| 05-SNMP Commands | 161.46 KB |
display snmp-agent local-engineid
snmp-agent trap if-mib link extended
snmp-agent usm-user { v1 | v2c }
SNMP commands
display snmp-agent community
Use display snmp-agent community to display SNMPv1 and SNMPv2c community information.
display snmp-agent community [ read | write ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
read: Displays information about SNMP read-only communities.
write: Displays information about SNMP read and write communities.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
This command displays the SNMPv1 and SNMPv2c communities that you have created using the snmp-agent community command or the snmp-agent usm-user { v1 | v2c } command.
This command is applicable only to non-FIPS mode.
# Display information about all SNMPv1 and SNMPv2c communities.
<Sysname> display snmp-agent community
Community name: aa
Group name: aa
Acl:2001
Storage-type: nonVolatile
Community name: bb
Group name: bb
Community name: userv1
Group name: testv1
Community name |
Displays the community name created by using the snmp-agent community command or the username created by using the snmp-agent usm-user { v1 | v2c } command. |
Group name |
SNMP group name: · If the community is created by using the snmp-agent community command, the group name is the same as the community name. · If the community is created by using the snmp-agent usm-user { v1 | v2c } command, the name of the group to which the user belongs is displayed. |
Acl |
Number of the ACL that controls the access of the NMSs in the community to the device. Only the NMSs with the IP addresses permitted in the ACL can access the device with the community name. |
Storage-type |
Storage type: · volatile—Settings are lost when the system reboots. · nonVolatile—Settings remain after the system reboots. · permanent—Settings remain after the system reboots and can be modified but not deleted. · readOnly—Settings remain after the system reboots and cannot be modified or deleted. · other—Any other storage type. |
· snmp-agent community
· snmp-agent usm-user { v1 | v2c }
display snmp-agent group
Use display snmp-agent group to display information about an SNMP group, including the group name, security model, MIB view, and storage type.
display snmp-agent group [ group-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group-name: Specifies an SNMP group name, a case-sensitive string of 1 to 32 characters. You can specify an SNMPv1, SNMPv2c, or SNMPv3 group.
If no group is specified, the command displays information about all SNMP groups.
# Display information about all SNMP groups.
<Sysname> display snmp-agent group
Group name: groupv1
Security model: v1 noAuthnoPriv
Readview: ViewDefault
Writeview: <no specified>
Notifyview: <no specified>
Group name: groupv3
Security model: v3 noAuthnoPriv
Group name |
SNMP group name. |
Security model |
Security model of the SNMP group: · authPriv—Authentication with privacy. · authNoPriv—Authentication without privacy. · noAuthNoPriv—No authentication, no privacy. The security model of an SNMPv1 or SNMPv2c group can only be noAuthNoPriv. |
Readview |
Read-only MIB view accessible to the SNMP group. |
Writeview |
Write MIB view accessible to the SNMP group. |
Notifyview |
Notify MIB view for the SNMP group. The SNMP users in the group can send traps only for the nodes in the notify MIB view. |
Storage-type |
Storage type: volatile, nonVolatile, permanent, readOnly, and other (see Table 1). |
snmp-agent group
Use display snmp-agent local-engineid to display the local SNMP engine ID.
display snmp-agent local-engineid [ | { begin | exclude | include } regular-expression ]
1: Monitor level
The local SNMP engine ID uniquely identifies the SNMP engine of the SNMP agent in an SNMP domain.
Every SNMP agent has one SNMP engine to provide services for sending and receiving messages, authenticating and encrypting messages, and controlling access to managed objects.
# Display the local engine ID.
<Sysname> display snmp-agent local-engineid
SNMP local EngineID: 800007DB7F0000013859
display snmp-agent mib-view
Use display snmp-agent mib-view to display MIB views.
display snmp-agent mib-view [ exclude | include | viewname view-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
exclude: Displays the subtrees excluded from any MIB view.
include: Displays the subtrees included in any MIB view.
viewname view-name: Displays information about the specified MIB view.
If you do not specify any parameter, the command displays all MIB views.
# Display all MIB views.
<Sysname> display snmp-agent mib-view
View name:ViewDefault
MIB Subtree:iso
Subtree mask:
View Type:included
View status:active
MIB Subtree:snmpUsmMIB
Subtree mask:
View Type:excluded
View status:active
MIB Subtree:snmpVacmMIB
Subtree mask:
View Type:excluded
View status:active
MIB Subtree:snmpModules.18
Subtree mask:
View Type:excluded
View status:active
ViewDefault is the default MIB view. The output shows that except for the MIB objects in the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees, all the MIB objects in the iso subtree are accessible.
View name |
MIB view name. |
MIB Subtree |
MIB subtree covered by the MIB view. |
Subtree mask |
MIB subtree mask. |
Storage-type |
Type of the medium where the subtree view is stored. |
View Type |
Access privilege for the MIB subtree in the MIB view: · Included—All objects in the MIB subtree are accessible in the MIB view. · Excluded—None of the objects in the MIB subtree is accessible in the MIB view. |
View status |
Status of the MIB view. |
display snmp-agent statistics
Use display snmp-agent statistics to display SNMP message statistics.
display snmp-agent statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display SNMP message statistics.
<Sysname> display snmp-agent statistics
1684 Messages delivered to the SNMP entity
5 Messages which were for an unsupported version
0 Messages which used a SNMP community name not known
0 Messages which represented an illegal operation for the community supplied
0 ASN.1 or BER errors in the process of decoding
1679 Messages passed from the SNMP entity
0 SNMP PDUs which had badValue error-status
0 SNMP PDUs which had genErr error-status
0 SNMP PDUs which had noSuchName error-status
0 SNMP PDUs which had tooBig error-status (Maximum packet size 4000)
16544 MIB objects retrieved successfully
2 MIB objects altered successfully
7 GetRequest-PDU accepted and processed
7 GetNextRequest-PDU accepted and processed
1653 GetBulkRequest-PDU accepted and processed
1669 GetResponse-PDU accepted and processed
2 SetRequest-PDU accepted and processed
0 Trap PDUs accepted and processed
0 Alternate Response Class PDUs dropped silently
0 Forwarded Confirmed Class PDUs dropped silently
Messages delivered to the SNMP entity |
Number of messages that the SNMP agent has received. |
Messages which were for an unsupported version |
Number of messages that had an SNMP version not configured on the SNMP agent. |
Messages which used a SNMP community name not known |
Number of messages that had a community name not configured on the SNMP agent. |
Messages which represented an illegal operation for the community supplied |
Number of messages carrying an operation that the community has no right to perform. |
ASN.1 or BER errors in the process of decoding |
Number of messages that had ASN.1 or BER errors during decoding. |
Messages passed from the SNMP entity |
Number of messages sent by the SNMP agent. |
SNMP PDUs which had badValue error-status |
Number of SNMP PDUs with a badValue error. |
SNMP PDUs which had genErr error-status |
Number of SNMP PDUs with a genErr error. |
SNMP PDUs which had noSuchName error-status |
Number of PDUs with a noSuchName error. |
SNMP PDUs which had tooBig error-status (Maximum packet size 4000) |
Number of PDUs with a tooBig error (the maximum packet size is 4000 bytes). |
MIB objects retrieved successfully |
Number of MIB objects that have been successfully retrieved. |
MIB objects altered successfully |
Number of MIB objects that have been successfully modified. |
GetRequest-PDU accepted and processed |
Number of get requests that have been received and processed. |
GetNextRequest-PDU accepted and processed |
Number of getNext requests that have been received and processed. |
GetBulkRequest-PDU accepted and processed |
Number of getBulk requests that have been received and processed. |
GetResponse-PDU accepted and processed |
Number of get responses that have been received and processed. |
SetRequest-PDU accepted and processed |
Number of set requests that have been received and processed. |
Trap PDUs accepted and processed |
Number of traps that have been received and processed. |
Alternate Response Class PDUs dropped silently |
Number of dropped response packets. |
Forwarded Confirmed Class PDUs dropped silently |
Number of forwarded packets that have been dropped. |
display snmp-agent sys-info
Use display snmp-agent sys-info to display the current SNMP system information.
display snmp-agent sys-info [ contact | location | version ] * [ | { begin | exclude | include } regular-expression ]
1: Monitor level
contact: Displays the system contact.
version: Displays the SNMP version of the SNMP agent.
If no keyword is specified, all SNMP agent system information is displayed.
# Display SNMP agent system information.
<Sysname> display snmp-agent sys-info
The contact person for this managed node:
New H3C Technologies Co., Ltd.
The physical location of this node:
Hangzhou, China
SNMP version running in the system:
SNMPv3
display snmp-agent trap queue
Use display snmp-agent trap queue to display basic information about the trap queue, including the trap queue name, queue length, and number of traps in the queue.
display snmp-agent trap queue [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the trap queue configuration and usage status.
<Sysname> display snmp-agent trap queue
Queue name: SNTP
Queue size: 100
Message number: 6
Table 5 Command output
Queue name |
Trap queue name. |
Queue size |
Trap queue size. |
Message number |
Number of traps in the current trap queue. |
· snmp-agent trap life
· snmp-agent trap queue-size
display snmp-agent trap-list
Use display snmp-agent trap-list to display modules that can generate traps and their trap status (enable or disable).
display snmp-agent trap-list [ | { begin | exclude | include } regular-expression ]
1: Monitor level
You can use the snmp-agent trap enable command to enable or disable the trap function of a module. For a module that has multiple sub-modules, the trap status is enable if the trap function of any of its sub-modules is enabled.
# Display the modules that can generate traps and their trap status.
<Sysname> display snmp-agent trap-list
configuration trap enable
flash trap enable
standard trap enable
system trap enable
vrrp trap enable
Enable traps: 5; Disable traps: 0
display snmp-agent usm-user
Use display snmp-agent usm-user to display SNMPv3 user information.
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] * [ | { begin | exclude | include } regular-expression ]
1: Monitor level
engineid engineid: Displays SNMPv3 user information for the SNMP engine ID identified by engineid. When an SNMPv3 user is created, the system records the local SNMP entity engine ID. The user becomes invalid when the engine ID changes and becomes valid again when the recorded engine ID is restored.
username user-name: Displays information about the specified SNMPv3 user. The username is case sensitive.
group group-name: Displays SNMPv3 user information for an SNMP group. The group name is case sensitive.
This command displays only SNMPv3 users that you have created by using the snmp-agent usm-user v3 command. To display SNMPv1 or SNMPv2c users created by using the snmp-agent usm-user { v1 | v2c } command, use the display snmp-agent community command.
# Display information about SNMPv3 users.
<Sysname> display snmp-agent usm-user
User name: userv3
Group name: mygroupv3
Engine ID: 800063A203000FE240A1A6
UserStatus: active
User name: userv3code
Group name: groupv3code
UserStatus: active
Table 6 Command output
User name |
SNMP username. |
Group name |
SNMP group name. |
Engine ID |
Engine ID for an SNMP entity. |
Storage-type |
Storage type: · volatile. · nonvolatile. · permanent. · readOnly. · other. For more information about these storage types, see Table 1. |
UserStatus |
SNMP user status. |
enable snmp trap updown
Use enable snmp trap updown to enable link state traps on an interface.
Use undo enable snmp trap updown to disable link state traps on an interface.
Link state traps are enabled.
Interface view
2: System level
For an interface to generate linkUp/linkDown traps when its state changes, you must also enable the linkUp/linkDown trap function globally by using the enable snmp trap updown command.
# Enable GigabitEthernet 1/0/1 to send linkUp/linkDown SNMP traps to 10.1.1.1 in the community public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[Sysname-GigabitEthernet1/0/1] enable snmp trap updown
· snmp-agent target-host
· snmp-agent trap enable
sample-interval
Use sample-interval to set the interval for collecting data (for example, member usage and CPU usage) for calculating statistics for certain user-specified MIB nodes.
Use undo sample-interval to restore the default.
sample-interval sample-interval
The sampling interval is 0, and the system does not sample data for calculating statistics for the user-specified MIB nodes.
3: Manage level
sample-interval: Specifies the sampling interval, in the range 0 to 300 seconds.
To make sure the system performs at least one data poll for each statistics interval, set the statistics interval equal to or greater than the sampling interval.
# Set the sampling interval to 100 seconds for calculating statistics for the user-specified MIB nodes.
[Sysname] statistics-interval 600
[Sysname] sample-interval 100
statistics-interval
snmp-agent
Use snmp-agent to enable the SNMP agent.
Use undo snmp-agent to disable the SNMP agent.
snmp-agent
undo snmp-agent
The SNMP agent is disabled.
3: Manage level
The snmp-agent command is optional for an SNMP configuration task. The SNMP agent is automatically enabled when you execute any command that begins with snmp-agent except for the snmp-agent calculate-password command.
# Enable the SNMP agent.
Use snmp-agent calculate-password to convert a plaintext key to an encrypted key for authentication or encryption in SNMPv3.
In non-FIPS mode:
snmp-agent calculate-password plain-password mode { 3desmd5 | 3dessha | md5 | sha } { local-engineid | specified-engineid engineid }
In FIPS mode:
snmp-agent calculate-password plain-password mode sha { local-engineid | specified-engineid engineid }
3: Manage level
plain-password: Specifies a plaintext authentication or privacy key.
mode: Specifies authentication and privacy algorithms. Select a mode option, depending on the authentication and privacy algorithm you are configuring with the snmp-agent usm-user v3 command. The privacy algorithms AES, 3DES, and DES are in descending order of security strength. Higher security means more complex implementation mechanism and lower speed. DES is enough to meet general requirements. The MD5 and SHA-1 are the two authentication algorithms. MD5 is faster but less secure than SHA-1. For more information about these algorithms, see Security Configuration Guide.
· 3desmd5: Converts the plaintext privacy key to an encrypted key for 3DES encryption used together with MD5 authentication.
· 3dessha: Converts the plaintext privacy key to an encrypted key for 3DES encryption used together with SHA-1 authentication.
· md5: Converts the plaintext authentication key to an encrypted key for MD5 authentication, or converts the plaintext privacy key to an encrypted key for AES or DES encryption used in conjunction with MD5.
· sha: Converts the plaintext authentication key to an encrypted key for SHA-1 authentication, or converts the plaintext privacy key to an encrypted key for AES or DES encryption used in conjunction with SHA-1 authentication.
local-engineid: Uses the local engine ID to calculate the encrypted key. For engine ID-related configuration, see the snmp-agent local-engineid command.
specified-engineid: Uses a user-defined engine ID to calculate the encrypted key.
engineid: Specifies an SNMP engine ID as a hexadecimal string. It must comprise an even number of hexadecimal characters, in the range of 10 to 64. All-zero and all-F strings are invalid.
This command helps you calculate encrypted authentication and privacy keys for SNMPv3 users that use encrypted authentication and privacy keys. To create an SNMPv3 user, see the snmp-agent usm-user v3 command.
Make sure the SNMP agent is enabled before you execute the snmp-agent calculate-password command.
The converted key is valid only under the engine ID specified for key conversion.
The 3des and md5 keywords are supported only in non-FIPS mode. Only the sha keyword is supported in FIPS mode.
# Use the local engine and the MD5 algorithm to convert the plaintext key authkey to an encrypted key.
[Sysname] snmp-agent calculate-password authkey mode md5 local-engineid
The secret key is: 09659EC5A9AE91BA189E5845E1DDE0CC
Use snmp-agent community to configure an SNMP community.
Use undo snmp-agent community to delete an SNMP community.
snmp-agent community { read | write } [ cipher ] community-name [ mib-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent community { read | write } [ cipher ] community-name
3: Manage level
read: Assigns the specified community the read-only access to MIB objects. A read-only community can only read MIB information.
write: Assigns the specified community the read and write access to MIB objects. A read and write community can configure MIB information.
cipher: Saves the specified community name in cipher text. If this keyword is not specified, the command saves the community name in plain text.
community-name: Sets a community name. If you specify the cipher keyword, the community name is a string of 1 to 73 characters. If you do not specify the cipher keyword, the community name is a string of 1 to 32 characters.
mib-view view-name: Specifies the MIB view available for the community. The view-name argument represents a MIB view name, a string of 1 to 32 characters. A MIB view represents a set of accessible MIB objects. If no MIB view is specified, the specified community can access the MIB objects in the default MIB view ViewDefault. To create a MIB view, use the snmp-agent mib-view command.
acl acl-number: Specifies a basic ACL to filter NMSs by source IP address. The acl-number argument represents a basic ACL number in the range of 2000 to 2999. In the specified community, only the NMSs with the IP addresses permitted in the ACL can access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents a basic ACL number in the range of 2000 to 2999. In the specified community, only the NMSs with the IPv6 addresses permitted in the ACL can access the SNMP agent.
This command is for SNMPv1 and SNMPv2c, and is applicable only to non-FIPS mode.
A community comprises NMSs and SNMP agents, and is identified by a community name. When devices in a community communicate with each other, they use the community name for authentication. An NMS and an SNMP agent can access each other only when they are configured with the same community name. Typically, public is used as the read-only community name, and private is used as the read and write community name. To improve security, assign your SNMP communities a name other than public and private.
To make sure the MIB objects are accessible only to a specific NMS, use a basic ACL to identify the source IP address of the NMS. To set the range of the MIB objects available for the community, use a MIB view.
# Create the read-only community readaccess so an NMS can use the protocol SNMPv1 or SNMPv2c and community name readaccess to read the MIB objects in the default view ViewDefault.
[Sysname] snmp-agent sys-info version v1 v2c
[Sysname] snmp-agent community read readaccess
# Create the read and write community writeaccess so only the host at 1.1.1.1 can use the protocol SNMPv2c and community name writeaccess to read and set the MIB objects in the default view ViewDefault.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0.0.0.0
[Sysname-acl-basic-2001] rule deny source any
[Sysname-acl-basic-2001] quit
[Sysname] snmp-agent sys-info version v2c
[Sysname] snmp-agent community write writeaccess acl 2001
# Create the read and write community wr-sys-acc so an SNMPv1 or SNMPv2c NMS can use the community name wr-sys-acc to read and set the MIB objects in the system subtree (OID 1.3.6.1.2.1.1).
[Sysname] undo snmp-agent mib-view ViewDefault
[Sysname] snmp-agent mib-view included test system
[Sysname] snmp-agent community write wr-sys-acc mib-view test
snmp-agent mib-view
snmp-agent group
Use snmp-agent group to create an SNMP group and specify its access right.
Use undo snmp-agent group to delete an SNMP group.
SNMPv1 and SNMP v2c (in non-FIPS mode):
snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent group { v1 | v2c } group-name
SNMPv3 (in non-FIPS or FIPS mode):
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent group v3 group-name [ authentication | privacy ]
No SNMP group exists. SNMPv3 groups use the no authentication, no privacy security model if neither authentication nor privacy is specified.
3: Manage level
v1: Specifies SNMPv1.
v2c: Specifies SNMPv2c.
v3: Specifies SNMPv3.
group-name: Specifies a group name, a string of 1 to 32 characters.
authentication: Specifies the security model of the SNMPv3 group to be authentication only (without privacy).
privacy: Specifies the security model of the SNMPv3 group to be authentication and privacy.
read-view view-name: Specifies a read-only MIB view. The view-name represents a MIB view, a string of 1 to 32 characters. The users in the specified group have read-only access to the objects included in the MIB view. The default read view is ViewDefault.
write-view view-name: Specifies a read and write MIB view. The view-name argument represents a MIB view, a string of 1 to 32 characters. The users in the specified group have read and write access to the objects included in the MIB view. By default, no write view is configured, which means the NMS cannot perform the write operations to all MIB objects on the device.
notify-view view-name: Specifies a trap MIB view. The view-name argument represents a MIB view, a string of 1 to 32 characters. The system sends traps to the users in the specified group for the objects included in the MIB view. By default, no notify view is configured, which means the agent does not send traps to the NMS.
acl acl-number: Specifies a basic ACL to filter NMSs by source IPv4 address. The acl-number argument represents a basic ACL number in the range of 2000 to 2999. In the specified SNMP group, only the NMSs with the IP addresses permitted in the ACL can access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents a basic ACL number in the range of 2000 to 2999. In the specified SNMP group, only the NMSs with the IPv6 addresses permitted in the ACL can access the SNMP agent.
All the users in an SNMP group share the security model and access rights of the group.
Only SNMPv3 is supported in FIPS mode.
# Create the SNMPv3 group group1 and assign the no authentication, no privacy security model to the group.
[Sysname] snmp-agent group v3 group1
· snmp-agent mib-view
Use snmp-agent local-engineid to configure the SNMP engine ID of the local SNMP agent.
Use undo snmp-agent local-engineid to restore the default local SNMP engine ID.
The local engine ID is the combination of the company ID and the device ID. Device ID is the MAC address.
3: Manage level
An SNMP engine ID uniquely identifies an SNMP entity in an SNMP managed network. Make sure the local SNMP engine ID is unique within your SNMP managed network to avoid communication problems.
If you have configured SNMPv3 users, change the local SNMP engine ID only when necessary. The change can void the SNMPv3 usernames and encrypted keys you have configured.
# Configure the local engine ID as 123456789A.
[Sysname] snmp-agent local-engineid 123456789A
snmp-agent usm-user
snmp-agent log
Use snmp-agent log to enable SNMP logging.
Use undo snmp-agent log to restore the default.
snmp-agent log { all | get-operation | set-operation }
undo snmp-agent log { all | get-operation | set-operation }
SNMP logging is disabled.
3: Manage level
all: Enables logging SNMP GET and SET operations.
get-operation: Enables logging SNMP GET operations.
set-operation: Enables logging SNMP SET operations.
Use SNMP logging to record the SNMP operations performed on the SNMP agent for auditing NMS behaviors. The SNMP agent sends log data to the information center. You can configure the information center to output the data to a specific destination as needed.
# Enable logging SNMP GET operations.
[Sysname] snmp-agent log get-operation
# Enable logging SNMP SET operations.
[Sysname] snmp-agent log set-operation
snmp-agent mib-view
Use snmp-agent mib-view to create or update a MIB view.
Use undo snmp-agent mib-view to delete a MIB view.
undo snmp-agent mib-view view-name
The system creates the ViewDefault view when the SNMP agent is enabled. In the default MIB view, all MIB objects in the iso subtree but the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees are accessible.
3: Manage level
excluded: Denies access to any node in the specified MIB subtree.
included: Permits access to the nodes in the specified MIB subtree.
view-name: Specifies a view name, a string of 1 to 32 characters.
oid-tree: Specifies a MIB subtree by its root node's OID (for example, 1.4.5.3.1) or object name (for example, system). An OID is a dotted numeric string that uniquely identifies an object in the MIB tree.
mask mask-value: Sets a MIB subtree mask, a hexadecimal string. Its length must be an even number in the range of 2 to 32. For example, you can specify 0a, aa, but not 0aa. If no subtree mask is specified, the MIB subtree mask is an all-F hexadecimal string. The MIB subtree and the subtree mask together identify a set of objects to be included or excluded from the view.
A MIB view represents a set of MIB objects (or MIB object hierarchies) with certain access privileges. The MIB objects included in the MIB view are accessible, and those excluded from the MIB view are inaccessible.
Each view-name oid-tree pair represents a view record. If you specify the same record with different MIB subtree masks multiple times, the most recent configuration takes effect.
The system can store entries for up to 20 unique MIB view records. In addition to the four default MIB view records, you can create up to 16 unique MIB view records. After you delete the default view with the undo snmp-agent mib-view command, you can create up to 20 unique MIB view records.
Be cautious with deleting the default MIB view. The operation blocks access to any MIB object on the device from NMSs that use the default view.
# Include the mib-2 (OID 1.3.6.1) subtree in the mibtest view and exclude the ip subtree from this view.
[Sysname] snmp-agent mib-view included mibtest 1.3.6.1
[Sysname] snmp-agent mib-view excluded mibtest ip
[Sysname] snmp-agent community read public mib-view mibtest
An SNMPv1 NMS in the public community can query the objects in the mib-2 subtree, but not any object (for example, the ipForwarding or ipDefaultTTL node) in the ip subtree.
· snmp-agent group
snmp-agent packet max-size
Use snmp-agent packet max-size to set the maximum size (in bytes) of SNMP packets that the SNMP agent can receive or send.
Use undo snmp-agent packet max-size to restore the default packet size.
The maximum size of SNMP packets that the SNMP agent can receive or send is 2000 bytes.
3: Manage level
byte-count: Specifies the maximum size (in bytes) of SNMP packets that the SNMP agent can receive or send. The value range is 484 to 17940, and the default is 1500.
If any device on the path to the NMS does not support packet fragmentation, limit the SNMP packet size to prevent large-sized packets from being discarded. For most networks, the default value is sufficient.
# Set the maximum SNMP packet size to 1024 bytes.
[Sysname] snmp-agent packet max-size 1024
snmp-agent proxy
NOTE: Support for this command depends on the device model. For more information about the command matrixes, see About the H3C Access Controllers Command References. |
Use snmp-agent proxy to set the local access controller as the SNMP proxy agent for an SNMP agent.
Use undo snmp-agent proxy to restore the default.
snmp-agent proxy { ip ipv4-address | ipv6 ipv6-address }
undo snmp-agent proxy }
The SNMP proxy agent function is disabled.
2: System level
ip ipv4-address: Specifies the IPv4 address of the SNMP agent that uses the SNMP agent proxy service.
ipv6 ipv6-address: Specifies the IPv6 address of the SNMP agent that uses the SNMP agent proxy service.
The SNMP proxy agent function is designed for access controllers installed with a SecBlade IAG card. The function enables the access controller to communicate with the SNMP management station on behalf of the SecBlade IAG card and transparently forwards SNMP messages to the SecBlade IAG card. From the perspective of the management station, the access controller and the SecBlade IAG card appear as if they were one managed node.
An access controller can work as the SNMP proxy agent for only one device.
To use this function, you must set up a tunnel between the SNMP proxy agent and the SNMP agent by using the IACTP mobility group feature.
For more information about the IACTP mobility group, see WLAN Configuration Guide.
# Configure the access controller at 192.168.1.56 as the SNMP proxy agent for the SecBlade IAG card at 192.168.1.55.
[Sysname] wlan mobility-group abc
[Sysname-wlan-mg-abc] member ip 192.168.1.55
[Sysname-wlan-mg-abc] source ip 192.168.1.56
[Sysname-wlan-mg-abc] mobility-group enable
[Sysname-wlan-mg-abc] quit
[Sysname] snmp-agent proxy ip 192.168.1.55
# Configure the access controller at 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF5 as the SNMP proxy agent for the SecBlade IAG card at 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF4.
[Sysname-wlan-mg-abc] member ipv6 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF4
[Sysname-wlan-mg-abc] source ipv6 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF5
[Sysname] snmp-agent proxy ipv6 3FFE:A6B0:AA00:16EF:122A:001A:F9E0:3BF4
snmp-agent sys-info
Use snmp-agent sys-info to configure system information for the SNMP agent, including the contact, location, and SNMP versions.
Use undo snmp-agent sys-info contact and undo snmp-agent sys-info location to restore the default.
Use undo snmp-agent sys-info version to disable an SNMP version.
In non-FIPS mode:
snmp-agent sys-info { contact sys-contact | location sys-location | version { all | { v1 | v2c | v3 }* } }
undo snmp-agent sys-info { contact | location | version { all | { v1 | v2c | v3 }* } }
In FIPS mode:
snmp-agent sys-info { contact sys-contact | location sys-location | version v3 }
undo snmp-agent sys-info { contact | location | version v3 }
The contact is New H3C Technologies Co., Ltd., the location is Hangzhou China, and the version is SNMPv3.
3: Manage level
contact sys-contact: Specifies the system contact, a string of 1 to 200 characters.
location sys-location: Specifies the system location, a string of 1 to 200 characters.
version: Specifies SNMP versions.
· all: Specifies SNMPv1, SNMPv2c, and SNMPv3.
· v1: Specifies SNMPv1.
· v2c: Specifies SNMPv2c.
· v3: Specifies SNMPv3.
Configure the SNMP agent with the same SNMP version as the NMS for successful communications between them.
# Configure the system contact as Dial System Operator at beeper # 27345.
[Sysname] snmp-agent sys-info contact Dial System Operator at beeper # 27345
Use snmp-agent target-host to configure a target host for receiving traps sent by the SNMP agent.
Use undo snmp-agent target-host to remove settings for an SNMP trap target host.
In non-FIPS mode:
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } params securityname security-string
In FIPS mode:
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] params securityname security-string v3 [ authentication | privacy ]
3: Manage level
trap: Specifies a target host for receiving the traps sent by the device.
address: Specifies the IP address of the target host.
udp-domain: Specifies UDP as the transport protocol.
ip-address: Specifies the IPv4 address or name of the target host. The host name is a string of 1 to 255 characters.
ipv6 ipv6-address: Specifies the IPv6 address of the target host.
udp-port port-number: Specifies the UDP port for receiving SNMP traps. The default UDP port is 162.
params securityname security-string: Specifies the authentication parameter. The security-string argument specifies an SNMPv1 or SNMPv2c community name or an SNMPv3 username, a string of 1 to 32 characters.
· authentication: Specifies the security model to be authentication without privacy. You must specify the authentication key when you create the SNMPv3 user.
· privacy: Specifies the security model to be authentication with privacy. You must specify the authentication key and privacy key when you create the SNMPv3 user.
You can specify up to 20 SNMP trap target hosts.
Make sure the SNMP agent uses the same UDP port number as the target host for traps. If udp-port port-number is not specified, UDP port 162 is used by default. Port 162 is the SNMP-specified port used for receiving traps, and is used by most NMSs, including IMC and MIB Browser.
Make sure the SNMP agent uses the same SNMP version as the trap host so the host can receive traps. If none of the keywords v1, v2c, or v3 is specified, SNMPv1 is used.
If neither authentication nor privacy is specified, the authentication mode is no authentication, no privacy.
# Configure the SNMP agent to send SNMPv1 traps to 10.1.1.1 in the community public.
[Sysname] snmp-agent trap enable standard
· enable snmp trap updown
· snmp-agent trap source
Use snmp-agent trap enable to enable traps globally.
Use undo snmp-agent trap enable to disable traps globally.
snmp-agent trap enable [ arp rate-limit | configuration | default-route | flash | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] | wlan ]
undo snmp-agent trap enable [ arp rate-limit | configuration | default-route | flash | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] | wlan ]
Traps are enabled for all modules.
3: Manage level
arp rate-limit: Enables ARP rate-limiting traps. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
configuration: Enables configuration traps.
default-route: Enables default route traps, which are sent when default routes are deleted.
flash: Enables Flash-related SNMP traps.
standard: Standard traps.
· authentication: Enables sending authentication failure traps in the event of authentication failure.
· coldstart: Sends coldstart traps when the device restarts.
· linkdown: Globally enables sending linkDown traps when the link of a port goes down.
· linkup: Globally enables sending linkUp traps when the link of a port goes up.
· warmstart: Sends warmstart traps when the SNMP restarts.
system: Enables system event (private MIB) traps.
vrrp: Enables traps for the VRRP module. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
· authfailure: VRRP authentication failure traps.
· newmaster: VRRP newmaster traps, which are sent when the device becomes the master.
wlan: Enables SNMP traps for the WLAN module.
After you globally enable a trap function for a module, whether the module generates traps also depends on the configuration of the module. For more information, see the sections for each module.
To generate linkUp or linkDown traps when the link state of an interface changes, you must enable the linkUp or linkDown trap function globally by using the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command and on the interface by using the enable snmp trap updown command.
# Enable the SNMP agent to send SNMP authentication failure traps to 10.1.1.1 in the community public.
[Sysname] snmp-agent trap enable standard authentication
Use snmp-agent trap if-mib link extended to configure the SNMP agent to send extended linkUp/linkDown traps.
Use undo snmp-agent trap if-mib link extended to restore the default.
The SNMP agent sends standard linkUp/linkDown traps.
3: Manage level
The extended linkUp and linkDown traps add interface description and interface type to the standard linkUp and linkDown traps for fast failure point identification. When you configure the snmp-agent trap if-mib link extended command, make sure the NMS supports the extended linkUp and linkDown traps. If not, the NMS will be unable to parse the traps.
· A standard linkUp trap is in the following format:
#Apr 24 11:48:04:896 2008 Sysname IFNET/4/INTERFACE UPDOWN:
Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983555 is Up, ifAdminStatus is 1, ifOperStatus is 1
· An extended linkUp trap is in the following format:
#Apr 24 11:43:09:896 2008 Sysname IFNET/4/INTERFACE UPDOWN:
Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983555 is Up, ifAdminStatus is 1, ifOperStatus is 1, ifDescr is GigabitEthernet1/0/1, ifType is 6
· A standard linkDown trap is in the following format:
#Apr 24 11:47:35:224 2008 Sysname IFNET/4/INTERFACE UPDOWN:
Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983555 is Down, ifAdminStatus is 2, ifOperStatus is 2
· An extended linkDown trap is in the following format:
#Apr 24 11:42:54:314 2008 AR29.46 IFNET/4/INTERFACE UPDOWN:
Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983555 is Down, ifAdminStatus is 2, ifOperStatus is 2, ifDescr is GigabitEthernet1/0/1, ifType is 6
# Extend standard linkUp/linkDown traps.
[Sysname] snmp-agent trap if-mib link extended
Use snmp-agent trap life to configure the holding time of the traps in the queue.
Use undo snmp-agent trap life to restore the default holding time of traps in the queue.
snmp-agent trap life seconds
The holding time of SNMP traps in the queue is 120 seconds.
3: Manage level
seconds: Specifies the timeout time, in the range of 1 to 2592000 seconds.
The SNMP module sends traps in queues. As soon as the traps are saved in the trap queue, a timer is started. If traps are not sent out until the timer times out (in other words, the holding time configured by using this command expires), the system removes the traps from the trap sending queue.
# Configure the holding time of traps in the queue as 60 seconds.
[Sysname] snmp-agent trap life 60
Use snmp-agent trap queue-size to set the size of the trap sending queue.
Use undo snmp-agent trap queue-size to restore the default queue size.
The trap sending queue can store 1000 traps.
3: Manage level
size: Specifies the number of traps that can be stored in the trap sending queue. The value range is 1 to 3000.
Traps are saved into the trap sending queue when generated. The size of the queue determines the maximum number of the traps that can be stored in the queue. When the size of the trap sending queue reaches the configured value, the newly generated traps are saved into the queue, and the earliest ones are discarded.
# Set the maximum number of traps that can be stored in the trap sending queue to 200.
[Sysname] snmp-agent trap queue-size 200
Use snmp-agent trap source to specify the source IP address contained in the trap.
Use undo snmp-agent trap source to restore the default.
snmp-agent trap source interface-type interface-number
SNMP chooses the IP address of an interface to be the source IP address of the trap.
3: Manage level
interface-type interface-number: Specifies a Layer 3 interface by its type and number.
Upon the execution of this command, the system uses the primary IP address of the specified interface as the source IP address of the traps, and the NMS uses this IP address to uniquely identify the agent. Even if the agent sends out traps through different interfaces, the NMS uses this IP address to filter all traps sent from the agent.
Before you can configure the IP address of a particular interface as the source IP address of the trap, make sure the interface already exists and that it has a legal IP address. If the configured interface does not exist, the configuration fails. If the specified IP address is illegal, the configuration becomes invalid. When a legal IP address is configured for the interface, the configuration automatically becomes valid.
# Configure the IP address of VLAN-interface 1 as the source address for traps.
[Sysname] snmp-agent trap source vlan-interface 1
Use snmp-agent usm-user { v1 | v2c } to add a user to an SNMPv1 or SNMPv2c group.
Use undo snmp-agent usm-user { v1 | v2c } to delete a user from an SNMPv1 or SNMPv2c group.
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent usm-user { v1 | v2c } user-name group-name
3: Manage level
user-name: Specifies a username, a case-sensitive string of 1 to 32 characters.
group-name: Specifies a group name, a case-sensitive string of 1 to 32 characters.
acl acl-number: Specifies a basic ACL to filter NMSs by source IPv4 address. The acl-number argument represents a basic ACL number in the range of 2000 to 2999. Only the NMSs with the IPv4 addresses permitted in the ACL can use the specified username (community name) to access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents a basic ACL number in the range of 2000 to 2999. Only the NMSs with the IPv6 addresses permitted in the ACL can use the specified username (community name) to access the SNMP agent.
Make sure you have created the SNMPv1 or SNMPv2c group.
When you create an SNMPv1 or SNMPv2c user, the system automatically creates a read-only community that has the same name as the SNMPv1 or SNMPv2c username. To change the access right of this community to write access, use the snmp-agent community command or the snmp-agent group { v1 | v2c } command. To display the SNMPv1 and SNMPv2c communities created in this way, use the display snmp-agent community command.
The snmp-agent usm-user { v1 | v2c } command enables managing SNMPv1 and SNMPv2c users in the same way as managing SNMPv3 users. It does not affect the method of configuring SNMPv1 and SNMPv2c communities on the NMS.
# Add the user userv2c to the SNMPv2c group readCom so an NMS can use the protocol SNMPv2c and the read-only community name userv2c to access the SNMP agent.
[Sysname] snmp-agent group v2c readCom
[Sysname] snmp-agent usm-user v2c userv2c readCom
# Add the user userv2c in the SNMPv2c group readCom so only the NMS at 1.1.1.1 can use the protocol SNMPv2c and read-only community name userv2c to access the SNMP agent.
[Sysname] snmp-agent usm-user v2c userv2c readCom acl 2001
· display snmp-agent community
· snmp-agent group
Use snmp-agent usm-user v3 to add an SNMPv3 user to an SNMP group.
Use undo snmp-agent usm-user v3 to delete an SNMPv3 user from an SNMP group.
In non-FIPS mode:
snmp-agent usm-user v3 user-name group-name [ cipher ] [ authentication-mode { md5 | sha } auth-password [ privacy-mode { 3des | aes128 | des56 } priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent usm-user v3 user-name group-name { local | engineid engineid-string }
In FIPS mode:
snmp-agent usm-user v3 user-name group-name [ cipher ] [ authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
3: Manage level
cipher: Specifies that auth-password and priv-password are encrypted keys, which can be calculated to a hexadecimal string by using the snmp-agent calculate-password command. If this keyword is not specified, auth-password and priv-password are plaintext keys.
authentication-mode: Specifies an authentication algorithm. MD5 is faster but less secure than SHA. For more information about these algorithms, see Security Configuration Guide.
· md5: Specifies the MD5 authentication algorithm.
· sha: Specifies the SHA-1 authentication algorithm.
auth-password: Specifies a case-sensitive plaintext or encrypted authentication key. A plaintext key is a string of 1 to 64 visible characters. If the cipher and md5 keywords are specified, auth-password represents a hexadecimal string of 32 characters or a non-hexadecimal string of 53 characters. If the cipher and sha keywords are specified, auth-password is a hexadecimal string of 40 characters or a non-hexadecimal string of 57 characters.
privacy-mode: Specifies an encryption algorithm for privacy. The encryption algorithms AES, 3DES, and DES are in descending order of security. Higher security means more complex implementation mechanism and lower speed. DES is secure enough for general security requirements. For more information about these algorithms, see Security Configuration Guide.
· 3des: Specifies the 3DES algorithm.
· des56: Specifies the DES algorithm.
· aes128: Specifies the AES algorithm.
priv-password: Specifies a case-sensitive plaintext or encrypted privacy key. A plaintext key is a string of 1 to 64 characters. If the cipher keyword is specified, the encrypted privacy key length requirements differ by authentication algorithm and key string format, as shown in Table 7.
Table 7 Encrypted privacy key length requirements
Authentication algorithm |
Encryption algorithm |
Hexadecimal string |
Non-hexadecimal string |
MD5 |
3DES |
64 characters |
73 characters |
MD5 |
AES128 or DES-56 |
32 characters |
53 characters |
SHA |
3DES |
80 characters |
73 characters |
SHA |
AES128 or DES-56 |
40 characters |
53 characters |
acl acl-number: Specifies a basic ACL to filter NMSs by source IPv4 address. The acl-number argument represents a basic ACL number in the range of 2000 to 2999. Only the NMSs with the IPv4 addresses permitted in the ACL can use the specified username to access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents a basic ACL number in the range of 2000 to 2999. Only the NMSs with the IPv6 addresses permitted in the ACL can use the specified username to access the SNMP agent.
local: Represents a local SNMP entity user.
engineid engineid-string: Specifies an SNMP engine ID as a hexadecimal string. The engineid-string argument must comprise an even number of hexadecimal characters, in the range of 10 to 64. All-zero and all-F strings are invalid.
You must create an SNMPv3 user for the agent and the NMS to use SNMPv3.
You must create an SNMP group before you assign an SNMP user to the group. Otherwise, the user cannot take effect after it is created. An SNMP group can contain multiple users. It defines SNMP objects accessible to the group of users in the MIB view and specifies whether to enable authentication and privacy functions. The authentication and encryption algorithms are defined when a user is created.
When you use the snmp-agent usm-user v3 cipher command, the pri-password argument in this command can be obtained by the snmp-agent calculate-password command. To make the calculated encrypted key applicable to the snmp-agent usm-user v3 cipher command and have the same effect as that in the snmp-agent usm-user v3 cipher command, make sure the same encryption algorithm is specified for the two commands and the local engine ID specified in the snmp-agent usm-user v3 cipher command is consistent with the SNMP entity engine ID specified in the snmp-agent calculate-password command.
When you execute this command repeatedly to configure the same user (the usernames remain the same, and there is no limitation to other keywords and arguments), the most recent configuration takes effect.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
Remember the username and the plaintext password when you create a user. A plaintext password is required when the NMS accesses the SNMP agent.
The md5, des56, and 3des keywords are supported only in non-FIPS mode.
# Add the user testUser to the SNMPv3 group testGroup. Configure the security model as authentication without privacy, the authentication algorithm as MD5, the plaintext key as authkey.
[Sysname] snmp-agent group v3 testGroup authentication
[Sysname] snmp-agent usm-user v3 testUser testGroup authentication-mode md5 authkey
To access the SNMP agent, specifically, the default view (ViewDefault) in this example, the NMS can use the protocol SNMPv3, username testUser, authentication algorithm MD5, and authentication key authkey.
# Add the user testUser to the SNMPv3 group testGroup. Configure the security model as authentication and privacy, the authentication algorithm as MD5, the privacy algorithm as DES56, the plain-text authentication key as authkey, and the plain-text privacy key as prikey.
[Sysname] snmp-agent group v3 testGroup privacy
[Sysname] snmp-agent usm-user v3 testUser testGroup authentication-mode md5 authkey privacy-mode des56 prikey
To access the SNMP agent, specifically, the default view (ViewDefault) in this example, the NMS must use the protocol SNMPv3, username testUser, authentication algorithm MD5, authentication key authkey, privacy algorithm DES, and privacy key prikey.
· display snmp-agent usm-user
· snmp-agent calculate-password
· snmp-agent group
statistics-interval
Use statistics-interval to set the interval for calculating statistics for certain user-specified MIB nodes.
Use undo statistics-interval to restore the default.
statistics-interval statistics-interval
The statistics interval is 0, and the system does not calculate statistics for the user-specified MIB nodes.
3: Manage level
Statistics-interval: Specifies the statistics interval (in seconds) for the user-specified MIB nodes. The value range is 0 to 900.
# Set the statistics interval to 600 seconds for the user-specified MIB nodes.
sample-interval
trap-send times
Use trap-send times to configure the maximum number of traps that the SNMP agent can send for an alarm condition.
Use undo trap-send times to restore the default.
trap-send times timevalue
The default is 0, which indicates that no limit is set on the number of traps that can be sent for an alarm condition.
3: Manage level
timevalue: Specifies the maximum number of traps that the SNMP agent can send for an event.
If the limit is reached, the SNMP agent stops sending traps even if the alarm condition has not been removed.
# Set the maximum number of traps that the SNMP agent can send for an alarm condition to five.
[Sysname] trap-send times 5
MIB configuration commands
display mib-style
Use display mib-style to display the MIB style of the device.
display mib-style [ | { begin | exclude | include } regular-expression ]
3: Manage level
Two MIB styles are available on the device: new and compatible. After obtaining the MIB style, you can select matched H3C network management software based on the MIB style.
# Display the current MIB style of the H3C device and the MIB style to use after the next startup.
<Sysname> display mib-style
Current MIB style: new
Next reboot MIB style: new
mib-style
mib-style
Use mib-style to set the MIB style of the device.
mib-style [compatible | new ]
The MIB style of the device is new.
3: Manage level
compatible: Specifies the MIB style of the device as H3C compatible. In this style, sysOID is located under the H3C enterprise ID 25506, and the private MIB is located under the enterprise ID 2011.
new: Specifies the MIB style of the device as H3C new. In this style, both sysOID and private MIB are located under the H3C enterprise ID 25506.
The configuration takes effect only when the device reboots.
# Change the MIB style of the device to compatible.
[Sysname] mib-style compatible
[Sysname] quit
Next reboot MIB style: compatible
<Sysname> reboot
