09 Security Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10009 Security Command Reference
19-ND attack defense commands
19-ND attack defense commands 50.3 KB
ipv6 nd check log enable
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. You can configure the information center module to set the log output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
H3C recommends that you disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
ipv6 nd mac-check enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND packets.
Use undo ipv6 nd mac-check enable to restore the default.
Source MAC consistency check for ND packets is disabled.
This feature is typically configured on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND packet. If an inconsistency is found, the gateway drops the ND packet. If the ND logging feature is enabled, the gateway also logs the packet dropping event.
# Enable source MAC consistency check for ND packets.
[Sysname] ipv6 nd mac-check enable
