- 11-Security Configuration Guide
- 01-AAA configuration
- 02-Portal configuration
- 03-User profile configuration
- 04-Password control configuration
- 05-Keychain configuration
- 06-Public key management
- 07-PKI configuration
- 08-IPsec configuration
- 09-Group domain VPN configuration
- 10-SSH configuration
- 11-SSL configuration
- 12-SSL VPN configuration
- 13-ASPF configuration
- 14-APR configuration
- 15-Session management
- 16-Connection limit configuration
- 17-Object group configuration
- 18-Object policy configuration
- 19-Attack detection and prevention configuration
- 20-ARP attack protection configuration
- 21-ND attack defense configuration
- 22-uRPF configuration
- 23-Crypto engine configuration
- 24-FIPS configuration
- 25-SMA configuration
| 17-Object group configuration | 45.18 KB |
Configuring an IPv4 address object group
Configuring an IPv6 address object group
Configuring a port object group
Configuring a service object group
Displaying and maintaining object groups
Configuring object groups
Overview
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
· IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
· IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
· Port object group—A group of port objects used to match the protocol port number in a packet.
· Service object group—A group of service objects used to match the upper-layer service in a packet.
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Configure an IPv4 address object group and enter its view. |
object-group ip address object-group-name |
The system has one default IPv4 address object group. |
3. (Optional.) Configure a description for the IPv4 address object group. |
description text |
By default, an object group does not have a description. |
4. Configure an IPv4 address object. |
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] } |
By default, no objects exist. |
5. Exclude an IPv4 address from the IPv4 address object. |
object-id network exclude ipv4-address |
By default, no IPv4 address in an IPv4 address object is excluded. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure an IPv6 address object group and enter its view. |
object-group ipv6 address object-group-name |
The system has one default IPv6 address object group. |
3. (Optional.) Configure a description for the IPv6 address object group. |
description text |
4. Configure an IPv6 address object. |
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] } |
5. Exclude an IPv6 address from the IPv6 address object. |
object-id network exclude ipv6-address |
By default, no IPv6 address in an IPv6 address object is excluded. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a port object group and enter its view. |
object-group port object-group-name |
The system has one default port object group. |
3. (Optional.) Configure a description for the port object group. |
description text |
4. Configure a port object. |
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name } |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a service object group and enter its view. |
object-group service object-group-name |
The system has multiple default service object groups. |
3. (Optional.) Configure a description for the service object group. |
description text |
4. Configure a service object. |
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name } |
Renaming an object group
To rename an object group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Rename an object group. |
object-group rename old-object-group-name new-object-group-name |
You can only rename non-default object groups. |
Task |
Command |
Display information about object groups. |
display object-group [ { { ip | ipv6 } address | service | port } [ default ] [ name object-group-name ] | name object-group-name ] |
