H3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
11-Port Isolation Commands
11-Port Isolation Commands 27.38 KB
Port Isolation Configuration Commands
display isolate port
View
Parameter
None
Use the display isolate port command to display the Ethernet ports assigned to the isolation group.
Example
# Display information about the Ethernet ports added to the isolation group.
<Sysname>  display isolate port
 Isolated port(s) on UNIT 1:
 Ethernet1/0/2, Ethernet1/0/3, Ethernet1/0/4
The information above shows that Ethernet1/0/2, Ethernet1/0/3, and Ethernet1/04 are in the isolation group.
port isolate
port isolate
undo port isolate
View
Ethernet port view
Parameter
None
Use the port isolate command to add an Ethernet port to the isolation group.
Use the undo port isolate command to remove an Ethernet port from the isolation group.
l          When a member port of an aggregation group joins/leaves an isolation group, the other ports in the same aggregation group on the local device will join/leave the isolation group at the same time.
l          For ports that belong to an aggregation group and an isolation group simultaneously, removing a port from the aggregation group has no effect on the other ports. That is, the rest ports remain in the aggregation group and the isolation group.
l          Ports that belong to an aggregation group and an isolation group simultaneously are still isolated even when you remove the aggregation group in system view.
l          Adding a port of an isolation group to an aggregation group causes all the ports in the aggregation group being added to the isolation group.
By default, the isolation group contains no port.
Example
# Add Ethernet1/0/1 to the isolation group.
<Sysname>  system-view
[Sysname] interface ethernet1/0/1
[Sysname-Ethernet1/0/1] port isolate
[Sysname-Ethernet1/0/1] quit
[Sysname] interface ethernet1/0/2
[Sysname-Ethernet1/0/2] port isolate
After the configuration, packets cannot be exchanged between Ethernet 1/0/1 and Ethernet 1/0/2.
# Remove Ethernet1/0/2 from the isolation group.
[Sysname-Ethernet1/0/2] undo port isolate
