- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency shell configuration
- 10-Automatic configuration
- 11-Device management configuration
- 12-Tcl configuration
- 13-License management
- 14-Management with BootWare
- 15-Python configuration
| 06-Configuration file management configuration | 136.03 KB |
Next-startup configuration file redundancy
Startup configuration file selection
Configuration file content organization and format
General configuration restrictions and guidelines
Enabling configuration encryption
Saving the running configuration
Configuring configuration rollback
Configuring configuration archive parameters
Enabling automatic configuration archiving
Manually archiving the running configuration
Specifying a next-startup configuration file
Backing up the main next-startup configuration file to a TFTP server
Restoring the main next-startup configuration file from a TFTP server
Deleting a next-startup configuration file
Displaying and maintaining configuration files
Overview
You can use the CLI or the BootWare menus to manage configuration files. This chapter explains how to manage configuration files from the CLI.
A configuration file saves a set of commands for configuring software features on the device. You can save any configuration to a configuration file so they can survive a reboot. You can also back up configuration files to a host for future use.
Configuration types
The device uses multiple types of configurations, including factory defaults, startup configuration, and running configuration.
Factory defaults
The device is shipped with some basic settings called factory defaults. These default settings ensure that the device can start up and run correctly when it does not have any configuration file or when the configuration file is corrupt.
Factory defaults might differ from the default settings of commands.
To display factory defaults, use the display default-configuration command.
The device uses startup configuration to configure software features during startup. After the device starts up, you can specify a different configuration file to be loaded at the next startup. This configuration file is called the next-startup configuration file. The configuration file that has been loaded is called the current startup configuration file.
If no next-startup configuration file exists, the device starts up with the factory defaults.
You can display the startup configuration by using one of the following methods:
· Execute the display startup command. To display detailed file contents, use the more command.
· After the device reboots, execute the display current-configuration command before making any configuration changes.
Running configuration
The running configuration includes unchanged startup settings and new settings. The running configuration is stored in the memory and is cleared at a device reboot or power off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
To display the running configuration, use the display current-configuration command.
You can specify one main next-startup configuration file and one backup next-startup configuration file for redundancy.
At startup, the device tries to start up with the main configuration file. If the main configuration file is corrupt or unavailable, the device tries the backup configuration file. If the backup configuration file is corrupt or unavailable, the device starts up with the factory defaults.
For high availability, do not specify one configuration file as both the main and backup configuration files.
Configuration file formats
Configuration files you specify for saving configuration must use the .cfg extension. A .cfg configuration file is a human-readable text file. When you save configuration to a .cfg file, the device automatically saves the configuration to an .mdb user-inaccessible binary file that has the same name as the .cfg file. The device loads an .mdb file faster than loading a .cfg file.
At startup, the device uses the following procedure to identify the configuration file to load:
1. The device searches for a valid .cfg next-startup configuration file.
2. If one is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3. If an .mdb file has the same name and content as the .cfg file, the device starts up with the .mdb file. If none is found, the device starts up with the .cfg file.
Unless otherwise stated, the term "configuration file" in this document refers to a .cfg configuration file.
IMPORTANT: To run on the device, a configuration file must meet the content and format requirements. To ensure a successful configuration load at startup, use a configuration file created on the device. If you edit the configuration file, make sure all edits are compliant with the requirements. |
A configuration file must meet the following requirements:
· All commands are saved in their complete form.
· Commands are sorted in sections by different command views, including system view, interface view, protocol view, and user line view.
· Two adjacent sections are separated by a comment line that starts with a pound sign (#).
· The configuration file ends with the word return.
The following is a sample configuration file excerpt:
local-user root class manage
password hash $h$6$+6QPbKurqEqKBtqU$ze42xyRhVu7FnyyVxA6oOfxfmy4VXR9QD6EV07qrOj+
vIddA6mlhHxud5SAni4wRsRB3EDztZE3oXu4tp+tPCQ==
interface GigabitEthernet3/0/1
port link-mode route
ip address 1.1.1.1 255.255.255.0
FIPS compliance
When you manage the next-startup configuration files, follow these restrictions and guidelines:
· Save the next-startup configuration files to the root directory of the default storage medium. The device loads startup configuration files only from the default storage medium. You can access the BootWare menus to specify the built-in flash memory, the CF card, or the USB disk as the default storage medium.
· In standalone mode, make sure both the active and standby MPUs use the same type of storage medium as the default storage medium.
· In IRF mode, make sure all MPUs use the same type of storage medium as the default storage medium.
· If the CF card or USB disk is used to store the startup configuration files, do not remove the CF card or USB disk during the startup process. If you remove the CF card or USB disk on a device, one of the following consequences occurs:
¡ In standalone mode, the device starts up with the factory defaults.
¡ In IRF mode, the device leaves the IRF fabric at startup and runs the factory defaults.
Configuration encryption enables the device to encrypt a startup configuration file automatically when it saves the running configuration. All H3C devices running Comware V7 software use the same private key or public key to encrypt configuration files.
NOTE: Only H3C devices running Comware V7 software can decrypt the encrypted configuration files. |
To enable configuration encryption:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable configuration encryption. |
configuration encrypt { private-key | public-key } |
By default, configuration encryption is disabled. Configuration is saved unencrypted. |
When saving the running configuration to a configuration file, you can specify the file as the next-startup configuration file.
If you are specifying the file as the next-startup configuration file, use one of the following methods to save the configuration:
· Fast mode—Use the save command without the safely keyword. In this mode, the device directly overwrites the target next-startup configuration file. If a reboot or power failure occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots (see "Specifying a next-startup configuration file").
· Safe mode—Use the save command with the safely keyword. Safe mode is slower than fast mode, but more secure. In safe mode, the system saves configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot or power failure occurs during the save operation, the next-startup configuration file is still retained.
Use the safe mode if the power source is not reliable or you are remotely configuring the device.
To save the running configuration, perform either of the following tasks in any view:
Task |
Command |
Remarks |
Save the running configuration to a configuration file without specifying the file as the next-startup configuration file. |
· In standalone mode: · In IRF mode: |
N/A |
Save the running configuration to a configuration file in the root directory of each MPU's storage medium and specify the file as the startup configuration file. |
save [ safely ] [ backup | main ] [ force ] [ mdc-all ] |
This command saves the configuration to a file on the default storage medium. For reliable configuration saving, H3C recommends that you specify the safely keyword. If you specify only the safely keyword, the command saves the configuration to the main startup configuration file for the MDC where you are logged in. If the force keyword is specified, the command saves the configuration to the existing configuration file. If the force keyword is not specified, the command allows you to specify a new next-startup configuration file. |
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback function. This function helps you revert to a previous configuration state or adapt the running configuration to different network environments.
The configuration rollback function compares the running configuration against the specified replacement configuration file and handles configuration differences as follows:
· If a command in the running configuration is not in the replacement file, the rollback function executes the undo form of the command.
· If a command in the replacement file is not in the running configuration, the rollback function adds the command to the running configuration.
· If a command has different settings in the running configuration and the configuration file, the rollback function replaces the running command setting with the setting in the configuration file.
The configuration archive function was developed to facilitate configuration rollback. This function enables the system to save the running configuration automatically at regular intervals.
Configuration task list
Tasks at a glance |
(Required.) Configuring configuration archive parameters |
(Required.) Perform either task: |
(Required.) Rolling back configuration |
Before archiving the running configuration, either manually or automatically, you must configure a file directory and file name prefix for configuration archives.
Configuration archives are saved with the file name format prefix_serial number.cfg, for example, 20080620archive_1.cfg and 20080620archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
After you change the file directory or file name prefix, or reboot the device, all of the following events occur:
· The old configuration archives are regarded as common configuration files.
· The configuration archive counter resets.
· The display archive configuration command no longer displays the old configuration archives.
· The serial number for new configuration archives starts at 1.
After the maximum number of configuration archives is reached, the system deletes the oldest archive to make room for the new archive.
Configuration guidelines
In standalone mode, the configuration archive function saves the running configuration only on the active MPU. In IRF mode, the function saves the running configuration only on the active MPU in the master device.
To make sure the system can archive the running configuration after an active/standby or master/subordinate switchover, create the configuration archive directory on all MPUs.
Configuration procedure
To configure configuration archive parameters:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the directory and file name prefix for archiving the running configuration. |
archive configuration location directory filename-prefix filename-prefix |
In standalone mode, do not include slot information in the directory name. In IRF mode, do not include member ID or slot information in the directory name. By default, no path or file name prefix is set for configuration archives, and the system does not regularly save configuration.
The undo form of this command disables both manual and automatic configuration archiving, restores the default settings for the archive configuration interval and archive configuration max commands, and deletes all saved configuration archives. |
3. (Optional.) Set the maximum number of configuration archives. |
archive configuration max file-number |
The default number is 5. Change the setting depending on the amount of storage available on the device. |
H3C recommends that you not delete configuration archives when the automatic configuration archiving is enabled. Otherwise, the rollback operation might fail.
Make sure you have set an archive path and file name prefix before performing this task.
To enable automatic configuration archiving:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable automatic configuration archiving and set the archiving interval. |
archive configuration interval minutes |
By default, this function is disabled. To view configuration archive names and their archiving time, use the display archive configuration command. |
To save system resources, disable automatic configuration archiving and manually archive the configuration if the configuration will not be changed very often. You can also manually archive configuration before performing complicated configuration tasks. Then, you can use the archive for configuration recovery if the configuration attempt fails.
Perform the following task in user view:
Task |
Command |
Manually archive the running configuration. |
archive configuration |
To ensure a successful rollback, follow these guidelines:
· Do not remove or install a card when the system is executing the configuration replace file command.
· Use the following types of configuration files to roll back configuration:
¡ Configuration file that was created on the local device by using the archive function or the save command.
¡ Configuration file that was created on another device and transferred to the local device.
Make sure the command lines in the configuration file are fully compatible with the local device.
· Make sure the replacement configuration file only contains hardware-consistency configurations. For example, if the replacement configuration file contains the configuration for a card that has been removed, the rollback process fails.
· The replacement configuration file is not encrypted.
To perform a configuration rollback:
Step |
Command |
Remarks |
system-view |
N/A |
2. Roll the running configuration back to the configuration defined by a configuration file. |
configuration replace file filename |
The specified configuration file must not be encrypted. |
The configuration rollback function might fail to reconfigure some commands in the running configuration for one of the following reasons:
· A command cannot be undone because prefixing the undo keyword to the command does not result in a valid undo command. For example, if the undo form designed for the A [B] C command is undo A C, the configuration rollback function cannot undo the A B C command. This is because the system does not recognize the undo A B C command.
· A command (for example, a hardware-dependent command) cannot be deleted, overwritten, or undone due to system restrictions.
· The commands in different views are dependent on each other.
· Commands or command settings that the device does not support cannot be added to the running configuration.
· The rollback operation does not take effect on the IRF settings. The IRF settings in the current running configuration continue to run after the rollback. For more information about IRF, see Virtual Technologies Command Reference.
CAUTION: In an IRF fabric, use the undo startup saved-configuration command with caution. This command can cause an IRF split after the IRF fabric or an IRF member reboots. |
You can execute the save [ safely ] [ backup | main ] [ force ] command to save the running configuration to a .cfg configuration file. The .cfg configuration file can be specified as both the main and backup next-startup configuration files.
Alternatively, you can execute the startup saved-configuration cfgfile [ backup | main ] command to specify a configuration file as the main or backup next-startup configuration file. Make sure the specified configuration file is valid and saved to the root directory of each MPU's default storage medium.
To specify a next-startup configuration file, perform the following task in user view:
Task |
Command |
Remarks |
Specify the next-startup configuration file. |
startup saved-configuration cfgfile [ backup | main ] |
By default, no next-startup configuration file is specified. Use the display startup command and the display saved-configuration command in any view to verify the configuration. If you specify neither the backup keyword nor the main keyword, this command sets the configuration file as the main next-startup configuration file. Even though the main and backup next-startup configuration files can be the same one, specify them as separate files for high availability. The undo startup saved-configuration command changes the attribute of the main or backup next-startup configuration file to NULL instead of deleting the file. |
Before backing up the main next-startup configuration file, make sure the following requirements are met:
· The server is reachable.
· The server is enabled with TFTP service.
· You have read and write permissions to the server.
To back up the main next-startup configuration file to a TFTP server:
Step |
Command |
Remarks |
1. (Optional.) Verify that a next-startup configuration file has been specified in user view. |
display startup |
If no next-startup configuration file has been specified, the backup operation will fail. |
2. Back up the next-startup configuration file to a TFTP server in user view. |
backup startup-configuration to dest-addr [ dest-filename ] |
This command is not supported in FIPS mode. |
To restore the main next-startup configuration file from a TFTP server, the device performs the following operations:
· Downloads a configuration file from a TFTP server to the root directory of the default storage medium on each MPU.
· Specifies the file as the main next-startup configuration file in one step.
Before restoring the next-startup configuration file, make sure the following requirements are met:
To restore the main next-startup configuration file from a TFTP server:
Step |
Command |
Remarks |
1. Restore the main next-startup configuration file from a TFTP server in user view. |
restore startup-configuration from src-addr src-filename |
This feature is not supported in FIPS mode. |
2. (Optional.) Verify that the specified configuration file has been set as the main next-startup configuration file. |
· display startup · display saved-configuration |
N/A |
CAUTION: This task permanently deletes the next-startup configuration file from each MPU. Before performing this task, back up the file as needed. |
Delete a next-startup configuration file if one of the following events occurs:
· After you upgrade system software, the file no longer matches the new system software.
· The file is corrupt or not fully compatible with the device.
If both the main and backup next-startup configuration files are deleted, the device uses factory defaults at the next startup.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specific file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
Task |
Command |
Remarks |
Delete next-startup configuration files. |
reset saved-configuration [ backup | main ] |
If neither backup nor main is specified, this command deletes the main next-startup configuration file. |
Task |
Command |
Display information about configuration rollback. |
display archive configuration |
Display the running configuration. |
display current-configuration [ configuration [ module-name ] | interface [ interface-type [ interface-number ] ] ] |
Display the factory defaults. |
display default-configuration |
Display the contents of the configuration file for the next system startup. |
Display the names of the configuration files for the current startup and the next startup. |
display startup |
Display the valid configuration in the current view. |
display this |
