09 Security Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10009 Security Command Reference
14-MFF commands
14-MFF commands 74.53 KB
MFF commands
display mac-forced-forwarding interface
Use display mac-forced-forwarding interface to display MFF port configuration.
# Display MFF port configuration.
<Sysname> display mac-forced-forwarding interface
Network Port:
FGE1/1/1              FGE1/1/2
User Port:
FGE1/1/3              FGE1/1/4              FGE1/1/5
FGE1/1/6              FGE1/1/7              FGE1/1/8
FGE1/1/9              FGE1/1/10             FGE1/1/11
FGE1/1/11             FGE1/1/12             FGE1/1/13
FGE1/1/14             FGE1/1/15             FGE1/1/16
FGE1/1/17             FGE1/1/18             FGE1/1/19
FGE1/1/20             FGE1/1/21             FGE1/1/22
FGE1/1/23             FGE1/1/24             FGE1/1/25
FGE1/1/26             FGE1/1/27             FGE1/1/28
FGE1/1/29             FGE1/1/30             FGE1/1/31
FGE1/1/32
Network Port
List of network ports.
User Port
List of user ports.
mac-forced-forwarding network-port
display mac-forced-forwarding vlan
Use display mac-forced-forwarding vlan to display the MFF configuration for a VLAN.
display mac-forced-forwarding vlan vlan-id
vlan-id: Specifies a VLAN by its number.
# Display the MFF configuration for VLAN 2.
<Sysname> display mac-forced-forwarding vlan 2
VLAN 2
Mode: Manual/Single
Gateway:
192.168.1.42         000f-e200-8046
Server:
192.168.1.48         192.168.1.49
VLAN
ID of the VLAN to which the gateways belong, such as VLAN 2.
Mode
MFF operating mode: manual (Manual), and single-gateway (Single).
Gateway
IP and MAC addresses of gateways. If no address is learned, this field displays N/A.
Server
Server IP addresses.
·     mac-forced-forwarding
·     mac-forced-forwarding server
Use mac-forced-forwarding to enable MFF in manual mode and specify a default gateway.
Use undo mac-forced-forwarding to disable MFF.
mac-forced-forwarding default-gateway gateway-ip
MFF is disabled.
VLAN view
default-gateway gateway-ip: Specifies the IP address of the default gateway in the manual mode.
For MFF to take effect in manual mode, make sure ARP snooping is enabled on the device.
For a network (or VLAN) with IP addresses manually configured, the gateway IP address must be manually configured. MFF checks for and denies only all-zero and all-one IP addresses as gateway addresses.
# Enable MFF in the manual mode for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding default-gateway 10.1.1.10
mac-forced-forwarding gateway probe
Use mac-forced-forwarding gateway probe to enable periodic gateway MAC address probe.
Use undo mac-forced-forwarding gateway probe to restore the default.
Periodic gateway MAC address probe is disabled.
VLAN view
Make sure you have enabled MFF before enabling periodic gateway MAC address probe.
The probe interval is 30 seconds, and the periodic probe is supported in manual modes.
# Enable periodic gateway MAC address probe.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding gateway probe
Use mac-forced-forwarding network-port to configure the Ethernet port as a network port.
Use undo mac-forced-forwarding network-port to restore the default.
The port is a user port.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
You should configure the following ports as network ports:
·     Upstream ports connected to a gateway.
·     Ports connected to the MFF devices in a cascaded network (a network with multiple MFF devices connected to one another).
·     Ports between devices in a ring network.
You can configure multiple ports as network ports.
You can configure a port as a network port regardless of whether MFF is enabled for the VLAN of the port. However, the configuration takes effect only after MFF is enabled.
Link aggregation is supported by network ports in an MFF-enabled VLAN, but is not supported by user ports in the VLAN. To cancel the network port configuration of a link aggregation member port in a MFF-enabled VLAN, remove the network port from the link aggregation group first. For more information about link aggregation, see Layer 2—LAN Switching Configuration Guide.
# Configure FortyGigE 1/1/1 as a network port.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] mac-forced-forwarding network-port
Use mac-forced-forwarding server to specify the IP addresses of servers.
Use undo mac-forced-forwarding server to remove the specified or all server IP addresses.
mac-forced-forwarding server server-ip&<1-10>
undo mac-forced-forwarding server server-ip&<1-10>
No server IP address is specified.
VLAN view
server-ip&<1-10>: Specifies a space-separated list of up to 10 server IP addresses.
You need to maintain a server list on the MFF device to ensure communication between the servers and clients.
Specify the IP addresses of the following items if they are in the network:
·     Servers providing some other service.
·     Interfaces on a router in a VRRP group.
When the MFF device receives an ARP request from a server, it searches the IP-to-MAC address entries it has stored. Then the device replies with the requested MAC address to the server. In this way, packets from the server to a host are not forwarded by the gateway. However, packets from a host to the server are forwarded by the gateway.
MFF does not check whether the IP address of a server is on the same network segment as that of a gateway. Instead, it checks whether the IP address of a server is all-zero or all-one. An all-zero or all-one server IP address is invalid.
Make sure MFF is enabled before you execute the mac-forced-forwarding server command.
# Specify the server at 192.168.1.100.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding server 192.168.1.100
