H3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
28-NTP Commands
28-NTP Commands 79.4 KB
To protect unused sockets against attacks by malicious users and improve security, H3C S3100 series Ethernet switches provide the following functions:
l          UDP port 123 is opened only when the NTP feature is enabled.
l          UDP port 123 is closed as the NTP feature is disabled.
These functions are implemented as follows:
l          Execution of one of the ntp-service unicast-server, ntp-service unicast-peer, ntp-service broadcast-client, ntp-service broadcast-server, ntp-service multicast-client, and ntp-service multicast-server commands enables the NTP feature and opens UDP port 123 at the same time.
l          Execution of the undo form of one of the above six commands disables all implementation modes of the NTP feature and closes UDP port 123 at the same time.
NTP Configuration Commands
display ntp-service sessions
display ntp-service sessions [ verbose ]
View
Parameter
verbose: Displays the detailed information about all the sessions maintained by the NTP service. Without this keyword, the command displays the brief information about all the sessions.
Use the display ntp-service sessions command to display the information about all the sessions maintained by local NTP services.
If you do not specify the verbose keyword, the brief information about all the sessions is displayed.
Example
# View the brief information of all sessions maintained by NTP services.
<Sysname>  display ntp-service sessions
     source        reference       stra reach poll  now offset  delay disper
[12345]3.0.1.32    LOCL               1    95   64   42  -14.3   12.9    2.7
[25]3.0.1.31    127.127.1.0          2     1   64    1 4408.6   38.7    0.0
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations :  2
Table 1-1 Description on the fields of the display ntp-service sessions command
source
IP address of the synchronization source
reference
Reference clock ID of the synchronization source
1)        If the reference clock is the local clock, the value of this field is related to the value of the stra field:
l      When the value of the stra field is 0 or 1, this field will be “LOCL”;
l      When the stra field has another value, this filed will be the IP address of the local clock.
2)        If the reference clock is the clock of another switch on the network, the value of this field will be the IP address of that switch.
stra
Stratum of the clock of the synchronization source
reach
Reachability count of the clock source. 0 indicates that the clock source is unreachable
poll
Polling interval in seconds, that is, the maximum interval between two successive messages
now
Time elapsing since the last NTP packet is sent
offset
The offset of the system clock relative to the reference clock, in milliseconds
delay
Network delay, that is, the roundtrip delay from the local switch to the clock source, in milliseconds
disper
Maximum offset of the local clock relative to the reference clock
[12345]
1: Clock source selected by the system, namely the current reference source, with a system clock stratum level smaller than or equal to 15
2: Stratum level of this clock source is smaller than or equal to 15
3: This clock source has passed the clock selection process
4: This clock source is a candidate clock source
5: This clock source was created by a configuration command
Total associations
Total number of associations
An S3100 series switch does not establish a session with its client when it works in the NTP server mode, but does so when it works in other NTP implementation modes.
display ntp-service status
View
Parameter
None
Use the display ntp-service status command to display the status of NTP services.
Example
# View the status of the NTP service of the local switch.
<Sysname>  display ntp-service status
 Clock status: synchronized
 Clock stratum: 4
 Reference clock ID: 1.1.1.11
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^18
 Clock offset: 0.8174 ms
 Root delay: 37.86 ms
 Root dispersion: 45.98 ms
 Peer dispersion: 35.78 ms
 Reference time: 16:30:46.078 UTC Mar 29 2007(C9689FB6.1431593E)
Table 1-2 Description on the fields of the display ntp-service status command
Clock status
Status of the local clock:
l      Synchronized
l      Unsynchronized
Clock stratum
Stratum of the local clock
Reference clock ID
Address of the remote server or ID of the reference clock after the local clock is synchronized to a remote NTP server or a reference clock
Nominal frequency
Nominal frequency of the local hardware clock, in Hz.
Actual frequency
Actual frequency of the local hardware clock, in Hz.
Clock precision
Precision of the local hardware clock
Clock offset
Offset of the local clock relative to the reference clock, in milliseconds.
Root delay
Roundtrip delay between the local clock and the primary reference clock source, in milliseconds.
Root dispersion
Maximum dispersion of the local clock relative to the primary reference clock, in milliseconds.
Peer dispersion
Maximum dispersion of the remote NTP server, in milliseconds.
Reference time
Reference timestamp
display ntp-service trace
View
Parameter
None
Use the display ntp-service trace command to display the brief information of each NTP time server along the time synchronization chain from the local switch to the reference clock source.
Example
# View the brief information of each NTP time server along the time synchronization chain from the local switch to the reference clock source.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 3, offset 0.018739, synch distance 0.04724
 server 172.1.2.3,stratum 2, offset 0.030714, synch distance 0.01094
 refid LOCL
The above information displays the time synchronization chain of server 127.0.0.1: server 172.0.0.1 is synchronized to server 172.1.2.3, and server 172.1.2.3 is synchronized to the local clock source.
Table 1-3 display ntp-service trace command output description
server
IP address of the NTP server
stratum
The stratum level of the corresponding system clock
offset
The clock offset relative to the upper-level clock, in milliseconds.
synch distance
The synchronization distance relative to the upper-level clock, in seconds
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL; otherwise, it is displayed as the IP address of the primary reference clock.
ntp-service access
ntp-service access { peer | server | synchronization | query } acl-number
undo ntp-service access { peer | server | synchronization | query }
View
Parameter
query: Control query right. This level of right permits the peer device to perform control query to the NTP service on the local device but does not permit the peer device to synchronize its clock to the local device. The so-called “control query” refers to query of state of the NTP service, including alarm information, authentication status, clock source information, and so on.
synchronization: Synchronization right. This level of right permits the peer device to synchronize its clock to the local switch but does not permit the peer device to perform control query.
server: Server right. This level of right permits the peer device to perform synchronization and control query to the local switch but does not permit the local switch to synchronize its clock to the peer device.
peer: Peer right. This level of right permits the peer device to perform synchronization and control query to the local switch and also permits the local switch to synchronize its clock to the peer device.
acl-number: Basic access control list (ACL) number, in the range of 2000 to 2999.
Use the ntp-service access command to set the access control right from the remote device to the local NTP server.
Use the undo ntp-service access command to remove the configured access control right to the local NTP server.
By default, the access control right from the remote device to the local NTP server is peer.
NTP service access-control rights from the highest to the lowest are peer, server, synchronization, and query. When a local NTP server receives an NTP request, it will perform an access-control right match and will use the first matched right.
The ntp-service access command only provides a minimal degree of security measure. A more secure way is to perform identity authentication.
Refer to the ntp-service authentication enable command for related configuration.
Example
# Configure the access right from the remote device in ACL 2076 to the local NTP server as peer.
[Sysname] ntp-service access peer 2076
# Configure the access right from the remote device in ACL 2028 to the local NTP server as server.
[Sysname] ntp-service access server 2028
undo ntp-service authentication enable
View
Parameter
None
Use the ntp-service authentication enable command to enable the NTP authentication.
Use the undo ntp-service authentication enable command to disable the NTP authentication.
By default, the NTP authentication is disabled.
Refer to the ntp-service reliable authentication-keyid and ntp-service authentication-keyid commands for related configuration.
Example
# Enable the NTP authentication.
[Sysname] ntp-service authentication enable
ntp-service authentication-keyid key-id authentication-mode md5 value
undo ntp-service authentication-keyid key-id
View
Parameter
key-id: Authentication key ID, in the range of 1 to 4294967295.
value: Authentication key, a string comprising 1 to 32 characters. Up to 1024 keys can be configured.
Use the ntp-service authentication-keyid command to configure an NTP authentication key.
Use the undo ntp-service authentication-keyid command to remove an NTP authentication key.
By default, no NTP authentication key is configured.
Currently, the system only supports the message digest 5 (MD5) algorithm.
After configuring the NTP authentication key, you need to use the ntp-service reliable authentication-keyid command to specify the authentication key as a trusted key.
Related commands: ntp-service reliable authentication-keyid.
Example
# Configure an MD5 authentication key, with the key ID being 10 and the key being BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
undo ntp-service broadcast-client
View
VLAN interface view
Parameter
None
Use the ntp-service broadcast-client command to configure an Ethernet switch to operate in the NTP broadcast client mode and receive NTP broadcast messages through the current interface.
Use the undo ntp-service broadcast-client command to remove the configuration.
By default, no NTP operate mode is configured.
Example
# Configure the switch to operate in the broadcast client mode and receive NTP broadcast messages through Vlan-interface1.
[Sysname] interface Vlan-interface1
[Sysname-Vlan-interface1] ntp-service broadcast-client
ntp-service broadcast-server [ authentication-keyid key-id | version number ]*
undo ntp-service broadcast-server
View
VLAN interface view
Parameter
authentication-keyid key-id: Specifies the key ID used for sending messages to broadcast clients. The key-id argument ranges from 1 to 4294967295. You do not need to configure authentication-keyid key-id if authentication is not required.
version number: Specifies the NTP version number which ranges from 1 to 3. The default version number is 3.
Use the ntp-service broadcast-server command to configure an Ethernet switch to operate in the NTP broadcast server mode and send NTP broadcast messages through the current interface.
Use the undo ntp-service broadcast-server command to remove the configuration.
Example
# Configure the switch to send NTP broadcast messages through Vlan-interface1 and use authentication key 4 for encryption, and set the NTP version number to 3.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-key 4 version 3
ntp-service in-interface disable
undo ntp-service in-interface disable
View
VLAN interface view
Parameter
None
Use the ntp-service in-interface disable command to disable the interface from receiving NTP messages.
Use the undo ntp-service in-interface disable command to restore the default.
By default, the interface can receive NTP messages.
Example
# Disable Vlan-interface1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Parameter
number: Maximum number of the dynamic NTP sessions that can be established locally. This argument ranges from 0 to 100.
Use the ntp-service max-dynamic-sessions command to set the maximum number of dynamic NTP sessions that can be established locally.
Use the undo ntp-service max-dynamic-sessions command to restore the default.
By default, up to 100 dynamic NTP sessions can be established locally.
Example
# Set the maximum number of dynamic NTP sessions that can be established locally to 50.
[Sysname] ntp-service max-dynamic-sessions 50
undo ntp-service multicast-client [ ip-address ]
View
VLAN interface view
Parameter
ip-address: Multicast IP address, in the range of 224.0.1.0 to 239.255.255.255. The default IP address is 224.0.1.1.
Use the ntp-service multicast-client command to configure an Ethernet switch to operate in the NTP multicast client mode and receive NTP multicast messages through the current interface.
Use the undo ntp-service multicast-client command to remove the configuration.
Example
# Configure the switch to receive NTP multicast messages through Vlan-interface1, with the multicast IP address being 224.0.1.2.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.2
ntp-service multicast-server [ ip-address ] [ authentication-keyid key-id | ttl ttl-number | version number ]*
undo ntp-service multicast-server [ ip-address ]
View
VLAN interface view
Parameter
authentication-keyid key-id: Specifies the key ID used for sending messages to multicast clients. The key-id argument ranges from 1 to 4294967295.
ttl ttl-number: Defines the lifetime of multicast messages. The ttl-number argument ranges from 1 to 255 and defaults to 16.
version number: Specifies the NTP version number which ranges from 1 to 3 and defaults to 3.
Use the ntp-service multicast-server command to configure an Ethernet switch to operate in the NTP multicast server mode and send NTP multicast messages through the current interface.
Use the undo ntp-service multicast-server command to remove the configuration.
Example
# Configure the switch to send NTP multicast messages through Vlan-interface1, and set the multicast group address to 224.0.1.2, keyid to 4, and the NTP version number to 2.
[Sysname-Vlan-interface1]ntp-service multicast-server 224.0.1.2
authentication-keyid 4 version 2
ntp-service reliable authentication-keyid key-id
undo ntp-service reliable authentication-keyid key-id
View
Parameter
Use the ntp-service reliable authentication-keyid command to specify an authentication key as a trusted key.
Use the undo ntp-service reliable authentication-keyid command to remove the configuration.
By default, no trusted key is configured.
When NTP authentication is enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Related commands: ntp-service authentication-keyid.
Example
# Enable NTP authentication. The encryption algorithm is MD5, the key ID is 37, and the trusted key is abc.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 abc
# Specify this key as a trusted key.
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
ntp-service source-interface Vlan-interface vlan-id
undo ntp-service source-interface
View
Parameter
vlan-interface vlan-id: Specifies an interface. The IP address of the interface serves as the source IP address of sent NTP messages. The vlan-id argument indicates the ID of the specified VLAN interface, ranging from 1 to 4094.
Use the ntp-service source-interface command to specify a VLAN interface through which NTP messages are to be sent.
Use the undo ntp-service source-interface command to remove the configuration.
If you do not want the IP addresses of the other interfaces on the local switch to be the destination addresses of response messages, you can use this command to specify a specific interface to send all NTP packets. In this way, the IP address of the interface is the source IP address of all NTP messages sent by the local device.
Example
# Specify the source IP addresses of all sent NTP messages as the IP address of Vlan-interface1.
[Sysname] ntp-service source-interface Vlan-interface 1
ntp-service unicast-peer { remote-ip | peer-name } [ authentication-keyid key-id | priority | source-interface Vlan-interface vlan-id | version number ]*
undo ntp-service unicast-peer { remote-ip | peer-name }
View
Parameter
remote-ip: IP address of the NTP symmetric-passive peer. This argument can be a unicast address only, and cannot be a broadcast address, a multicast address, or the IP address of the local reference clock.
peer-name: Symmetric-passive peer host name, a string comprising 1 to 20 characters.
authentication-keyid key-id: Specifies the key ID used for sending messages to the peer. The key-id argument ranges from 1 to 4294967295. By default, authentication is not enabled.
priority: Specifies the peer identified by the remote-ip argument as the preferred peer for synchronization.
source-interface Vlan-interface vlan-id: Specifies an interface whose IP address serves as the source IP address of NTP message sent to the peer. vlan-id is the VLAN interface number.
version number: Specifies the NTP version number. The version number ranges from 1 to 3 and defaults to 3.
Use the ntp-service unicast-peer command to configure an Ethernet switch to operate in the symmetric-active peer mode.
Use the undo ntp-service unicast-peer command to remove the configuration.
If you use remote-ip or peer-name to specify a remote device as the peer of the local Ethernet switch, the local switch operates in the symmetric-active peer mode. In this case, the clock of local Ethernet switch and that of the remote device can be synchronized to each other.
Example
# Configure the local switch to obtain time information from the peer with the IP address 128.108.22.44 and also to provide time information to the peer. Set the NTP version number to 3. The source IP address of NTP messages is the IP address of Vlan- interface1.
[Sysname] ntp-service unicast-peer 128.108.22.44 version 3 source-interface Vlan-interface 1
ntp-service unicast-server { remote-ip | server-name } [ authentication-keyid key-id | priority | source-interface Vlan-interface vlan-id | version number ]*
undo ntp-service unicast-server { remote-ip | server-name }
View
Parameter
remote-ip: IP address of an NTP server. This argument can be a unicast address only, and cannot be a broadcast address, multicast group address, or IP address of the local clock.
server-name: NTP server name, a string comprising 1 to 20 characters.
authentication-keyid key-id: Specifies the key ID used for sending messages to the NTP server. The key-id argument ranges from 1 to 4294967295. You do not need to configure authentication-keyid key-id if authentication is not required.
priority: Specifies the server identified by the remote-ip or the server-name argument as the preferred server.
source-interface Vlan-interface vlan-id: Specifies an interface whose IP address serves as the source IP address of NTP packets sent by the local switch to the server.
version number: Specifies the NTP version number. The number argument ranges from 1 to 3 and defaults to 3.
Use the ntp-service unicast-server command to configure an Ethernet switch to operate in the NTP client mode.
Use the undo ntp-service unicast-server command to remove the configuration.
The remote server specified by remote-ip or server-name serves as the NTP server, and the local switch serves as the NTP client. The clock of the NTP client will be synchronized by but will not synchronize that of the NTP server.
Example
# Configure the local switch to be synchronized to the NTP server with the IP address 128.108.22.44, and set the version number to 3.
[Sysname] ntp-service unicast-server 128.108.22.44 version 3
