H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration GuidesH3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
29-Information Center Operation
29-Information Center Operation 220.25 KB
Chapter 1  Information Center
1.1  Information Center Overview
An information center is an indispensable part of Ethernet switches and exists as an information hub of system software modules. The information center manages most information outputs; it sorts information carefully, and hence can screen information in an efficient way. Combined with the debugging program (debugging commands), it provides powerful support for network administrators and developers in network operation monitoring and fault diagnosis.
Information items output by S3100-52P switch is presented in the following format:
<priority>timestamp sysname module/level/digest:content
Here, angle brackets “<>”, spaces, slashes “/” and colon are the fixed format of information.
Below is an example of log output to a log host:
<188>Apr  9 17:28:50:524 2004 H3C IFNET/5/UPDOWN:Line protocol on the interface M-Ethernet0/0/0 is UP    (SIP=10.5.1.5 ,SP=1080)
The following describes the fields in front of the content field of an information item:
1)         Priority
The calculation formula for priority is priority = facility × 8 + severity – 1. For Comware, the default facility value is 23 and severity ranges from one to eight. See Table 1-2 for description of severity levels.
Note that no character is permitted between the priority and time stamp. The priority takes effect only when the information is sent to the log host.
2)         Time stamp
The time stamp sent to the log host is in the format of Mmm dd hh:mm:ss:ms yyyy, where:
“Mmm” represents the month, and the available values are: Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, and Dec.
“dd” is the date, which shall follow a space if less than 10, for example, “ 7”.
“hh:mm:ss:ms” is the local time, where “hh” is in the 24-hour format, ranging from 00 to 23, both “mm” and ”ss” range from 00 to 59, “ms” ranges from 000 to 999, and “yyyy” is the year.
Note that a space separates the time stamp and the host name.
3)         Host name
It refers to the system name of the host, which is “H3C” by default.
You can modify the host name with the sysname command. Refer to System Maintaining and Debugging part of the manual for detailed operations.
Note that a space separates the host name and module name.
4)         Module name
It indicates the modules that generate the information. The module name is in abbreviation form to indicate different modules. Table 1-1 lists all the modules.
Table 1-1 Examples of modules generating the information
Module name
8021X
802.1x module
ACL
Access control list module
ADBM
Address base module
AM
Access management module
ARP
Address resolution protocol module
CFAX
Configuration agent module
CFG
Configuration management plane module
CFM
Configuration file management module
CLST
Cluster management module
CMD
Command line module
COMMONSY
Common system MIB module
DEV
Device management module
DHCC
DHCP client module
DHCP
Dynamic host configuration protocol module
DHCPS
DHCP server module
DLDP
Device link detection protocol module
DNS
Domain name system module
DRV
Driver module
DRV_MNT
Driver management module
DTCT
IP network auto-detect module
ENTEXMIB
Entity extended MIB module
ESP
End-station polling module
ETH
Ethernet module
FIB
Forwarding module
FTM
Fabric topology management module
FTMCMD
Fabric topology management command module
FTPS
FTP server module
HA
High availability module
HABP
Huawei authentication bypass protocol module
HTTPD
HTTP server module
HWCM
Huawei Configuration Management private MIB module
HWP
HWPing module
IFNET
Interface management module
IGSP
IGMP snooping module
IP
Internet protocol module
IPC
Inter-process communication module
IPMC
IP multicast module
L2INF
Layer 2 interface management module
L4RDT
Layer 4 redirect module
LACL
Lanswitch access control list module
LAGG
Link aggregation module
LINE
Terminal line module
LQOS
Lanswitch quality of service module
LS
Local server module
MACAUTH
Centralized MAC authentication module
MPM
Multicast port management module
MSDP
Multicast source discovery protocol module
MSTP
Multiple spanning tree protocol module
MTRACE
Multicast traceroute query module
MULTICAS
MULTICAS module
NAT
Network address translation module
NDP
Neighbor discovery protocol module
NTDP
Network topology discovery protocol module
NTP
Network time protocol module
OSPF
Open shortest path first module
PKI
Public key infrastructure module
POE
Power over Ethernet module
PORTSEC
Port Security module
PPRDT
Protocol packet redirect module
PTVL
VLAN (Port VLAN) module
QACL
Quality of service / access control list module
QOSF
Traffic management module
RDS
Radius module
RESIL
Resilient ARP module
RM
Routing management module
RMON
Remote monitor module
RSA
Revest, Shamir and Adleman encryption module
RTPRO
Routing protocol module
SC
Server control module
SHELL
User interface module
SNMP
Simple network management protocol module
SOCKET
Socket module
SSH
Secure shell module
SYSMIB
System MIB module
TAC
HWTACACS module
TELNET
Telnet module
TFTPC
TFTP client module
UDPH
UDP helper module
VFS
Virtual file system module
VLAN
Virtual local area network module
VRRP
VRRP (virtual router redundancy protocol) module
VTY
VTY (virtual type terminal) module
WCN
Web management module
XM
Xmodem module
default
Default settings for all the modules
Note that a slash (/) separates the module name and severity level.
5)         Severity
Switch information falls into three categories: log information, debugging information and trap information. The information center classifies the information into eight levels by severity or emergency. The higher the information severity is, the lower the corresponding level is. For example, the “debugging” severity corresponds to level 8, and the “emergencies“ severity corresponds to level 1. If filtered by severity, the information of a severity level greater than the defined threshold will be filtered out for output. Therefore, when the severity threshold is set to “debugging”, all information will be output. See Table 1-2 for description of severities and corresponding levels.
Table 1-2 Severity definitions on the information center
Severity
Value
emergencies
1
The system is unavailable.
alerts
2
Errors that need to be corrected immediately
critical
3
Critical errors
errors
4
Common errors
warnings
5
Warnings
notifications
6
Normal information that needs to be noticed
informational
7
Normal prompt information
debugging
8
Debugging information
Note that a slash (/) separates the level and digest.
6)         Digest
It is a phrase within 32 characters, abstracting the information contents.
A colon (:) separates the digest and information contents.
&  Note:
The above section describes the log information format sent to a log server by a switch. Some log server software will resolve the received information as well as its format, so that you may see the log format displayed on the log server is different from the one described in this manual.
1.2  Information Center Configuration
The switch supports information output to six directions, and the system defaults to assign one information channel for each output direction, as shown in Table 1-3.
Table 1-3 Information channel names and numbers
Output direction
Channel number
Default channel name
Console
0
console
Monitor terminal
1
monitor
Log host
2
loghost
Trap buffer
3
trapbuffer
Log buffer
4
logbuffer
SNMP
5
snmpagent
&  Note:
Settings for the six output directions are independent. However, for any output direction, you must first enable the information center to make all other settings effective.
Information center of the Ethernet switch features:
l           Supporting six information output directions, namely, console (console), monitor terminal (monitor), log host (loghost), trap buffer (trapbuffer), log buffer (logbuffer) and SNMP (snmp agent).
l           Filtering information by severities (information is divided into eight severity levels).
l           Filtering information by modules where information is generated.
l           Language options (Chinese or English) for information output to a log host.
1.2.1  Enabling Synchronous Terminal Output
To prevent your input from being interrupted by system information output, you can enable the synchronous terminal output function, which echoes your input after each system output. This makes your work with ease, for you no longer worry about losing uncompleted inputs.
Table 1-4 Enable synchronous terminal output
Operation
Enter system view
info-center synchronous
Optional
By default, synchronous terminal output is disabled.
&  Note:
Running the info-center synchronous command during debugging information collection may result in a command prompt echoed after each item of debugging information. To avoid unnecessary output, you are recommended to disable synchronous terminal output in such cases.
1.2.2  Enabling Information Output to a Log Host
Table 1-5 lists the related configurations on the switch.
Table 1-5 Enable information output to a log host
Operation
Enter system view
Enable the information center
info-center enable
Optional
By default, the information center is enabled.
info-center loghost host-ip-addr [ channel { channel-number | channel-name } | facility local-number | language { chinese | english } ]*
Required
By default, the switch does not output information to the log host.
After you configure the switch to output information to the log host, the switch uses information channel 2 by default.
Be sure to set the correct IP address. A loopback IP address will cause an error message prompting that this address is invalid.
Configure the source interface through which log information is sent to the log host
Optional
Define an information source
info-center source { modu-name | default } channel { channel-number | channel-name } [ { log | trap | debug } { level severity | state state } ]*
Required
Set the format of the time stamp to be sent to the log host
info-center timestamp loghost { date | no-year-date | none }
Optional
&  Note:
1.2.3  Enabling Information Output to the Console
Table 1-6 lists the related configurations on the switch.
Table 1-6 Enable information output to the console
Operation
Enter system view
info-center enable
Optional
info-center console channel { channel-number | channel-name }
Required
By default, the switch uses information channel 0 to output log/debugging/trap information to the console.
Required
Set the format of time stamp
info-center timestamp { log | trap | debugging } { boot | date | none }
Optional
To view debugging/log/trap output information on the console, you should also enable the corresponding debugging/log/trap information terminal display on the switch.
For example, to view log information of the switch on the console, you should not only enable log information output to the console, but also enable log information terminal display with the terminal logging command.
Perform the following operations in user view.
Table 1-7 Enable debugging/log/trap terminal display
Operation
Enable the debugging/log/trap information terminal display function
terminal monitor
Optional
By default, this function is enabled for console users.
Enable debugging information terminal display function
terminal debugging
Optional
By default, the debugging information terminal display is disabled for terminal users.
Enable log information terminal display function
terminal logging
Optional
By default, log information terminal display is enabled for console users.
Enable trap information terminal display function
terminal trapping
Optional
By default, trap information terminal display is enabled for terminal users.
1.2.4  Enabling Information Output to a Monitor Terminal
Table 1-8 lists the related configurations on the switch.
Table 1-8 Enable information output to a monitor terminal
Operation
Enter system view
info-center enable
Optional
Enable information output to Telnet terminal or dumb terminal
info-center monitor channel { channel-number | channel-name }
Required
By default, a switch outputs log/debugging/trap information to user terminal through information channel 1.
Required
Optional
This is to set the time stamp format for log/debugging/trap information output.
This determines how the time stamp is presented to users.
&  Note:
l      When there are multiple Telnet users or dumb terminal users, they share some configuration parameters including module filter, language and severity level threshold. In this case, change to any such parameter made by one user will also be reflected on all other user terminals.
l      To view debugging information of specific modules, you need to set the information type as debug when defining the information source, and enable debugging for corresponding modules through the debugging command.
To view the debugging/log/trap output information on the monitor terminal, you should enable the corresponding debugging/log/trap display function on the switch.
For example, to view log information of the switch on a monitor terminal, you need to not only enable log information output to the monitor terminal, but also enable log information terminal display function with the terminal logging command.
Perform the following configuration in user view.
Table 1-9 Enable debugging/log/trap terminal display
Operation
terminal monitor
Optional
By default, this function is enabled for console user.
terminal debugging
Optional
By default, debugging information terminal display is disabled for terminal users.
terminal logging
Optional
terminal trapping
Optional
1.2.5  Enabling Information Output to the Log Buffer
Table 1-10 lists the related configurations on the switch.
Table 1-10 Enable information output to the log buffer
Operation
Enter system view
info-center enable
Optional
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ]*
Optional
By default, the switch uses information channel 4 to output log information to the log buffer, which can holds up to 512 items by default.
Required
Optional
&  Note:
To view debugging information of specific modules, you need to configure the information type as debug in the info-center source command, and enable debugging on corresponding modules with the debugging command as well.
1.2.6  Enabling Information Output to the Trap Buffer
Table 1-11 lists the related configurations on the switch.
Table 1-11 Enable information output to the trap buffer
Operation
Enter system view
info-center enable
Optional
info-center trapbuffer [channel { channel-number | channel-name } | size buffersize]*
Optional
By default, the switch uses information channel 3 to output trap information to the trap buffer, which can holds up to 256 items by default.
Required
Optional
&  Note:
To view debugging information of specific modules, you need to set the information type as debug in the info-center source command, and enable debugging on corresponding modules with the debugging command as well.
1.2.7  Enabling Information Output to the SNMP
Table 1-12 lists the related configurations on the switch.
Table 1-12 Enable information output to the SNMP
Operation
Enter system view
info-center enable
Optional
info-center snmp channel { channel-number | channel-name }
Required
By default, the switch outputs trap information to SNMP through channel 5.
Required
Optional
&  Note:
l      To view debug information of specific modules, you need to set the information type as debug in the info-center source command, and enable debugging on corresponding modules with the debugging command as well.
l      To send information to a remote SNMP workstation properly, related configurations are required on both the switch and the SNMP workstation.
1.3  Displaying and Debugging Information Center
After the above configurations, you can execute the display command in any view to display the running status of the information center, and thus validating your configurations. You can also execute the reset command in user view to clear the information in the log buffer and trap buffer.
Table 1-13 Display and debug information center
Operation
Display information on an information channel
display channel [ channel-number | channel-name ]
The display command can be executed in any view
Display the operation status of information center, the configuration of information channels, the format of time stamp and the information output in case of fabric
display info-center [ unit unit-id ]
Display the status of log buffer and the information recorded in log buffer
display logbuffer [ unit unit-id ] [ level severity | size buffersize ]* [ | { begin | exclude | include } regular-expression ]
Display the summary information recorded in log buffer
display logbuffer summary [ level severity ]
Display the status of trap buffer and the information recorded in trap buffer
display trapbuffer [ unit unit-id ] [ size buffersize ]
Clear information recorded in log buffer
reset logbuffer [ unit unit-id ]
The reset command can be executed in user view
Clear information recorded in trap buffer
reset trapbuffer [ unit unit-id ]
1.4  Information Center Configuration Examples
1.4.1  Log Output to a UNIX Log Host
I. Network requirements
The switch sends the following log information in English to the UNIX log host whose IP address is 202.38.1.10: the log information of the two modules ARP and IP, with severity higher than “informational”.
II. Network diagram
Figure 1-1 Network diagram for log output to a Unix log host
III. Configuration procedure
1)         Configure the switch:
# Enable the information center.
<H3C> system-view
[H3C] info-center enable
# Disable the function of outputting information to log host channels.
[H3C] undo info-center source default channel loghost
# Configure the host whose IP address is 202.38.1.10 as the log host. Set the output language to English. Permit ARP and IP modules to output information with severity level higher than informational to the log host.
[H3C] info-center loghost 202.38.1.10 facility local4 language english
[H3C] info-center source arp channel loghost log level informational debug state off trap state off
[H3C] info-center source ip channel loghost log level informational debug state off trap state off
2)         Configure the log host:
The operations here are performed on SunOS 4.0. The operations on other manufacturers' UNIX operation systems are similar.
Step 1: Execute the following commands as the super user (root user).
# mkdir /var/log/H3C
# touch /var/log/H3C/information
Step 2: Edit the file “/etc/syslog.conf” as the super user (root user) to add the following selector/action pairs.
# H3C configuration messages
local4.info    /var/log/H3C/information
&  Note:
When you edit the file “/etc/syslog.conf”, note that:
l      A note must start in a new line, starting with a “#” sign.
l      In each pair, a tab should be used as a separator instead of a space.
l      No space is allowed at the end of a file name.
l      The facility and received log information severity level specified in the file “/etc/syslog.conf” must be the same as those corresponding parameters configured in the commands info-center loghost and info-center source. Otherwise, log information may not be output to the log host normally.
Step 3: After the log file “information” is created and the file “/etc/syslog.conf” is modified, execute the following command to send a HUP signal to the system daemon “syslogd”, so that it can read its new configuration file “/etc/syslog.conf”.
# ps -ae | grep syslogd
147
# kill -HUP 147
After all the above operations, the switch can make records in the corresponding log file.
&  Note:
Through combined configuration of the device name (facility), information severity level threshold (severity), module name (filter) and the file “syslog.conf”, you can sort information precisely for filtering.
1.4.2  Log Output to a Linux Log Host
The switch sends the following log information in English to the Linux log host whose IP address is 202.38.1.10: All modules' log information, with severity higher than “errors”.
II. Network diagram
Figure 1-2 Network diagram for log output to a Linux log host
<H3C> system-view
# Configure the host whose IP address is 202.38.1.10 as the log host. Set the output language to English. Permit all modules to output information with severity level higher than error to the log host.
[H3C] info-center loghost 202.38.1.10 facility local7 language english
[H3C] info-center source default channel loghost log level errors debug state off trap state off
Step 1: Execute the following commands as a super user (root user).
local7.info    /var/log/H3C/information
&  Note:
Note the following items when you edit file “/etc/syslog.conf”.
l      A note must start in a new line, starting with a “#" sign.
l      No space is permitted at the end of the file name.
l      The facility and received log information severity specified in file “/etc/syslog.conf” must be the same with those corresponding parameters configured in commands info-center loghost and info-center source. Otherwise, log information may not be output to the log host normally.
Step 3: After the log file “information” is created and the file “/etc/syslog.conf” is modified, execute the following commands to view the process ID of the system daemon “syslogd”, stop the process, and then restart the daemon "syslogd" in the background with the “-r” option.
147
# kill -9 147
# syslogd -r &
&  Note:
In case of Linux log host, the daemon “syslogd” must be started with the “-r” option.
After all the above operations, the switch can record information in the corresponding log file.
&  Note:
1.4.3  Log Output to the Console
The switch sends the following information to the console: the log information of the two modules ARP and IP, with severity higher than “informational”.
II. Network diagram
Figure 1-3 Network diagram for log output to the console
<H3C> system-view
# Disable the function of outputting information to the console channels.
[H3C] undo info-center source default channel console
# Enable log information output to the console. Permit ARP and IP modules to output information with severity level higher than informational to the console.
[H3C] info-center console channel console
[H3C] info-center source arp channel console log level informational debug state off trap state off
[H3C] info-center source ip channel console log level informational debug state off trap state off
# Enable terminal display.
<H3C> terminal monitor
<H3C> terminal logging
