H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration GuidesH3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
22-Mirroring Operation
22-Mirroring Operation 232.05 KB
Chapter 1  Mirroring Configuration
1.1  Mirroring Overview
Mirroring refers to the process of copying packets that meet the specified rules to a destination port. Generally, a destination port is connected to a data detect device, which users can use to analyze the mirrored packets for monitoring and troubleshooting the network.
Figure 1-1 Mirroring
1.1.1  Port Mirroring
Port mirroring refers to the process of copying the packets received or sent by the specified port to the destination port.
1.1.2  Remote Port Mirroring — RSPAN
Remote switched port analyzer (RSPAN) refers to remote port mirroring. It eliminates the limitation that the source port and the destination port must be located on the same switch. This feature makes it possible for the source port and the destination port to be located across several devices in the network, and facilitates the network administrator to manage remote switches.
The application of RSPAN is illustrated in the following figure:
Figure 1-2 RSPAN application
There are three types of switches with the RSPAN enabled.
l           Source switch: The monitored port resident switch. Through Layer 2 forwarding, it sends traffics to be mirrored to an intermediate switch or destination switch over the remote-probe VLAN.
l           Intermediate switch: Switches between the source switch and destination switch on the network. An intermediate switch forwards mirrored traffic flows to the next intermediate switch or the destination switch. Circumstances can occur where no intermediate switch is present, if a direct connection exists between the source and destination switches.
l           Destination switch: The remote mirroring destination port resident switch. It forwards mirrored traffic flows it received from the remote-probe VLAN to the monitoring device through the destination port.
Table 1-1 describes how the ports on various switches are involved in the mirroring operation.
Table 1-1 Ports involved in the mirroring operation
Switch
Ports involved
Function
Source switch
Source port
Port monitored. It copies user data packets to the specified reflector port through local port mirroring. There can be more than one source port.
Reflector port
Receives user data packets that are mirrored on a local port.
Trunk port
Sends mirrored packets to the intermediate switch or the destination switch.
Intermediate switch
Trunk port
Sends mirrored packets to the destination switch.
Two Trunk ports are necessary for the intermediate switch to connect the devices at the source switch side and the destination switch side.
Destination switch
Trunk port
Receives remote mirrored packets.
Destination port
Monitors remote mirrored packets
To implement remote port mirroring, you need to define a special VLAN, called remote-probe VLAN, on a switch. All mirrored packets will be transferred from the source switch to the destination ports of the destination switch through this VLAN. Thus, the destination switch can monitor the port packets sent from the ports of the source switch. Remote-probe VLAN requires that:
l           All ports connecting the devices in remote-probe VLAN are configured as the trunk ports.
l           The default VLAN and management VLAN cannot be configured as remote-probe VLAN.
l           Layer 2 interoperability must be ensured by configuration between the source and destination switches over the remote-probe VLAN.
  Caution:
To ensure the normal packet mirroring, it is not recommended to perform any of the following operations on the remote-probe VLAN:
l      Configuring a source port to the remote-probe VLAN that is used by the local mirroring group;
l      Configuring a Layer 3 interface for the remote-probe VLAN;
l      Configuring to run other protocol packets, or bear other service packets;
l      Using remote-probe VLAN as a special type of VLAN, such as voice VLAN or protocol VLAN;
l      Configuring other VLAN-related functions.
1.2  Mirroring Configuration
For mirroring features, see section 1.1   "Mirroring Overview".
1.2.1  Configuring Port Mirroring
I. Configuration prerequisites
l           The source port is determined and whether the packets to be mirrored are inbound, outbound or both inbound and outbound is specified. Inbound means only to mirror the packets received by the port; outbound means only to mirror the packets sent by the port; both means to mirror the packets received and sent by the port.
l           The destination port is determined.
l           The mirroring group number is determined.
II. Configuring port mirroring in Ethernet port view
Table 1-2 Configure port mirroring in Ethernet port view (1)
Operation
Enter system view
Create a port mirroring group
mirroring-group group-id local
Required
Enter Ethernet port view of the determined destination port
Define the current port as the destination port
monitor-port
Required
LACP and TCP must be disabled on the destination port.
Exit current view
Enter Ethernet port view of the determined source port
Define the current port as the source port and specify the direction of the packets to be mirrored
mirroring-port { inbound | outbound | both }
Required
Display the mirroring parameter settings
display mirroring-group { all | local }
Optional
This command can be executed in any view.
&  Note:
If you specify the destination port and source port in Ethernet port view without creating a port mirroring group, mirroring group 1 will be created automatically.
Table 1-3 Configure port mirroring in Ethernet port view (2)
Operation
Enter system view
Required
mirroring-group group-id monitor-port
Required
Exit current view
mirroring-group group-id mirroring-port { both | inbound | outbound }
Required
Required
III. Configuring port mirroring in system view
Table 1-4 Configure port mirroring in system view
Operation
Enter system view
Required
Define the determined destination port
mirroring-group group-id monitor-port monitor-port
Required
Define the determined source port and specify the direction of the packets to be mirrored
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
Required
Optional
&  Note:
l      Configurations listed in Table 1-2 do not involve specifying a mirroring group. Therefore these mirroring settings made in Ethernet port view applies to mirroring group 1 only.
l      Configurations listed in Table 1-3 can be used to add mirroring settings for any defined mirroring group in Ethernet port view.
l      Configurations listed in Table 1-4 are performed in system view. Therefore the mirroring group ID and port number must be specified.
IV. Configuration Example
Network requirements:
l           The source port is GigabitEthernet 1/1/1. All packets received and sent by this port are to be mirrored.
l           The destination port is GigabitEthernet 1/1/4.
Configuration procedure 1:
<H3C> system-view
[H3C] mirroring-group 1 local
[H3C] interface gigabitEthernet 1/1/4
[H3C-GigabitEthernet1/1/4] monitor-port
[H3C-GigabitEthernet1/1/4] quit
[H3C] interface gigabitEthernet 1/1/1
[H3C-GigabitEthernet1/1/1] mirroring-port both
Configuration procedure 2:
<H3C> system-view
[H3C] interface GigabitEthernet 1/1/4
[H3C-GigabitEthernet1/1/4] mirroring-group 1 monitor-port
[H3C] interface GigabitEthernet 1/1/1
[H3C-GigabitEthernet1/1/1] mirroring-group 1 mirroring-port both
Configuration procedure 3:
<H3C> system-view
[H3C] mirroring-group 1 monitor-port GigabitEthernet 1/1/4
[H3C] mirroring-group 1 mirroring-port GigabitEthernet 1/1/1 both
1.2.2  Configuring RSPAN
l           The source switch, intermediate switch, and the destination switch are determined.
l           The source port, the reflector port, the destination port, and the remote-probe VLAN are determined.
l           Layer 2 interoperability is ensured by configuration between the source and destination switches over the remote-probe VLAN
l           The direction of the packets to be monitored is determined.
l           The remote-probe VLAN is enabled.
II. Configuring RSPAN on the source switch
Table 1-5 Configure RSPAN on the source switch
Operation
Enter system view
Create a VLAN and enter the VLAN view
vlan vlan-id
vlan-id is the ID of the remote-probe VLAN to be defined.
Define the current VLAN as the remote-probe VLAN
remote-probe vlan enable
Required
Exit the current view
Enter the port view of the port that connects to the intermediate switch or destination switch
Configure the current port as Trunk port
port link-type trunk
Required
By default, the port type is Access.
Configure Trunk port to permit packets from the remote-probe VLAN
port trunk permit vlan remote-probe-vlan-id
Required
This setting is required for the source switch port that connects to the intermediate switch or destination switch.
Exit current view
Configure a remote source mirroring group
mirroring-group group-id remote-source
Required
Configure a source port for remote mirroring
Required
Configure a remote reflector port
mirroring-group group-id reflector-port reflector-port
Required
The remote reflector port must be of the Access type. LACP and STP must be disabled on this port.
After a port is configured as a reflector port, the switch does not allow you to perform any of the following configurations:
l      Changing the port type or its default VLAN ID
l      Add the port to another VLAN
Configure the remote-probe VLAN for the remote source mirroring group
mirroring-group group-id remote-probe vlan remote-probe-vlan-id
Required
Display the configuration of the remote source mirroring group
display mirroring-group remote-source
Optional
&  Note:
l      To mirror tagged packets, you need to configure VLAN VPN on the reflector port.
l      The reflector port cannot forward traffics as a normal port. In this scenario, it is recommended that you use an idle and down port as the reflector port, and do not perform other configuration on this port.
l      If the mac-address max-mac-count 0 command is executed on a port in a VLAN, it is recommended not to configure this VLAN as the remote-probe VLAN. Otherwise, remote mirroring may not work properly.
l      Do not configure a port connecting the intermediate switch or destination switch as the mirroring source port. Otherwise, traffic disorder may occur in the network.
III. Configuring RSPAN on the intermediate switch
Table 1-6 Configure RSPAN on the intermediate switch
Operation
Enter system view
Create a VLAN and enter VLAN view
vlan vlan-id
Define the current VLAN as a remote-probe VLAN
Required
Enter Ethernet port view of the port connecting to the source switch, destination switch or other intermediate switch
Required
Required
This configuration is necessary for ports on the intermediate switch that are connected to the source switch, the destination switch or other intermediate switch.
IV. Configuring RSPAN on the destination switch
Table 1-7 Configure RSPAN on the destination switch
Operation
Enter system view
vlan vlan-id
Required
Enter Ethernet port view of the port connecting to the source switch or an intermediate switch
Required
Required
This configuration is necessary for ports through which the destination switch is connected to the source switch or an intermediate switch.
Configure a remote destination mirroring group
mirroring-group group-id remote-destination
Required
Configure the destination port for remote mirroring
Required
The destination port for remote mirroring must be of the Access type. LACP and STP must be disabled on this port.
After you configure a port as the destination port for remote mirroring, the switch does not allow you to change the port type or its default VLAN ID.
Configure the remote-probe VLAN for the remote destination mirroring group
Required
Display the configuration of the remote destination mirroring group
display mirroring-group remote-destination
Optional
&  Note:
V. Configuration example
l           Switch A is connected to the data detect device through GigabitEthernet 1/1/2.
l           GigabitEthernet 1/1/1, the Trunk port of Switch A, is connected to GigabitEthernet 1/1/1, the Trunk port of Switch B.
l           GigabitEthernet 1/1/2, the Trunk port of Switch B, is connected to GigabitEthernet 1/1/1, the Trunk port of Switch C.
l           GigabitEthernet 1/1/2, the port of Switch C, is connected to PC1.
The purpose is to use the data detect device to monitor and analyze the packets sent by PC1.
To meet the above purpose by using the RSPAN function, perform the following configuration:
l           Define VLAN10 as the remote-probe VLAN.
l           Define Switch A as the destination switch; configure GigabitEthernet 1/1/2, the port that is connected to the data detect device, as the destination port for remote mirroring. Set GigabitEthernet1/1/2 to an Access port, with STP and LACP functions disabled.
l           Define Switch B as the intermediate switch.
l           Define Switch C as the source switch, GigabitEthernet 1/1/2 as the source port for remote mirroring, and GigabitEthernet 1/1/3 as the reflector port. Set GigabitEthernet 1/1/3 to an Access port, with STP and LACP disabled.
Network diagram:
Figure 1-3 Network diagram for RSPAN
Configuration procedure:
# Configure Switch C.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] remote-probe vlan enable
[H3C-vlan10] quit
[H3C-GigabitEthernet1/1/1] port link-type trunk
[H3C-GigabitEthernet1/1/1] port trunk permit vlan 10
[H3C-GigabitEthernet1/1/1] quit
[H3C] mirroring-group 1 remote-source
[H3C] mirroring-group 1 mirroring-port GigabitEthernet 1/1/2 inbound
[H3C] mirroring-group 1 reflector-port GigabitEthernet 1/1/3
[H3C] mirroring-group 1 remote-probe vlan 10
[H3C] display mirroring-group remote-source
mirroring-group 1:
    type: remote-source
    status: active
    mirroring port:
        GigabitEthernet1/1/2  outbound
    reflector port: GigabitEthernet1/1/3
    remote-probe vlan: 10
# Configure Switch B.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C] interface GigabitEthernet 1/1/2
[H3C-GigabitEthernet1/1/2] port link-type trunk
[H3C-GigabitEthernet1/1/2] port trunk permit vlan 10
# Configure Switch A.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C] mirroring-group 1 remote-destination
[H3C] mirroring-group 1 monitor-port GigabitEthernet 1/1/2
[H3C] display mirroring-group remote-destination
mirroring-group 1:
    type: remote-destination
    status: active
    monitor port: GigabitEthernet1/1/2
1.3  Displaying Mirroring Parameter Settings
After the above configuration, you can use the display command in any view to view the mirroring running information, so as to verify the configurations you made.
Table 1-8 Display mirroring parameter settings
Operation
Display parameter settings of a mirroring group
display mirroring-group { group-id | all | local | remote-destination | remote-source }
The command can be executed in any view.
