H3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
34-VLAN-VPN Commands
34-VLAN-VPN Commands 88.32 KB
VLAN-VPN Configuration Commands
display port vlan-vpn
View
None
Use the display port vlan-vpn command to display the information about VLAN-VPN configuration of the current system.
Related commands: vlan-vpn enable, vlan-vpn inner-cos-trust, vlan-vpn tpid.
# Display the VLAN-VPN configuration of the current system.
<Sysname> display port vlan-vpn
VLAN-VPN TPID: 8200
Ethernet1/0/1
 VLAN-VPN status: enabled
 VLAN-VPN VLAN: 1
Ethernet1/0/5
 VLAN-VPN VLAN: 1
Table 1-1 Description on the fields of the display port vlan-vpn command
VLAN-VPN TPID
Global TPID value
Ethernet1/0/1
The port with the VLAN VPN feature enabled
VLAN-VPN status
The operation status of the VLAN VPN feature on the port
VLAN-VPN VLAN
The VLAN corresponding to the tag that the port tags packets with, that is, the default VLAN of the port
vlan-vpn enable
vlan-vpn enable
undo vlan-vpn
View
Ethernet port view
None
Use the vlan-vpn enable command to enable the VLAN-VPN feature for a port.
Use the undo vlan-vpn command to disable the VLAN-VPN feature for a port.
By default, the VLAN-VPN feature is disabled.
With the VLAN-VPN feature enabled, a received packet is tagged with the default VLAN tag of the receiving port no matter whether or not the packet already carries a VLAN tag.
l          If the packet already carries a VLAN tag, the packet becomes a dual-tagged packet.
l          Otherwise, the packet becomes a packet carrying the default VLAN tag of the port.
You can use the display port vlan-vpn command to display the configuration information of VLAN-VPN on the ports to verity your configuration.
After the VLAN-VPN function is enabled, you can use the vlan-vpn vid command and the raw-vlan-id inbound command to configure the selective QinQ function. Refer to Selective QinQ Configuration Commands for details.
# Enable the VLAN-VPN feature for Ethernet 1/0/1 port.
[Sysname-Ethernet1/0/1] vlan-vpn enable
vlan-vpn tpid
This command is available to only S3100-EI series Ethernet switches.
vlan-vpn tpid value
undo vlan-vpn tpid
View
value: User-defined TPID value (in hexadecimal format), in the range 0x0001 to 0xFFFF.
Use the vlan-vpn tpid command to set the global TPID value. With the TPID value set , the port fills the value to the TPID field of the outer tag to be added for a packet and, upon receiving a packet, compares the TPID value with the TPID field of the packet to determine whether the packet carries a VLAN tag or not.
Use the undo vlan-vpn tpid command to restore the default TPID value.
The default TPID value is 0x8100.
For the position and function of the TPID field in a packet, refer to VLAN Operation.
The TPID field in an Ethernet frame has the same position with the protocol type field in a frame without a VLAN tag. To prevent other devices in the network from recognizing the tag-encapsulated packets of the current switch as protocol packets, you are not allowed to set the TPID value to any of the values in the table below.
Table 1-2 Common Ethernet frame protocol type values
Protocol type
Value
ARP
0x0806
IP
0x0800
MPLS
0x8847/0x8848
IPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1x
0x888E
# Set the global TPID value to 0x9100.
[Sysname] vlan-vpn tpid 9100
This chapter is only applicable to S3100-EI series switches.
raw-vlan-id inbound
raw-vlan-id inbound vlan-id-list
undo raw-vlan-id inbound { all | vlan-id-list }
View
QinQ view
vlan-id-list: Lists of VLAN IDs. After receiving packets of these VLANs, the switch will encapsulate the packets with the specified outer VLAN tag. You need to provide this argument in the form of { vlan-id [ to vlan-id ] }&<1-10>, where the VLAN ID after the to keyword must be larger than or equal to the VLAN ID before the to keyword and &<1-10> means that you can specify up to 10 VLANs/VLAN ranges for this argument.
all: Removes all configurations of encapsulating an outer VLAN tag for specified inner VLANs in the current view.
Use the raw-vlan-id inbound command to specify to encapsulate packets with the specified inner VLAN tags with the specified outer tag. This command must be configured on ports connecting the user network.
Use the undo raw-vlan-id inbound command to remove the configuration.
By default, the switch does not encapsulate packets with any outer VLAN tag.
A packet cannot be tagged with different outer VLAN tags. To change the outer VLAN tag of a packet, you need to remove the existing outer VLAN tag configuration and configure a new outer VLAN tag.
Before configuring this command in QinQ view, you need to use the vlan-vpn vid command to configure the outer VLAN tag to be used in the selective QinQ policy.
Related commands: vlan-vpn vid.
# Configure Switch to add the tag of VLAN 20 as the outer tag to packets with their inner VLAN IDs being 8 through 15.
[Sysname] vlan-vpn vid 20
[Sysname-vid-20] raw-vlan-id inbound 8 to 15
vlan-vpn vid
vlan-vpn vid vlan-id
undo vlan-vpn vid vlan-id
View
vlan-id: VLAN ID, in the range 1 to 4094.
Use the vlan-vpn vid command to configure the outer VLAN tag for a selective QinQ policy (that is, the outer VLAN tag to be used by a port to encapsulate received packets) and to enter QinQ view.
Use the undo vlan-vpn vid command to remove the configured outer VLAN tag. Note that this command will also remove all configurations configured by the raw-vlan-id inbound command in QinQ view.
By default, no selective QinQ policy is configured on a port.
After specifying an outer VLAN tag and enter QinQ view, you need to use the raw-vlan-id inbound command to specify which VLANs’ packets will be encapsulated with the specified outer VLAN tag. Otherwise, the configuration of the outer VLAN tag is of no use.
Related commands: raw-vlan-id inbound.
# Specify to add VLAN 20 tag as the outer tags to the packets with their inner VLAN IDs being 2 through 14.
[Sysname-vid-20] raw-vlan-id inbound 2 to 14
vlan-vpn selective enable
undo vlan-vpn selective enable
View
Ethernet port view
Parameter
None
Use the vlan-vpn selective enable command to enable the selective QinQ feature on a port. With the selective QinQ feature enabled, packets carrying specific inner VLAN tags are tagged with specific outer VLAN tags according to the VLAN tag mapping rules defined.
Use the undo vlan-vpn selective enable command to disable the selective QinQ feature.
By default, the selective QinQ feature is disabled on a port.
Related commands: vlan-vpn vid, raw-vlan-id inbound.
Example
# Enable the selective QinQ feature on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] vlan-vpn selective enable
VLAN Mapping Configuration Commands
vlan-mapping
vlan-mapping vlan old-vlan-id remark new-vlan-id
undo vlan-mapping vlan old-vlan-id
View
System view, Ethernet port view
Parameter
vlan old-vlan-id: Specifies the source VLAN ID for VLAN mapping. The old-vlan-id argument is in the range of 1 to 4094.
remark new-vlan-id: Specifies the target VLAN ID for VLAN mapping. The new-vlan-id argument is in the range of 1 to 4094.
Use the vlan-mapping command in system view to define a global VLAN mapping rule. A VLAN mapping rule maps the VLAN tag of a specific VLAN carried in packets to another one.
Use the vlan-mapping command in Ethernet port view to define a VLAN mapping rule for the current port and enable the VLAN mapping function for the port.
Use the undo vlan-mapping command in system view to invalidate a VLAN mapping rule.
Use the undo vlan-mapping command in Ethernet port view to invalidate a VLAN mapping rule and disable the VLAN mapping function on the current port.
By default, no global VLAN mapping rule or port-level VLAN mapping rule is defined.
l          A port that is in a link aggregation port group cannot have the VLAN Mapping feature enabled.
l          The VLAN mapping function and the protocol-based VLAN function are mutually exclusive on the same port.
l          To modify a VLAN mapping relationship, you need to delete the corresponding VLAN mapping rule and then define a new one.
l          With a global VLAN mapping rule defined in system view, you cannot define any VLAN mapping rules in Ethernet port view.
Related commands: vlan-mapping enable.
Example
# Define a VLAN mapping rule on Ethernet 1/0/1 to map VLAN 100 to VLAN 200.
[Sysname-Ethernet1/0/1]vlan-mapping vlan 100 remark 200
vlan-mapping enable
vlan-mapping enable
undo vlan-mapping enable
View
Ethernet port view
Parameter
None
Use the vlan-mapping enable command to enable the VLAN mapping function on a port based on global VLAN mapping rules.
Use the undo vlan-mapping enable command to disable the VLAN mapping function on a port.
By default, the VLAN mapping function is disabled.
l          With port-based VLAN mapping rules configured for a port, the VLAN mapping function is enabled on the port at the same time. In this case, the vlan-mapping enable command cannot be used to enable the VLAN mapping function again.
Related command: vlan-mapping.
Example
# Enable the VLAN mapping function on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] vlan-mapping enable
This chapter is only applicable to the S3100-EI series Ethernet switches.
BPDU Tunnel Configuration Commands
bpdu-tunnel
bpdu-tunnel protocol-type
undo bpdu-tunnel { protocol-type | all }
View
Ethernet port view
protocol-type: Protocol type, packets of which will be transmitted through a BPDU tunnel, This argument can be a keyword listed in Table 4-1.
Table 4-1 Description on the protocol-name argument
Value
cdp
Enable/Disable BPDU tunnel for CISCO discovery protocol (CDP).
hgmp
Enable/Disable BPDU tunnel for Huawei group management protocol (HGMP) related protocols, including neighbor discovery protocol (NDP), neighbor topology discovery protocol, cluster member remote control (MRC), and Huawei authentication bypass protocol (HABP).
lacp
Enable/Disable BPDU tunnel for link aggregation control protocol (LACP).
pagp
Enable/Disable BPDU tunnel for port aggregation protocol (PAGP).
pvst
Enable/Disable BPDU tunnel for per-VLAN spanning tree (PVST).
stp
Enable/Disable BPDU tunnel for spanning tree protocol (STP).
vtp
Enable/Disable BPDU tunnel for VLAN trunk protocol (VTP).
udld
Enable/Disable BPDU tunnel for uni-directional link direction (UDLD).
all: Disables BPDU tunnel for all protocol packets.
Use the bpdu-tunnel command to enable BPDU tunnel on a port, so that packets of the specified protocol will be transparently transmitted through the BPDU tunnel on the port.
Use the undo bpdu-tunnel command to disable BPDU tunnel on a port.
By default, BPDU tunnel is disabled on a port.
After you enable a port to transmit packets of a specified protocol type through the BPDU tunnel, when the port receives such a packet, it will use the specified private multicast MAC address to replace the original destination MAC address of the packet before sending it. As a result, the packet will not be recognized as a protocol packet by other devices in the operator network during transmission. In this way, transparent transmission is implemented.
You can use the bpdu-tunnel tunnel-dmac command to change the destination MAC addresses of protocol packets to a specified multicast MAC address.
l          If this command is enabled on a port for a specific protocol, the specific protocol cannot be enabled on the port. For example, if you have configured the bpdu-tunnel lacp command, the lacp enable command cannot be enabled on the port.
l          The commands configured for service provider’s devices at both ends of a BPDU tunnel must be consistent. Otherwise, BPDU packets of the customer network cannot be transparently transmitted properly.
# Enable BPDU tunnel for packets of LACP.
[Sysname-Ethernet1/0/1] bpdu-tunnel lacp
bpdu-tunnel tunnel-dmac mac-address
undo bpdu-tunnel tunnel-dmac
View
mac-address: Destination MAC address to be assigned to the protocol packets transmitted along a BPDU tunnel. This argument must be a multicast MAC address.
Use the bpdu-tunnel tunnel-dmac command to configure the destination MAC address for protocol packets transmitted along a BPDU tunnel.
Use the undo bpdu-tunnel tunnel-dmac command to restore the default destination MAC address.
By default, the destination MAC address for protocol packets transmitted along a BPDU tunnel is 010f-e200-0003.
l          To prevent the devices in the service provider network from processing the tunnel packets as other protocol packets, the MAC address for tunnel packets must be a multicast address specially for BPDU tunnels in the service provider network.
l          The destination MAC addresses configured at the two ends of a BPDU tunnel must be the same; otherwise, the protocol packets cannot be transmitted and forwarded normally.
Related commands: display bpdu-tunnel.
# Set the destination MAC address for protocol packets transmitted along BPDU tunnels to 010f-e266-c3ab.
[Sysname] bpdu-tunnel tunnel-dmac 010f-e266-c3ab
display bpdu-tunnel
display bpdu-tunnel
View
None
Use the display bpdu-tunnel command to display the private multicast MAC address configured for protocol packets transmitted along the BPDU tunnel(s).
Related commands: bpdu-tunnel tunnel-dmac.
# Display the private multicast MAC address configured for packets transmitted along the BPDU tunnel(s).
<Sysname> display bpdu-tunnel
Tunnel packet's destination-mac-address: 010f-e2cd-0003
The above output information indicates that all the protocol packets transmitted along the BPDU tunnel(s) use 010f-e2cd-0003 as their destination MAC addresses.
