09 Security Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10009 Security Command Reference
16-Crypto engine commands
16-Crypto engine commands 54.35 KB
display crypto-engine
Use display crypto-engine to display crypto engine information, including the crypto engine name and supported algorithms.
# Display information about crypto engines.
<Sysname> display crypto-engine
  Crypto engine name: Software crypto engine
  Crypto engine state: Enabled
  Crypto engine type: Software
  Slot ID: 1
  Crypto engine ID: 0
  Symmetric algorithms: des-cbc 3des-cbc aes-cbc md5 sha1 md5-hmac sha1-hmac
  Asymmetric algorithms:
  Random number generation function: Supported
Crypto engine name
Crypto engine name. The value is Software crypto engine in the current software version.
Crypto engine state
Software crypto engine state can only be Enabled.
Crypto engine type
Crypto engine type. The value is Software in the current software version.
Slot ID
ID of the IRF member device that holds the crypto engine.
Supported symmetric algorithms.
Supported asymmetric algorithms.
Whether random number generation function is supported:
·     Supported.
·     Not supported.
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engines statistics, including the number of established sessions and the number of operations performed by crypto engines.
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
engine-id engine-id: Specifies a crypto engine by its ID. The switch supports only a software crypto engine in the current software version, and the engine ID can only be 0.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays statistics for the crypto engines on all member devices.
# Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
  Submitted sessions: 0
  Failed sessions: 0
  Symmetric operations: 0
  Symmetric errors: 0
  Asymmetric operations: 0
  Asymmetric errors: 0
  Get-random operations: 0
  Get-random errors: 0
Submitted sessions
Number of established sessions.
Failed sessions
Number of failed sessions.
Number of operations using symmetric algorithms.
Symmetric errors
Number of failed operations using symmetric algorithms.
Number of operations using asymmetric algorithms.
Asymmetric errors
Number of failed operations using asymmetric algorithms.
Number of operations for obtaining random numbers.
Get-random errors
Number of failed operations for obtaining random numbers.
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command clears statistics for the crypto engines on all member devices.
# Clear all crypto engine statistics.
<Sysname> reset crypto-engine statistics
