H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration GuidesH3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
21-QoS Operation
21-QoS Operation 542.95 KB
Chapter 1  QoS Configuration
1.1  Overview
QoS (Quality of Service) is a concept generally existing in occasions with service supply and demand. It evaluates the ability to meet the need of the customers in service. Generally, the evaluation is not to grade precisely. Its purpose is to analyze the conditions where the service is the best and the conditions where the service still needs improvement and then to make improvements in the specified aspects.
In an internet, QoS evaluates the ability of the network to deliver packets. The evaluation on QoS can be based on different aspects because the network provides various services. Generally speaking, QoS is the evaluation on the service ability to support the core requirements such as delay, jitter, and packet loss ratio in the packet delivery.
1.1.1  Traffic
Traffic means service traffic; that is, all the packets passing the switch.
1.1.2  Traffic Classification
Traffic classification means identifying packets that conform to certain characteristics according to certain rules.
A classification rule is a filter rule configured to meet your management requirements. It can be very simple. For example, you can use a classification rule to identify traffic with different priorities according to the ToS field in the IP packet header. It can be very complicated too. For example, you can use a classification rule to identify the packets according to the combination of link layer (Layer 2), network layer (Layer 3), and transport layer (Layer 4) information including MAC addresses, IP protocols, source addresses, destination addresses, port numbers of applications, and so on.
Classification is generally based on the information in the packet header and rarely based on the packet contents.
1.1.3  Precedence
1)         IP precedence, ToS precedence, and DSCP precedence
Figure 1-1 DS field and TOS byte
The TOS field in an IP header contains eight bits:
l           The first three bits indicate IP precedence in the range of 0 to 7.
l           Bit 3 to bit 6 indicate ToS precedence in the range of 0 to 15.
l           RFC2474 re-defines the ToS field in the IP packet header, which is called the DS field. The first six (bit 0 to bit 5) bits of the DS field indicate DSCP precedence in the range of 0 to 63. The first three bits in DSCP precedence are class selector codepoints, bit 4 and bit 5 indicate drop precedence, and bit 6 is zero indicating that the device sets the service class with the DS model. The last two bits (bit 6 and bit 7) are reserved bits.
The precedence values of the IP packet indicate eight different service classes.
Table 1-1 Description on IP Precedence
IP Precedence (decimal)
IP Precedence (binary)
0
000
routine
1
001
priority
2
010
immediate
3
011
flash
4
100
flash-override
5
101
critical
6
110
internet
7
111
network
The Diff-Serv network defines four traffic classes:
l           Expedited Forwarding (EF) class: In this class, packets can be forwarded regardless of link share of other traffic. The class is suitable for preferential services with low delay, low packet loss ratio, low jitter, and assured bandwidth (such as virtual leased line);
l           Assured forwarding (AF) class: This class is further divided into four subclasses (AF1/2/3/4) and a subclass is further divided into three drop priorities, so the AF service level can be segmented. The QoS rank of the AF class is lower than that of the EF class;
l           Class selector (CS) class: This class comes from the IP TOS field and includes eight classes;
l           Best Effort (BE) class: This class is a special class without any assurance in the CS class. The AF class can be degraded to the BE class if it exceeds the limit. Current IP network traffic belongs to this class by default.
Table 1-2 Description on DSCP values
DSCP value (decimal)
DSCP value (binary)
46
101110
ef
10
001010
af11
12
001100
af12
14
001110
af13
18
010010
af21
20
010100
af22
22
010110
af23
26
011010
af31
28
011100
af32
30
011110
af33
34
100010
af41
36
100100
af42
38
100110
af43
8
001000
cs1
16
010000
cs2
24
011000
cs3
32
100000
cs4
40
101000
cs5
48
110000
cs6
56
111000
cs7
0
000000
default (be)
2)         802.1p priority
802.1p priority lies in Layer 2 packet headers and is applicable to occasions where the Layer 3 packet header does not need analysis but QoS must be assured at Layer 2.
Figure 1-2 An Ethernet frame with an 802.1Q tag header
As shown in the figure above, each host supporting 802.1Q protocol adds a 4-byte 802.1Q tag header after the source address of the former Ethernet frame header when sending packets.
The 4-byte 802.1Q tag header contains a 2-byte Tag Protocol Identifier (TPID) whose value is 8100 and a 2-byte Tag Control Information (TCI). TPID is a new class defined by IEEE to indicate a packet with an 802.1Q tag. Figure 1-3 describes the detailed contents of an 802.1Q tag header.
Figure 1-3 802.1Q tag headers
In the figure above, the 3-bit priority field in TCI is 802.1p priority in the range of 0 to 7. These three bits specify the precedence of the frame. Eight classes of precedence are used to determine which packet is sent preferentially when congestion occurs.
Table 1-3 Description on 802.1p priority
CoS (decimal)
CoS (binary)
0
000
best-effort
1
001
background
2
010
spare
3
011
excellent-effort
4
100
controlled-load
5
101
video
6
110
voice
7
111
network-management
The precedence is called 802.1p priority because the related applications of this precedence are defined in detail in the 802.1p specifications.
1.1.4  Priority of Protocol Packets
Protocol packets carry their own priority. You can perform QoS actions on protocol packets by setting their priorities.
1.1.5  Port Rate Limit
Port rate limit is port-based rate limit. It limits the total rate of outbound packets on a port.
1.1.6  Queue Scheduling Configuration Synchronization on Aggregated Ports
The feature of queue scheduling configuration synchronization on aggregated ports makes the queue scheduling configuration synchronous on each port of an aggregation group.
l           Supporting the feature of queue scheduling configuration synchronization on the ports in an aggregation group
When you modify or delete the queue scheduling mode in Ethernet port view, the queue scheduling modes of all the ports in the aggregation group are modified or deleted if this port belongs to an aggregation group; only the queue scheduling mode of this port is modified or deleted if this port does not belong to any aggregation group.
l           Dynamic aggregation supported by queue scheduling modes on ports
If the queue scheduling configuration information of some LACP-enabled ports in up state is the same, these ports can be aggregated into the same aggregation group.
l           Static aggregation or manual aggregation supported by queue scheduling modes on ports
You can add a queue-scheduling-enabled port into a specific static or manual aggregation group. This operation can be performed not only on the local device but also across devices in an intelligent resilient framework (IRF).
l           You can use the copy command to copy the queue scheduling configuration of a port.
&  Note:
For the introduction to the copy command, refer to the Basic Port Configuration Module in this manual.
1.1.7  Queue Scheduling
When the network is congested, the problem that many packets compete for resources must be solved, usually through queue scheduling.
In the following section, strict priority (SP) queueing and weighted round robin (WRR) queueing are introduced.
1)         SP queueing
Figure 1-4 Diagram for SP queueing
SP queue-scheduling algorithm is specially designed for critical service applications. An important feature of critical services is that they demand preferential service in congestion in order to reduce the response delay. Assume that there are eight output queues on the port and the preferential queue classifies the eight output queues on the port into eight classes, which are queue7, queue6, queue5, queue4, queue3, queue2, queue1, and queue0. Their priorities decrease in order.
In queue scheduling, SP sends packets in the queue with higher priority strictly following the priority order from high to low. When the queue with higher priority is empty, packets in the queue with lower priority are sent. You can put critical service packets into the queues with higher priority and put non-critical service (such as e-mail) packets into the queues with lower priority. In this case, critical service packets are sent preferentially and non-critical service packets are sent when critical service groups are not sent.
The disadvantage of SP queue is that: if there are packets in the queues with higher priority for a long time in congestion, the packets in the queues with lower priority will be “starved” because they are not served.
2)         WRR queueing
Figure 1-5 Diagram for WRR
WRR queue-scheduling algorithm schedules all the queues in turn and every queue can be assured of a certain service time. Assume there are eight priority queues on a port. WRR configures a weight value for each queue, which is w7, w6, w5, w4, w3, w2, w1, and w0. The weight value indicates the proportion of obtaining resources. On a 100 M port, configure the weight value of WRR queue-scheduling algorithm to 50, 50, 30, 30, 10, 10, 10, and 10 (corresponding to w7, w6, w5, w4, w3, w2, w1, and w0 in order). In this way, the queue with the lowest priority can get 5 Mbps bandwidth at least, and the disadvantage of SP queue-scheduling that the packets in queues with lower priority may not get service for a long time is avoided. Another advantage of WRR queue is that: though the queues are scheduled in order, the service time for each queue is not fixed; that is to say, if a queue is empty, the next queue will be scheduled. In this way, the bandwidth resources are made full use.
1.2  QoS Supported by S3100-52P
Table 1-4 QoS functions supported by S3100-52P and related commands
QoS
Specification
Related command
Priority mapping
Support only the mapping between 802.1p priority and local queues
qos cos-local-precedence-map
Port priority
Supported
priority priority-level
priority trust
Queue scheduling
Support SP and WRR
Support queue scheduling configuration synchronization on aggregated ports
queue-scheduler
Set the priority of protocol packets
Supported
protocol-priority
Set port rate limit
Supported
line-rate
1.3  Configuring the Mapping between 802.1p Priority and Queues
The mapping between the local precedence and the outbound queue is one-to-one. You can modify the mapping between the 802.1p priority and the outbound queue by modifying the mapping between the 802.1p priority and the local precedence.
I. Configuration prerequisites
You have understood the mapping between the 802.1p priority and the local precedence and the default mapping table.
II. Configuration procedure
Table 1-5 Configure the mapping table
Operation
Enter system view
Configure the COS-to-local-precedence mapping table
qos cos-local-precedence-map cos0-map-local-prec cos1-map-local-prec cos2-map-local-prec cos3-map-local-prec cos4-map-local-prec cos5-map-local-prec cos6-map-local-prec cos7-map-local-prec
Optional
Display the mapping table
display qos cos-local-precedence-map
Optional
You can execute the display command in any view
III. Configuration example
l           Configure the following 802.1p priority-to-local precedence mappings: 0 to 2, 1 to 3, 2 to 4, 3 to 1, 4 to 7, 5 to 0, 6 to 5, and 7 to 6.
l           Display the configuration results.
Configuration procedure:
<H3C> system-view
[H3C] qos cos-local-precedence-map 2 3 4 1 7 0 5 6
[H3C] dis qos cos-local-precedence-map
 cos-local-precedence-map:
            cos(802.1p) :      0     1     2     3     4     5     6     7
local precedence(queue) :      2     3     4     1     7     0     5     6
1.4  Setting to Use the Port Priority or Packet Priority
By default, the switch replaces the 802.1p priority of the received packet with the priority of the inbound interface, and then assigns local precedence to the packet according to the priority. In this case, you can set the port priority.
In addition, you can specify the switch to use the packet priority.
l           The priority trust mode is specified
l           The port whose priority is to be configured is specified
l           The priority value of the specified port is specified
Table 1-6 Set to use the port priority
Operation
Enter system view
Enter Ethernet port view
Set the port priority
Optional
By default, the port priority is 0
Table 1-7 Set to use the packet priority
Operation
Enter system view
Set the switch to use the packet priority
priority trust
Through this configuration, the switch uses the packet priority instead of the port priority
l           Set to use the port priority and specify the priority of Ethernet1/0/1 to 7.
<H3C> system-view
[H3C] interface Ethernet1/0/1
[H3C-Ethernet1/0/1] undo priority
[H3C-Ethernet1/0/1] priority 7
l           Set the switch to use the 802.1p priority carried in the packet on Ethernet1/0/1.
<H3C> system-view
[H3C-Ethernet1/0/1] priority trust
1.5  Setting the Precedence of Protocol Packet
The protocol packet carries its own precedence. You can modify the precedence of the protocol packet by setting its precedence. And then you can match the precedence with the corresponding QoS action to perform the corresponding QoS operation on the protocol packet.
1.5.1  Configuration Prerequisites
l           The type of protocol whose precedence needs modification is specified
l           The precedence value after modification is specified
1.5.2  Configuration Procedure
Table 1-8 Set the precedence of the protocol packet
Operation
Enter system view
protocol-priority protocol-type protocol-type { ip-precedence ip-precedence | dscp dscp-value }
Required
You can modify the IP precedence or DSCP precedence of the protocol packet
Only the precedence of TELNET, OSPF, SNMP, and ICMP protocol packets is supported currently
Display the precedence of the protocol packet
display protocol-priority
Optional
1.5.3  Configuration Example
l           Set the IP precedence of ICMP protocol packets to 3.
<H3C> system-view
[H3C] protocol-priority protocol-type icmp ip-precedence 3
[H3C] display protocol-priority
Protocol: icmp
  IP-Precedence: flash(3)
1.6  Configuring Port Rate Limit
1.6.1  Configuration Prerequisites
l           The ports on which rate limit is to be performed is specified
l           The target rate is specified
l           The direction of rate limit is specified
1.6.2  Configuration Procedure
Table 1-9 Configure port rate limit
Operation
Enter system view
Configure port-based rate limit
line-rate { inbound | outbound } target-rate
Required
l      target-rate: Total rate to limit packet sending and receiving on the port, in Kbps. The granularity of rate limit is 64 Kbps. If the number you input is in the range of N*64 to (N+1)*64 (N is a natural number), the switch will set the value to (N+1)*64 Kbps automatically
l      The rate range of 100 M Ethernet ports is from 64 to 99,968
l      The rate range of Gigabit Ethernet ports is in from 64 to 1,000,000
1.6.3  Configuration Example
l           Set rate limit in the outbound direction of Ethernet1/0/1 on the switch
l           The limit rate is 1 Mbps (1,024 Kbps)
<H3C> system-view
[H3C-Ethernet1/0/1] line-rate outbound 1024
1.7  Configuring Queue-Scheduling
Refer to section 1.1.7  "Queue Scheduling" for the introduction to queue scheduling.
1.7.1  Configuration Prerequisites
The queue-scheduling algorithm is specified: which queues adopt the WRR queue-scheduling algorithm, and which queues adopt the SP queue-scheduling algorithm.
1.7.2  Configuration Procedure
Table 1-10 Configure queue scheduling in system view
Operation
Enter system view
Configure the queue scheduling mode
queue-scheduler { strict-priority | wrr queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight }
Required
In WRR mode, if the weight value of one or more queues is set to 0, SP algorithm is used for this or these queues
By default, all the outbound queues on the port adopt the WRR queue scheduling algorithm and their default weight values are 1:2:3:4:5:9:13:15.
Display the queue-scheduling mode and related parameters on the switch
display queue-scheduler
Optional
You can execute the display command in any view.
Table 1-11 Configure queue scheduling in Ethernet port view
Operation
Enter system view
queue-scheduler  wrr queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight
Required
&  Note:
l      The queue scheduling algorithm defined by executing the queue-scheduler command in system view takes effect on all ports of the switch. The queue scheduling algorithm defined by executing the queue-scheduler command in Ethernet port view takes effect on the current port only. If the weight values  of the queues in the WRR queue scheduling algorithm defined globally cannot satisfy the requirement of a port, you can modify the weight values of the queues in Ethernet port view of this port. A new queue scheduling algorithm on this port will overwrite the globally defined queue weight value. You cannot use the display queue-scheduler command to display the queue weight defined in Ethernet port view.
l      If you have configured link aggregation groups, the queue scheduling algorithm defined on a port in an aggregation group will be synchronized to other ports in the aggregation group automatically.
1.7.3  Configuration Example
l           The switch adopts the WRR queue scheduling algorithm, and the weight values of outbound queues are 2, 2, 3, 3, 4, 4, 5, and 5, respectively;
l           Disable the applied queue scheduling mode. By default, all outbound queues on the port adopts the WRR queue scheduling algorithm and their default weight values are 1:2:3:4:5:9:13:15;
l           Query the configuration information.
<H3C> system-view
[H3C] queue-scheduler wrr 2 2 3 3 4 4 5 5
[H3C]display queue-scheduler
 Queue scheduling mode: weighted round robin
 weight of queue 0: 2
 weight of queue 1: 2
 weight of queue 2: 3
 weight of queue 3: 3
 weight of queue 4: 4
 weight of queue 5: 4
 weight of queue 6: 5
 weight of queue 7: 5
[H3C] undo queue-scheduler
[H3C] display queue-scheduler
weight of queue 0: 1
 weight of queue 3: 4
 weight of queue 4: 5
 weight of queue 5: 9
 weight of queue 6: 13
 weight of queue 7: 15
1.8  Displaying QOS Configuration
After finishing the configurations mentioned above, you can execute the display command in any view to check the running state of the QoS profile after the configuration. You can verify the effect of the configuration by checking the information on display.
Table 1-12 Display the QoS configuration
Operation
Display the configuration of protocol packet precedence
Display the Mapping between 802.1p Priority and Queues
Display all QoS configurations on a port or all ports
display qos-interface {interface-type interface-number | unit-id } all
Display the rate limit configuration
display qos-interface { interface-type interface-number | unit-id } line-rate
Display the global queue scheduling configuration
