation is greater than or equal to cumulate-probe-failures. The value for cumulate-probe-failures is in the range of 1 to 15. The system counts the total probe failures after the last operation completes, so one trap at most is sent.
# Configure the system to send a trap if the number of consecutive probe failures in an ICMP echo operation is greater than or equal to 5.
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
route-option bypass-route
Use route-option bypass-route to enable the routing table bypass function to test the direct connectivity to the direct destination.
Use undo route-option bypass-route to disable the routing table bypass function.
The routing table bypass function is disabled.
2: System level
When the routing table bypass function is enabled, the routing table is not searched, and the packet is sent directly to the destination in a directly connected network.
# Enable the routing table bypass function.
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface
Use source interface to configure the source interface for ICMP echo request packets. The ICMP echo request packets take the primary IP address of the source interface as their source IP address when no source IP address is specified. The specified source interface must be up. Otherwise, no ICMP echo requests can be sent out.
Use undo source interface to restore the default.
source interface interface-type interface-number
No source interface is configured for ICMP echo request packets.
2: System level
If you configure both the source interface command and the source ip command, the source ip command takes effect.
# Specify the primary IP address of interface VLAN-interface 2 as the source IP address of ICMP echo request packets.
[Sysname-nqa-admin-test-icmp-echo] source interface vlan-interface 2
source ip
source ip
Use source ip to configure the source IP address of probe packets. The specified source IP address must be the IP address of a local interface. The local interface must be up. Otherwise, no probe packets can be sent out.
Use undo source ip to remove the configured source address. The primary IP address of the interface that sends a probe packet serves as the source IP address of the probe packet.
source ip ip-address
undo source ip
No source IP address is configured for probe packets.
2: System level
ip-address: Specifies the source IP address of the operation.
If you configure the source interface command but not the source ip command for the ICMP echo operation, the IP address of source interface is used as the source IP address of the ICMP echo request packet.
# Configure the source IP address of the ICMP echo packets as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
source interface
source port
Use source port to configure the source port of probe packets.
Use undo source port to remove the configured port number.
source port port-number
undo source port
No source port number is configured.
SNMP operation view, UDP echo operation view, UDP jitter operation view
2: System level
port-number: Specifies the source port number of probe packets, in the range of 1 to 50000.
# Configure port 8000 as the source port of probe packets in the UDP echo operation.
[Sysname-nqa-admin-test-udp-echo] source port 8000
statistics hold-time
Use statistics hold-time to configure the hold time of statistics groups for an NQA operation. A statistics group is deleted when its hold time expires.
Use undo statistics hold-time to restore the default.
statistics hold-time hold-time
The hold time of statistics groups is 120 minutes.
2: System level
hold-time: Specifies the hold time of statistics groups in minutes, in the range of 1 to 1440.
This command is not available for the DHCP operation.
# Configure the hold time of statistics groups as 3 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics max-group
Use statistics max-group to configure the maximum number of statistics groups that can be saved.
Use undo statistics max-group to restore the default.
statistics max-group number
A maximum of two statistics groups can be saved.
2: System level
number: Specifies the maximum number of statistics groups that can be saved, in the range of 0 to 100. To disable collecting statistics, set the value to 0.
When the number of statistics groups saved reaches the upper limit and a new statistics group is to be saved, the earliest statistics group is deleted.
This command is not supported by DHCP operation.
# Configure the NQA to save up to 5 statistics groups for the ICMP operation.
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
statistics interval
Use statistics interval to configure the interval for collecting result statistics for an NQA operation.
Use undo statistics interval to restore the default.
statistics interval interval
The interval is 60 minutes.
2: System level
interval: Specifies the interval in minutes for collecting statistics for an NQA operation, in the range of 1 to 35791394.
NQA collects the result statistics within the specified interval in a statistics group. The statistics form a statistics group. To view information about the statistics groups, use the display nqa statistics command.
# Configure the interval for collecting the test result statistics of the ICMP echo operation as 2 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
tos
Use tos to specify the ToS value in the IP packet header of probe packets.
Use undo tos to restore the default.
tos value
undo tos
The ToS value in the IP packet header of probe packets is 0.
2: System level
value: Specifies the ToS value in the IP packet header of probe packets, in the range of 0 to 255.
# Configure the ToS value in an IP packet header of probe packets as 1.
[Sysname-nqa-admin-test-icmp-echo] tos 1
ttl
Use ttl to specify the TTL for probe packets.
Use undo ttl to restore the default.
ttl value
undo ttl
The TTL for probe packets is 20.
2: System level
value: Specifies the TTL for probe packets, in the range of 1 to 255.
After you configure the route-option bypass-route command, the TTL for probe packets is 1, and the ttl command does not take effect.
# Configure the TTL for probe packets as 16.
[Sysname-nqa-admin-test-icmp-echo] ttl 16
type
Use type to specify the operation type of the NQA operation and enter operation view.
type { dhcp | ftp | http | icmp-echo | snmp | tcp | udp-echo | udp-jitter }
No operation type is specified.
NQA operation view
2: System level
dhcp: Specifies the DHCP operation type.
ftp: Specifies the FTP operation type.
http: Specifies the HTTP operation type.
icmp-echo: Specifies the ICMP echo operation type.
snmp: Specifies the SNMP operation type.
tcp: Specifies the TCP operation type.
udp-echo: Specifies the UDP echo operation type.
udp-jitter: Specifies the UDP jitter operation type.
# Specify the type of the NQA operation as FTP and enter FTP operation view.
url
Use url to specify the website URL for the HTTP operation to visit.
Use undo url to remove the specified website URL.
url url
undo url
HTTP operation view
2: System level
url: Specifies the website URL for the operation to visit, a case-sensitive string of 1 to 185 characters.
The character string of the configured URL cannot contain spaces.
# Configure the website URL that the HTTP operation visits as /index.htm.
[Sysname-nqa-admin-test-http] url /index.htm
username (FTP operation view)
Use username to configure a username used to log in to the FTP server.
Use undo username to remove the username.
username username
undo username
No username is configured for logging in to the FTP server.
FTP operation view
Default command level
2: System level
username: Specifies the username used to log in to the FTP server. The username is a case-sensitive string of 1 to 32 characters.
# Configure the login username as administrator.
[Sysname-nqa-admin-test-ftp] username administrator
·     password
·     operation
NQA server configuration commands
You only need to configure the NQA server for UDP jitter, TCP, and UDP echo operations.
display nqa server status
Use display nqa server status to display NQA server status.
display nqa server status [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display NQA server status.
<Sysname> display nqa server status
nqa server is: enabled
tcp-connect:
    IP Address     Port           Status
    2.2.2.2        2000           active
udp-echo:
    3.3.3.3        3000            inactive
Table 8 Command output
tcp-connect
TCP connect listening service.
udp-echo
UDP echo listening service.
IP Address
IP address specified for the TCP/UDP listening service on the NQA server.
Port
Port number of the TCP/UDP listening service on the NQA server.
Status
Listening service status:
·     active—Listening service is ready.
·     inactive—Listening service is not ready.
nqa server enable
Use nqa server enable to enable the NQA server.
Use undo nqa server enable to disable the NQA server.
nqa server enable
The NQA server is disabled.
2: System level
# Enable the NQA server.
[Sysname] nqa server enable
·     nqa server tcp-connect
·     nqa server udp-echo
·     display nqa server status
Use nqa server tcp-connect to configure a listening service to enable the NQA server to listen and respond on the specified IP address and port.
Use undo nqa server tcp-connect to remove the TCP listening service.
nqa server tcp-connect ip-address port-number
undo nqa server tcp-connect ip-address port-number
2: System level
ip-address: Specifies the IP address for the TCP connect listening service.
port-number: Specifies the port number for the TCP connect listening service, in the range of 1 to 50000.
Configure the command on the NQA server for the TCP operation only.
The IP address and port number must be consistent with those on the NQA client and must be different from those of an existing TCP listening service.
The IP address must be that of an interface on the NQA server. Otherwise, the configuration is invalid.
# Configure a TCP listening service to enable the NQA server to listen and respond on the IP address 169.254.10.2 and port 9000.
[Sysname] nqa server tcp-connect 169.254.10.2 9000
·     nqa server enable
nqa server udp-echo
Use nqa server udp-echo to configure a UDP echo listening service to enable the NQA server to listen and respond on the specified IP address and port.
Use undo nqa server udp-echo to remove the UDP listening service created.
nqa server udp-echo ip-address port-number
undo nqa server udp-echo ip-address port-number
2: System level
ip-address: Specifies the IP address for the UDP echo listening service.
port-number: Specifies the port number for the UDP listening service, in the range of 1 to 50000.
Configure the command on the NQA server for the UDP jitter and UDP echo operations only.
The IP address and port number must be consistent with those configured on the NQA client and must be different from those of an existing UDP listening service.
The IP address must be that of an interface on the NQA server. Otherwise, the configuration becomes invalid.
# Configure a UDP listening service to enable the NQA server to listen and respond on the IP address 169.254.10.2 and port 9000.
[Sysname] nqa server udp-echo 169.254.10.2 9000
·     nqa server enable
