09-Network Management Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10209-Network Management Configuration Guide
03-NTP Commands
03-NTP Commands 100.51 KB
NTP configuration commands
display ntp-service sessions
Use display ntp-service sessions to display information about all NTP associations.
display ntp-service sessions [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
verbose: Displays detailed information about all NTP associations. If you do not specify this keyword, the command displays only brief information about the NTP associations.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display brief information about all NTP associations.
<Sysname> display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]127.127.1.0     127.127.1.0        3     1   64   33    0.0    0.0    0.0
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations :  1
source
IP address of the clock source.
reference
Reference clock ID of the clock source:
·     If the reference clock is the local clock, the value of this field is related to the value of the stra field:
¡     When the value of the stra field is 0 or 1, this field will be LOCL.
¡     When the stra field has another value, this field will be the IP address of the local clock.
·     If the reference clock is the clock of another device on the network, the value of this field will be the IP address of that device.
stra
Stratum level of the clock source, which determines the clock precision. The value is in the range of 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized.
reach
Reachability count of the clock source. 0 indicates that the clock source is unreachable.
poll
Poll interval in seconds, namely, the maximum interval between successive NTP messages.
now
Length of time from when the last NTP message was received or when the local clock was last updated to the current time.
By default time is in seconds. If the time length is greater than 2048 seconds, it is displayed in minutes. If greater than 300 minutes, it is displayed in hours. If greater than 96 hours, it is displayed in days.
offset
Offset of the system clock relative to the reference clock, in milliseconds.
delay
Roundtrip delay from the local device to the clock source, in milliseconds.
disper
Maximum error of the system clock relative to the reference source.
[12345]
·     1—The current reference source that the device is synchronizing to.
·     2—Stratum level of the clock source is less than or equal to 15.
·     3—This clock source has survived the clock selection algorithm.
·     4—This clock source is a candidate clock source.
·     5—This clock source was created by a configuration command.
Total associations
Total number of associations.
# Display detailed information about all NTP associations.
<Sysname> display ntp-service sessions verbose
 clock source: 127.127.1.0
 clock stratum: 3
 clock status: configured, master, sane, valid
 reference clock ID: 127.127.1.0
 local mode: client, local poll: 6
 peer mode: server, peer poll: 6
 offset: 0.0000 ms,delay: 0.00 ms,  disper: 0.02 ms
 root delay: 0.00 ms, root disper: 10.00 ms
 reach: 1, sync dist: 0.010, sync state: 2
 precision: 2^18, version: 3, peer interface: InLoopBack0
 reftime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 orgtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 rcvtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.7149E881)
 xmttime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71464DC2)
 filter delay :  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter offset:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter disper:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 reference clock status: working abnormally
 timecode:
clock source
clock stratum
clock status
Status of the clock source:
·     configured—The association is a static one.
·     dynamic—The association is a dynamic one.
·     master—The clock source is the primary reference source of the current system.
·     selected—The clock source has survived the clock selection algorithm.
·     candidate—The clock source is the candidate reference source.
·     sane—The clock source has passed the sane authentication.
·     insane—The clock source has failed the sane authentication.
·     valid—The clock source is valid: it has passed the authentication and is in synchronized state, its stratum level is valid, and its root delay and root dispersion values are within the allowed ranges.
·     invalid—The clock source is invalid.
·     unsynced—The clock source has not been synchronized or the value of the stratum level is invalid.
reference clock ID
·     If the reference clock is the local clock, the value of this field is related to the stratum level of the clock source:
¡     When the stratum level of the clock source is 0 or 1, this field is LOCL.
¡     When the stratum level of the clock source has another value, this field is the IP address of the local clock.
·     If the reference clock is the clock of another device on the network, the value of this field is the IP address of that device.
local mode
Operation mode of the local device:
·     unspec—The mode is unspecified.
·     active—Active mode.
·     passive—Passive mode.
·     client—Client mode.
·     server—Server mode.
·     bdcast—Broadcast server mode.
·     control—Control query mode.
·     private—Private message mode.
local poll
Poll interval of the local device, in seconds. The value displayed is a power of 2. For example, if the displayed value is 6, the poll interval of the local device is 26, or 64 seconds.
peer mode
Operation mode of the peer device:
peer poll
Poll interval of the peer device, in seconds. The value displayed is a power of 2. For example, if the displayed value is 6, the poll interval of the local device is 26, or 64 seconds.
offset
delay
disper
Maximum error of the system clock relative to the reference clock.
root delay
Roundtrip delay from the local device to the primary reference source, in milliseconds.
root disper
Maximum error of the system clock relative to the primary reference clock, in milliseconds.
reach
sync dist
Synchronization distance relative to the upper-level clock, in seconds, and calculated from dispersion and roundtrip delay values.
sync state
State of the state machine.
The displayed value is an integer that is in the range of 0 to 5.
precision
Precision of the system clock.
version
NTP version.
The displayed value is an integer that is in the range of 1 to 4.
peer interface
Source interface.
If the source interface is not specified, this field is wildcard.
reftime
Reference timestamp in the NTP message.
orgtime
Originate timestamp in the NTP message.
rcvtime
Receive timestamp in the NTP message.
xmttime
Transmit timestamp in the NTP message.
filter delay
Delay information.
filter offset
Offset information.
filter disper
Dispersion information.
Status of the reference clock:
·     working normally—The clock is working correctly.
·     working abnormally—The clock is working incorrectly.
timecode
Time code.
Total associations
If the device is operating in NTP broadcast/multicast server mode, the display ntp-service sessions command does not display the NTP association created for the broadcast/multicast server. However, the association is included in the total number of associations.
display ntp-service status
Use display ntp-service status to display NTP service status information.
display ntp-service status [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display NTP service status information.
<Sysname> display ntp-service status
Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^17
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Clock status
Status of the system clock:
·     Synchronized—The system clock has been synchronized.
·     Unsynchronized—The system clock has not been synchronized.
Clock stratum
Stratum level of the system clock.
Reference clock ID
When the system clock is synchronized to a remote time server, this field indicates the address of the remote time server. When the system clock is synchronized to a local reference source, this field indicates the address of the local clock source:
·     When the local clock has a stratum level of 1, the value of this field is LOCL.
·     When the stratum of the local clock has another value, the value of this field is the IP address of the local clock.
Nominal frequency
Nominal frequency of the local system hardware clock, in Hz.
Actual frequency
Actual frequency of the local system hardware clock, in Hz.
Clock precision
Clock offset
Offset of the system clock relative to the reference source, in milliseconds.
Root delay
Root dispersion
Maximum error of the system clock relative to the primary reference source, in milliseconds.
Peer dispersion
Maximum error of the system clock relative to the reference source, in milliseconds.
Reference time
Reference timestamp.
display ntp-service trace
Use display ntp-service trace to display brief information about each NTP server on the path from the local device to the primary reference source.
display ntp-service trace [ | { begin | exclude | include } regular-expression ]
1: Monitor level
The display ntp-service trace command takes effect only when the local device and all the devices on the NTP server chain can reach one another. Otherwise, this command is unable to display all the NTP servers on the NTP chain due to timeout.
# Display brief information about each NTP server on the path from the local device to the primary reference source.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
 server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
 refid LOCL
The output shows an NTP server chain for server 127.0.0.1: Server 127.0.0.1 is synchronized to server 133.1.1.1, and server 133.1.1.1 is synchronized to the local clock source.
server
IP address of the NTP server.
stratum
Stratum level of the corresponding system clock.
offset
Clock offset relative to the upper-level clock, in seconds.
synch distance
Synchronization distance (in seconds) relative to the upper-level clock. It is calculated from dispersion and roundtrip delay values.
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL. Otherwise, it is displayed as the IP address of the primary reference clock.
ntp-service access
Use ntp-service access to configure the access-control right for the peer devices to access the NTP services of the local device.
Use undo ntp-service access to remove the configured NTP service access-control right to the local device.
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
The access-control right for the peer devices to access the NTP services of the local device is set to peer.
3: Manage level
peer: Permits full access. This level of right permits a remote device to use the local device as a synchronization source and perform control query, and it also permits the local device to use the remote device as a synchronization source.
query: Permits control query. This level of right permits a remote NTP device to get NTP-related information (such as NTP states, authentication status, and clock sources) from the local device, but it prevents the local device from becoming a synchronization source of the remote NTP device.
server: Permits server access and query. This level of right permits a remote device to use the local device as a synchronization source and perform control query, but it does not permit synchronization by the remote device.
synchronization: Permits server access only. This level of right permits a remote device to use the local device as a synchronization source, but it does not permit the remote device to perform control query.
acl-number: Specifies a basic ACL number in the range of 2000 to 2999.
NTP service access-control rights are peer, server, synchronization, and query, from highest to lowest. When the device receives an NTP message, it performs an access-control right match and uses the first matching right to process the message. If no matching right is found, the device drops the NTP message.
The ntp-service access command provides only a minimum degree of security protection. Identity authentication is more secure. The related command is ntp-service authentication enable.
Before specifying an ACL number in the ntp-service access command, make sure you have created and configured this ACL.
# Configure the peer devices on subnet 10.10.0.0/16 to have the full access right to the local device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
Use ntp-service authentication enable to enable NTP authentication.
Use undo ntp-service authentication enable to disable NTP authentication.
NTP authentication is disabled.
3: Manage level
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
·     ntp-service authentication-keyid
·     ntp-service reliable authentication-keyid
Use ntp-service authentication-keyid to set an NTP authentication key.
Use undo ntp-service authentication-keyid to remove the NTP authentication key.
ntp-service authentication-keyid keyid authentication-mode md5 [ cipher | simple ] value [ acl ipv4-acl-number ] *
undo ntp-service authentication-keyid keyid
No NTP authentication key is set.
3: Manage level
keyid: Specifies an authentication key ID in the range of 1 to 4294967295.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key. This key will be saved in cipher text for secrecy.
value: Specifies the MD5 authentication key string. This argument is case sensitive. If simple is specified, it is a string of 1 to 32 characters. If cipher is specified, it is a string of 1 to 73 characters. If neither cipher nor simple is specified, it is a plaintext key string.
acl ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. Only the devices permitted by the ACL can use the key ID for authentication.
In a security-demanding network, the NTP authentication feature should be enabled for a system running NTP. This feature enhances network security by using the client-server key authentication, which prohibits a client from synchronizing with a device that has failed authentication.
The key ID in the message from the peer device identifies the key used for authentication. The acl ipv4-acl-number option is used to identify the peer device that can use the key ID.
To ensure a successful NTP authentication, configure the same authentication key ID and key on the time server and client. Make sure the peer device is allowed to use the key ID for authentication on the local device.
After you specify an NTP authentication key, configure the key as a trusted key by using the ntp-service reliable authentication-keyid command.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
The system supports only the MD5 algorithm for key authentication.
A maximum of 1,024 keys can be set for each device.
If an NTP authentication key is specified as a trusted key, the key automatically changes to untrusted after you delete the key. In this case, you do not need to execute the undo ntp-service reliable authentication-keyid command.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
ntp-service broadcast-client
Use ntp-service broadcast-client to configure the device to operate in NTP broadcast client mode and use the current interface to receive NTP broadcast packets.
Use undo ntp-service broadcast-client to remove the configuration.
The device does not operate in any NTP operation mode.
Interface view
3: Manage level
# Configure the device to operate in broadcast client mode and receive NTP broadcast messages on VLAN-interface 1.
[Sysname-Vlan-interface1] ntp-service broadcast-client
ntp-service broadcast-server
Use ntp-service broadcast-server to configure the device to operate in NTP broadcast server mode and use the current interface to send NTP broadcast packets.
Use undo ntp-service broadcast-server to remove the configuration.
Interface view
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid is in the range of 1 to 4294967295. This parameter is not necessary if authentication is not required.
version number: Specifies the NTP version. The value range for the number argument is 1 to 3, and the default is 4.
# Configure the device to operate in broadcast server mode and send NTP broadcast messages on VLAN-interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
ntp-service in-interface disable
Use ntp-service in-interface disable to disable an interface from receiving NTP messages.
Use undo ntp-service in-interface disable to restore the default.
All interfaces are enabled to receive NTP messages.
Interface view
3: Manage level
# Disable VLAN-interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
ntp-service max-dynamic-sessions
Use ntp-service max-dynamic-sessions to set the maximum number of dynamic NTP associations that can be established on the device.
Use undo ntp-service max-dynamic-sessions to restore the maximum number of dynamic NTP associations to the system default.
The number is 100.
3: Manage level
number: Maximum number of dynamic NTP associations that are allowed to be established, in the range of 0 to 100.
NTP has the following types of associations:
·     Static association—Association that is created in response to a manual NTP command configuration. A static association is removed when the command that triggered the creation of the association is undone.
·     Dynamic association—Association that is created in response to an NTP message exchange. A dynamic association is removed if no messages are exchanged over a specific period of time.
All static and dynamic associations are created automatically.
The following describes how an association is established in different operation modes:
·     Client/server mode—When the NTP server is specified on the client, the client creates a static association with the server and sends an NTP message to the server. The server responds to the client, but it does not create an association with the client.
·     Symmetric active/passive mode—The symmetric-active peer creates a static association when you specify a symmetric-passive peer on it. When receiving an NTP message from the symmetric-active peer, the symmetric-passive peer creates a dynamic association.
·     Broadcast or multicast mode—When you enable a broadcast or multicast server, a static association is created. When receiving an NTP message from the server, the clients creates a dynamic association.
The device supports a maximum of 128 concurrent associations, including static associations and dynamic associations.
# Set the maximum number of dynamic NTP associations allowed to be established to 50.
[Sysname] ntp-service max-dynamic-sessions 50
ntp-service multicast-client
Use ntp-service multicast-client to configure the device to operate in NTP multicast client mode and use the current interface to receive NTP multicast packets.
Use undo ntp-service multicast-client to remove the configuration.
undo ntp-service multicast-client [ ip-address ]
Interface view
3: Manage level
ip-address: Specifies the multicast IP address. The default is 224.0.1.1.
# Configure the device to operate in multicast client mode and receive NTP multicast messages on VLAN-interface 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
ntp-service multicast-server
Use ntp-service multicast-server to configure the device to operate in NTP multicast server mode and use the current interface to send NTP multicast packets.
Use undo ntp-service multicast-server to remove the configuration.
undo ntp-service multicast-server [ ip-address ]
Interface view
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending multicast messages to multicast clients, where keyid is in the range of 1 to 4294967295. This parameter is not necessary if authentication is not required.
ttl ttl-number: Specifies the TTL of NTP multicast messages. The value range for the ttl-number argument is 1 to 255, and the default is 16.
version number: Specifies the NTP version. The value range for the number argument is 1 to 4, and the default is 3.
# Configure the device to operate in multicast server mode and send NTP multicast messages on VLAN-interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
ntp-service refclock-master
Use ntp-service refclock-master to configure the local clock as a reference source for other devices.
Use undo ntp-service refclock-master to remove the configuration.
undo ntp-service refclock-master [ ip-address ]
The local clock does not work as a synchronization source.
3: Manage level
ip-address: IP address of the local clock, which is 127.127.1.u, where u is the NTP process ID that is in the range of 0 to 3. If you do not specify ip-address, it defaults to 127.127.1.0.
stratum: Specifies the stratum level of the local clock, in the range of 1 to 15. The default is 8.
The stratum level of a clock defines the clock precision. NTP supports 16 stratums. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is always in unsynchronized state.
# Specify the local clock as the reference source, with the stratum level 3.
[Sysname] ntp-service refclock-master 3
Use ntp-service reliable authentication-keyid to specify that the created authentication key is a trusted key. When NTP authentication is enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Use undo ntp-service reliable authentication-keyid to remove the configuration.
undo ntp-service reliable authentication-keyid keyid
No authentication key is configured to be trusted.
3: Manage level
keyid: Specifies an authentication key number in the range of 1 to 4294967295.
# Enable NTP authentication, specify to use MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
# Specify this key as a trusted key.
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
Use ntp-service source-interface to specify the source interface for NTP messages.
Use undo ntp-service source-interface to restore the default.
ntp-service source-interface interface-type interface-number
No source interface is specified for NTP messages, and the system uses the IP address of the interface determined by the matched route as the source IP address of NTP messages.
3: Manage level
If you do not want the IP address of a specific interface on the local device to become the destination address of response messages, use this command to specify the source interface for NTP messages so that the source IP address in NTP messages is the primary IP address of this interface.
If the specified source interface goes down, NTP searches the routing table for the outgoing interface, and uses the primary IP address of the outgoing interface as the source IP address.
# Specify the source interface of NTP messages as VLAN-interface 1.
[Sysname] ntp-service source-interface vlan-interface 1
ntp-service unicast-peer
Use ntp-service unicast-peer to designate a symmetric-passive peer for the device.
Use undo ntp-service unicast-peer to remove the symmetric-passive peer designated for the device.
ntp-service unicast-peer { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer { ip-address | peer-name }
No symmetric-passive peer is designated for the device.
3: Manage level
ip-address: IP address of the symmetric-passive peer. It must be a unicast address and not a broadcast address, a multicast address or the IP address of the local clock.
peer-name: Host name of the symmetric-passive peer, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer, where keyid is in the range of 1 to 4294967295.
priority: Specifies the peer designated by ip-address or peer-name as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local device sends to its peer, the source IP address is the primary IP address of this interface. The interface-type interface-number argument represents the interface type and number.
# Designate the device with the IP address of 10.1.1.1 as the symmetric-passive peer of the device, configure the device to run NTP version 3, and specify the source interface of NTP messages as VLAN-interface 1.
[Sysname] ntp-service unicast-peer 10.1.1.1 version 3 source-interface vlan-interface 1
ntp-service unicast-server
Use ntp-service unicast-server to designate an NTP server for the device.
Use undo ntp-service unicast-server to remove an NTP server designated for the device.
ntp-service unicast-server { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-server { ip-address | server-name }
No NTP server is designated for the device.
3: Manage level
ip-address: IP address of the NTP server. It must be a unicast address and not a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid is in the range of 1 to 4294967295.
priority: Specifies this NTP server as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local device sends to the NTP server, the source IP address is the primary IP address of this interface. The interface-type interface-number argument represents the interface type and number.
# Designate NTP server 10.1.1.1 for the device, and configure the device to run NTP version 3.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
