09-Network Management Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10209-Network Management Configuration Guide
00-Preface
00-Preface 113.19 KB
Preface
This command reference describes the network management and monitoring configuration commands.
The Network Management and Monitoring Command Reference describes the configuration commands for system maintenance and debugging, NQA, NTP, IPC, SNMP, RMON, mirroring, information center, sFlow, and flow log.
Support of the H3C access controllers for commands might vary by device model. For the command matrixes, see About the H3C Access Controllers Command References.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
We appreciate your comments.
