09 Security Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10009 Security Command Reference
10-SSH commands
10-SSH commands 234.96 KB
SSH commands
SSH server commands
display ssh server
Use display ssh server on an SSH server to display the SSH server status or sessions.
session: Displays the SSH server sessions.
status: Displays the SSH server status.
# Display the SSH server status.
<Sysname> display ssh server status
 Stelnet server: Disable
 SSH version : 1.99
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH authentication retries : 3 time(s)
 SFTP server: Disable
 SFTP server Idle-Timeout: 10 minute(s)
 NETCONF server: Disable
 SCP server: Disable
Stelnet server
Whether the Stelnet server is enabled.
SSH version
SSH protocol version.
When the SSH supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.
Authentication timeout timer.
Minimum update interval for the RSA server key pair.
Maximum number of authentication attempts for SSH users.
SFTP server
Whether the SFTP server is enabled.
SFTP connection idle timeout timer.
NETCONF server
Whether NETCONF over SSH is enabled.
SCP server
Whether the SCP server is enabled.
# Display SSH server sessions.
<Sysname> display ssh server session
UserPid   SessID Ver   Encrypt    State          Retries  Serv     Username
 184       0     2.0   aes128-cbc Established    1        Stelnet  abc@123
UserPid
User process ID.
SessID
Session ID.
Ver
Protocol version of the SSH server.
Encrypt
Encryption algorithm used on the SSH server.
Session state:
·     Init—Initialization.
·     Ver-exchange—Version negotiation.
·     Keys-exchange—Keys exchange.
·     Auth-request—Authentication request.
·     Serv-request—Session service request.
·     Established—The session is established.
·     Disconnected—The session is disconnected.
Retries
Number of authentication failures.
Serv
Service type:
·     SCP.
·     SFTP.
·     Stelnet.
·     NETCONF.
Username
Name of a user for logging in to the server.
display ssh user-information
Use display ssh user-information to display information about SSH users on an SSH server.
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters. If you do not specify an SSH user, this command displays information about all SSH users.
This command displays information only about SSH users that are configured with the ssh user command on the SSH server.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users:2
 Username            Authentication-type  User-public-key-name  Service-type
 yemx                password             null                  Stelnet
 test                publickey            pubkey                SFTP
Total ssh users
Total number of SSH users.
Authentication-type
Authentication methods:
·     Password authentication.
·     Publickey authentication.
·     Password-publickey authentication.
·     Any authentication.
Public key name of the user. If password authentication is used, this field displays null.
Service-type
Service types:
·     Stelnet.
·     SFTP.
·     SCP.
·     NETCONF.
ssh user
scp server enable
Use scp server enable to enable the SCP server.
Use undo scp server enable to restore the default.
scp server enable
The SCP server is disabled.
# Enable the SCP server.
[Sysname] scp server enable
display ssh server
sftp server enable
Use sftp server enable to enable the SFTP server.
Use undo sftp server enable to restore the default.
sftp server enable
The SFTP server is disabled.
# Enable the SFTP server.
[Sysname] sftp server enable
display ssh server
sftp server idle-timeout
Use sftp server idle-timeout to set the idle timeout timer for SFTP connections on an SFTP server.
Use undo sftp server idle-timeout to restore the default.
The idle timeout timer is 10 minutes.
time-out-value: Specifies a timeout timer in the range of 1 to 35791 minutes.
If an SFTP connection is idle when the idle timeout timer expires, the system automatically terminates the connection. If many SFTP connections are established, set a small value so that the connection resources can be promptly released.
# Set the idle timeout timer to 500 minutes for SFTP user connections.
[Sysname] sftp server idle-timeout 500
display ssh server
ssh server acl
Use ssh server acl to specify an ACL to control IPv4 SSH connections to the server.
Use undo ssh server acl to restore the default.
ssh server acl acl-number
undo ssh server acl
ACLs are not specified and all IPv4 SSH users can initiate IPv4 SSH connections to the server.
acl-number: Specifies an ACL number in the range of 2000 to 4999.
The specified ACL filters IPv4 SSH users' connection requests. Only the IPv4 SSH users that the ACL permits can initiate SSH connections to the server.
All IPv4 SSH users can initiate SSH connections to the server when any one of the following conditions exists:
·     You do not specify an ACL.
·     The specified ACL does not exist.
·     The specified ACL does not have rules.
The ACL takes effect only on SSH connections that are initiated after the ACL configuration.
# Configure ACL 2001 and permit only the users at 1.1.1.1 to initiate SSH connections to the server.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0
[Sysname-acl-basic-2001] quit
[Sysname] ssh server acl ipv6 2001
display ssh server
ssh server authentication-retries
Use ssh server authentication-retries to set the maximum number of authentication attempts for SSH users.
Use undo ssh server authentication-retries to restore the default.
ssh server authentication-retries times
The maximum number of authentication attempts for SSH users is 3.
times: Specifies the maximum number of authentication attempts for SSH users, in the range of 1 to 5.
You can set this limit to prevent malicious hacking of usernames and passwords.
This configuration does not affect logged-in users. It affects only new SSH users.
If the authentication method is any, the total number of authentication attempts (including both publickey and password authentication attempts) must not exceed the upper limit.
If the authentication method is password-publickey, the server first uses publickey authentication, and then uses password authentication to authenticate the SSH user. The process is considered one authentication attempt.
# Set the maximum number of authentication attempts to 4 for SSH users.
[Sysname] ssh server authentication-retries 4
display ssh server
ssh server authentication-timeout
Use ssh server authentication-timeout to set the SSH user authentication timeout timer on the SSH server.
Use undo ssh server authentication-timeout to restore the default.
The authentication timeout timer is 60 seconds.
time-out-value: Specifies an authentication timeout timer in the range of 1 to 120 seconds.
If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
To prevent malicious occupation of TCP connections, set a small value for the timeout timer.
# Set the SSH user authentication timeout timer to 10 seconds.
[Sysname] ssh server authentication-timeout 10
display ssh server
ssh server compatible-ssh1x enable
Use ssh server compatible-ssh1x enable to enable the SSH server to support SSH1 clients.
Use undo ssh server compatible-ssh1x [ enable ] to disable the SSH server from supporting SSH1 clients.
The SSH server supports SSH1 clients.
This command is not available in FIPS mode.
# Enable the SSH server to support SSH1 clients.
[Sysname] ssh server compatible-ssh1x enable
display ssh server
ssh server dscp
Use ssh server dscp to set the DSCP value in the IPv4 packets that the SSH server sends to the SSH clients.
Use undo ssh server dscp to restore the default.
ssh server dscp dscp-value
The DSCP value in IPv4 packets sent by the SSH server is 48.
dscp-value: Specifies the DSCP value in the outbound IPv4 packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for IPv4 packets sent by the SSH server.
[Sysname] ssh server dscp 30
ssh server enable
Use ssh server enable to enable the Stelnet server.
Use undo ssh server enable to restore the default.
ssh server enable
The Stelnet server is disabled.
# Enable the Stelnet server.
[Sysname] ssh server enable
display ssh server
ssh server ipv6 acl
Use ssh server ipv6 acl to specify an ACL to control IPv6 SSH user connections..
Use undo ssh server ipv6 acl to restore the default.
ssh server ipv6 acl [ ipv6 ] acl-number
ACLs are not specified and all IPv6 SSH users can initiate SSH connections to the server.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, Layer 2 ACL is applied.
acl-number: Specifies an ACL by its number. If you specify the ipv6 keyword, the value range for this argument is 2000 to 3999. If you do not specify the ipv6 keyword, the value range for this argument is 4000 to 4999.
The specified ACL filters IPv6 SSH users' connection requests. Only the IPv6 SSH users that the ACL permits can initiate SSH connections to the device.
All IPv6 SSH users can initiate SSH connections to the device when any one of the following conditions exists:
# Configure ACL 2001 and permit the users on the subnet 1::1/64 to initiate SSH connections to the server.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 1::1 64
[Sysname-acl6-basic-2001] quit
[Sysname] ssh server ipv6 acl ipv6 2001
display ssh server
ssh server ipv6 dscp
Use ssh server ipv6 dscp to set the DSCP value in the IPv6 packets that the SSH server sends to the SSH clients.
Use undo ssh server ipv6 dscp to restore the default.
The DSCP value in IPv6 packets sent by the SSH server is 48.
dscp-value: Specifies the DSCP value in the outbound IPv6 packets, in the range of 0 to 63.
The DSCP value of an IPv6 packet specifies the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for IPv6 packets sent by the SSH server.
[Sysname] ssh server ipv6 dscp 30
ssh server rekey-interval
Use ssh server rekey-interval to set the minimum interval for updating the RSA server key pair.
Use undo ssh server rekey-interval to restore the default.
ssh server rekey-interval hours
The minimum interval for updating the RSA server key pair is 0 hours, and the system does not update the RSA server key pair.
hours: Specifies the minimum interval for updating the RSA server key pair, in the range of 1 to 24 hours.
This command takes effect only on SSH1 clients.
The system starts to count down the minimum update interval after the first SSH1 user logs in to the server. If a new SSH1 user logs in to the server after the minimum update interval, the system performs the following operations:
1.     Updates the RSA server key pair.
2.     Uses the updated RSA server key pair for key pair negotiation with the new user.
3.     Starts to count down the minimum update interval again.
Updating the RSA server key pair periodically can prevent malicious hacking to the key pair and enhance security of the SSH connections.
# Set the RSA server key pair update interval to 3 hours.
[Sysname] ssh server rekey-interval 3
display ssh server
ssh user
Use ssh user to create an SSH user and specify the service type and authentication method.
Use undo ssh user to delete an SSH user.
In non-FIPS mode:
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | { any | password-publickey | publickey } assign { pki-domain domain-name | publickey keyname } }
undo ssh user username
In FIPS mode:
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | password-publickey assign { pki-domain domain-name | publickey keyname } }
No SSH users exist.
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters. If the username contains an ISP domain name, use the form pureusername@domain. The pureusername argument is a string of 1 to 55 characters. The domain argument is a string of 1 to 24 characters.
service-type: Specifies a service type for an SSH user.
·     all: Specifies Stelnet, SFTP, SCP, and NETCONF.
·     scp: Specifies the service type as SCP.
·     sftp: Specifies the service type as SFTP.
·     stelnet: Specifies the service type as Stelnet.
·     netconf: Specifies the service type as NETCONF.
authentication-type: Specifies an authentication method for an SSH user.
·     password: Specifies password authentication. This authentication method provides easy and fast encryption, but it is vulnerable. It can work with AAA to implement user authentication, authorization, and accounting.
·     any: Specifies either password authentication or publickey authentication.
·     password-publickey: Specifies both password authentication and publickey authentication for SSH2 clients. In SSH2, the password-publickey authentication method provides higher security. If the client runs SSH1, this keyword specifies either password authentication or publickey authentication.
·     publickey: Specifies publickey authentication. This authentication method has complicated and slow encryption, but it provides strong authentication that can defend against brute-force attacks. This authentication method is easy to use. If this method is configured, the authentication process completes automatically without entering any password.
assign: Specifies parameters used for verifying the client.
·     pki-domain domain-name: Specifies the PKI domain that verifies the client certificate. The domain-name argument is a case-insensitive string of 1 to 31 characters. The server uses the CA certificate that is saved in the PKI domain to verify the client certificate. In this scenario, the server does not need to save clients' public keys in advance.
·     publickey keyname: Specifies the public key of the SSH client. The keyname argument represents the SSH client's public key configured on the server. It is a case-insensitive string of 1 to 64 characters. The server uses the client's public key to check the validity of the client. If the public key file of the client is changed, you must update the client's public key on the server promptly.
Use this command to configure an SSH user depending on the authentication method.
·     If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
·     If the authentication method is password, you must perform one of the following tasks:
¡     For local authentication, configure a local user on the SSH server.
¡     For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
·     If the authentication method is password-publickey or any, you must create an SSH user and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
If you use this command to specify a host public key or a PKI domain for a user multiple times, the most recent configuration takes effect.
You can change the authentication parameters for a logged-in SSH user, but your changes take effect on the user at the next login.
For an SFTP or SCP user, the working directory depends on the authentication method.
·     If the authentication method is password, the working directory is authorized by AAA.
·     If the authentication method is publickey or password-publickey, the working directory is specified by the authorization-attribute command in the associated local user view.
For an SSH user, the user role also depends on the authentication method.
·     If the authentication method is password, the user role is authorized by the remote AAA server or the local device.
·     If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
# Create an SSH user user1. Specify the service type as sftp and the authentication method as password-publickey for the user. Assign the host public key key1 to the user.
[Sysname] ssh user user1 service-type sftp authentication-type password-publickey assign publickey key1
# Create a local device management user user1. Specify the password as 123456TESTplat&! in plain text and the service type as ssh for the user. Assign the working directory flash: and the user role network-admin to the user.
[Sysname-luser-manage-user1] service-type ssh
[Sysname-luser-manage-user1] authorization-attribute work-directory flash: user-role network-admin
·     authorization-attribute
·     display ssh user-information
·     local-user
·     pki domain
SSH client commands
bye
Use bye to terminate the connection with an SFTP server and return to user view.
bye
SFTP client view
This command has the same function as the exit and quit commands.
# Terminate the connection with the SFTP server.
sftp> bye
<Sysname>
cd
Use cd to change the working directory on an SFTP server.
cd [ remote-path ]
SFTP client view
remote-path: Specifies the name of a directory on the server.
You can use the cd .. command to return to the upper-level directory.
You can use the cd / command to return to the root directory of the system.
# Change the working directory to new1.
sftp> cd new1
Current Directory is:/new1
sftp> pwd
Remote working directory: /new1
sftp>
cdup
Use cdup to return to the upper-level directory.
cdup
SFTP client view
Example
# Return to the upper-level directory from the current working directory /test1.
sftp> cd test1
Current Directory is:/test1
sftp> pwd
Remote working directory: /test1
sftp> cdup
sftp> pwd
sftp>
delete
Use delete to delete a file from the SFTP server.
delete remote-file
SFTP client view
remote-file: Specifies a file.
This command has the same function as the remove command.
# Delete the file temp.c from the server.
sftp> delete temp.c
Removing /temp.c
dir
Use dir to display information about the files and subdirectories under a directory.
SFTP client view
-a: Displays detailed information about files and subdirectories under a directory in a list, including the files and subdirectories with names starting with dots (.).
-l: Displays detailed information about the files and subdirectories under a directory in a list, excluding the files and subdirectories with names starting with dots (.).
remote-path: Specifies the name of the directory to be queried. If you do not specify this argument, the command displays detailed information about the files and subdirectories under the current working directory.
If you do not specify both of the –a and –l keywords, this command displays detailed information about files and subdirectories under a directory in a list.
This command has the same function as the ls command.
# Display detailed information about the files and subdirectories under the current directory, including the files and subdirectories with names starting with dots (.).
sftp> dir -a
drwxrwxrwx    2 1        1               512 Dec 18 14:12 .
drwxrwxrwx    2 1        1               512 Dec 18 14:12 ..
-rwxrwxrwx    1 1        1               301 Dec 18 14:11 010.pub
-rwxrwxrwx    1 1        1               301 Dec 18 14:12 011.pub
-rwxrwxrwx    1 1        1               301 Dec 18 14:12 012.pub
# Display detailed information about the files and subdirectories under the current directory.
sftp> dir -l
display sftp client source
Use display sftp client source to display the source IP address configured for the SFTP client.
This command only displays the source IP address of the SFTP client that is configured by using one of the following commands:
·     sftp client ipv6 source
·     sftp client source
The default source IP address of the SFTP client is not provided in the command output.
# Display the source IP address configured for the SFTP client.
<Sysname> display sftp client source
The source IP address of the SFTP client is 192.168.0.1
The source IPv6 address of the SFTP client is 2:2::2:2.
display ssh client source
Use display ssh client source to display the source IP address configured for the Stelnet client.
This command only displays the source IP address of the Stelnet client that is configured by using one of the following commands:
·     ssh client ipv6 source
·     ssh client source
The default source IP address of the Stelnet client is not provided in the command output.
# Display the source IP address configured for the Stelnet client.
<Sysname> display ssh client source
The source IP address of the SSH client is 192.168.0.1
The source IPv6 address of the SSH client is 2:2::2:2.
·     ssh client source
exit
Use exit to terminate the SFTP connection and return to user view.
exit
SFTP client view
This command has the same function as the bye and quit commands.
# Terminate the SFTP connection.
sftp> exit
<Sysname>
get
Use get to download a file from an SFTP server and save it locally.
SFTP client view
remote-file: Specifies the name of a file on the SFTP server.
local-file: Specifies the name for the local file. If you do not specify this argument, the file will be saved locally with the same name as the file on the SFTP server.
# Download the file temp1.c and save it as temp.c locally.
sftp> get temp1.c temp.c
Fetching /temp1.c to temp.c
/temp.c                                                 100% 1424     1.4KB/s   00:00
help
Use help to display help information.
help
SFTP client view
The help command has the same function as entering the question mark (?).
# Display help information.
sftp> help
Available commands:
  bye                          Quit sftp
  cd [path]                    Change remote directory to 'path'
  cdup                         Change remote directory to the parent directory
  delete path                  Delete remote file
  dir [-a|-l][path]            Display remote directory listing
       -a                        List all filenames
       -l                        List filename including the specific
                                 information of the file
  exit                         Quit sftp
  get remote-path [local-path] Download file
  help                         Display this help text
  ls [-a|-l][path]             Display remote directory
  mkdir path                   Create remote directory
  put local-path [remote-path] Upload file
  pwd                          Display remote working directory
  quit                         Quit sftp
  rename oldpath newpath       Rename remote file
  remove path                  Delete remote file
  rmdir path                   Delete remote empty directory
  ?                            Synonym for help
ls
Use ls to display information about the files and subdirectories under a directory.
SFTP client view
remote-path: Specifies the name of the directory to be queried. If you do not specify this argument, the command displays information about the files and subdirectories under the current working directory.
If you do not specify both of the –a and –l keywords, this command displays the names of the files and subdirectories under a directory.
This command has the same function as the dir command.
sftp> ls -a
# Display detailed information about the files and subdirectories under the current working directory.
sftp> ls -l
mkdir
Use mkdir to create a directory on an SFTP server.
mkdir remote-path
SFTP client view
remote-path: Specifies the name of a directory.
# Create a directory test on the SFTP server.
sftp> mkdir test
put
Use put to upload a local file to an SFTP server.
SFTP client view
local-file: Specifies the name of a local file.
remote-file: Specifies the name of a file on an SFTP server. If you do not specify this argument, the file will be remotely saved with the same name as the local file.
# Upload the local file startup.bak to the SFTP server and save it as startup01.bak.
sftp> put startup.bak startup01.bak
Uploading startup.bak to /startup01.bak
startup01.bak                                   100% 1424     1.4KB/s   00:00
pwd
Use pwd to display the current working directory of an SFTP server.
pwd
SFTP client view
# Display the current working directory of the SFTP server.
sftp> pwd
The output shows that the current working directory is the root directory.
Use quit to terminate the SFTP connection and return to user view.
SFTP client view
This command has the same function as the bye and exit commands.
sftp> quit
<Sysname>
remove
Use remove to delete a file from an SFTP server.
remove remote-file
SFTP client view
This command has the same function as the delete command.
# Delete the file temp.c from the SFTP server.
sftp> remove temp.c
Removing /temp.c
rename
Use rename to change the name of a file or directory on an SFTP server.
rename old-name new-name
SFTP client view
oldname: Specifies the name of an existing file or directory.
newname: Specifies a new name for the file or directory.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp> dir
aa.pub  temp1.c
sftp> rename temp1.c temp2.c
sftp> dir
aa.pub  temp2.c
rmdir
Use rmdir to delete a directory from an SFTP server.
rmdir remote-path
SFTP client view
remote-path: Specifies a directory.
# Delete the subdirectory temp1 under the current directory on the SFTP server.
sftp> rmdir temp1
scp
Use scp to establish a connection to an IPv4 SCP server and transfer files with the server.
In non-FIPS mode:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
In FIPS mode:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
server: Specifies a server by its IPv4 address or host name, a case-insensitive string of 1 to 253 characters.
port-number: Specifies the port number of the server, in the range of 0 to 65535. The default is 22.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the server belongs, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
get: Downloads the file.
put: Uploads the file.
source-file-name: Specifies the name of the source file.
destination-file-name: Specifies the name of the target file. If you do not specify this argument, the target file uses the same file name as the source file.
identity-key: Specifies a public key algorithm for the client. The default is dsa in non-FIPS mode and rsa in FIPS mode. If the server uses publickey authentication, you must specify this keyword. The client generates the digital signature by using the local private key that is associated with the algorithm.
·     dsa: Specifies the public key algorithm dsa.
·     ecdsa: Specifies the public key algorithm ecdsa.
·     rsa: Specifies the public key algorithm rsa.
prefer-compress: Specifies the preferred compression algorithm between the server and the client. By default, compression is not supported.
zlib: Specifies the compression algorithm zlib.
prefer-ctos-cipher: Specifies the preferred client-to-server encryption algorithm. The default is aes128.
Algorithms des, 3des, aes128, and aes256 are arranged in ascending order in the aspects of security strength and calculation time.
·     3des: Specifies the encryption algorithm 3des-cbc.
·     aes128: Specifies the encryption algorithm aes128-cbc.
·     aes256: Specifies the encryption algorithm aes256-cbc.
·     des: Specifies the encryption algorithm des-cbc.
prefer-ctos-hmac: Specifies the preferred client-to-server HMAC algorithm. The default is sha1. Algorithm sha1 provides stronger security but costs more time in calculation than md5.
·     md5: Specifies the HMAC algorithm hmac-md5.
·     md5-96: Specifies the HMAC algorithm hmac-md5-96.
·     sha1: Specifies the HMAC algorithm hmac-sha1.
·     sha1-96: Specifies the HMAC algorithm hmac-sha1-96.
prefer-kex: Specifies the preferred key exchange algorithm. The default is dh-group-exchange in non-FIPS mode and dh-group14 in FIPS mode.
Algorithm dh-group14 provides stronger security but costs more time in calculation than dh-group1.
·     dh-group-exchange: Specifies the key exchange algorithm diffie-hellman-group-exchange-sha1.
·     dh-group1: Specifies the key exchange algorithm diffie-hellman-group1-sha1.
·     dh-group14: Specifies the key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Specifies the preferred server-to-client encryption algorithm. The default is aes128.
prefer-stoc-hmac: Specifies the preferred server-to-client HMAC algorithm. The default is sha1.
publickey keyname: Specifies the host public key of the sever, which is used to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IP address or source interface to connect to the server. By default, the SCP packets use the primary IPv4 address of the output interface specified in the routing entry as their source address. For successful SCP connections, use one of the following methods:
·     Specify the loopback interface as the source interface.
·     Specify the IPv4 address of the loopback interface as the source IPv4 address.
interface interface-type interface-number: Specifies a source interface by its type and number. The IPv4 address of this interface is the source IPv4 address of SCP packets.
ip ip-address: Specifies a source IPv4 address.
# Connect an SCP client to the SCP server 200.1.1.1. Specify the public key of the server as svkey, and download the file abc.txt from the server. The SCP client uses publickey authentication. Use the following algorithms:
·     Preferred key exchange algorithm: dh-group14.
·     Preferred server-to-client encryption algorithm: aes128.
·     Preferred client-to-server HMAC algorithm: sha1.
·     Preferred server-to-client HMAC algorithm: sha1-96.
·     Preferred compression algorithm: zlib.
<Sysname> scp 200.1.1.1 get abc.txt prefer-kex dh-group14 prefer-stoc-cipher aes128 prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
scp ipv6
Use scp ipv6 to establish a connection to an IPv6 SCP server and transfer files with the server.
In non-FIPS mode:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
In FIPS mode:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
server: Specifies a server by its IPv6 address or host name, a case-insensitive string of 1 to 253 characters.
port-number: Specifies the port number of the server, in the range of 1 to 65535. The default is 22.
-i interface-type interface-number: Specifies an output interface by its type and number for SCP packets. This option is used only when the server uses a link-local address to provide the SCP service for the client. The specified outgoing interface on the client must have a link-local address.
prefer-kex: Specifies the preferred key exchange algorithm. The default is dh-group-exchange in non-FIPS mode and dh-group14 in FIPS mode. Algorithm dh-group14 provides stronger security but costs more time in calculation than dh-group1.
source: Specifies a source IPv6 address or source interface for IPv6 SCP packets. By default, the IPv6 SCP packets automatically select an IPv6 address as their source address in compliance with RFC 3484. For successful SCP connections, use one of the following methods:
·     Specify the IPv6 address of the loopback interface as the source IPv6 address.
interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address of SCP packets.
ipv6 ipv6-address: Specifies a source IPv6 address.
# Connect an SCP client to the SCP server 2000::1. Specify the public key of the server as svkey, and download the file abc.txt from the server. The SCP client uses publickey authentication. Use the following algorithms:
<Sysname> scp ipv6 2000::1 get abc.txt prefer-kex dh-group14 prefer-stoc-cipher aes128 prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
sftp
Use sftp to establish a connection to an IPv4 SFTP server and enter SFTP client view.
In non-FIPS mode:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
In FIPS mode:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters.
prefer-ctos-cipher: Specifies the preferred client-to-server encryption algorithm. The default is aes128. Algorithms des, 3des, aes128, and aes256 are arranged in ascending order in the aspects of security strength and calculation time.
dscp dscp-value: Specifies the DSCP value in the IPv4 SFTP packets sent by the SFTP client, in the range of 0 to 63. The default value is 48. The DSCP value determines the transmission priority of the packet.
source: Specifies a source IPv4 address or source interface for the SFTP packets. By default, the SFTP packets use the primary IPv4 address of the output interface specified in the routing entry as their source address. For successful SFTP connections, use one of the following methods:
interface interface-type interface-number: Specifies a source interface by its type and number. The primary IPv4 address of this interface is the source IPv4 address of SFTP packets.
# Connect an SFTP client to the IPv4 SFTP server 10.1.1.2 and specify the public key of the server as svkey. The SFTP client uses publickey authentication. Use the following algorithms:
<Sysname> sftp 10.1.1.2 prefer-kex dh-group14 prefer-stoc-cipher aes128 prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
Use sftp client ipv6 source to specify the source IPv6 address for SFTP packets.
Use undo sftp client ipv6 source to restore the default.
sftp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
The source IPv6 address for SFTP packets is not configured. The SFTP packets automatically select an IPv6 address as their source address in compliance with RFC 3484.
interface interface-type interface-number: Specifies a source interface by its type and number. The SFTP packets use the longest-matching IPv6 address of the specified interface as their source address.
The IPv6 address specified by this command also acts as the source IPv6 address of the SFTP client.
This command takes effect on all IPv6 SFTP connections. The source IPv6 address specified in the sftp ipv6 command takes effect only on the current IPv6 SFTP connection.
If you specify the source IPv6 address both in this command and the sftp ipv6 command, the source IPv6 address specified in the sftp ipv6 command takes effect.
# Specify the source IPv6 address for SFTP packets as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source
Use sftp client source to specify the source IPv4 address for SFTP packets.
Use undo sftp client source to restore the default.
sftp client source { interface interface-type interface-number | ip ip-address }
The source IPv4 address for SFTP packets is not configured. The SFTP packets use the primary IPv4 address of the output interface specified in the routing entry as their source IPv4 address.
interface interface-type interface-number: Specifies a source interface by its type and number. The SFTP packets use the primary IPv4 address of the interface as their source address.
The IPv4 address specified by this command also acts as the source IPv4 address of the SFTP client.
This command takes effect on all SFTP connections. The source IPv4 address specified in the sftp command takes effect only on the current SFTP connection.
If you specify the source IPv4 address both in this command and the sftp command, the source IPv4 address specified in the sftp command takes effect.
# Specify the source IPv4 address for SFTP packets as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
sftp ipv6
Use sftp ipv6 to connect an SFTP client to an IPv6 SFTP server and enter SFTP client view.
In non-FIPS mode:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
In FIPS mode:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
-i interface-type interface-number: Specifies an output interface by its type and number for IPv6 SFTP packets. The specified outgoing interface must have a link-local address. This option is used only when the server uses a link-local address to provide the SFTP service for the client.
dscp dscp-value: Specifies the DSCP value in the IPv6 SFTP packets sent by the SFTP client, in the range of 0 to 63. The default value is 48. The DSCP value determines the transmission priority of the packet.
publickey keyname: Specifies the host public key of the server, which is used to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IP address or source interface for IPv6 SFTP packets. By default, the IPv6 SFTP packets automatically select an IPv6 address as their source address in compliance with RFC 3484. For successful IPv6 SFTP connections, use one of the following methods:
interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address of SFTP packets.
# Connect an SFTP client to the IPv6 SFTP server 2000::1 and specify the public key of the server as svkey. The SFTP client uses publickey authentication. Use the following algorithms:
<Sysname> sftp ipv6 2000::1 prefer-kex dh-group14 prefer-stoc-cipher aes128 prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
Username:
Use ssh client ipv6 source to specify the source IPv6 address for SSH packets.
Use undo ssh client ipv6 source to restore the default.
The source IPv6 address for SSH packets is not configured. The SSH packets automatically select an IPv6 address as their source address in compliance with RFC 3484.
interface interface-type interface-number: Specifies a source interface by its type and number. The SSH packets use the longest-matching IPv6 address of the specified interface as their source address.
The IPv6 address specified by this command also acts as the source IPv6 address of the Stelnet client.
This command takes effect on all IPv6 Stelnet connections. The source IPv6 address specified in the ssh2 ipv6 command takes effect only on the current IPv6 Stelnet connection.
If you specify the source IPv6 address both in this command and the ssh2 ipv6 command, the source IPv6 address specified in the ssh2 ipv6 command takes effect.
# Specify the source IPv6 address as 2:2::2:2 for SSH packets.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source
Use ssh client source to specify the source IPv4 address for SSH packets.
Use undo ssh client source to restore the default.
The source IPv4 address for SSH packets is not configured. The SSH packets use the primary IPv4 address of the output interface specified in the routing entry as their source IPv4 address.
interface interface-type interface-number: Specifies a source interface by its type and number. The SSH packets use the primary IPv4 address of the interface as their source address.
The IPv4 address specified by this command also acts as the source IPv4 address of the Stelnet client.
This command takes effect on all Stelnet connections. The source IPv4 address specified in the ssh2 command takes effect only on the current Stelnet connection.
If you specify the source IPv4 address both in this command and the ssh2 command, the source IPv4 address specified in the ssh2 command takes effect.
# Specify the source IPv4 address for SSH packets as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh2
Use ssh2 to establish a connection to an IPv4 Stelnet server.
In non-FIPS mode:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | escape character | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
In FIPS mode:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ escape character | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
port-number: Specifies the port number of the server, in the range 1 to 65535. The default is 22.
dscp dscp-value: Specifies the DSCP value in the IPv4 SSH packets sent by the SSH client, in the range of 0 to 63. The default value is 48. The DSCP value determines the transmission priority of the packet.
escape character: Specifies an escape character. By default, the escape character is a tilde (~).
source: Specifies a source IPv4 address or source interface to connect to the server. By default, the SSH packets use the primary IPv4 address of the output interface specified in the routing entry as their source address. For successful Stelnet connections, use one of the following methods:
interface interface-type interface-number: Specifies a source interface by its type and number. The primary IPv4 address of this interface is the source IPv4 address of SSH packets.
The combination of an escape character and a dot (.) works as an escape sequence. This escape sequence is typically used to fast terminating an SSH connection when the server reboots or runs exceptionally.
For the escape sequence to take effect, you must enter it at the very beginning of a line. If you have entered other characters or performed operations in a line, enter the escape sequence in the next line.
H3C recommends that you use the default escape character (~). Do not use any character in SSH usernames as the escape character.
# Establish a connection to the IPv4 Stelnet server 3.3.3.3 and specify the public key of the server as svkey. The Stelnet client uses publickey authentication. Specify the dollar sign ($) as the escape character. Use the following algorithms:
<Sysname> ssh2 3.3.3.3 prefer-kex dh-group14 prefer-stoc-cipher aes128 prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey escape $
ssh2 ipv6
Use ssh2 ipv6 to establish a connection to an IPv6 Stelnet server.
In non-FIPS mode:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | escape character | publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
In FIPS mode:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ escape character | publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
-i interface-type interface-number: Specifies an output interface by its type and number for IPv6 SSH packets. The specified outgoing interface must have a link-local address. This option is used only when the server uses a link-local address to provide the SSH service for the client.
dscp dscp-value: Specifies the DSCP value in the IPv6 SSH packets sent by the SSH client, in the range of 0 to 63. The default value is 48. The DSCP value determines the transmission priority of the packet.
publickey keyname: Specifies the server by its host public key, which is used to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IP address or source interface for IPv6 SSH packets. By default, the IPv6 SSH packets automatically select an IPv6 address as their source address in compliance with RFC 3484. For successful IPv6 Stelnet connections, use one of the following methods:
interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address of SSH packets.
# Establish a connection to the IPv6 Stelnet server 2000::1 and specify the public key of the server as svkey. The SSH client uses publickey authentication. Specify the dollar sign ($) as the escape character. Use the following algorithms:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group14 prefer-stoc-cipher aes128 prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey escape $
