09 Security Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10009 Security Command Reference
15-uRPF commands
15-uRPF commands 50.4 KB
uRPF commands
display ip urpf
Use display ip urpf to display uRPF configuration.
display ip urpf [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot number argument specifies the ID of the IRF member device.
# Display uRPF configuration.
<Sysname> display ip urpf
Global uRPF configuration information:
   Check type: strict
   Allow default route
Global uRPF configuration.
(failed)
Failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources. If this field does not exist, the delivery is successful.
Check type
uRPF check mode: loose or strict.
Allow default route
Allow use of the default route.
ip urpf
Use ip urpf to enable uRPF.
Use undo ip urpf to disable uRPF.
ip urpf { loose | strict }
undo ip urpf
uRPF is disabled.
loose: Enables loose uRPF check. To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry.
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
Global uRPF configuration takes effect on both IPv4 and IPv6 routes.
uRPF can be deployed on a PE connected to a CE or another ISP, or on a CE.
Configure strict uRPF check on a PE interface connected to a CE, and configure loose uRPF check on a PE interface connected to another ISP.
For asymmetrical routing where the interface receiving upstream traffic is different from the interface forwarding downstream traffic on a PE device, configure loose uRPF to avoid discarding valid packets. If the two interfaces are the same (symmetrical routing), configure strict uRPF. An ISP usually adopts symmetrical routing on a PE device.
# Enable strict uRPF check globally.
[Sysname] ip urpf strict
display ip urpf
