07-Layer 3 - IP Routing Configuration Guide
HomeSupportResource CenterRoutersH3C SR6600-X Router SeriesH3C SR6600-X Router SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C SR6600 SR6600-X Routers Configuration Guides-R7607-6W10007-Layer 3 - IP Routing Configuration Guide
14-MTR configuration
14-MTR configuration 61.23 KB
Configuring MTR
Overview
Multi-Topology Routing (MTR) splits a base topology into multiple topologies, which intersect or overlap with one another. Route calculation is performed on a per-topology basis.
For example, IS-IS MTR enables IS-IS to perform separate route calculation for the IPv4 and IPv6 topologies in an IS-IS routing domain.
Work mechanism
Figure 1 Work mechanism of MTR
As shown in Figure 1, the base topology is split into two topologies, topology A and topology B. You can forward voice traffic through topology A and video traffic through topology B.
Router B does not belong to topology A. In topology B, no direct link exists between Router A and Router D, or between Router B and Router C. Route calculation and traffic forwarding are performed in each topology independently.
Supported features
·     IS-IS MTR. For more information, see "Configuring IS-IS" and "Configuring IPv6 IS-IS."
·     Static routing MTR. For more information, see "Configuring static routing."
Configuring MTR
MTR classifies traffic by MTR policy. An MTR policy uses ACL, DSCP, and IP precedence as the match criteria.
An MTR policy can contain multiple nodes, which are in a logical OR relationship. A node with a smaller number is matched first. A packet that matches one node matches the MTR policy.
Each node contains a set of if-match and apply clauses.
·     if-match—Defines a criterion to match packet attributes. The if-match clauses of a node are in an OR relationship. If a packet matches one of the if-match clauses, it matches the node.
·     apply—Specifies a topology for packets matching the MTR policy node.
IMPORTANT
IMPORTANT:
A node must contain both if-match and apply clauses. Otherwise, the topology configuration cannot take effect.
To configure MTR:
Step
Remarks
N/A
2.     Create the global address family and enter its view.
global-address-family ipv4 [ unicast ]
By default, no global address family exists.
3.     Create a topology and enter its view.
topology topo-name
By default, no topologies exist.
4.     (Optional.) Configure the maximum number of active routes supported by the topology.
N/A
5.     Return to system view.
N/A
6.     Enter interface view.
N/A
7.     Associate the interface with a topology and enter IPv4 unicast topology view of the interface.
topology ipv4 [ unicast ] topo-name
By default, the interface is not associated with any topology.
8.     Return to system view.
N/A
9.     Create an MTR policy node and enter its view.
mtr-policy policy-name node node-value
By default, no MTR policy node is created.
10.     Specify a topology for the MTR policy node.
apply topology topo-name
By default, no topology is specified for the MTR policy node.
11.     Configure the match criteria.
·     Configure an ACL match criterion:
if-match ip acl acl-number
·     Configure a DSCP match criterion:
if-match ip dscp dscp-value
·     Configure an IP precedence match criterion:
if-match ip precedence ip-prec-value
By default, no match criterion is configured.
12.     Return to system view.
N/A
13.     Enter global address family view.
N/A
14.     Enable the MTR policy.
topology-routing mtr-policy policy-name
By default, the MTR policy is disabled.
Displaying and maintaining MTR
Display topology information.
display topology [ name topo-name ]
Display MTR policy information.
display mtr-policy [ name mtr-policy-name ]
  • Become a Partner
  • Partner Resources
